Date/Time: Sun, 22 Dec 2024 14:38:10 +0000
Fxcm FixTrading Login Issue
View Count: 3300
[2015-05-29 11:48:01] |
User787669 - Posts: 5 |
Been back and forth with fxcm support to help with login. No luck thus far. Received credentials from them as shown below. SocketConnectHost=fixreal.fxcorporate.com SocketConnectPort=8037 SenderCompID=6100001161_client1 TargetCompID=FXCM TargetSubID=XTPREAL01 Message Log: FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:40:56 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:40:56 FXCM FIX Trading session socket (24) | Connected. | 2015-05-29 07:40:56 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:40:56 FXCM FIX Trading session socket (24) | Closed. No error. | 2015-05-29 07:40:56 FXCM FIX Trading session socket (24) | Shutdown and closed. | 2015-05-29 07:40:56 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:40:56 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:40:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:40:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:40:56 FXCM FIX Trading: Disconnected. | 2015-05-29 07:40:56 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:40:56 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:01 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:01 FXCM FIX Trading session socket (25) | Connected. | 2015-05-29 07:41:02 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:02 FXCM FIX Trading session socket (25) | Closed. No error. | 2015-05-29 07:41:02 FXCM FIX Trading session socket (25) | Shutdown and closed. | 2015-05-29 07:41:02 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:02 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:02 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:02 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:02 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:07 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:07 FXCM FIX Trading session socket (26) | Connected. | 2015-05-29 07:41:07 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:07 FXCM FIX Trading session socket (26) | Closed. No error. | 2015-05-29 07:41:07 FXCM FIX Trading session socket (26) | Shutdown and closed. | 2015-05-29 07:41:07 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:07 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:07 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:07 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:07 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:12 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:12 FXCM FIX Trading session socket (27) | Connected. | 2015-05-29 07:41:12 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:13 FXCM FIX Trading session socket (27) | Closed. No error. | 2015-05-29 07:41:13 FXCM FIX Trading session socket (27) | Shutdown and closed. | 2015-05-29 07:41:13 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:13 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:13 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:13 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:13 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:18 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:18 FXCM FIX Trading session socket (28) | Connected. | 2015-05-29 07:41:18 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:18 FXCM FIX Trading session socket (28) | Closed. No error. | 2015-05-29 07:41:18 FXCM FIX Trading session socket (28) | Shutdown and closed. | 2015-05-29 07:41:18 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:18 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:18 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:18 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:18 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:23 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:23 FXCM FIX Trading session socket (29) | Connected. | 2015-05-29 07:41:23 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:23 FXCM FIX Trading session socket (29) | Closed. No error. | 2015-05-29 07:41:24 FXCM FIX Trading session socket (29) | Shutdown and closed. | 2015-05-29 07:41:24 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:24 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:24 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:24 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:24 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:29 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:29 FXCM FIX Trading session socket (30) | Connected. | 2015-05-29 07:41:29 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:29 FXCM FIX Trading session socket (30) | Closed. No error. | 2015-05-29 07:41:29 FXCM FIX Trading session socket (30) | Shutdown and closed. | 2015-05-29 07:41:29 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:29 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:29 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:29 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:29 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:34 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:34 FXCM FIX Trading session socket (31) | Connected. | 2015-05-29 07:41:34 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:34 FXCM FIX Trading session socket (31) | Closed. No error. | 2015-05-29 07:41:34 FXCM FIX Trading session socket (31) | Shutdown and closed. | 2015-05-29 07:41:34 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:34 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:35 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:35 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:35 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:40 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:40 FXCM FIX Trading session socket (32) | Connected. | 2015-05-29 07:41:40 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:40 FXCM FIX Trading session socket (32) | Closed. No error. | 2015-05-29 07:41:40 FXCM FIX Trading session socket (32) | Shutdown and closed. | 2015-05-29 07:41:40 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:40 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:40 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:40 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:40 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:45 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:45 FXCM FIX Trading session socket (33) | Connected. | 2015-05-29 07:41:45 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:45 FXCM FIX Trading session socket (33) | Closed. No error. | 2015-05-29 07:41:45 FXCM FIX Trading session socket (33) | Shutdown and closed. | 2015-05-29 07:41:45 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:45 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:45 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:45 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:45 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:50 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:50 FXCM FIX Trading session socket (34) | Connected. | 2015-05-29 07:41:51 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:51 FXCM FIX Trading session socket (34) | Closed. No error. | 2015-05-29 07:41:51 FXCM FIX Trading session socket (34) | Shutdown and closed. | 2015-05-29 07:41:51 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:51 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:51 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:51 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:51 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:41:56 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:41:56 FXCM FIX Trading session socket (35) | Connected. | 2015-05-29 07:41:56 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:41:56 FXCM FIX Trading session socket (35) | Closed. No error. | 2015-05-29 07:41:56 FXCM FIX Trading session socket (35) | Shutdown and closed. | 2015-05-29 07:41:56 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:41:56 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:41:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:41:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:41:56 FXCM FIX Trading: Disconnected. | 2015-05-29 07:41:56 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:41:56 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:42:01 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:42:01 FXCM FIX Trading session socket (36) | Connected. | 2015-05-29 07:42:01 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:42:02 FXCM FIX Trading session socket (36) | Closed. No error. | 2015-05-29 07:42:02 FXCM FIX Trading session socket (36) | Shutdown and closed. | 2015-05-29 07:42:02 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:42:02 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:42:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:42:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:42:02 FXCM FIX Trading: Disconnected. | 2015-05-29 07:42:02 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:42:02 Current selected Data/Trading service: FXCM FIX Trading | 2015-05-29 07:42:04 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-29 07:42:07 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-29 07:42:07 FXCM FIX Trading session socket (37) | Connected. | 2015-05-29 07:42:07 FXCM FIX Trading session: Sending the Logon message. | 2015-05-29 07:42:07 FXCM FIX Trading session socket (37) | Closed. No error. | 2015-05-29 07:42:07 FXCM FIX Trading session socket (37) | Shutdown and closed. | 2015-05-29 07:42:07 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-29 07:42:07 FXCM FIX Trading session: Disconnected. | 2015-05-29 07:42:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-29 07:42:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-29 07:42:07 FXCM FIX Trading: Disconnected. | 2015-05-29 07:42:07 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-29 07:42:07 File >> Disconnect selected. | 2015-05-29 07:42:10 FXCM FIX Trading: Disconnected. | 2015-05-29 07:42:10 Firewall disabled. Virus Protector disabled. I have numerous hours trying to resolve this. Thank you in advance. |
screenshot.PNG / V - Attached On 2015-05-29 11:44:23 UTC - Size: 54.64 KB - 477 views |
[2015-05-29 16:37:51] |
We have tested this. This is not set correctly: SenderCompID: 6100001161_client1 You need to enter the 1 after client. Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-31 23:54:46
[2015-05-31 23:08:51] |
Hello Sierra Engineering team. Still no success. I am getting a differnt error message now. See the log. FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:00:14 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:00:14 FXCM FIX Trading session socket (64) | Connected. | 2015-05-31 19:00:14 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:00:14 FXCM FIX Trading session: Session connected. Sending logon user request. | 2015-05-31 19:00:14 FXCM FIX Trading session | User status: 19915;DAS 19915: ZDas Exception ORA-20101: Wrong user name or password ORA-06512: at "U10R20.ERROR", line 23 ORA-06512: at "U10R20.API", line 417 ORA-06512: at line 1 | 2015-05-31 19:00:14 FXCM FIX Trading session: Logon Error. Expecting logout message from server. | 2015-05-31 19:00:14 * FXCM FIX Trading session: Received a Logout message. Text = user not recognised or password incorrect.2 | 2015-05-31 19:00:14 FXCM FIX Trading session: Sending a Logout message. Text = Received Logout message. | 2015-05-31 19:00:14 FXCM FIX Trading session socket (64) | Shutdown and closed. | 2015-05-31 19:00:14 FXCM FIX Trading session: Logged out and disconnected. | 2015-05-31 19:00:14 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:00:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:00:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:00:14 FXCM FIX Trading: Disconnected. | 2015-05-31 19:00:14 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:00:14 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:00:19 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:00:19 FXCM FIX Trading session socket (65) | Connected. | 2015-05-31 19:00:19 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:00:20 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:00:20 * FXCM FIX Trading session socket (65) | Closed. No error. | 2015-05-31 19:00:20 FXCM FIX Trading session socket (65) | Shutdown and closed. | 2015-05-31 19:00:20 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:00:20 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:00:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:00:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:00:20 FXCM FIX Trading: Disconnected. | 2015-05-31 19:00:20 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:00:20 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:00:25 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:00:25 FXCM FIX Trading session socket (66) | Connected. | 2015-05-31 19:00:25 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:00:25 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:00:25 * FXCM FIX Trading session socket (66) | Closed. No error. | 2015-05-31 19:00:25 FXCM FIX Trading session socket (66) | Shutdown and closed. | 2015-05-31 19:00:25 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:00:25 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:00:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:00:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:00:25 FXCM FIX Trading: Disconnected. | 2015-05-31 19:00:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:00:25 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:00:30 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:00:30 FXCM FIX Trading session socket (67) | Connected. | 2015-05-31 19:00:30 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:00:30 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:00:30 * FXCM FIX Trading session socket (67) | Closed. No error. | 2015-05-31 19:00:30 FXCM FIX Trading session socket (67) | Shutdown and closed. | 2015-05-31 19:00:30 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:00:30 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:00:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:00:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:00:30 FXCM FIX Trading: Disconnected. | 2015-05-31 19:00:30 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:00:30 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:00:35 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:00:35 FXCM FIX Trading session socket (68) | Connected. | 2015-05-31 19:00:36 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:00:36 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:00:36 * FXCM FIX Trading session socket (68) | Closed. No error. | 2015-05-31 19:00:36 FXCM FIX Trading session socket (68) | Shutdown and closed. | 2015-05-31 19:00:36 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:00:36 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:00:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:00:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:00:36 FXCM FIX Trading: Disconnected. | 2015-05-31 19:00:36 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:00:36 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:00:41 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:00:41 FXCM FIX Trading session socket (69) | Connected. | 2015-05-31 19:00:41 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:00:41 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:00:41 * FXCM FIX Trading session socket (69) | Closed. No error. | 2015-05-31 19:00:41 FXCM FIX Trading session socket (69) | Shutdown and closed. | 2015-05-31 19:00:41 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:00:41 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:00:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:00:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:00:41 FXCM FIX Trading: Disconnected. | 2015-05-31 19:00:41 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:00:41 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:00:46 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:00:46 FXCM FIX Trading session socket (70) | Connected. | 2015-05-31 19:00:46 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:00:47 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:00:47 * FXCM FIX Trading session socket (70) | Closed. No error. | 2015-05-31 19:00:47 FXCM FIX Trading session socket (70) | Shutdown and closed. | 2015-05-31 19:00:47 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:00:47 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:00:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:00:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:00:47 FXCM FIX Trading: Disconnected. | 2015-05-31 19:00:47 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:00:47 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:00:52 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:00:52 FXCM FIX Trading session socket (71) | Connected. | 2015-05-31 19:00:52 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:00:52 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:00:52 * FXCM FIX Trading session socket (71) | Closed. No error. | 2015-05-31 19:00:52 FXCM FIX Trading session socket (71) | Shutdown and closed. | 2015-05-31 19:00:52 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:00:52 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:00:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:00:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:00:52 FXCM FIX Trading: Disconnected. | 2015-05-31 19:00:52 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:00:52 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:00:57 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:00:57 FXCM FIX Trading session socket (72) | Connected. | 2015-05-31 19:00:58 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:00:58 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:00:58 * FXCM FIX Trading session socket (72) | Closed. No error. | 2015-05-31 19:00:58 FXCM FIX Trading session socket (72) | Shutdown and closed. | 2015-05-31 19:00:58 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:00:58 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:00:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:00:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:00:58 FXCM FIX Trading: Disconnected. | 2015-05-31 19:00:58 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:00:58 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:01:03 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:01:03 FXCM FIX Trading session socket (73) | Connected. | 2015-05-31 19:01:03 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:01:03 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:01:04 * FXCM FIX Trading session socket (73) | Closed. No error. | 2015-05-31 19:01:04 FXCM FIX Trading session socket (73) | Shutdown and closed. | 2015-05-31 19:01:04 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:01:04 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:01:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:01:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:01:04 FXCM FIX Trading: Disconnected. | 2015-05-31 19:01:04 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:01:04 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:01:09 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:01:09 FXCM FIX Trading session socket (74) | Connected. | 2015-05-31 19:01:09 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:01:09 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:01:09 * FXCM FIX Trading session socket (74) | Closed. No error. | 2015-05-31 19:01:09 FXCM FIX Trading session socket (74) | Shutdown and closed. | 2015-05-31 19:01:09 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:01:09 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:01:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:01:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:01:10 FXCM FIX Trading: Disconnected. | 2015-05-31 19:01:10 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:01:10 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:01:15 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:01:15 FXCM FIX Trading session socket (75) | Connected. | 2015-05-31 19:01:15 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:01:15 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:01:15 * FXCM FIX Trading session socket (75) | Closed. No error. | 2015-05-31 19:01:15 FXCM FIX Trading session socket (75) | Shutdown and closed. | 2015-05-31 19:01:15 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:01:15 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:01:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:01:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:01:15 FXCM FIX Trading: Disconnected. | 2015-05-31 19:01:15 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:01:15 FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8037. | 2015-05-31 19:01:20 FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-05-31 19:01:20 FXCM FIX Trading session socket (76) | Connected. | 2015-05-31 19:01:20 FXCM FIX Trading session: Sending the Logon message. | 2015-05-31 19:01:20 FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:01:20 * FXCM FIX Trading session socket (76) | Closed. No error. | 2015-05-31 19:01:20 FXCM FIX Trading session socket (76) | Shutdown and closed. | 2015-05-31 19:01:20 FXCM FIX Trading session: Socket connection was closed without any logout messages sent or received. | 2015-05-31 19:01:20 FXCM FIX Trading session: Disconnected. | 2015-05-31 19:01:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-31 19:01:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-31 19:01:20 FXCM FIX Trading: Disconnected. | 2015-05-31 19:01:20 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-31 19:01:20 Thank you in advance. |
[2015-05-31 23:59:23] |
For this message: FXCM FIX Trading session: Received a Logout message. Text = user not recognised or password incorrect.2 | 2015-05-31 19:00:14
Go to Global Settings >> Data/Trade Service Settings. Make sure the Password is set correctly. Contact FXCM if you are not sure what it is.FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 1. Reference Message Type = A. SessionRejectReason = 9. Text = This session is already connected. Multiple logons/connections are not allowed. | 2015-05-31 19:01:20 * And based upon the first message which we listed above it should have closed the connection immediately after sending the log out message. But it did not. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-01 00:14:15
[2015-06-01 16:44:54] |
Resolved. This ticket can be closed. FXCM did not properly have my username programmed in. ugggg. Days wasted. Thanks. One question: is it possible to pull in last weeks recent trades into sierra charts for analysis. I see today's trades but not last weeks. I have adjusted the calander to reflect the days needed from last week. There is no output into trade activity log.... |
[2015-06-01 20:21:59] |
is it possible to pull in last weeks recent trades into sierra charts for analysis. Not automatically. You can manually Insert them. Refer to this section here:https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#MenuCommands Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
