Date/Time: Tue, 04 Nov 2025 14:57:34 +0000
accumulated volume on day
View Count: 2913
|   [2013-03-27 20:50:22]     |
| sleepless2 - Posts: 4 |
                Is there a simple study/field to get the accumulated trade volume on day for a future just like the acc volume that the exchange reports in its datafeeds ?  thanks  |
|   [2013-03-28 01:55:53]     |
                You can do this with the Current Quote Window: http://www.sierrachart.com/index.php?l=doc/doc_WindowMenu.html#CurrentQuoteWindow Or add a Daily Volume field to the Chart Header: Global Settings >> Customize Chart Header Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2013-03-28 02:26:39]     |
                Can this be seen in intraday historical charts ? Is it stored in sierra's market data ? Also can it be accessed in acsil for backtesting auto trading algo ?  Thanks  |
|   [2013-03-28 22:37:22]     |
                 For historical daily  volume you need to use a Historical Daily chart and that data can be referenced in an ACSIL trading system.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-28 22:37:52
