Date/Time: Sun, 20 Sep 2026 08:45:15 +0000
Opening Stock Option position from a Stock Chart
View Count: 5401
| [2016-02-04 07:29:26] |
It is a very important that you clearly communicate to us the particular problem you are currently having. What is the problem you are currently having?: This has been disabled as of this morning and we still had issues.
It is best to focus on just one problem and only one problem we will address that and move forward. As far as any kind of problems you have with Interactive Brokers accepting the orders or taking some proper action on them, that is outside of our control. You will need to contact Interactive Brokers about those. And at this point, it is our understanding that the remaining issues are on the Interactive Brokers side. The source code you posted looks fine. and as per trailing only the OCO stop order is being modified
Why is this the case? What does the Trade >> Trade Activity Log tell you? Any error messages relating to this in the Trade >> Trade Service Log? There is no need to give us the answer. This is just for your own information. If you have a question about something specific let us know.You need to understand, we did indicate this before, what you are involved with is complicated for many reasons. This is not going to be easy. You can rely on us, but relying on Interactive Brokers is going to be difficult but there is no other choice other than them for option trading. We do hope to offer another choice at some point in the future though. Also in regards to adding a symbol pattern to the Global Symbol Settings. Make sure you enable "Use Pattern Matching". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-17 21:48:32] |
| User99735 - Posts: 234 |
Hi, Have successfully implemented our own custom stop ( "different Symbol" / for opening a AAPL option position from an AAPL chart ). Had another query, can BuyExit() can be used for exiting a long position for a "different Symbol". The manual link Automated Trading From an Advanced Custom Study: Submitting and Managing Orders for Different Symbol and/or Trade Account has no mention of this. Regards Vivek |
| [2016-02-18 00:16:28] |
To exit a Long Position requires a sell order. Therefore, you need to use in this particular case sc.SellOrder: Automated Trading From an Advanced Custom Study: Sell Entry | Sell Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-18 00:25:12] |
Hi, Tried sc.SellOrder, but is flattening the long and opening a short position. Do the trade related variables work for "different Symbol" also? Have tried setting sc.SupportReversals = false; Is there any other variable which needs to be set to flatten a long with a sc.SellOrder for "different Symbols". Regards Vivek |
| [2016-02-18 01:42:26] |
Tried sc.SellOrder, but is flattening the long and opening a short position. Provide us all of the lines in the Trade Activity Log for the order generated by this function called. Here are instructions: Trade Activity Log: Providing Trade Activity Log Data Lines to Support Have tried setting sc.SupportReversals = false; This will not have an effect one way or another. Is there any other variable which needs to be set to flatten a long with a sc.SellOrder for "different Symbols". No. Just make sure the Order Quantity structure member is set correctly. This is all.
| [2016-02-18 01:58:20] |
| User713273 - Posts: 409 |
ActivityType DateTime Symbol OrderActionSource InternalOrderID ServiceOrderID OrderType Quantity BuySell Price Price2 OrderStatus FillPrice FilledQuantity TradeAccount OpenClose ParentInternalOrderID PositionQuantity FillExecutionServiceID Order 2016-02-17 09:59:55.132 AAPL-OPT-20160219-97-C-SMART-100-USD IB open order update 55282 6933 Market 10 Sell Filled 1.22 10 DU273679 Open -19 Fill 2016-02-17 09:59:55.128 AAPL-OPT-20160219-97-C-SMART-100-USD IB order fill (execution) 55282 6933 Market 5 Sell Pending Open 1.22 10 DU273679 Open -19 0001f4e4.56c41f0c.01.01 Order 2016-02-17 09:59:55.056 AAPL-OPT-20160219-97-C-SMART-100-USD IB open order update 55282 6933 Market 10 Sell Pending Open 1.22 5 DU273679 Open -14 Fill 2016-02-17 09:59:55.044 AAPL-OPT-20160219-97-C-SMART-100-USD IB order fill (execution) 55282 6933 Market 5 Sell Order Sent 1.22 5 DU273679 Open -14 0001f4e4.56c41f0b.01.01 Order 2016-02-17 09:59:54.753 AAPL-OPT-20160219-97-C-SMART-100-USD Auto-trade: AAPL [M] 1 Min #2 | Option Trader | sc.SubmitOrder | Bar start time: 2016-02-17 10:00:00 55282 Market 10 Sell Order Sent DU273679 Open -9 Fill 2016-02-17 09:22:45.858 AAPL-OPT-20160219-97-C-SMART-100-USD IB order fill (execution) 55281 6932 Stop 9 Sell 1.00 Filled 0.98 10 DU273679 Open -9 0001f4e4.56c41c88.01.01 Order 2016-02-17 09:22:45.857 AAPL-OPT-20160219-97-C-SMART-100-USD IB order fill (execution) 55281 6932 Stop 10 Sell 1.00 Filled 0.98 10 DU273679 Close Fill 2016-02-17 09:22:45.853 AAPL-OPT-20160219-97-C-SMART-100-USD IB order fill (execution) 55281 6932 Stop 1 Sell 1.00 Open 0.98 1 DU273679 Close 0001f4e4.56c41c87.01.01 Order 2016-02-17 09:22:35.001 Requesting Open orders from trading service Unspecified None Order 2016-02-17 09:22:20.101 AAPL-OPT-20160219-97-C-SMART-100-USD IB open order update 55281 6932 Stop 10 Sell 1.00 Open DU273679 Close 1 Order 2016-02-17 09:22:20.003 AAPL-OPT-20160219-97-C-SMART-100-USD Auto-trade order modification: AAPL [M] 1 Min #2 | Option Trader. Requested Price: 0.99999998. Requested Quantity: 10 55281 6932 Stop 10 Sell 0.84 Pending Modify DU273679 Close 1 Order 2016-02-17 09:21:29.261 Requesting Open orders from trading service Unspecified None Order 2016-02-17 09:21:14.524 AAPL-OPT-20160219-97-C-SMART-100-USD IB open order update 55281 6932 Stop 10 Sell 0.84 Open DU273679 Close 1 Order 2016-02-17 09:21:14.255 AAPL-OPT-20160219-97-C-SMART-100-USD Auto-trade: AAPL [M] 1 Min #2 | Option Trader | sc.SubmitOrder | Bar start time: 2016-02-17 09:21:00 55281 Stop 10 Sell 0.84 Order Sent DU273679 Close 1 Fill 2016-02-17 09:21:14.095 AAPL-OPT-20160219-97-C-SMART-100-USD IB order fill (execution) 55280 6931 Market 1 Buy Filled 0.98 10 DU273679 Open 1 0001f4e4.56c41c5d.01.01 Order 2016-02-17 09:21:14.094 AAPL-OPT-20160219-97-C-SMART-100-USD IB order fill (execution) 55280 6931 Market 10 Buy Filled 0.98 10 DU273679 Close Fill 2016-02-17 09:21:14.090 AAPL-OPT-20160219-97-C-SMART-100-USD IB order fill (execution) 55280 6931 Market 4 Buy Open 0.98 9 DU273679 Close 0001f4e4.56c41c5c.01.01 Fill 2016-02-17 09:21:13.999 AAPL-OPT-20160219-97-C-SMART-100-USD IB order fill (execution) 55280 6931 Market 5 Buy Open 0.99 5 DU273679 Close -4 0001f4e4.56c41c5b.01.01 Order 2016-02-17 09:21:13.163 AAPL-OPT-20160219-97-C-SMART-100-USD IB open order update 55280 6931 Market 10 Buy Open DU273679 Close -9 Order 2016-02-17 09:21:12.756 AAPL-OPT-20160219-97-C-SMART-100-USD Auto-trade: AAPL [M] 1 Min #2 | Option Trader | sc.SubmitOrder | Bar start time: 2016-02-17 09:21:00 55280 Market 10 Buy Order Sent DU273679 Close -9 |
| [2016-02-18 01:59:33] |
Also order and position" log attached with same internal ids listed above.
| [2016-02-18 02:14:38] |
We see three separate orders which were the result of calling sc.SellOrder/sc.BuyOrder three separate times: Order 17/02/16 09:21 AAPL-OPT-20160219-97-C-SMART-100-USD Auto-trade: AAPL [M] 1 Min #2 | Option Trader | sc.SubmitOrder | Bar start time: 2016-02-17 09:21:00 55280 Market 10 Buy Order Sent DU273679 Close -9
Order 17/02/16 09:21 AAPL-OPT-20160219-97-C-SMART-100-USD Auto-trade: AAPL [M] 1 Min #2 | Option Trader | sc.SubmitOrder | Bar start time: 2016-02-17 09:21:00 55281 Stop 10 Sell 0.84 Order Sent DU273679 Close 1 Order 17/02/16 09:59 AAPL-OPT-20160219-97-C-SMART-100-USD Auto-trade: AAPL [M] 1 Min #2 | Option Trader | sc.SubmitOrder | Bar start time: 2016-02-17 10:00:00 55282 Market 10 Sell Order Sent DU273679 Open -9 We examined the internal code and verified what we say is correct. Each of these orders has a quantity of 10. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
