Date/Time: Tue, 04 Nov 2025 12:18:44 +0000
Triggered Trailing Stop
View Count: 1196
|   [2015-10-06 14:55:12]     |
| jivetrader - Posts: 410 |
                could you explain why Trigger Offset and Trail Offset cannot be larger than the initial Stop Offset? i am trying to create an initial stop loss of 3 ticks that will trail the market by 4 ticks once the trade is in profit. thanks.
|   [2015-10-06 17:37:48]     |
                This may be a problem in the version you are running.  Update Sierra Chart to the current version and let us know if you still see a problem. Here are instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2015-10-06 17:55:31]     |
                downloading the latest pre-release with new spreadsheets solved this,  thanks
|   [2015-10-07 14:27:49]     |
                new issue: now, using chart-based trading, when i modify a pending order, the attached orders do not move with it. please advise.
|   [2015-10-07 15:38:41]     |
                also, cannot move pending orders to a new price level. what is wrong sierra??
|   [2015-10-07 17:30:43]     |
                In the case of OEC, if you try to modify the Attached Orders before they have been activated, you cannot because OEC will not allow it. The solution to this is to uncheck this option here: Global Settings >> General Trade Settings >> Use Server-Side OCO and Bracket Orders This limitation is documented here: https://www.sierrachart.com/index.php?page=doc/openecry.php Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
