Date/Time: Tue, 04 Nov 2025 14:57:37 +0000
IB TWS and SC Orders
View Count: 2863
|   [2013-03-27 13:34:40]     |
| User23815 - Posts: 211 |
                I am a new user. For now I want to place orders in IBs TWS. It would be good if they showed on my SC chart window, but I don't want SC to have any automatic control or input over the trade. How do I set this up? Thanks
|   [2013-03-27 18:56:23]     |
                You need to disable Trade Simulation Mode as documented here: http://www.sierrachart.com/index.php?l=doc/doc_Trading.html#TradeSimulationMode Go to the chart and enable Trade >> Show Orders and Position. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
