Date/Time: Thu, 26 Dec 2024 13:40:31 +0000
SC Data NYMEX CL Spreads Quote
View Count: 1729
[2015-09-24 15:25:18] |
User210422 - Posts: 19 |
How do I get a NYMEX CL calendar spread (CLX5-CLZ5) quote on the quote board. I have CQG FIX and SC Data Thanks |
[2015-09-24 18:11:44] |
Since you are using the Sierra Chart Exchange Data Feed you can get exchange traded spreads from the Sierra Chart Data Feed. Update Sierra Chart to the latest release following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate The spread symbols can be found in File >> Find Symbol or through the Settings >> Set Symbols >> Find button on the Quote Board. They will be in the "Futures Spreads" section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-24 18:12:45
[2015-09-24 18:49:52] |
Here is a chart of the spread that you requested: http://www.sierrachart.com/image.php?l=1443120574768.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-14 12:18:37] |
Thank you. I have done that, and it populates my DOM, but I cannot trade it because the symbol is different in CGQ? Is there anything I can do?
[2015-10-14 17:13:54] |
If you want to trade the spread, you need to use the CQG symbol. Here are instructions: https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#ExchangeTradedSymbolFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-14 17:23:38] |
Thanks. When I use the symbol "F.US.CLES1X15" I cannot see anyhting on the DOM. How do I send an order to that symbol, but view the dom with the SC symbol?
[2015-10-14 17:50:47] |
Actually there is a way to use the Sierra Chart spread symbols and trade using the CQG symbol. On the Trade DOM select Chart >> Chart Settings. Set the "Trade and Current Quote Symbol" to F.US.CLES1X15. This should work. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-14 17:58:00] |
I tried that, and now I cannot see the market depth though?
[2015-10-14 19:20:54] |
Thinking about this, that would be a problem. You would actually end up using the CQG data. Not sure what we can do about this right now. It probably would require us to allow setting of the "Trade" symbol only. We have to think about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-14 19:22:09] |
ok cool... that would really help!
[2015-12-13 08:58:24] |
Letting you know, we expect to have this completed before the end of December.
