Date/Time: Tue, 04 Nov 2025 10:02:02 +0000
Passing SCGraphData Object as argument
View Count: 1287
[2015-11-06 01:27:47]
reticent67 - Posts: 4
I’m coding a strategy based on four custom studies I have coded. Each study has multiple subgraphs. I am using a SCGraphData object and mapping my subgraphs in with GetStudyArraysFromChartUsingID() to SCFloatArray’s.
SCGraphData D_S;
  sc.GetStudyArraysFromChartUsingID(DS.GetChartNumber(), DS.GetStudyID(), D_S);
  int RefChartIndex = sc.GetContainingIndexForDateTimeIndex(DS.GetChartNumber(), sc.Index);
  SCFloatArray DubStoch = D_S[0];
  SCFloatArray DS_Sig = D_S[5];
  SCFloatArray DS_OB = D_S[6];
  SCFloatArray DS_OS = D_S[7];
This works fine when I generate signals from within the strategy function, but since I have multiple studies and each study generates multiple signals, I would like to create a helper function for each study. However, when I try to pass the SCGraphData object (in this case D_S), the data doesn’t get passed with it. Well, the data for the main subgraphs – the double stochastic and its signal line – remains at zero for every bar. But the values for the overbought and oversold lines show they got passed when I debug.
Is there a trick to passing the Graph Data object? Or is it better to just pass each float array as a parameter?
[2015-11-06 03:21:39]
We are not totally clear what you are doing. Our only suggestion is to pass SCGraphData by reference when passing it to a function.
[2015-11-06 22:42:24]
Sorry for the confusion, I will attempt to clarify. Here is a simple example of what I’m trying to do using a double stochastics crossover.
If I use the following code, everything works as expected…
SCGraphData DS;
sc.GetStudyArraysFromChartUsingID(DS_in.GetChartNumber(), DS_in.GetStudyID(), DS);
int RefIndex = sc.GetExactMatchForSCDateTime(DS_in.GetChartNumber(), sc.BaseDateTimeIn[sc.Index]);
SCFloatArray DubStoch = DS[0];
SCFloatArray DS_Sig = DS[5];
SCFloatArray DS_OB = DS[6];
SCFloatArray DS_OS = DS[7];
//Create New order object
if (DubStoch[RefIndex] < DS_OS[RefIndex] && sc.CrossOver(DubStoch, DS_Sig) == CROSS_FROM_BOTTOM)
  sc.BuyEntry(BuyOrder);
if (PositionData.PositionQuantity > 0 && DubStoch[RefIndex] > DS_OB[RefIndex] && sc.CrossOver(DubStoch, DS_Sig) == CROSS_FROM_TOP)
  sc.BuyExit(BuyOrder);
However, if I create a function to generate the trading signals and pass the graph data object (whether by reference or by value), the subgraph values for DubStoch (the main subgraph) and DS_Sig (it’s signal line) always remain at zero and no trades are executed. But the overbought and oversold lines correctly receive their values - 90 and 10, respectively.
SCGraphData DS;
if (calcDoubleStoch(DS, sc, RefIndex) > 0))
if (PositionData.PositionQuantity > 0 && calcDoubleStoch(DS, sc, RefIndex) < 0))
//Declared outside of study function...
int calcDoubleStoch(SCGraphData &DS, SCStudyInterfaceRef sc, int Index)
  if (DubStoch[Index] < DS_OS[Index] && sc.CrossOver(DubStoch, DS_Sig) == CROSS_FROM_BOTTOM)
    return 1;
  if (DubStoch[Index] > DS_OB[Index] && sc.CrossOver(DubStoch, DS_Sig) == CROSS_FROM_TOP)
    return -1;
  else
    return 0;
[2015-11-15 00:40:50]
We apologize for the delay.
We see where the mistake is:
Needs to be:
SCFloatArrayRef DubStoch = DS[0];
SCFloatArrayRef DS_Sig = DS[5];
SCFloatArrayRef DS_OB = DS[6];
SCFloatArrayRef DS_OS = DS[7];
Let us know if that helps and solves the problem. Once again we apologize for the delay.
Date Time Of Last Edit: 2017-10-23 06:03:00
[2015-11-15 03:08:56]
As we went to update the documentation related to this, we see this function already demonstrates how to take a reference to one of the SCGraphData arrays:
scsf_ReferenceDataFromAnotherChart(SCStudyInterfaceRef sc)
This function is located in the /ACS_Source/Studies8.cpp file
Date Time Of Last Edit: 2015-11-15 03:10:44
