Date/Time: Sun, 04 Oct 2026 14:01:31 +0000
AT customer cannot connect
View Count: 1633
| [2015-04-20 07:01:32] |
| User82032 - Posts: 35 |
My data feed to AT charts was disconnected at 12:54 am 4/20/15. I have logged out and and logged back in but data will not reconnect. Please advise.
| [2015-04-20 07:11:29] |
We have another user reporting this as well. For the fastest resolution to the problem we recommend contacting TransAct support: http://www.transactfutures.com/ContactUs.htm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-20 07:16:53] |
That's great. Transact night support line informed me everything was fine on there end and the problem was with Sierra Charts. They said there was nothing they could do and I would have to resolve this myself with Sierra chart support.
| [2015-04-20 07:20:35] |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-20 07:23:22] |
TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:28:59 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:28:59 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 01:28:59 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 01:28:59 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 01:28:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:28:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:28:59 Socket (27) | Closed. No error. | 2015-04-20 01:28:59 Socket (27) | Shutdown and closed. | 2015-04-20 01:28:59 TransAct Trading | Disconnected from the server. | 2015-04-20 01:29:01 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:29:01 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 01:29:04 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:29:07 Socket (28) | Connected. | 2015-04-20 01:29:07 TransAct Trading | Connected to server. | 2015-04-20 01:29:07 TransAct Trading | Sending logon request message. | 2015-04-20 01:29:07 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 01:30:07 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 01:30:07 TransAct Trading | Connection error: Error. | 2015-04-20 01:30:07 Socket (28) | Shutdown and closed. | 2015-04-20 01:30:07 TransAct Trading | Disconnected from the server. | 2015-04-20 01:30:07 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 01:39:14 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:39:17 Socket (29) | Connected. | 2015-04-20 01:39:17 TransAct Trading | Connected to server. | 2015-04-20 01:39:17 TransAct Trading | Sending logon request message. | 2015-04-20 01:39:17 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:39:49 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:39:49 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 01:39:49 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 01:39:49 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 01:39:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:39:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:39:49 Socket (29) | Shutdown and closed. | 2015-04-20 01:39:50 TransAct Trading | Disconnected from the server. | 2015-04-20 01:39:50 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:39:50 TransAct Trading | Bridge process is still running. | 2015-04-20 01:39:53 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:39:56 Socket (30) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:39:57 Socket (30) | Shutdown and closed. | 2015-04-20 01:39:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:39:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:39:57 TransAct Trading | Disconnected from the server. | 2015-04-20 01:39:58 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:39:58 TransAct Trading | Bridge process is still running. | 2015-04-20 01:40:00 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:40:03 Socket (31) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:40:04 Socket (31) | Shutdown and closed. | 2015-04-20 01:40:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:40:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:40:04 TransAct Trading | Disconnected from the server. | 2015-04-20 01:40:05 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:40:05 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 01:40:08 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:40:11 Socket (32) | Connected. | 2015-04-20 01:40:11 TransAct Trading | Connected to server. | 2015-04-20 01:40:11 TransAct Trading | Sending logon request message. | 2015-04-20 01:40:11 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:40:43 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:40:43 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 01:40:43 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 01:40:43 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 01:40:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:40:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:40:43 Socket (32) | Shutdown and closed. | 2015-04-20 01:40:44 TransAct Trading | Disconnected from the server. | 2015-04-20 01:40:44 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:40:44 TransAct Trading | Bridge process is still running. | 2015-04-20 01:40:47 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:40:50 Socket (33) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:40:51 Socket (33) | Shutdown and closed. | 2015-04-20 01:40:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:40:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:40:51 TransAct Trading | Disconnected from the server. | 2015-04-20 01:40:52 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:40:52 TransAct Trading | Bridge process is still running. | 2015-04-20 01:40:54 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:40:57 Socket (34) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:40:58 Socket (34) | Shutdown and closed. | 2015-04-20 01:40:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:40:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:40:58 TransAct Trading | Disconnected from the server. | 2015-04-20 01:40:59 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:40:59 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 01:41:02 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:41:05 Socket (35) | Connected. | 2015-04-20 01:41:05 TransAct Trading | Connected to server. | 2015-04-20 01:41:05 TransAct Trading | Sending logon request message. | 2015-04-20 01:41:05 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 01:42:05 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 01:42:05 TransAct Trading | Connection error: Error. | 2015-04-20 01:42:05 Socket (35) | Shutdown and closed. | 2015-04-20 01:42:05 TransAct Trading | Disconnected from the server. | 2015-04-20 01:42:05 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 01:55:01 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:55:04 Socket (36) | Connected. | 2015-04-20 01:55:04 TransAct Trading | Connected to server. | 2015-04-20 01:55:04 TransAct Trading | Sending logon request message. | 2015-04-20 01:55:04 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:55:30 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:55:30 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 01:55:30 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 01:55:30 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 01:55:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:55:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:55:30 Socket (36) | Shutdown and closed. | 2015-04-20 01:55:31 TransAct Trading | Disconnected from the server. | 2015-04-20 01:55:31 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:55:31 TransAct Trading | Bridge process is still running. | 2015-04-20 01:55:34 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:55:36 Socket (37) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:55:37 Socket (37) | Shutdown and closed. | 2015-04-20 01:55:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:55:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:55:37 TransAct Trading | Disconnected from the server. | 2015-04-20 01:55:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:55:38 TransAct Trading | Bridge process is still running. | 2015-04-20 01:55:41 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:55:43 Socket (38) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:55:44 Socket (38) | Shutdown and closed. | 2015-04-20 01:55:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:55:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:55:44 TransAct Trading | Disconnected from the server. | 2015-04-20 01:55:45 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:55:45 TransAct Trading | Bridge process is still running. | 2015-04-20 01:55:48 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:55:50 Socket (39) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:55:51 Socket (39) | Shutdown and closed. | 2015-04-20 01:55:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:55:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:55:51 TransAct Trading | Disconnected from the server. | 2015-04-20 01:55:52 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:55:52 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 01:55:55 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:55:58 Socket (40) | Connected. | 2015-04-20 01:55:58 TransAct Trading | Connected to server. | 2015-04-20 01:55:58 TransAct Trading | Sending logon request message. | 2015-04-20 01:55:58 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:56:38 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:56:38 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 01:56:38 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 01:56:38 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 01:56:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:56:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:56:38 Socket (40) | Shutdown and closed. | 2015-04-20 01:56:39 TransAct Trading | Disconnected from the server. | 2015-04-20 01:56:39 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:56:39 TransAct Trading | Bridge process is still running. | 2015-04-20 01:56:41 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:56:44 Socket (41) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:56:45 Socket (41) | Shutdown and closed. | 2015-04-20 01:56:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:56:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:56:45 TransAct Trading | Disconnected from the server. | 2015-04-20 01:56:46 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:56:46 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 01:56:49 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:56:51 Socket (42) | Connected. | 2015-04-20 01:56:51 TransAct Trading | Connected to server. | 2015-04-20 01:56:51 TransAct Trading | Sending logon request message. | 2015-04-20 01:56:51 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:57:17 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:57:17 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 01:57:17 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 01:57:17 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 01:57:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:57:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:57:17 Socket (42) | Shutdown and closed. | 2015-04-20 01:57:18 TransAct Trading | Disconnected from the server. | 2015-04-20 01:57:18 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:57:18 TransAct Trading | Bridge process is still running. | 2015-04-20 01:57:21 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:57:23 Socket (43) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:57:24 Socket (43) | Shutdown and closed. | 2015-04-20 01:57:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:57:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:57:24 TransAct Trading | Disconnected from the server. | 2015-04-20 01:57:25 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:57:25 TransAct Trading | Bridge process is still running. | 2015-04-20 01:57:28 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:57:30 Socket (44) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:57:31 Socket (44) | Shutdown and closed. | 2015-04-20 01:57:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:57:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:57:31 TransAct Trading | Disconnected from the server. | 2015-04-20 01:57:32 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:57:32 TransAct Trading | Bridge process is still running. | 2015-04-20 01:57:35 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:57:38 Socket (45) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:57:39 Socket (45) | Shutdown and closed. | 2015-04-20 01:57:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:57:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:57:39 TransAct Trading | Disconnected from the server. | 2015-04-20 01:57:39 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:57:39 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 01:57:42 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:57:45 Socket (46) | Connected. | 2015-04-20 01:57:45 TransAct Trading | Connected to server. | 2015-04-20 01:57:45 TransAct Trading | Sending logon request message. | 2015-04-20 01:57:45 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 01:58:45 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 01:58:45 TransAct Trading | Connection error: Error. | 2015-04-20 01:58:45 Socket (46) | Shutdown and closed. | 2015-04-20 01:58:45 TransAct Trading | Disconnected from the server. | 2015-04-20 01:58:45 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 01:59:02 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:59:04 Socket (47) | Connected. | 2015-04-20 01:59:04 TransAct Trading | Connected to server. | 2015-04-20 01:59:04 TransAct Trading | Sending logon request message. | 2015-04-20 01:59:04 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:59:32 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 01:59:32 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 01:59:32 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 01:59:32 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 01:59:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:59:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:59:32 Socket (47) | Shutdown and closed. | 2015-04-20 01:59:33 TransAct Trading | Disconnected from the server. | 2015-04-20 01:59:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:59:33 TransAct Trading | Bridge process is still running. | 2015-04-20 01:59:36 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:59:38 Socket (48) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:59:40 Socket (48) | Shutdown and closed. | 2015-04-20 01:59:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:59:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:59:40 TransAct Trading | Disconnected from the server. | 2015-04-20 01:59:40 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:59:40 TransAct Trading | Bridge process is still running. | 2015-04-20 01:59:43 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:59:46 Socket (49) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:59:47 Socket (49) | Shutdown and closed. | 2015-04-20 01:59:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:59:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:59:47 TransAct Trading | Disconnected from the server. | 2015-04-20 01:59:48 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:59:48 TransAct Trading | Bridge process is still running. | 2015-04-20 01:59:50 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 01:59:53 Socket (50) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 01:59:54 Socket (50) | Shutdown and closed. | 2015-04-20 01:59:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 01:59:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 01:59:54 TransAct Trading | Disconnected from the server. | 2015-04-20 01:59:55 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 01:59:55 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 01:59:57 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:00:00 Socket (51) | Connected. | 2015-04-20 02:00:00 TransAct Trading | Connected to server. | 2015-04-20 02:00:00 TransAct Trading | Sending logon request message. | 2015-04-20 02:00:00 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:00:32 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:00:32 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:00:32 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:00:32 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 02:00:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:00:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:00:32 Socket (51) | Shutdown and closed. | 2015-04-20 02:00:32 TransAct Trading | Disconnected from the server. | 2015-04-20 02:00:32 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:00:32 TransAct Trading | Bridge process is still running. | 2015-04-20 02:00:35 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:00:38 Socket (52) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:00:39 Socket (52) | Shutdown and closed. | 2015-04-20 02:00:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:00:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:00:39 TransAct Trading | Disconnected from the server. | 2015-04-20 02:00:40 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:00:40 TransAct Trading | Bridge process is still running. | 2015-04-20 02:00:42 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:00:45 Socket (53) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:00:46 Socket (53) | Shutdown and closed. | 2015-04-20 02:00:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:00:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:00:46 TransAct Trading | Disconnected from the server. | 2015-04-20 02:00:47 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:00:47 TransAct Trading | Bridge process is still running. | 2015-04-20 02:00:49 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:00:52 Socket (54) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:00:53 Socket (54) | Shutdown and closed. | 2015-04-20 02:00:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:00:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:00:53 TransAct Trading | Disconnected from the server. | 2015-04-20 02:00:54 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:00:54 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:00:57 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:00:59 Socket (55) | Connected. | 2015-04-20 02:00:59 TransAct Trading | Connected to server. | 2015-04-20 02:00:59 TransAct Trading | Sending logon request message. | 2015-04-20 02:00:59 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:01:25 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:01:25 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:01:25 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:01:25 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 02:01:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:01:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:01:25 Socket (55) | Shutdown and closed. | 2015-04-20 02:01:26 TransAct Trading | Disconnected from the server. | 2015-04-20 02:01:26 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:01:26 TransAct Trading | Bridge process is still running. | 2015-04-20 02:01:29 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:01:31 Socket (56) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:01:32 Socket (56) | Shutdown and closed. | 2015-04-20 02:01:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:01:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:01:32 TransAct Trading | Disconnected from the server. | 2015-04-20 02:01:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:01:33 TransAct Trading | Bridge process is still running. | 2015-04-20 02:01:36 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:01:39 Socket (57) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:01:40 Socket (57) | Shutdown and closed. | 2015-04-20 02:01:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:01:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:01:40 TransAct Trading | Disconnected from the server. | 2015-04-20 02:01:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:01:41 TransAct Trading | Bridge process is still running. | 2015-04-20 02:01:43 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:01:46 Socket (58) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:01:47 Socket (58) | Shutdown and closed. | 2015-04-20 02:01:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:01:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:01:47 TransAct Trading | Disconnected from the server. | 2015-04-20 02:01:48 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:01:48 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:01:55 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:01:58 Socket (59) | Connected. | 2015-04-20 02:01:58 TransAct Trading | Connected to server. | 2015-04-20 02:01:58 TransAct Trading | Sending logon request message. | 2015-04-20 02:01:58 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:02:23 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:02:23 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:02:23 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:02:23 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 02:02:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:02:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:02:23 Socket (59) | Shutdown and closed. | 2015-04-20 02:02:24 TransAct Trading | Disconnected from the server. | 2015-04-20 02:02:24 Will reconnect to the server in 35.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:02:24 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:03:00 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:03:03 Socket (60) | Connected. | 2015-04-20 02:03:03 TransAct Trading | Connected to server. | 2015-04-20 02:03:03 TransAct Trading | Sending logon request message. | 2015-04-20 02:03:03 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:04:03 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:04:03 TransAct Trading | Connection error: Error. | 2015-04-20 02:04:03 Socket (60) | Shutdown and closed. | 2015-04-20 02:04:03 TransAct Trading | Disconnected from the server. | 2015-04-20 02:04:03 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:04:25 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:04:28 Socket (61) | Connected. | 2015-04-20 02:04:28 TransAct Trading | Connected to server. | 2015-04-20 02:04:28 TransAct Trading | Sending logon request message. | 2015-04-20 02:04:28 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:04:57 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:04:57 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:04:57 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:04:57 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 02:04:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:04:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:04:57 Socket (61) | Shutdown and closed. | 2015-04-20 02:04:58 TransAct Trading | Disconnected from the server. | 2015-04-20 02:04:58 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:04:58 TransAct Trading | Bridge process is still running. | 2015-04-20 02:05:01 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:05:04 Socket (62) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:05:05 Socket (62) | Shutdown and closed. | 2015-04-20 02:05:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:05:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:05:05 TransAct Trading | Disconnected from the server. | 2015-04-20 02:05:05 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:05:05 TransAct Trading | Bridge process is still running. | 2015-04-20 02:05:08 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:05:11 Socket (63) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:05:12 Socket (63) | Shutdown and closed. | 2015-04-20 02:05:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:05:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:05:12 TransAct Trading | Disconnected from the server. | 2015-04-20 02:05:13 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:05:13 TransAct Trading | Bridge process is still running. | 2015-04-20 02:05:16 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:05:19 Socket (64) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:05:20 Socket (64) | Shutdown and closed. | 2015-04-20 02:05:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:05:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:05:20 TransAct Trading | Disconnected from the server. | 2015-04-20 02:05:20 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:05:20 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:05:23 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:05:26 Socket (65) | Connected. | 2015-04-20 02:05:26 TransAct Trading | Connected to server. | 2015-04-20 02:05:26 TransAct Trading | Sending logon request message. | 2015-04-20 02:05:26 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:05:55 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:05:55 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:05:55 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:05:55 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 02:05:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:05:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:05:55 Socket (65) | Shutdown and closed. | 2015-04-20 02:05:56 TransAct Trading | Disconnected from the server. | 2015-04-20 02:05:56 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:05:56 TransAct Trading | Bridge process is still running. | 2015-04-20 02:05:59 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:06:02 Socket (66) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:06:03 Socket (66) | Shutdown and closed. | 2015-04-20 02:06:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:06:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:06:03 TransAct Trading | Disconnected from the server. | 2015-04-20 02:06:04 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:06:04 TransAct Trading | Bridge process is still running. | 2015-04-20 02:06:07 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:06:09 Socket (67) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:06:10 Socket (67) | Shutdown and closed. | 2015-04-20 02:06:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:06:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:06:10 TransAct Trading | Disconnected from the server. | 2015-04-20 02:06:11 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:06:11 TransAct Trading | Bridge process is still running. | 2015-04-20 02:06:14 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:06:17 Socket (68) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:06:18 Socket (68) | Shutdown and closed. | 2015-04-20 02:06:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:06:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:06:18 TransAct Trading | Disconnected from the server. | 2015-04-20 02:06:19 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:06:19 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:06:21 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:06:24 Socket (69) | Connected. | 2015-04-20 02:06:24 TransAct Trading | Connected to server. | 2015-04-20 02:06:24 TransAct Trading | Sending logon request message. | 2015-04-20 02:06:24 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:07:01 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:07:01 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:07:01 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:07:01 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 02:07:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:07:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:07:01 Socket (69) | Shutdown and closed. | 2015-04-20 02:07:02 TransAct Trading | Disconnected from the server. | 2015-04-20 02:07:02 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:07:02 TransAct Trading | Bridge process is still running. | 2015-04-20 02:07:05 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:07:08 Socket (70) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:07:09 Socket (70) | Shutdown and closed. | 2015-04-20 02:07:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:07:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:07:09 TransAct Trading | Disconnected from the server. | 2015-04-20 02:07:10 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:07:10 TransAct Trading | Bridge process is still running. | 2015-04-20 02:07:13 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:07:15 Socket (71) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:07:16 Socket (71) | Shutdown and closed. | 2015-04-20 02:07:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:07:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:07:16 TransAct Trading | Disconnected from the server. | 2015-04-20 02:07:17 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:07:17 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:07:20 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:07:23 Socket (72) | Connected. | 2015-04-20 02:07:23 TransAct Trading | Connected to server. | 2015-04-20 02:07:23 TransAct Trading | Sending logon request message. | 2015-04-20 02:07:23 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:07:50 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:07:50 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:07:50 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:07:50 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 02:07:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:07:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:07:50 Socket (72) | Shutdown and closed. | 2015-04-20 02:07:51 TransAct Trading | Disconnected from the server. | 2015-04-20 02:07:51 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:07:51 TransAct Trading | Bridge process is still running. | 2015-04-20 02:07:53 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:07:56 Socket (73) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:07:57 Socket (73) | Shutdown and closed. | 2015-04-20 02:07:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:07:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:07:57 TransAct Trading | Disconnected from the server. | 2015-04-20 02:07:58 Will reconnect to the server in 35.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:07:58 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:08:34 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:08:37 Socket (74) | Connected. | 2015-04-20 02:08:37 TransAct Trading | Connected to server. | 2015-04-20 02:08:37 TransAct Trading | Sending logon request message. | 2015-04-20 02:08:37 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:09:37 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:09:37 TransAct Trading | Connection error: Error. | 2015-04-20 02:09:37 Socket (74) | Shutdown and closed. | 2015-04-20 02:09:37 TransAct Trading | Disconnected from the server. | 2015-04-20 02:09:37 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:19:34 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:19:37 Socket (75) | Connected. | 2015-04-20 02:19:37 TransAct Trading | Connected to server. | 2015-04-20 02:19:37 TransAct Trading | Sending logon request message. | 2015-04-20 02:19:37 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:20:11 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:20:11 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:20:11 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:20:11 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 02:20:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:20:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:20:11 Socket (75) | Shutdown and closed. | 2015-04-20 02:20:11 TransAct Trading | Disconnected from the server. | 2015-04-20 02:20:11 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:20:11 TransAct Trading | Bridge process is still running. | 2015-04-20 02:20:14 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:20:17 Socket (76) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:20:18 Socket (76) | Shutdown and closed. | 2015-04-20 02:20:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:20:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:20:18 TransAct Trading | Disconnected from the server. | 2015-04-20 02:20:19 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:20:19 TransAct Trading | Bridge process is still running. | 2015-04-20 02:20:21 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:20:24 Socket (77) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:20:25 Socket (77) | Shutdown and closed. | 2015-04-20 02:20:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:20:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:20:25 TransAct Trading | Disconnected from the server. | 2015-04-20 02:20:26 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:20:26 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:20:29 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:20:32 Socket (78) | Connected. | 2015-04-20 02:20:32 TransAct Trading | Connected to server. | 2015-04-20 02:20:32 TransAct Trading | Sending logon request message. | 2015-04-20 02:20:32 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:20:58 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:20:58 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:20:58 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:20:58 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 02:20:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:20:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:20:58 Socket (78) | Shutdown and closed. | 2015-04-20 02:20:59 TransAct Trading | Disconnected from the server. | 2015-04-20 02:20:59 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:20:59 TransAct Trading | Bridge process is still running. | 2015-04-20 02:21:02 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:21:04 Socket (79) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:21:05 Socket (79) | Shutdown and closed. | 2015-04-20 02:21:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:21:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:21:05 TransAct Trading | Disconnected from the server. | 2015-04-20 02:21:06 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:21:06 TransAct Trading | Bridge process is still running. | 2015-04-20 02:21:09 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:21:12 Socket (80) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:21:13 Socket (80) | Shutdown and closed. | 2015-04-20 02:21:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:21:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:21:13 TransAct Trading | Disconnected from the server. | 2015-04-20 02:21:14 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:21:14 TransAct Trading | Bridge process is still running. | 2015-04-20 02:21:17 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:21:20 Socket (81) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-20 02:21:21 Socket (81) | Shutdown and closed. | 2015-04-20 02:21:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-20 02:21:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-20 02:21:21 TransAct Trading | Disconnected from the server. | 2015-04-20 02:21:22 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-20 02:21:22 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2015-04-20 02:21:25 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2015-04-20 02:21:28 Socket (82) | Connected. | 2015-04-20 02:21:28 TransAct Trading | Connected to server. | 2015-04-20 02:21:28 TransAct Trading | Sending logon request message. | 2015-04-20 02:21:28 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:22:28 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:22:28 TransAct Trading | Connection error: Error. | 2015-04-20 02:22:28 Socket (82) | Shutdown and closed. | 2015-04-20 02:22:28 TransAct Trading | Disconnected from the server. | 2015-04-20 02:22:28 |
| [2015-04-20 07:23:38] |
You are having the same problem as the other user. This was our response to other user who posted the same problem: CANNOT CONNECT | Post: 57354 Reference: TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:20:58 TransAct Trading | Market data feed reported to be lost. | 2015-04-20 02:20:58 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2015-04-20 02:20:58 TransAct Trading | Server protocol version: 4. Client protocol version: 5. There is a protocol mismatch! | 2015-04-20 02:20:58 TransAct Trading | Logon error from server : Communications Error | 2015-04-20 02:20:58 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-20 07:24:42
