Date/Time: Thu, 26 Dec 2024 03:46:02 +0000
frustrating problems
View Count: 883
[2015-12-06 20:21:26]
madra - Posts: 109
Hello I have been happily using SC for a number of years. a few days ago i BOUGHT a new COMPUTER asked that all Sierra data be transferred to the new computer. This has not worked.
Tried to us backup option still nothing.
I can open a new symbol when I try to customize tool bar nothing appears on the symbol line at top of chart.
Available toolbar commands all this window shows is a sequence of numbers tht mean nothing to me.
I would appreciate a step by step procedure to deal with this issue.
I am at sea when \i try to use documentation
madra
[2015-12-06 21:13:53]
The first thing that we want you to do is to select Help >> Download Prerelease.
Follow through the step-by-step instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
That will solve the problem of seeing numbers on the Control Bar/ToolBar.
Do you have all of the files in the "Data" subfolder from your prior installation of Sierra Chart on your old computer?
[2015-12-06 21:38:34]
madra - Posts: 109
I have followed the steps repeated dwnload current version several times. There ha been no change.
The 'datA' subfolder has been transferred and shows on C:/ drive
[2015-12-07 01:49:15]
We will be contacting you about this tomorrow.
Make sure your current telephone number is set here:
https://www.sierrachart.com/usercp.php?page=ManageAccountInfo
[2015-12-07 04:00:31]
madra - Posts: 109
Great, thank you,the contact including phone is correct.
Please call me between 10:30 am and 1:00 pm Auckland time which would be between 1:30 and 4:00 pm pacific time
regards
charlie
[2015-12-07 05:14:57]
bekitz3 - Posts: 83
In order to retain the same look & feel of a previous install on another computer you need to copy the "Sierra3.cfg" file from the old to new computer. This is located in the C:/SierraChart folder. It is not in C:/SierraChart/Data folder
