Date/Time: Sat, 12 Sep 2026 08:18:54 +0000
[User Discussion] - ACSIL REPLAY PROBLEM
View Count: 3407
[2015-08-26 19:05:27]
User668659 - Posts: 6
Hello! I've recently notice that a study i made with some moving averages signals doesn't work well in realtime/replay(Accurate trading system back test mode). If i disconnect the live data and apply the study it works without a problem. The study draw some lines above/under price based on two movavg positions and draw a triangle above/under the crossing point of another two movavg.
After a replay or working in real time appear signals that doesn't exist.
Maybe there is something i don't know that changes in ACSIL under a replay/real time.
I left the screenshots before/after replay.
Here is the code:
#include "sierrachart.h"
#include "scstudyfunctions.h"
#define RED RGB(255,0,0)
#define BLUE RGB(0,128,255)
SCDLLName("MovSlope")
SCSFExport scsf_MovSlope(SCStudyInterfaceRef sc){
  SCSubgraphRef MovSlope1 = sc.Subgraph[0];
  SCSubgraphRef MovSlope2 = sc.Subgraph[1];
  SCSubgraphRef MovSlope3 = sc.Subgraph[2];
  SCSubgraphRef MovSlope4 = sc.Subgraph[3];
  SCSubgraphRef MovSlope5 = sc.Subgraph[4];
  SCSubgraphRef MovSlope6 = sc.Subgraph[5];
  SCSubgraphRef MovSlope7 = sc.Subgraph[6];
  SCSubgraphRef MovSlope8 = sc.Subgraph[7];
  if (sc.SetDefaults){
    sc.GraphName = "MovSlope";
    sc.StudyDescription = "MovSlope";
    sc.AutoLoop = 1;
    sc.FreeDLL = 0;
    sc.GraphRegion = 0;
    MovSlope1.Name = "MV1";
    MovSlope1.DrawStyle = DRAWSTYLE_HIDDEN;
    MovSlope1.LineStyle = LINESTYLE_SOLID;
    MovSlope1.LineWidth = 3;
    MovSlope1.DrawZeros = false;
    MovSlope2.Name = "MV2";
    MovSlope2.DrawStyle = DRAWSTYLE_HIDDEN;
    MovSlope2.LineStyle = LINESTYLE_SOLID;
    MovSlope2.LineWidth = 3;
    MovSlope2.DrawZeros = false;
    MovSlope3.Name = "MV3";
    MovSlope3.DrawStyle = DRAWSTYLE_LINE_SKIPZEROS;
    MovSlope3.LineStyle = LINESTYLE_SOLID;
    MovSlope3.LineWidth = 3;
    MovSlope3.DrawZeros = false;
    MovSlope4.Name = "MV4";
    MovSlope4.DrawStyle = DRAWSTYLE_LINE_SKIPZEROS;
    MovSlope4.LineStyle = LINESTYLE_SOLID;
    MovSlope4.LineWidth = 3;
    MovSlope4.DrawZeros = false;
    MovSlope5.Name = "MV5";
    MovSlope5.DrawStyle = DRAWSTYLE_TRIANGLEDOWN;
    MovSlope5.LineWidth = 3;
    MovSlope5.DrawZeros = false;
    MovSlope6.Name = "MV6";
    MovSlope6.DrawStyle = DRAWSTYLE_TRIANGLEUP;
MovSlope6.LineWidth = 3;
    MovSlope6.DrawZeros = false;
    MovSlope7.Name = "MV7";
    MovSlope7.DrawStyle = DRAWSTYLE_HIDDEN;
    MovSlope7.LineStyle = LINESTYLE_SOLID;
    MovSlope7.LineWidth = 3;
    MovSlope7.DrawZeros = false;
    MovSlope8.Name = "MV8";
    MovSlope8.DrawStyle = DRAWSTYLE_HIDDEN;
    MovSlope8.LineStyle = LINESTYLE_SOLID;
    MovSlope8.LineWidth = 3;
    MovSlope8.DrawZeros = false;
    sc.Input[1].Name = "Red";
    sc.Input[1].SetColor(RED);
    sc.Input[2].Name = "Blue";
    sc.Input[2].SetColor(BLUE);
    return;
  SCFloatArrayRef Last = sc.Close;
  sc.SimpleMovAvg(Last, MovSlope1, sc.Index, 5);
  sc.SimpleMovAvg(Last, MovSlope2, sc.Index, 10);
  sc.SimpleMovAvg(Last, MovSlope7, sc.Index, 12);
  sc.SimpleMovAvg(Last, MovSlope8, sc.Index, 16);
  float mov1 = MovSlope1[sc.Index];
  float mov2 = MovSlope2[sc.Index];
  float mov7 = MovSlope7[sc.Index];
  float mov8 = MovSlope8[sc.Index];
  if (mov1 > mov2)
    MovSlope3[sc.Index] = mov1 + 6.0f;
    MovSlope3.DataColor[sc.Index] = sc.Input[2].GetColor();
  else if (mov1 < mov2)
    MovSlope4[sc.Index] = mov1 - 6.0f;
    MovSlope4.DataColor[sc.Index] = sc.Input[1].GetColor();
  if ((MovSlope7[sc.Index - 1] > MovSlope8[sc.Index - 1]) && (MovSlope7[sc.Index] < MovSlope8[sc.Index])){
    MovSlope5[sc.Index] = mov1 + 8.5f;
    MovSlope5.DataColor[sc.Index] = sc.Input[1].GetColor();
  else if ((MovSlope7[sc.Index - 1] < MovSlope8[sc.Index - 1]) && (MovSlope7[sc.Index] > MovSlope8[sc.Index])){
    MovSlope6[sc.Index] = mov1 - 8.5f;
MovSlope6.DataColor[sc.Index] = sc.Input[2].GetColor();
image1.png / V - Attached On 2015-08-26 19:01:02 UTC - Size: 28.41 KB - 501 views
image2.png / V - Attached On 2015-08-26 19:01:12 UTC - Size: 29.03 KB - 450 views
[2015-08-26 19:34:43]
We cannot analyze your code.
Do you notice a problem when you just perform a normal chart replay?
We recommend simplifying the study down to the absolute minimum and keep it very simple and then gradually make changes/additions until you discover where the problem is.
So you need to simplify the study down to this line only after the SetDefaults code block:
They gradually make the changes until you see were the problem is.
[2015-08-27 04:11:07]
During a normal chart replay remains the same. I think i found the problem.
Look at the images 1 and 2, this false signal is after the second half of the example image. I simplify the code, the only thing it does is drawing a triangle at the crossing points between both sma. In the image 1 there is a signal but the value of the sma MV1 is: 1898.430 but MV2 is: 1898.460. MV1 still is < than MV2. Evidently there is a problem of precision, how can i increment the precision?
At the image 1 this is false:
((MovSlope1[sc.Index - 1] < MovSlope2[sc.Index - 1]) && (MovSlope1[sc.Index] > MovSlope2[sc.Index]))
    sc.AutoLoop = 1;
    sc.FreeDLL = 0;
    sc.GraphRegion = 0;
    return;
  if ((MovSlope1[sc.Index - 1] > MovSlope2[sc.Index - 1]) && (MovSlope1[sc.Index] < MovSlope2[sc.Index]))
    MovSlope3[sc.Index] = MovSlope2[sc.Index] + 6.0f;
  else if ((MovSlope1[sc.Index - 1] < MovSlope2[sc.Index - 1]) && (MovSlope1[sc.Index] > MovSlope2[sc.Index]))
    MovSlope4[sc.Index] = MovSlope2[sc.Index] - 6.0f;
image1.png / V - Attached On 2015-08-27 04:02:37 UTC - Size: 13.62 KB - 512 views
image2.png / V - Attached On 2015-08-27 04:02:43 UTC - Size: 14.04 KB - 456 views
imageexample.png / V - Attached On 2015-08-27 04:02:50 UTC - Size: 44.18 KB - 423 views
[2015-08-27 05:53:06]
ejtrader - Posts: 689
You can look at the following function:
sc.FormattedEvaluate(value1, sc.BasedOnGraphValueFormat, EQUAL_OPERATOR, value2, sc.BasedOnGraphValueFormat)
[2015-08-27 13:49:12]
I'll try it ejtrader, thanks! But i'll really would like to know why this simple condition:
works while live data is disconnected, and fails once in a while during a replay or working with live data. Can someone explain this to me?
[2015-08-27 14:47:37]
Marek F - Posts: 254
Maybe used the function: sc.GetBarHasClosedStatus() for perform calculations on a fully completed bar, resolve your issue?
http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Functions.html#scGetBarHasClosedStatus
[2015-08-27 16:01:08]
Thanks sampater! I tried it and help me understand a little more the problem. If i use this:
if(sc.GetBarHasClosedStatus(Index)==BHCS_BAR_HAS_CLOSED)
Then i'll no longer see false signals after the bar colsed, but i need the signal in real time while both sma cross. So during the period of a bar i would like to be able to draw the signal while it's true but the moment after it's no longer true i would like to remove the signal(during or after the current bar).
How can i check in real time if a condition it's no longer true and then remove the statement(in this case drawing with a subgraph)?I mean before the bar has closed, because maybe i can check at the end of the bar if the condition it's no longer true, but i need to remove the statement at the moment the condition turns false.
I need to see during the period of the last bar only the result of the last execution. Can i delete the result of the last execution during the period of the current bar at the current execution?
[2015-08-29 11:53:58]
You need to set to 0 the Subgraphs of signal if both sma cross is not true.
This your code from post #1:
change to:
else
  MovSlope5[sc.Index] = 0;
  MovSlope5.DataColor[sc.Index] = RGB(0,0,0);
else
  MovSlope6[sc.Index] = 0;
  MovSlope6.DataColor[sc.Index] = RGB(0,0,0);
Marek
