Date/Time: Thu, 17 Sep 2026 15:42:17 +0000
ACSIL user buttons
View Count: 2129
| [2015-07-10 20:19:56] |
| User231363 - Posts: 31 |
I am looking to implement 2 types of buttons that ACSIL can interact with: (1) I am creating ACSIL code for a bid/ask pressure gauge, and need the user to be able to push a button to reset the pressure back to zero. (2) I want to add a button that enables/disables each of my ACSIL studies I can't find how to add a toolbar button that my ACSIL can receive a click event from. I've read about the 50 ACSIL toolbar buttons, but it seems these won't work for me because only 1 of them can be active at a time. Can you please point me toward how to create these buttons? thanks! |
| [2015-07-11 00:02:14] |
1. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_MouseAndMenuInteractionFromACStudy.html#UsingACSTBButtons1TimeEvents Be sure to reload the page because we have updated the documentation. 2. If this is the same as 1, then refer to the answer for 1. Otherwise, refer to this section here: https://www.sierrachart.com/index.php?page=doc/doc_MouseAndMenuInteractionFromACStudy.html#ACSToolButtonAndPointerEvents Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
