Date/Time: Mon, 23 Dec 2024 07:32:14 +0000
Connection problem
View Count: 814
[2015-09-22 20:14:42]
User37779 - Posts: 12
Hello, after installing the platform, I can not establish a connection with Interactive Brokers. Will you help me please? Below please find attached the text of the platform Sierra Chart. Thank you and best regards, Jan Opatrný
Software version: 1297 | 2015-09-22 21:54:51
Uses New Spreadsheets | 2015-09-22 21:54:51
Usage end date: 2016-01-18 | 2015-09-22 21:54:51
Enabled for: Advanced Features. | 2015-09-22 21:54:51
Enabled for: Sierra Chart Historical Data Service. | 2015-09-22 21:54:51
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-09-22 21:54:51
Current selected Data/Trading service: Interactive Brokers | 2015-09-22 21:54:51
Chart Update Interval: 500 | 2015-09-22 21:54:51
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2015-09-22 21:54:51
2015-09-22 21:54:51 Local computer time | 2015-09-22 21:54:51
2015-09-22 19:54:51 Local computer time in UTC | 2015-09-22 21:54:51
2015-09-22 21:54:51 Local computer time in SC Time Zone | 2015-09-22 21:54:51
2015-09-22 19:54:51 Server time in UTC | 2015-09-22 21:54:51
Local computer UTC time and Server UTC time difference: 2 seconds. | 2015-09-22 21:54:51
Program path: C:\SierraChart\ | 2015-09-22 21:54:51
Data Files path: C:\SierraChart\Data\ | 2015-09-22 21:54:51
OS Version Number: 6.2 | 2015-09-22 21:54:51
Locale Information: C | 2015-09-22 21:54:51
Checking for new symbol settings for ib | 2015-09-22 21:54:51
Symbol settings are up-to-date for ib | 2015-09-22 21:54:52
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:54:56
Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:54:57
Socket (4) | Shutdown and closed. | 2015-09-22 21:54:57
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:54:57 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:54:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:54:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:54:57
Interactive Brokers | Disconnected. | 2015-09-22 21:54:57
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:54:57
Starting TWS auto-login thread. | 2015-09-22 21:55:00
TWS auto-login thread ending. | 2015-09-22 21:55:00
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:55:02
Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:55:03
Socket (5) | Shutdown and closed. | 2015-09-22 21:55:03
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:55:03 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:55:03 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:55:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:55:03
Interactive Brokers | Disconnected. | 2015-09-22 21:55:03
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:55:03
Starting TWS auto-login thread. | 2015-09-22 21:55:04
TWS auto-login thread ending. | 2015-09-22 21:55:04
Starting TWS auto-login thread. | 2015-09-22 21:55:08
TWS auto-login thread ending. | 2015-09-22 21:55:08
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:55:08
Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:55:09
Socket (6) | Shutdown and closed. | 2015-09-22 21:55:09
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:55:09 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:55:09 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:55:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:55:09
Interactive Brokers | Disconnected. | 2015-09-22 21:55:09
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:55:09
Starting TWS auto-login thread. | 2015-09-22 21:55:12
TWS auto-login thread ending. | 2015-09-22 21:55:12
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:55:14
Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:55:15
Socket (7) | Shutdown and closed. | 2015-09-22 21:55:15
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:55:15 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:55:15 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:55:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:55:15
Interactive Brokers | Disconnected. | 2015-09-22 21:55:15
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:55:15
Starting TWS auto-login thread. | 2015-09-22 21:55:16
TWS auto-login thread ending. | 2015-09-22 21:55:16
Starting TWS auto-login thread. | 2015-09-22 21:55:20
TWS auto-login thread ending. | 2015-09-22 21:55:20
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:55:20
Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:55:21
Socket (8) | Shutdown and closed. | 2015-09-22 21:55:21
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:55:21 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:55:21 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:55:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:55:21
Interactive Brokers | Disconnected. | 2015-09-22 21:55:21
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:55:21
Starting TWS auto-login thread. | 2015-09-22 21:55:24
TWS auto-login thread ending. | 2015-09-22 21:55:24
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:55:26
Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:55:27
Socket (9) | Shutdown and closed. | 2015-09-22 21:55:27
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:55:27 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:55:27 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:55:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:55:27
Interactive Brokers | Disconnected. | 2015-09-22 21:55:27
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:55:27
Starting TWS auto-login thread. | 2015-09-22 21:55:28
TWS auto-login thread ending. | 2015-09-22 21:55:28
Starting TWS auto-login thread. | 2015-09-22 21:55:32
TWS auto-login thread ending. | 2015-09-22 21:55:32
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:55:32
Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:55:33
Socket (10) | Shutdown and closed. | 2015-09-22 21:55:33
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:55:33 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:55:33 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:55:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:55:33
Interactive Brokers | Disconnected. | 2015-09-22 21:55:33
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:55:33
Starting TWS auto-login thread. | 2015-09-22 21:55:36
TWS auto-login thread ending. | 2015-09-22 21:55:36
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:55:38
Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:55:39
Socket (11) | Shutdown and closed. | 2015-09-22 21:55:39
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:55:39 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:55:39 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:55:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:55:39
Interactive Brokers | Disconnected. | 2015-09-22 21:55:39
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:55:39
Starting TWS auto-login thread. | 2015-09-22 21:55:40
TWS auto-login thread ending. | 2015-09-22 21:55:40
Starting TWS auto-login thread. | 2015-09-22 21:55:44
TWS auto-login thread ending. | 2015-09-22 21:55:44
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:55:44
Socket (12) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:55:45
Socket (12) | Shutdown and closed. | 2015-09-22 21:55:45
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:55:45 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:55:45 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:55:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:55:45
Interactive Brokers | Disconnected. | 2015-09-22 21:55:45
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:55:45
Starting TWS auto-login thread. | 2015-09-22 21:55:48
TWS auto-login thread ending. | 2015-09-22 21:55:48
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:55:50
Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:55:51
Socket (13) | Shutdown and closed. | 2015-09-22 21:55:51
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:55:51 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:55:51 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:55:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:55:51
Interactive Brokers | Disconnected. | 2015-09-22 21:55:51
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:55:51
Starting TWS auto-login thread. | 2015-09-22 21:55:52
TWS auto-login thread ending. | 2015-09-22 21:55:52
Starting TWS auto-login thread. | 2015-09-22 21:55:56
TWS auto-login thread ending. | 2015-09-22 21:55:56
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:55:56
Socket (14) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:55:57
Socket (14) | Shutdown and closed. | 2015-09-22 21:55:57
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:55:57 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:55:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:55:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:55:57
Interactive Brokers | Disconnected. | 2015-09-22 21:55:57
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:55:57
Starting TWS auto-login thread. | 2015-09-22 21:56:00
TWS auto-login thread ending. | 2015-09-22 21:56:00
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:56:02
Socket (15) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:56:03
Socket (15) | Shutdown and closed. | 2015-09-22 21:56:03
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:56:03 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:56:03 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:56:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:56:03
Interactive Brokers | Disconnected. | 2015-09-22 21:56:03
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:56:03
Starting TWS auto-login thread. | 2015-09-22 21:56:04
TWS auto-login thread ending. | 2015-09-22 21:56:04
Starting TWS auto-login thread. | 2015-09-22 21:56:08
TWS auto-login thread ending. | 2015-09-22 21:56:08
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:56:08
Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:56:09
Socket (16) | Shutdown and closed. | 2015-09-22 21:56:09
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:56:09 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:56:09 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:56:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:56:09
Interactive Brokers | Disconnected. | 2015-09-22 21:56:09
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:56:09
Starting TWS auto-login thread. | 2015-09-22 21:56:12
TWS auto-login thread ending. | 2015-09-22 21:56:12
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:56:14
Socket (17) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:56:15
Socket (17) | Shutdown and closed. | 2015-09-22 21:56:15
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:56:15 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:56:15 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:56:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:56:15
Interactive Brokers | Disconnected. | 2015-09-22 21:56:15
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:56:15
Starting TWS auto-login thread. | 2015-09-22 21:56:16
TWS auto-login thread ending. | 2015-09-22 21:56:16
Starting TWS auto-login thread. | 2015-09-22 21:56:20
TWS auto-login thread ending. | 2015-09-22 21:56:20
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:56:20
Socket (18) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:56:21
Socket (18) | Shutdown and closed. | 2015-09-22 21:56:21
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:56:21 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:56:21 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:56:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:56:21
Interactive Brokers | Disconnected. | 2015-09-22 21:56:21
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:56:21
Starting TWS auto-login thread. | 2015-09-22 21:56:24
TWS auto-login thread ending. | 2015-09-22 21:56:24
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:56:26
Socket (19) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:56:27
Socket (19) | Shutdown and closed. | 2015-09-22 21:56:27
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:56:27 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:56:27 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:56:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:56:27
Interactive Brokers | Disconnected. | 2015-09-22 21:56:27
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:56:27
Starting TWS auto-login thread. | 2015-09-22 21:56:28
TWS auto-login thread ending. | 2015-09-22 21:56:28
Starting TWS auto-login thread. | 2015-09-22 21:56:32
TWS auto-login thread ending. | 2015-09-22 21:56:32
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:56:32
Socket (20) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:56:33
Socket (20) | Shutdown and closed. | 2015-09-22 21:56:33
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:56:33 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:56:33 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:56:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:56:34
Interactive Brokers | Disconnected. | 2015-09-22 21:56:34
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:56:34
Starting TWS auto-login thread. | 2015-09-22 21:56:36
TWS auto-login thread ending. | 2015-09-22 21:56:36
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:56:39
Starting TWS auto-login thread. | 2015-09-22 21:56:40
TWS auto-login thread ending. | 2015-09-22 21:56:40
Socket (21) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:56:40
Socket (21) | Shutdown and closed. | 2015-09-22 21:56:40
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:56:40 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:56:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:56:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:56:40
Interactive Brokers | Disconnected. | 2015-09-22 21:56:40
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:56:40
Starting TWS auto-login thread. | 2015-09-22 21:56:44
TWS auto-login thread ending. | 2015-09-22 21:56:44
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:56:45
Socket (22) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:56:46
Socket (22) | Shutdown and closed. | 2015-09-22 21:56:46
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:56:46 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:56:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:56:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:56:46
Interactive Brokers | Disconnected. | 2015-09-22 21:56:46
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:56:46
Starting TWS auto-login thread. | 2015-09-22 21:56:48
TWS auto-login thread ending. | 2015-09-22 21:56:48
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:56:51
Starting TWS auto-login thread. | 2015-09-22 21:56:52
TWS auto-login thread ending. | 2015-09-22 21:56:52
Socket (24) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:56:52
Socket (24) | Shutdown and closed. | 2015-09-22 21:56:52
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:56:52 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:56:52 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:56:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:56:52
Interactive Brokers | Disconnected. | 2015-09-22 21:56:52
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:56:52
Starting TWS auto-login thread. | 2015-09-22 21:56:56
TWS auto-login thread ending. | 2015-09-22 21:56:56
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:56:57
Socket (25) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:56:58
Socket (25) | Shutdown and closed. | 2015-09-22 21:56:58
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:56:58 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:56:58 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:56:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:56:58
Interactive Brokers | Disconnected. | 2015-09-22 21:56:58
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:56:58
Starting TWS auto-login thread. | 2015-09-22 21:57:00
TWS auto-login thread ending. | 2015-09-22 21:57:00
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:57:03
Starting TWS auto-login thread. | 2015-09-22 21:57:04
TWS auto-login thread ending. | 2015-09-22 21:57:04
Socket (26) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:57:04
Socket (26) | Shutdown and closed. | 2015-09-22 21:57:04
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:57:04 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:57:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:57:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:57:04
Interactive Brokers | Disconnected. | 2015-09-22 21:57:04
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:57:04
Starting TWS auto-login thread. | 2015-09-22 21:57:08
TWS auto-login thread ending. | 2015-09-22 21:57:08
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:57:09
Socket (27) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:57:10
Socket (27) | Shutdown and closed. | 2015-09-22 21:57:10
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:57:10 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:57:10 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:57:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:57:10
Interactive Brokers | Disconnected. | 2015-09-22 21:57:10
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:57:10
Starting TWS auto-login thread. | 2015-09-22 21:57:12
TWS auto-login thread ending. | 2015-09-22 21:57:12
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:57:15
Starting TWS auto-login thread. | 2015-09-22 21:57:16
TWS auto-login thread ending. | 2015-09-22 21:57:16
Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:57:16
Socket (28) | Shutdown and closed. | 2015-09-22 21:57:16
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:57:16 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:57:16 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:57:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:57:16
Interactive Brokers | Disconnected. | 2015-09-22 21:57:16
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:57:16
Starting TWS auto-login thread. | 2015-09-22 21:57:20
TWS auto-login thread ending. | 2015-09-22 21:57:20
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:57:21
Socket (29) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:57:22
Socket (29) | Shutdown and closed. | 2015-09-22 21:57:22
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:57:22 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:57:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:57:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:57:22
Interactive Brokers | Disconnected. | 2015-09-22 21:57:22
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:57:22
Starting TWS auto-login thread. | 2015-09-22 21:57:24
TWS auto-login thread ending. | 2015-09-22 21:57:24
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:57:27
Starting TWS auto-login thread. | 2015-09-22 21:57:28
TWS auto-login thread ending. | 2015-09-22 21:57:28
Socket (30) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:57:28
Socket (30) | Shutdown and closed. | 2015-09-22 21:57:28
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:57:28 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:57:28 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:57:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:57:28
Interactive Brokers | Disconnected. | 2015-09-22 21:57:28
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:57:28
Starting TWS auto-login thread. | 2015-09-22 21:57:32
TWS auto-login thread ending. | 2015-09-22 21:57:32
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:57:33
Socket (31) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:57:34
Socket (31) | Shutdown and closed. | 2015-09-22 21:57:34
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:57:34 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:57:34 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:57:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:57:34
Interactive Brokers | Disconnected. | 2015-09-22 21:57:34
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:57:34
Starting TWS auto-login thread. | 2015-09-22 21:57:36
TWS auto-login thread ending. | 2015-09-22 21:57:36
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:57:39
Starting TWS auto-login thread. | 2015-09-22 21:57:40
TWS auto-login thread ending. | 2015-09-22 21:57:40
Socket (32) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:57:40
Socket (32) | Shutdown and closed. | 2015-09-22 21:57:40
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:57:40 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:57:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:57:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:57:40
Interactive Brokers | Disconnected. | 2015-09-22 21:57:40
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:57:40
Starting TWS auto-login thread. | 2015-09-22 21:57:44
TWS auto-login thread ending. | 2015-09-22 21:57:44
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:57:45
Socket (33) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:57:46
Socket (33) | Shutdown and closed. | 2015-09-22 21:57:46
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:57:46 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:57:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:57:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:57:46
Interactive Brokers | Disconnected. | 2015-09-22 21:57:46
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:57:46
Starting TWS auto-login thread. | 2015-09-22 21:57:48
TWS auto-login thread ending. | 2015-09-22 21:57:48
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 21:57:51
Starting TWS auto-login thread. | 2015-09-22 21:57:52
TWS auto-login thread ending. | 2015-09-22 21:57:52
Socket (34) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 21:57:52
Socket (34) | Shutdown and closed. | 2015-09-22 21:57:52
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 21:57:52 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 21:57:52 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 21:57:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 21:57:52
Interactive Brokers | Disconnected. | 2015-09-22 21:57:52
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 21:57:52
Starting TWS auto-login thread. | 2015-09-22 21:57:56
TWS auto-login thread ending. | 2015-09-22 21:57:56
Starting TWS auto-login thread. | 2015-09-22 21:58:00
TWS auto-login thread ending. | 2015-09-22 21:58:00
Starting TWS auto-login thread. | 2015-09-22 21:58:04
TWS auto-login thread ending. | 2015-09-22 21:58:04
Starting TWS auto-login thread. | 2015-09-22 21:58:08
TWS auto-login thread ending. | 2015-09-22 21:58:08
Starting TWS auto-login thread. | 2015-09-22 21:58:12
TWS auto-login thread ending. | 2015-09-22 21:58:12
Starting TWS auto-login thread. | 2015-09-22 21:58:16
TWS auto-login thread ending. | 2015-09-22 21:58:16
Current selected Data/Trading service: Interactive Brokers | 2015-09-22 21:58:36
File >> Disconnect selected. | 2015-09-22 21:59:53
Interactive Brokers | Disconnected. | 2015-09-22 21:59:53
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:00:15
Socket (36) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:00:16
Socket (36) | Shutdown and closed. | 2015-09-22 22:00:16
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:00:16 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:00:16 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:00:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:00:16
Interactive Brokers | Disconnected. | 2015-09-22 22:00:16
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:00:16
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:00:21
Socket (37) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:00:22
Socket (37) | Shutdown and closed. | 2015-09-22 22:00:22
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:00:22 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:00:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:00:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:00:22
Interactive Brokers | Disconnected. | 2015-09-22 22:00:22
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:00:22
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:00:27
Socket (38) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:00:28
Socket (38) | Shutdown and closed. | 2015-09-22 22:00:28
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:00:28 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:00:28 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:00:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:00:28
Interactive Brokers | Disconnected. | 2015-09-22 22:00:28
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:00:28
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:00:33
Socket (39) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:00:34
Socket (39) | Shutdown and closed. | 2015-09-22 22:00:34
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:00:34 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:00:34 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:00:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:00:34
Interactive Brokers | Disconnected. | 2015-09-22 22:00:34
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:00:34
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:00:39
Socket (40) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:00:40
Socket (40) | Shutdown and closed. | 2015-09-22 22:00:40
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:00:40 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:00:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:00:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:00:40
Interactive Brokers | Disconnected. | 2015-09-22 22:00:40
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:00:40
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:00:45
Socket (41) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:00:46
Socket (41) | Shutdown and closed. | 2015-09-22 22:00:46
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:00:46 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:00:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:00:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:00:46
Interactive Brokers | Disconnected. | 2015-09-22 22:00:46
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:00:46
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:00:51
Socket (43) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:00:52
Socket (43) | Shutdown and closed. | 2015-09-22 22:00:52
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:00:52 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:00:52 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:00:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:00:52
Interactive Brokers | Disconnected. | 2015-09-22 22:00:52
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:00:52
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:00:57
Socket (44) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:00:58
Socket (44) | Shutdown and closed. | 2015-09-22 22:00:58
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:00:58 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:00:58 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:00:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:00:58
Interactive Brokers | Disconnected. | 2015-09-22 22:00:58
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:00:58
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:01:03
Socket (45) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:01:04
Socket (45) | Shutdown and closed. | 2015-09-22 22:01:04
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:01:04 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:01:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:01:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:01:04
Interactive Brokers | Disconnected. | 2015-09-22 22:01:04
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:01:04
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:01:09
Socket (46) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:01:10
Socket (46) | Shutdown and closed. | 2015-09-22 22:01:10
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:01:10 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:01:10 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:01:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:01:10
Interactive Brokers | Disconnected. | 2015-09-22 22:01:10
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:01:10
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:01:15
Socket (47) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:01:16
Socket (47) | Shutdown and closed. | 2015-09-22 22:01:16
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:01:16 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:01:16 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:01:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:01:16
Interactive Brokers | Disconnected. | 2015-09-22 22:01:16
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:01:16
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:01:21
Socket (48) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:01:22
Socket (48) | Shutdown and closed. | 2015-09-22 22:01:22
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:01:22 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:01:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:01:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:01:22
Interactive Brokers | Disconnected. | 2015-09-22 22:01:22
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:01:22
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:01:27
Socket (49) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:01:28
Socket (49) | Shutdown and closed. | 2015-09-22 22:01:28
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:01:28 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:01:28 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:01:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:01:28
Interactive Brokers | Disconnected. | 2015-09-22 22:01:28
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:01:28
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:01:33
Socket (50) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:01:34
Socket (50) | Shutdown and closed. | 2015-09-22 22:01:34
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:01:34 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:01:34 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:01:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:01:34
Interactive Brokers | Disconnected. | 2015-09-22 22:01:34
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:01:34
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:01:39
Socket (51) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:01:40
Socket (51) | Shutdown and closed. | 2015-09-22 22:01:40
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:01:40 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:01:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:01:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:01:40
Interactive Brokers | Disconnected. | 2015-09-22 22:01:40
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:01:40
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:01:45
Socket (52) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:01:46
Socket (52) | Shutdown and closed. | 2015-09-22 22:01:46
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:01:46 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:01:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:01:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:01:46
Interactive Brokers | Disconnected. | 2015-09-22 22:01:46
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:01:46
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:01:51
Socket (53) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:01:52
Socket (53) | Shutdown and closed. | 2015-09-22 22:01:52
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:01:52 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:01:52 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:01:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:01:52
Interactive Brokers | Disconnected. | 2015-09-22 22:01:52
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:01:52
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:01:57
Socket (54) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:01:58
Socket (54) | Shutdown and closed. | 2015-09-22 22:01:58
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:01:58 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:01:58 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:01:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:01:58
Interactive Brokers | Disconnected. | 2015-09-22 22:01:58
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:01:58
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:02:03
Socket (55) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:02:04
Socket (55) | Shutdown and closed. | 2015-09-22 22:02:04
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:02:04 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:02:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:02:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:02:04
Interactive Brokers | Disconnected. | 2015-09-22 22:02:04
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:02:04
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:02:09
Socket (56) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:02:10
Socket (56) | Shutdown and closed. | 2015-09-22 22:02:10
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:02:10 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:02:10 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:02:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:02:10
Interactive Brokers | Disconnected. | 2015-09-22 22:02:10
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:02:10
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:02:15
Starting TWS auto-login thread. | 2015-09-22 22:02:16
TWS auto-login thread ending. | 2015-09-22 22:02:16
Socket (57) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:02:16
Socket (57) | Shutdown and closed. | 2015-09-22 22:02:16
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:02:16 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:02:16 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:02:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:02:16
Interactive Brokers | Disconnected. | 2015-09-22 22:02:16
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:02:16
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:02:21
Socket (58) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:02:22
Socket (58) | Shutdown and closed. | 2015-09-22 22:02:22
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:02:22 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:02:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:02:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:02:22
Interactive Brokers | Disconnected. | 2015-09-22 22:02:22
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:02:22
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:02:27
Socket (59) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:02:28
Socket (59) | Shutdown and closed. | 2015-09-22 22:02:28
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:02:28 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:02:28 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:02:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:02:28
Interactive Brokers | Disconnected. | 2015-09-22 22:02:28
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:02:28
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:02:33
Socket (60) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:02:34
Socket (60) | Shutdown and closed. | 2015-09-22 22:02:34
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:02:34 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:02:34 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:02:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:02:34
Interactive Brokers | Disconnected. | 2015-09-22 22:02:34
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:02:34
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:02:39
Socket (61) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:02:40
Socket (61) | Shutdown and closed. | 2015-09-22 22:02:40
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:02:40 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:02:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:02:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:02:40
Interactive Brokers | Disconnected. | 2015-09-22 22:02:40
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:02:40
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:02:45
Socket (62) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:02:46
Socket (62) | Shutdown and closed. | 2015-09-22 22:02:46
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:02:46 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:02:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:02:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:02:46
Interactive Brokers | Disconnected. | 2015-09-22 22:02:46
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:02:46
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:02:51
Socket (64) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:02:52
Socket (64) | Shutdown and closed. | 2015-09-22 22:02:52
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:02:52 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:02:52 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:02:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:02:52
Interactive Brokers | Disconnected. | 2015-09-22 22:02:52
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:02:52
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:02:57
Socket (65) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:02:59
Socket (65) | Shutdown and closed. | 2015-09-22 22:02:59
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:02:59 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:02:59 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:02:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:02:59
Interactive Brokers | Disconnected. | 2015-09-22 22:02:59
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:02:59
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:03:04
Socket (66) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:03:05
Socket (66) | Shutdown and closed. | 2015-09-22 22:03:05
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:03:05 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:03:05 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:03:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:03:05
Interactive Brokers | Disconnected. | 2015-09-22 22:03:05
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:03:05
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:03:10
Socket (67) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:03:11
Socket (67) | Shutdown and closed. | 2015-09-22 22:03:11
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:03:11 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:03:11 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:03:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:03:11
Interactive Brokers | Disconnected. | 2015-09-22 22:03:11
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:03:11
Current selected Data/Trading service: Interactive Brokers | 2015-09-22 22:04:27
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:06:11
Socket (69) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:06:12
Socket (69) | Shutdown and closed. | 2015-09-22 22:06:12
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:06:12 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:06:12 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:06:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:06:12
Interactive Brokers | Disconnected. | 2015-09-22 22:06:12
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:06:12
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:09:12
Socket (72) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:09:13
Socket (72) | Shutdown and closed. | 2015-09-22 22:09:13
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:09:13 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:09:13 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:09:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:09:13
Interactive Brokers | Disconnected. | 2015-09-22 22:09:13
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:09:13
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2015-09-22 22:12:13
Socket (74) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-22 22:12:14
Socket (74) | Shutdown and closed. | 2015-09-22 22:12:14
Interactive Brokers | Failed to connect to the data and trade server. | 2015-09-22 22:12:14 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-09-22 22:12:14 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-22 22:12:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-22 22:12:14
Interactive Brokers | Disconnected. | 2015-09-22 22:12:14
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-22 22:12:14
[2015-09-22 22:53:59]
Disregard the prior response if you saw it, from a user. It is not relevant and we do not agree with what is says. It has been hidden now. Connecting to Interactive Brokers is very simple.
This is the relevant error message:
Refer to step 22 here for help with this:
https://www.sierrachart.com/index.php?page=doc/IB.php#SetupInstructions
