Date/Time: Tue, 06 Oct 2026 07:40:08 +0000
connect to CQG
View Count: 1371
[2015-05-19 20:21:31]
User584992 - Posts: 1
hello dear, please clarify me the reason why I cannot connect to CQG?
What kind of connection I should to choose?
CQG WebAPI | Connecting to CQG web API. | 2015-05-20 00:19:43
Connecting to websocket server. | 2015-05-20 00:19:43
Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-05-20 00:19:43
Socket (36) | Connected. | 2015-05-20 00:19:43
Socket (36) | Starting SSL connection. | 2015-05-20 00:19:43
Socket (36) | SSL connection established. | 2015-05-20 00:19:43
Opening websocket. | 2015-05-20 00:19:43
Sending websocket handshake. | 2015-05-20 00:19:43
Received websocket handshake acknowledgment. | 2015-05-20 00:19:43
Web socket state is now open. | 2015-05-20 00:19:43
CQG WebAPI | Websocket connected. | 2015-05-20 00:19:43
CQG WebAPI | Sending market data logon message. | 2015-05-20 00:19:43
CQG WebAPI | Logon unsuccessful. Server message: The password is incorrect. | 2015-05-20 00:19:44 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-20 00:19:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-20 00:19:44
Socket (36) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-20 00:19:44
Socket (36) | SSL has been shut down. | 2015-05-20 00:19:44
Socket (36) | SSL object has been freed. SSL state is now disconnected. | 2015-05-20 00:19:44
Socket (36) | Shutdown and closed. | 2015-05-20 00:19:44
CQG WebAPI | Websocket closed. | 2015-05-20 00:19:44
CQG WebAPI | Disconnected. | 2015-05-20 00:19:44
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-20 00:19:44
CQG WebAPI | Connecting to CQG web API. | 2015-05-20 00:19:49
Connecting to websocket server. | 2015-05-20 00:19:49
Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-05-20 00:19:49
Socket (37) | Connected. | 2015-05-20 00:19:49
Socket (37) | Starting SSL connection. | 2015-05-20 00:19:49
Socket (37) | SSL connection established. | 2015-05-20 00:19:49
Opening websocket. | 2015-05-20 00:19:49
Sending websocket handshake. | 2015-05-20 00:19:49
Received websocket handshake acknowledgment. | 2015-05-20 00:19:49
Web socket state is now open. | 2015-05-20 00:19:49
CQG WebAPI | Websocket connected. | 2015-05-20 00:19:49
CQG WebAPI | Sending market data logon message. | 2015-05-20 00:19:49
CQG WebAPI | Logon unsuccessful. Server message: The password is incorrect. | 2015-05-20 00:19:50 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-20 00:19:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-20 00:19:50
Socket (37) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-20 00:19:50
Socket (37) | SSL has been shut down. | 2015-05-20 00:19:50
Socket (37) | SSL object has been freed. SSL state is now disconnected. | 2015-05-20 00:19:50
Socket (37) | Shutdown and closed. | 2015-05-20 00:19:50
CQG WebAPI | Websocket closed. | 2015-05-20 00:19:50
CQG WebAPI | Disconnected. | 2015-05-20 00:19:50
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-20 00:19:50
CQG WebAPI | Connecting to CQG web API. | 2015-05-20 00:19:55
Connecting to websocket server. | 2015-05-20 00:19:55
Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-05-20 00:19:55
Socket (38) | Connected. | 2015-05-20 00:19:55
Socket (38) | Starting SSL connection. | 2015-05-20 00:19:55
Socket (38) | SSL connection established. | 2015-05-20 00:19:55
Opening websocket. | 2015-05-20 00:19:55
Sending websocket handshake. | 2015-05-20 00:19:55
Received websocket handshake acknowledgment. | 2015-05-20 00:19:56
Web socket state is now open. | 2015-05-20 00:19:56
CQG WebAPI | Websocket connected. | 2015-05-20 00:19:56
CQG WebAPI | Sending market data logon message. | 2015-05-20 00:19:56
CQG WebAPI | Logon unsuccessful. Server message: Too many logon attempts. Please contact your FCM. | 2015-05-20 00:19:56 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-20 00:19:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-20 00:19:56
Socket (38) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-20 00:19:56
Socket (38) | SSL has been shut down. | 2015-05-20 00:19:56
Socket (38) | SSL object has been freed. SSL state is now disconnected. | 2015-05-20 00:19:56
Socket (38) | Shutdown and closed. | 2015-05-20 00:19:56
CQG WebAPI | Websocket closed. | 2015-05-20 00:19:56
CQG WebAPI | Disconnected. | 2015-05-20 00:19:56
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-20 00:19:56
File >> Disconnect selected. | 2015-05-20 00:19:57
CQG WebAPI | Disconnected. | 2015-05-20 00:19:57
[2015-05-19 21:57:53]
These are the relevant messages from the CQG server:
Make sure the Connection Details >>Password is set correctly in Global Settings >> Data/Trade Service Settings.
And contact your broker and tell them your account needs to be unlocked so you can try to login again. Refer your broker to the messages above.
