Date/Time: Tue, 04 Nov 2025 14:57:35 +0000
Horizontal Lines
View Count: 2720
|   [2013-03-26 18:58:24]     |
| User23815 - Posts: 211 |
                I'm a new user. Trading fx futures using 4 digits to the right of the decimal. Ex; 1.0001. Is there a tool that allows me to have SC draw horizontal lines at fixed levels. EX; 1.0020, 1.0050, 1.0080, 2.0000, 2.0020. I know I can draw them daily as price moves around but I wondered if I could cause them to draw on those points automatically? Thanks
|   [2013-03-26 19:00:08]     |
| joshtrader - Posts: 526 |
                See the "Horizontal Line" study.  SC has a lot of very good built in studies, and sometimes looking in that list will turn up what you want.
|   [2013-03-26 19:02:36]     |
| M5amhan - Posts: 468 |
                you can also use horizontal line draw tool, right click and lock it, and set the values in anchors depending on what you are trying to do, if you switch between symbols using a quoteboard this would be preferable  |
|   [2013-03-26 23:35:47]     |
                Refer to the Horizontal Line tool here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#VerticalandHorizontalLines And this: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ToolValuesAdjustToNearestTick Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
