Date/Time: Tue, 04 Nov 2025 13:48:51 +0000
line tool-draw a vertical line
View Count: 1337
[2015-10-06 14:46:25]
Ed Meckelborg - Posts: 71
I would like to use/set the "line tool" to begin beyond the last price bar.
E.g. I'd like to draw a vertical line 15 minutes beyond the last price bar.
Under the old system I could do that.
[2015-10-08 02:39:05]
You need to use the Forward Projection Area and this is thoroughly documented here:
Chart Drawing Tools: Forward Projection Area
Nothing has changed which would prevent this. Maybe you have locked the Right side Fill Space?
[2015-10-09 15:04:41]
No, I have not locked the "Right side Fill Space"
I can start drawing a vertical line 10 minutes beyond the last price bar using the "Tools Value window", it will show me the starting point.
But, I cannot start to draw a vertical "Line Tool" 10 minutes beyond the last price bar using "Show Compact Tool Values Window".
To clarify: The "Show Compact Tool Values Window" will not show me the starting point until I engage the "Line Tool" feature.
That staring point then becomes a guessing game. Frustrating !
Can the "Show Compact Tool Values Window" be set to start [actually showing me the starting point] drawing a vertical line beyond the last price bar using the "Line Tool"
Currently I'm flipping back and forth between the "Show Compact Tool Values Window" and the "Tools Value window".
[2015-10-09 17:36:31]
Update Sierra Chart following the instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
After the update select Global Settings >> Tool Settings >> Chart Values.
Near the bottom there is a list box that has Always On When Using Other Tools. Make sure that is selected.
Date Time Of Last Edit: 2015-10-09 17:38:15
[2015-10-12 14:49:19]
I give up. I, apparently, am not communicating my problem. OR the problem cannot be fixed.
It's too bad that the programmers found it necessary to change something that worked fine.
[2015-10-12 16:51:45]
We know exactly what you mean. We will call you to show you how this works.
Let us know when is a good time.
[2015-10-12 16:57:56]
Any time before 2 MST
[2015-10-12 17:55:41]
Attached is a screenshot showing how the Chart Values settings needs to be configured as you require.
To get that particular tab select Global Settings >> Tool Settings >> Chart Values.
imageChartValuesSettings.png / V - Attached On 2015-10-12 17:54:54 UTC - Size: 19.06 KB - 340 views
