Date/Time: Tue, 06 Oct 2026 10:27:23 +0000
save new studies on charts and lose everything
View Count: 1072
[2015-07-02 18:32:37]
User716402 - Posts: 28
I posted a new message earlier this morning . I went thru each chart making a study on each for volume profile saved each chart by clicking with the pointer on each then going to file save as and saving each ,closing the platform and reopening and all my study changes foe volume profile werew gone. Please help. Cant trade -too wore out from trying to fix this=Gary
[2015-07-02 18:46:09]
All charts that are visible are contained within a single Chartbook. You do not save them individually. If you do, then you will have multiple Chartbooks and when you open one of them, it will only contain one chart, assuming you saved each chart under a different name.
Once you are done setting up the charts the way you require you simply go to File >> Save and this is all.
Here is the documentation for Chartbooks:
http://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html
