Date/Time: Fri, 10 Jan 2025 23:12:25 +0000
Volume By Price option
View Count: 2171
[2015-06-25 11:05:38] |
User87197 - Posts: 65 |
Hey SC. I think this would be a super-quick implementation that could be really handy for people using the Volume By Price study (of which SC's is the already pre-eminent iteration IMO). In the study settings under "Maximum Volume Bar Width Type" a third option for "Fill Space" would allow someone to have their VBP study fill a percentage of the Fill Space. I think the case for adding it is pretty straightforward, but to elaborate just in case: The existing: 'Window Width' setting can become awkward for users that are switching their chart windows to/from 'Fullscreen' mode frequently or changing their window-size. The 'Period Length' option (by necessity) begins each new session with essentially zero width and gradually becomes legible as time elapses (which is not as appropriate for users that are assessing the changes in the profile near the beginning of their chosen period length. Thanks SC, Jon |
[2015-06-25 16:59:25] |
We will see about this.
[2016-01-18 23:00:48] |
Letting you know we are getting close to working on this in the next week: In the study settings under "Maximum Volume Bar Width Type" a third option for "Fill Space" would allow someone to have their VBP study fill a percentage of the Fill Space.
[2016-01-18 23:39:58] |
Because you're awesome. Thanks SC.
[2016-02-07 16:32:57] |
Al SC Developer - Posts: 434 |
We have added a new option "Include Fill Space In Developing Period Width". When this Input setting is set, the chart fill space is included into the period width of a developing period, allowing more space for a developing period to be displayed. |
[2016-02-07 16:39:12] |
That's even better, brilliant! :)
[2016-10-17 13:43:10] |
6c7574686572 - Posts: 20 |
Is it possible to have an option that would display the study in the fill space only?
