Date/Time: Sun, 22 Dec 2024 03:17:42 +0000
TAL not reporting properly
View Count: 1048
[2015-04-02 17:12:32] |
User77721 - Posts: 8 |
I have noticed that after March 20.2015 that the TAL-NON simulated account has not been reporting the information to the right side of the Cum P/L at all. However it does work correctly on the Simulated account fine. Can you suggest any resolutions..?
[2015-04-02 17:46:22] |
We do not know specifically what you are referring to since the columns are adjustable. You may want to clear out the Trade Activity Log when your position is flat: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ClearingtheLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-02 17:46:51
[2015-04-02 17:48:15] |
here is a picture of the issue at hand
TAL Report.JPG / V - Attached On 2015-04-02 17:47:38 UTC - Size: 156.64 KB - 377 views |
[2015-04-02 18:15:44] |
We need to see a complete image of the Trade Activity Log. You can privately attach it.
[2015-04-02 20:18:28] |
Here are the screen shots of the TAL in both modes..
Private File Private File |
[2015-04-06 17:19:24] |
We do not have sufficient information because these do not show all of the Trade Activity Log window.
[2015-04-06 17:25:40] |
I have supplied screens shots of this problem... Please define what you need. Those are actual pictures of my TAL short of not having the headers...If that is what you are after..???
[2015-04-06 17:30:19] |
Here is another picture of the TAL including headings
Private File |
[2015-04-06 18:02:59] |
In this section here: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#TradesTabFieldsDescriptions Refer to this subsection: Notes about Runup, Drawdown, Maximum Open Position Profit/Loss, Entry Efficiency, Exit Efficiency, Total Efficiency Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-06 18:27:54] |
Your suggestion to read "Note about Runup, Drawdown, Maximum Open Position Profit/Loss, Highest/Lowest Price During Positions fields: For these values to be accurate and contain nonzero values, it is necessary that Sierra Chart is running and connected to the data feed during the entire life of the Non-Simulated (Live) Trade Positions that these fields are for". MY COMMENTS: This trade was taken in REAL TIME and with real money and connected until the trade was complete, therefore this little bit of a definition does not apply here.. Sierra charts support has to do better than this to help resolve this issue. looking forward to your response..... |
[2015-04-06 18:54:13] |
We did do better than this. We reviewed that documentation and updated it today. There is more information in that section. What are the values for Highest/Lowest Price During Positions on the Trade Statistics tab? And are you using the Order Fill Calculated Position? Specifically the global setting. The section we referred you to does contain a link to the documentation for that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-06 18:54:43
[2015-04-06 19:52:01] |
Thank you now I have some detail as to what to look for. No I am not using the Order Fill Calculated Position-global and as for the values for Highest/Lowest Price During Positions here is just "zero's" no information.. |
[2015-04-06 20:03:10] |
OK this is the problem. We have done a test, and the recording of the high and low values during a position is functioning correctly. So not totally sure about the cause of the problem at the moment. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-06 20:03:28
[2015-04-06 20:05:38] |
Thank you it seems fine in the simulated environment BUT fails in the NON simulated. When you have a resolution let me know. Your time is appreciated..
