Date/Time: Sun, 13 Sep 2026 17:10:42 +0000
SC Will not run after install
View Count: 1485
| [2015-04-28 13:32:24] |
| User70859 - Posts: 3 |
Hi, I am trying to run SC on my new computer (Windows 7). The install seems to work fine since all the files are downloaded ( I see the folder in the C-drive) and I see the icons. However, when I hit the SC to run the program does not start no matter how many times I click or restart my computer. I have also downloaded the MSFT redistribution package from the link below as requested in the installation help page. This has not helped.Please help. Thank you. http://www.microsoft.com/en-us/download/details.aspx?id=8328 |
| [2015-04-28 13:34:37] |
I have also disabled my firewall.
| [2015-04-28 14:43:53] |
Not sure if it matters but I am running on 32 bit.
| [2015-04-28 17:02:17] |
The problem might be caused by not having Microsoft .NET on your computer. You can install it from here: http://www.microsoft.com/en-us/download/details.aspx?id=30653 Sierra Chart Support |
