Date/Time: Tue, 04 Nov 2025 14:57:40 +0000
[User Discussion] - Custom study help
View Count: 2741
|   [2013-03-28 00:03:13]     |
| M5amhan - Posts: 468 |
                Hello I am curious if it would be possible to make a study that would draw an arrow/triangle at the low of a bar that comes 50% off the low with volume higher than prior 2 bars, and an arrow/triangle at the high of a bar that comes 50% off the high with higher volume than prior 2 bars? This would be greatly appreciated if someone could help with this Thanks for reading  |
|   [2013-03-28 03:05:53]     |
| TechTrader - Posts: 116 |
                Hi, Add the SPREADSHEET STUDY to a clean chart. Settings and Inputs, Set CHART REGION to 1, SCALE to same as region, VALUE FORMAT to inherited, SPREADSHEET NAME - your choice, Go to SUBGRAPHS, select draw style parameters for K and L to your preference, OK, SAVE ALL Type the following in column K row 3 =IF(AND(F3>F4,F3>F5,E3>=(C3+D3)/2),D3,0) Type the following in column L row 3 =IF(AND(F3>F4,F3>F5,E3<=(C3+D3)/2),C3,0) Regards, TechTrader Date Time Of Last Edit: 2013-03-28 03:07:19
|   [2013-03-28 04:33:05]     |
                thanks a ton!
                 Date Time Of Last Edit: 2013-03-28 04:41:07
