Date/Time: Sat, 19 Sep 2026 11:40:35 +0000
tried that
View Count: 1265
| [2015-07-02 18:58:01] |
| User716402 - Posts: 28 |
Tried to save that way. Even then the chars are clicked on when you close the platfoem you save the chartbook -right It should come back as it is . Ive saved when I was with infinity and had no problems saving for 3 or 4 years . I think there is another problrm - Thanks=Gary
| [2015-07-02 19:08:28] |
After the Chartbook is saved, and Sierra Chart is restarted, you will need to open the saved Chartbook through File >> Open Chartbook. Are you doing that? If not, and that solves the problem and you want the Chartbook opened automatically then this be done through Global Settings >> General Settings >> Files to Open on Start up. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-02 19:10:14
| [2015-07-02 19:08:41] |
I just tried your recommendation and it worked . Ill fool with this over the weekend. I could be wrong. In fact one time I thought I was wrong and then realized I was right so I guess that counts as a wrong. Thanks Gary
| [2015-07-02 19:10:44] |
If you want the Chartbook opened automatically, then this can be done through Global Settings >> General Settings >> Files to Open on Startup.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-07 15:04:29
| [2015-07-07 12:20:19] |
Used your sugestion of Global Settings>>General Settings>>Files to open on start up everything was going good. Using many closes after file>>save and reopening. Reopened at 200am and everyyhing perfect. Closed with file save and reopened just now and several charts were missing --Gary
| [2015-07-07 15:22:29] |
We see no reason why there would be a problem with this. Do you see the charts listed under the CW menu? Are any of the charts detached? If you are not sure what that is, refer to this page: http://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
