Date/Time: Sun, 08 Sep 2024 00:29:43 +0000
Hotkey for Draw Volume Profile
View Count: 2125
[2015-10-22 22:54:12] |
User35326 - Posts: 57 |
SC: Can I set a hotkey to access the draw volume profile feature? Also, the draw peaks and valleys does not have a feature to extend it only to the end of the drawn profile. I think it is called 'none' in the POC feature. Your charts are way cool. Thanks in advance. |
[2015-10-23 07:01:16] |
Kiwi - Posts: 375 |
Mine (a happy SC user :)) is set to Ctrl-Shift-Z but I suspect I did that myself. You can set most things up under Global Settings >> Customize Keyboard Shortcuts. DVP is in the tools submenu. http://i.imgur.com/EaOz6Ya.png Not sure about peaks and valleys - I just adjust the Max Volume Bar Width Percentage in the VbP study settings. |
[2015-10-23 10:12:33] |
Yes. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeKeyboardShortcuts For the Volume by Price study, look at the Extend Peaks and Valleys Input Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-23 18:59:05] |
SC: I guess I didn't make my question plain enough re: the extend lines on the peaks and valleys. I would only like the peak and valley extend lines to extend as far as the profile lines do. The red horizontal lines are the valleys. However, they are extending clear to the left. Note how the POC, the pink line stops. I would also like the peak and valley lines to stop at the same place as the POC line does. The POC is the point of control. Notice how the extend POC setting is set to stop at the end of the window; and, the red horizontal lines, the extend peak and valley setting, is also set to stop at end of window. However, the red horizontal line continues on until the end of the window. Both the extend POC and the extend peak and valleys are set to end of window. That is what I am trying to fix. Here is a picture example of this.... http://www.sierrachart.com/image.php?l=1445628511307.png Please instruct how to stop the peaks and valley lines at the same spot as the POC stops. Thanks in advance. Date Time Of Last Edit: 2015-10-23 19:37:00
