Date/Time: Sun, 22 Dec 2024 05:04:58 +0000
Alerts for IB Extensions and Crossover usage
View Count: 764
[2015-07-04 02:25:04] |
Acro - Posts: 441 |
Hi, Just looking for advice/knowledge from Alert Experts. If I am using the Initial Balance study do I need two separate instances of this study if I want separate alerts for price hitting two separate IB extensions. I've tried using the following type of alert formula: =AND(BARTIME>((10*60+30)/(24*60)),OR((C+0.75)>=ID6.SG5,(C-0.75)<=ID6.SG11)) But I find I need two separate study instances to get two separate alerts for different IB Extensions. The other question I had was the use of the CROSSOVER function. Can anyone confirm this does NOT work if you put in eg "C + 0.25" - ie you can't use it where you want the alert on price approaching rather than hitting your price level. Cheers for any help |
[2015-07-06 18:13:51] |
If I am using the Initial Balance study do I need two separate instances of this study if I want separate alerts for price hitting two separate IB extensions. No. You just need to use the OR function. The OR function must be the outermost function call in the formula. Since the CROSSOVER function requires a range of values, this definitely will not work: The other question I had was the use of the CROSSOVER function. Can anyone confirm this does NOT work if you put in eg "C + 0.25" - ie you can't use it where you want the alert on price approaching rather than hitting your price level. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
