Date/Time: Mon, 23 Dec 2024 02:27:34 +0000
Save data
View Count: 845
[2015-09-12 19:06:03] |
User832215 - Posts: 27 |
Hi, Is there a way to save the downloaded data so that you don't have to download it every time you start Sierra chart?
[2015-09-12 21:32:59] |
There is nothing special to do. Sierra Chart always saves the data. This is how Sierra Chart is designed. When you connect to the data feed, or when Historical Daily charts are opened, there will be a download request to bring them up to date. However, the previous data downloaded and received in real-time is already there in the data files. Maybe you are experiencing a problem with the Continuous Futures Contract feature? We recommend updating to the latest version because there have been some small changes made. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-12 21:33:58
[2015-09-12 21:36:56] |
But I don't see a reason to re-download old data for contracts that has expired. I could save a lot of time when starting Sierra Chart if I could save data for expired contracts. Isn't that possible?
[2015-09-12 21:50:12] |
This most definitely could not be happening. There will be one data request to make sure they are up-to-date but this is all. That happens very fast.Provide us evidence this is happening from the Message Log: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Provide the relevant portion of the Message Log only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-13 06:48:38] |
http://www.sierrachart.com/image.php?l=1442126823708.png This is what I see on the chart and this takes several minutes before it's done. |
[2015-09-13 07:16:36] |
That message does not indicate the downloading of historical data from the remote server. Indicates the loading of data from the local data file. This indicates a performance problem. Refer to help topic 30 for solutions: Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html Is that a Continuous Futures Contract chart? If so, you might want to re-download the data for all contract months following these instructions: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading The reason for this suggestion is just in case there is some unknown data problem causing this issue which will be corrected by a re-download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-13 07:17:22
