Date/Time: Tue, 04 Nov 2025 14:57:46 +0000
Place Vertical Lines at Daily Session Role
View Count: 2691
|   [2013-03-26 22:48:12]     |
| User23815 - Posts: 211 |
                New user. How do I place a vertical line at the daily session rollover time that I use. It is not 24:00 so I need to be able to set the time or match it to my session times in chart settings. Thanks
|   [2013-03-26 23:30:31]     |
                Please see: http://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#Vgrid Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
