Date/Time: Mon, 05 Oct 2026 05:28:23 +0000
differences in the data
View Count: 1086
| [2015-03-31 21:27:07] |
| User66292 - Posts: 12 |
hi I have a variety of data, (1 tick data in DTS) using only historical data and real data from Rithmic in conjunction with historical data, why? and how to get an exact match historical data with real data? |
| [2015-04-01 00:09:29] |
Since you are using Price Changes Per Bar, this requires tick by tick data. You are using Rithmic. Therefore, you need to be on Sierra Chart service package 5 to get historical tick by tick data. Follow the instructions here for a tick by tick data configuration: Tick by Tick Data Configuration And change the service package to 5: https://www.sierrachart.com/usercp.php?page=ChangePackage You need to restart Sierra Chart after changing the service package. After this is done re-download the data in the chart with Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
