Date/Time: Sun, 22 Dec 2024 17:37:46 +0000
New computer - data and settings transferred, but problem with spreadsheet conversion
View Count: 949
[2015-08-25 18:57:23]
User0123 - Posts: 36
I recently purchased a new computer, successfully downloaded Sierra Chart software and transferred settings and data per the instructions on the SC website. Upon loading a chartbook, however, there seemed to be problems with my custom spreadsheets. The message log stated:
Launching C:\SierraChart\SpreadsheetFileConverter.exe with parameters: "C:\SierraChart\Data\Dl.scwbf" "Dl.scss" 67396 -culture=1033 | 2015-08-25 14:31:26
Launching C:\SierraChart\SpreadsheetFileConverter.exe with parameters: "C:\SierraChart\Data\Dg.scwbf" "Dg.scss" 67398 -culture=1033 | 2015-08-25 14:31:26
Launching C:\SierraChart\SpreadsheetFileConverter.exe with parameters: "C:\SierraChart\Data\D1Hl.scwbf" "D1Hl.scss" 67442 -culture=1033 | 2015-08-25 14:31:26
Message from the spreadsheet file converter: Unhandled exception in the conversion process. | 2015-08-25 14:31:27 *
Spreadsheet conversion process running. | 2015-08-25 14:31:27
Unable to open C:\SierraChart\Data\Dl.scwbf because the spreadsheet file conversion failed. | 2015-08-25 14:31:27 *
Unable to open C:\SierraChart\Data\Dg.scwbf because the spreadsheet file conversion failed. | 2015-08-25 14:31:27 *
Unable to open C:\SierraChart\Data\D1Hl.scwbf because the spreadsheet file conversion failed. | 2015-08-25 14:31:27 *
Any and all help in resolving this issue would be very much appreciated
[2015-08-25 19:15:38]
You need to use the version of Sierra Chart with Old Spreadsheets.
Here is the download link:
https://www.sierrachart.com/downloads/SierraChartSetup.exe
Use this link to download and install Sierra Chart. This will solve the problem.
