Date/Time: Sat, 23 Nov 2024 00:45:27 +0000
Operations Question
View Count: 1735
[2013-06-13 13:12:30]
Richard Reyes - Posts: 98
I run Sierra Charts 24 hours a day 6 days a week. I noticed that the last two (2) days that in the morning, when I re-activate the displays (4 displays), that Sierra Charts is gone and I only have a Windows screen on all 4 displays. I have spoken with my internet provider (Time Warner Cable) and they tell me that there have been no problem outages on their end. Has Sierra Charts gone offline at anytime in the last 2 to 3 days, in the evenings? If not, what do you recommend that I look at or look for? Many Thanks.
[2013-06-13 15:24:45]
TastyRisk - Posts: 119
Hi, I'm not SierraChart Support but I'll suggest looking in your Windows Event Viewer (under Admin Tools) > Windows Logs > Application... Then see if you can find any error message relating to SierraChart.exe
An example below of what an error report looks like. You might not find one, or it might look different, but you might get some useful information from it.
Application: SierraChart_CTS.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.OutOfMemoryException
Stack:
at System.Text.StringBuilder.ExpandByABlock(Int32)
at System.Text.StringBuilder.Append(Char*, Int32)
at System.Text.StringBuilder.AppendHelper(System.String)
at System.Text.StringBuilder.Append(System.String)
at System.Text.StringBuilder.AppendFormat(System.IFormatProvider, System.String, System.Object[])
at System.String.Format(System.IFormatProvider, System.String, System.Object[])
at System.String.Format(System.String, System.Object[])
at T4.Connections.Connection.GetDescription()
at T4.Connections.Connection.RaiseDisconnected(System.Object)
at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(System.Object)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
[2013-06-13 16:28:30]
This is very unusual. Generally these issues are due to a stack corruption.
Refer to this help topic:
Http://www.sierrachart.com/index.php?l=doc/helpdetails17.html
[2013-06-13 18:06:35]
Richard, When you see that SC has gone, did you press control-alt-delete to pull up task manager so you can see if the SC exe process has gone too ?
