Date/Time: Tue, 04 Nov 2025 14:57:39 +0000
User Email Question
View Count: 2521
[2013-03-27 15:07:29]
Sierra Chart - Max - Posts: 5880
From User:
Wondering if there would be a forced recalculation of the Chart study
- when replay function is used or is this something that needs to be
built into study itself?
Basically - using manual loop - Wanted to store certain values as the
bars progress and wanted to understand - what would happen if replay
is used - whether some intelligent logic needs to be built into study
itself or would SC automatically performs cleanup/forced recalc for
the study when replay is used.
Sierra Chart Support
[2013-03-27 19:23:14]
When you start a Replay when a replay is not running and you are not paused, all of the chart arrays are cleared and rebuilt and studies are fully recalculated.
