Date/Time: Thu, 26 Dec 2024 18:03:54 +0000
orders from SC to IB
View Count: 1018
[2015-09-08 16:58:59] |
User888876 - Posts: 33 |
hi, I have connected IB with SC, data flow with no problem. But when I set an order in SC for NQ futures, it does not transmit into IB. Can u assist me? Thanks, Z
[2015-09-08 17:28:57] |
Do you see the order in Sierra Chart with a Status of "Order Sent"? You can check this Status in Trade >> Trade Orders and Positions >> Orders.
[2015-09-09 11:48:29] |
Zdislav - Posts: 73 |
I have similar experience. Then I noticed, that the order remained in TWS with "Transmit" button next to it. It is really annoying to transmit every order... not possible for trading. I am on SIM, so I don't care yet, but I will soon... I guess, there must be a way to set transmitting without confirmation in TWS. I briefly looked at it and found some settings. I haven't tried it yet. Does anybody now how to set it? Maybe this is not the case... Date Time Of Last Edit: 2015-09-09 11:50:56
[2015-09-09 18:39:22] |
This is the relevant documentation for this: https://www.sierrachart.com/index.php?page=doc/IB.php#OrderNotTransmitted Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-15 11:29:39] |
Good day, I have SC connected to IB. Recently SC trade window shows position and P/L only for a short time after I enter into a position, within few seconds it resets and does not show either qty nor P/L although I am still in a position on IB. How can I fix it?
[2015-12-15 15:33:59] |
User62936 - Posts: 68 |
I just had this exact same problem as well. I found it odd since they appear to have fixed the issues with contracts for 2016 and IB. When I filled out a support ticket, I noticed that for some reason I was on version 1307 even though I just upgraded last night. I manually selected the newest version from the previous versions page and at least now have the newest version. My entry and exit fills weren't showing up properly, and after trying one scalp, this seems fixed now, but I haven't entered a trade yet that I will hold for a minutes to see if the position line stays. Until we get a reply, at least make sure you are on a current version. |
[2015-12-15 17:50:59] |
We see you are currently running version 1336. Are you still noticing this problem? What is the Symbol you are noticing this with? In response to post #6: 1307 is the latest version you will get when using Help >> Download Current Version (Old Spreadsheets) because Old Spreadsheets are no longer supported in newer versions of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-15 17:52:04
[2015-12-15 18:34:11] |
I downloaded latest version and it works now.
[2015-12-15 18:44:04] |
This is good.
[2015-12-17 16:16:35] |
Good day, I have SC connected to IB. Recently SC trade window shows position and P/L only for a short time after I enter into a position, within few seconds it resets and does not show either qty nor P/L although I am still in a position on IB. I downloaded latest version of SC. How can I fix it?
[2015-12-17 17:31:57] |
When you notice this problem, go to Trade >> Trade Orders and Positions >> Positions. Do you see the Position there for the Symbol and Trade Account? If so, what is the exact symbol displayed there for the Position? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
