Date/Time: Wed, 01 May 2024 00:20:51 +0000
[User Discussion] - Saving feature chart layout
View Count: 1969
[2015-10-26 19:51:28] |
User767947 - Posts: 3 |
Can you make a feature to save a chart layout? Even I delelete a chart I can use the chart layout to populate later easily.
[2015-10-27 01:23:32] |
Refer to this page here about Chart Templates: https://www.sierrachart.com/index.php?page=doc/helpdetails20.html This is all that is available and nothing else is planned in this area. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-17 11:06:29] |
aknsyu71@gmail - Posts: 49 |
Hi Sierra support. Please consider this feature as it would make the platform even better. Its one of the basic features available on better platforms. I have 15 chartbooks open, all have the same layout containing 4 charts each. If I decide to change the layout I'd have to modify each chartbook individually (and the other 45 in 3 more instances of Sierra) It wouldnt be that difficult to program in C++, to save current layout of windows (location and size of each chart using chart number) as template, then apply this to other chartbooks (to the same chartnumbers in other chartbooks) |
