Date/Time: Sun, 22 Dec 2024 05:33:02 +0000
Color Bar based on Alert- Alert manager "Go to chart" hides last bar
View Count: 1190
[2015-08-04 19:06:13] |
phaedonk - Posts: 352 |
What the title says. When I press "go to chart", focus goes to the bar before the last (where alert is true) but last bar is hidden and I need to press End to see it. I would appreciate it if you made it that the last bar is not hidden Also, seeing as we cannot post in the "New Control Bar to replace ToolBar and Status Bar" the CTV windows is still repositioning itself even with version 1280. Superb work on the new toolbars by the way. Date Time Of Last Edit: 2015-08-04 19:10:37
[2015-08-04 19:10:34] |
It is very unlikely there is something wrong with this. Copy and paste here the particular Alert Line in the Alerts Log you are using the Go to Chart function with. And what is the starting Date-Time of the two last bars in the chart? You can determine this with the Tools >> Chart Values tool. Update: After we read what you wrote again, we realize we misunderstood it. What you see is normal. The bar with the matching Date-Time becomes the last bar in the the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-04 19:13:21
[2015-08-04 19:12:41] |
The repositioning problem has been solved in the latest revision of 1280. Update with Help >> Download Prerelease. That will become the main release later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-04 19:13:54] |
Alert - Chart: EUR.GBP-CASH-IDEALPRO 60 Min #1 | Study: Color Bar Based On Alert Condition | Formula: =AND((L[-1]-L>H-L[-1]), L[-1]>C) is TRUE. | Last Price: 0.69957 | Bar Start Time: 2015-08-04 21:00:00 | No alert sound/email Last two bars time is 2100 and 2200. For all other alerts (rectangle hits for example) Go to chart functions correctly without hiding last bar. |
