Date/Time: Tue, 15 Sep 2026 03:11:57 +0000
non-OCO orders / Order Price Adjustments
View Count: 1386
| [2015-10-14 19:05:49] |
| User94740 - Posts: 333 |
SC, is it possible to connect independent orders into an OCO? Secondly, I was in the process of adjusting my price target at which time my target was hit right before clicking the confirmation window and as soon as I hit the confirmation window a second order had been placed causing me a second long position which I then had to market order out resulting in a loss. It was strange, because it all happened so very fast.
| [2015-10-15 00:45:36] |
It is not possible to connect existing working orders into an OCO group if they are not already. Also when modifying an order, if it fills before the modification is completed and the modification is sent after, it will not result in a new order. You can see what happened through the Trade Activity Log: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ViewingHistoricalTA If you show us the lines from the Trade Activity Log where this happened we can get a better understanding of what happened: Trade Activity Log: Providing Trade Activity Log Data Lines to Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-17 20:51:32
| [2015-10-15 12:24:43] |
Trade Activity Log attached
| [2015-10-16 10:38:12] |
This Trade Activity log shows simulated trading and in trade simulation mode, it is not possible for what you describe to happen. This log: Order 2015-10-14 13:29:56.001 [Sim]GC-201512-NYMEX Simulated order modify complete 18675 18675 Stop 1 Buy 1187.8 Open Sim1 Open 1
Order 2015-10-14 13:29:56.002 [Sim]GC-201512-NYMEX Trade simulation fill. Bid: 1187.6 Ask: 1187.7 Last: 1187.8 18675 18675 Stop 1 Buy 1187.8 Filled 1187.7 1 Sim1 Open 1 Order 2015-10-14 13:30:07.000 [Sim]GC-201512-NYMEX Canceling all orders for Symbol and Account. Flatten/Reverse. Unspecified Sim1 Order 2015-10-14 13:30:07.001 [Sim]GC-201512-NYMEX Canceling all orders for Symbol and Account. Flatten/Reverse. 18674 18674 Stop 1 Sell 1182.2 Pending Cancel Sim1 Open 2 Order 2015-10-14 13:30:07.002 [Sim]GC-201512-NYMEX Simulated order canceled 18674 18674 Stop 1 Sell 1182.2 Canceled Sim1 Open 2 Order 2015-10-14 13:30:07.003 [Sim]GC-201512-NYMEX GC-201512-NYMEX [C] 55 Trades #13 | User order entry. Flatten&Cancel | Last: 1187.4. Current Position quantity: 2 18676 Market 2 Sell Order Sent Sim1 Close 2 Order 2015-10-14 13:30:07.004 [Sim]GC-201512-NYMEX Simulated order accepted 18676 18676 Market 2 Sell Open Sim1 Close 2 Order 2015-10-14 13:30:07.005 [Sim]GC-201512-NYMEX Trade simulation fill. Bid: 1187.3 Ask: 1187.4 Last: 1187.4 18676 18676 Market 2 Sell Filled 1187.3 2 Sim1 Close 2 Shows that you modified an order and then it filled. When it filled, your position Quantity went to 2. And then after you flattened the position taking the Position quantity back to 0. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-16 11:35:45] |
can only tell you what happened. I entered no other order or did anything which would have caused another order to be entered and considering the fact the position quantity went to 2 seems strange in itself.
Date Time Of Last Edit: 2015-10-16 11:37:18
| [2015-10-16 17:40:40] |
When an order fills, obviously the position quantity will change by the quantity of the fill. We did not see another order being entered at the time of the order modification. Do you see that in the Trade Activity Log? You will see a line that has "user order entry" in it for a new order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-10-17 19:25:33] |
I have found no line indicating "User order entry" for the second contract. I will also state this has happened on various occasions.
Date Time Of Last Edit: 2015-10-17 19:30:53
| [2015-10-18 21:59:21] |
We are not totally clear what is happening because we cannot see exactly what you're doing and what is happening. However, possibly the information here about the Simulation Fills Source setting might be related to the problem: Feature Removal: Simulation Fills Source Setting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
