Date/Time: Tue, 24 Dec 2024 02:30:19 +0000
persistant array of structs
View Count: 1572
[2015-10-15 10:08:05]
KhaosTrader - Posts: 128
Is there a way to make a persistant array of stucts?
[2015-10-15 10:12:13]
I want to make my own array that holds swing values. I have several data elements that I store for each swing occurance. I was thinking of holding these different data values in a struct, then having an array of these structs hold my swing values for each swing, which I can reference in relation to each other in my formulas on the chart.
Date Time Of Last Edit: 2015-10-15 10:13:11
[2015-10-15 10:45:06]
If cant do an array of persistant structs, can I make a persistant array that holds a number of elements that I define? Not one per bar sort of thing?
[2015-10-15 17:32:21]
Yes this can be done. Refer to the documentation for this here:
https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#DynamicMemoryAllocations
[2015-10-16 21:00:25]
I believe got my array of structs to work, thanks ....
I have 2 other questions.
1) if I want to just have a persistent integer for a counter or something, should I use the same code structure?
2) If I want to have a collection of classes or array of classes, rather than an array of structs, could I use the structure you recommended me for structs for that?
[2015-10-28 04:02:41]
The documentation for your questions has now been prepared here:
https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#GettingAndSettingPersistentData
[2015-10-29 21:09:21]
I am using an array of structs, not classes, so is this code correct? Thank you for your kind help.
  int& NbrLongSwings = sc.GetPersistentInt(3);
  int& NbrShortSwings = sc.GetPersistentInt(4);
  s_SwingInfo* p_LongSwings = (s_SwingInfo*)sc.GetPersistentPointer(1);
  s_SwingInfo* p_ShortSwings = (s_SwingInfo*)sc.GetPersistentPointer(2);
  if (sc.UpdateStartIndex == 0)
    NbrLongSwings = 0;
    NbrShortSwings = 0;
  if (sc.LastCallToFunction)
    if (p_LongSwings != NULL)
      delete p_LongSwings;
      sc.SetPersistentPointer(1, NULL);
    if (p_ShortSwings != NULL)
      delete p_ShortSwings;
      sc.SetPersistentPointer(2, NULL);
    return;
  if (p_LongSwings == NULL)
    //Allocate an array of 20k structs.
    p_LongSwings = (s_SwingInfo *) new s_SwingInfo[20000];
      sc.SetPersistentPointer(1, p_LongSwings);
    else
      return;
  if (p_ShortSwings == NULL)
    p_ShortSwings = (s_SwingInfo *) new s_SwingInfo[20000];
      sc.SetPersistentPointer(2, p_ShortSwings);
    else
      return;
Date Time Of Last Edit: 2015-10-29 22:25:15
[2015-10-29 23:30:00]
In the case of an array of structures, there is no need to use new and delete.
[2015-10-29 23:57:45]
Ok I had some troubles, I had to remove the dll from the chart and re-apply it...
I rewrote the code here, please tell me if its correct, I am using 2 arrays, and 2 counter int vars...
    NbrLongSwings = 0;
    NbrShortSwings = 0;
    if (NbrLongSwings != NULL)
      sc.SetPersistentPointer(3, NULL);
    if (NbrShortSwings != NULL)
      sc.SetPersistentPointer(4, NULL);
    return;
    else
      return;
    else
      return;
Date Time Of Last Edit: 2015-10-30 00:19:16
[2015-10-30 00:41:45]
We do not provide programming help. You will have to analyze your own code. We do not do that.
[2015-10-30 01:19:38]
What we can do for you though is put together an example for structures and we will do that.
[2015-10-30 05:36:06]
Ok yes that would be helpful, especially if we use 2 or more structs in the program and 2 or more counters.
Thank you.
