Date/Time: Tue, 04 Nov 2025 14:57:45 +0000
barchart download failed
View Count: 3223
|   [2013-03-20 11:58:19]     |
| User86090 - Posts: 3 |
                hi i just engaged into barchart feed service, but i data fails to upload in sierra charts. please advise as to source of the problem. tnx  |
|   [2013-03-20 15:29:24]     |
                Please provide us a copy of the message log following the steps here: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support   |
|   [2013-03-20 18:03:30]     |
                We see  2 potential Issues: First you are running an older version of Sierra Chart. Update by selecting Help >> Download Current Version. You do not appear to have the proper Service selected. Follow through the Step-by-step instructions here: http://www.sierrachart.com/index.php?l=doc/Barchart.com.php#Using Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
