Date/Time: Tue, 04 Nov 2025 05:43:02 +0000
Suppress IB TWS API window popup?
View Count: 1209
|   [2015-10-15 18:08:45]     |
| User844355 - Posts: 7 |
                Every time I place an order through IB TWS, I get an annoying TWS API orders window that pops up. Is there some way for Sierra Chart to suppress this? I have disabled all messages and API precaustions in TWS to no avail.  Thanks.  |
|   [2015-10-15 18:36:01]     |
                No. You need to contact Interactive Brokers for help with this.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
