Date/Time: Wed, 17 Jun 2026 10:52:33 +0000
drawing file for each chart
View Count: 938
[2015-12-29 23:45:37]
umair1 - Posts: 86
I was wondering if it would be possible to store the drawings associated with a symbol. For example if I have a chart of GBPUSD open then the drawings would be stored in GBPUSD.drawing or something similar.
So if I change the chart symbol to EURUSD then I won't see the GBPUSD drawings. And if I open GBPUSD in a new chart then I would see the drawings again.
I realize I could simply have a chart open for EURUSD and GBPUSD each one with unique drawings but it's cumbersome to have a chart open for each forex pair.
After years of using SC I recently discovered the quick typing ability to change time period and symbol and I find it very useful. I can quickly look at forex and stocks I really like it. But if I draw something on a chart then I have to delete the drawings when I change symbol. I'd like to be able to preserve those drawings without having a separate chartbook for each instrument.
I feel like this is the most elegant solution- to store the drawings in a separate file. Ideally if we could edit the drawing files and adjust the drawings that would be even more awesome.
[2015-12-30 03:54:19]
Effectively all of this is already supported now. Refer to all of these sections:
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ShowingDrawingsforDifferentSymbols
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ManageChartDrawings
http://www.sierrachart.com/index.php?page=doc/helpdetails72.html
