DTC Protocol Discussion Forum
Date/Time: Tue, 04 Nov 2025 15:43:12 +0000
HistoricalOrderFillsRequest
View Count: 3204
[2015-09-13 23:42:52]
vbmithr - Posts: 204
Does SC already send this message through DTC ?
I implemented this server side but I can't make SC send this message at all. I imagine that it is not yet implemented, is it true ?
Edit: Sometimes SC sends this message, when connecting to the service, but not all the time.
What makes SC sends this message or not at startup ?
Date Time Of Last Edit: 2015-09-14 09:09:00
[2015-09-14 09:56:58]
DTC Engineering - Posts: 320
Refer to step 14 here for information about this:
Data and Trading Communications (DTC) Protocol Test Client: Test Client instructions
The page has just been updated.
[2015-09-14 10:03:56]
Thanks, though in my case, it happens that SC does not send this message at all (though open order and position requests are sent). Do you have any idea about this?
[2015-09-14 10:09:18]
We have looked at the code and really we see 0% chance of a problem with this on our side.
It is only sent once 5 seconds later after the server responds with the LOGON_RESPONSE.
Date Time Of Last Edit: 2015-09-14 10:33:31
[2015-09-14 10:20:53]
This is really weird, I'm investigating.
From my side, I would say there is no way it is systematically sent. What are the exact condition under which you send this message ?
Are you sure there is no way you would sent, for example, positions request and order requests and send no historical fill requests ?
Thanks.
Date Time Of Last Edit: 2015-09-14 17:09:34
[2015-09-28 04:04:55]
The reason there was no response to the recent questions is because these questions are an edit.
You need to make a new posting.
Are you still experiencing a problem?
Step 14 explains the conditions which will cause it to be sent:
All three of these will go out five seconds after the Logon Response is received. Subsequent to this, only an Orders and Positions request will be sent.
The DTC Client in Sierra Chart is also used by the Rithmic and TransAct trading services. There is no problem with this with those services.
Date Time Of Last Edit: 2015-09-28 04:09:55
