Date/Time: Mon, 30 Dec 2024 17:56:58 +0000
[Locked] - Error connecting to rithmic data service
View Count: 1305
[2015-03-27 12:18:58] |
S.O. - Posts: 25 |
I've sent an error log report as it instructed int he message log. also pasted here... Software version: 1224 | 2015-03-27 07:51:10 Uses New Spreadsheets | 2015-03-27 07:51:10 Usage end date: 2015-04-23 | 2015-03-27 07:51:10 Enabled for: Advanced Features. | 2015-03-27 07:51:10 Enabled for: Advanced Features 2. | 2015-03-27 07:51:10 Enabled for: Sierra Chart Historical Data Service. | 2015-03-27 07:51:10 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-03-27 07:51:10 Active service: Rithmic Trading | 2015-03-27 07:51:10 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-03-27 07:51:10 2015-03-27 07:51:10 Local computer clock time | 2015-03-27 07:51:10 2015-03-27 11:51:10 GMT time | 2015-03-27 07:51:10 2015-03-27 07:51:10 Time zone adjusted time | 2015-03-27 07:51:10 Time difference to server time: 1 seconds. | 2015-03-27 07:51:10 Program path: C:\SierraChart\ | 2015-03-27 07:51:10 Data Files path: C:\SierraChart\Data\ | 2015-03-27 07:51:10 OS Version Number: 6.2 | 2015-03-27 07:51:10 Locale Information: C | 2015-03-27 07:51:10 Checking for new symbol settings for rim | 2015-03-27 07:51:10 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-03-27 07:51:10 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-03-27 07:51:10 Symbol settings are up-to-date for rim | 2015-03-27 07:51:10 Rithmic Trading | Port for executable: 50311 | 2015-03-27 07:51:15 Listening socket (1748), port 50311 | Closed. | 2015-03-27 07:51:15 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 07:51:15 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-03-27 07:51:15 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-03-27 07:51:15 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50311 | 2015-03-27 07:51:17 Socket (2) | Connected. | 2015-03-27 07:51:17 Rithmic Trading | Connected to server. | 2015-03-27 07:51:17 Rithmic Trading | Sending logon request message. | 2015-03-27 07:51:17 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 07:51:17 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 07:51:17 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 07:51:17 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 07:51:38 Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-03-27 07:51:39 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-03-27 07:51:39 Rithmic Trading | Server Alert: PnL Connection Opened | 2015-03-27 07:51:39 Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-03-27 07:51:39 Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-03-27 07:51:39 Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-03-27 07:51:39 Connection timed out. Will disconnect and retry. | 2015-03-27 07:53:15 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:53:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:53:15 Socket (2) | Shutdown and closed. | 2015-03-27 07:53:15 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:53:15 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:53:15 Rithmic Trading | Port for executable: 50376 | 2015-03-27 07:53:17 Listening socket (960), port 50376 | Closed. | 2015-03-27 07:53:17 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 07:53:17 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50376 | 2015-03-27 07:53:19 Socket (3) | Connected. | 2015-03-27 07:53:19 Rithmic Trading | Connected to server. | 2015-03-27 07:53:19 Rithmic Trading | Sending logon request message. | 2015-03-27 07:53:19 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 07:53:19 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 07:53:19 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 07:53:19 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 07:53:41 Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-03-27 07:53:41 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-03-27 07:53:41 Rithmic Trading | Server Alert: PnL Connection Broken | 2015-03-27 07:54:03 Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-03-27 07:54:03 Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-03-27 07:54:03 Connection timed out. Will disconnect and retry. | 2015-03-27 07:55:17 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:55:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:55:17 Socket (3) | Shutdown and closed. | 2015-03-27 07:55:17 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:55:17 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:55:17 Rithmic Trading | Port for executable: 50516 | 2015-03-27 07:55:19 Listening socket (924), port 50516 | Closed. | 2015-03-27 07:55:19 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 07:55:19 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50516 | 2015-03-27 07:55:21 Socket (4) | Connected. | 2015-03-27 07:55:21 Rithmic Trading | Connected to server. | 2015-03-27 07:55:21 Rithmic Trading | Sending logon request message. | 2015-03-27 07:55:21 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 07:55:21 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 07:55:21 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 07:55:21 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 07:55:43 Rithmic Trading | Server Alert: Trading System Connection Broken | 2015-03-27 07:56:04 Rithmic Trading | Server Name: DTC Bridge. | 2015-03-27 07:56:04 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-03-27 07:56:04 Rithmic Trading | Logon error from server | 2015-03-27 07:56:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:56:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:56:04 Socket (4) | Shutdown and closed. | 2015-03-27 07:56:04 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:56:04 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:56:04 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:56:06 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50516 | 2015-03-27 07:56:08 Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:56:09 Socket (5) | Shutdown and closed. | 2015-03-27 07:56:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:56:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:56:09 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:56:09 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:56:09 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:56:11 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50516 | 2015-03-27 07:56:13 Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:56:14 Socket (6) | Shutdown and closed. | 2015-03-27 07:56:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:56:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:56:14 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:56:14 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:56:14 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:56:16 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50516 | 2015-03-27 07:56:18 Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:56:19 Socket (7) | Shutdown and closed. | 2015-03-27 07:56:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:56:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:56:19 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:56:19 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:56:19 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:56:21 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50516 | 2015-03-27 07:56:23 Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:56:24 Socket (8) | Shutdown and closed. | 2015-03-27 07:56:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:56:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:56:24 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:56:24 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:56:24 Rithmic Trading | Port for executable: 50575 | 2015-03-27 07:56:26 Listening socket (1100), port 50575 | Closed. | 2015-03-27 07:56:26 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 07:56:26 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50575 | 2015-03-27 07:56:28 Socket (9) | Connected. | 2015-03-27 07:56:28 Rithmic Trading | Connected to server. | 2015-03-27 07:56:28 Rithmic Trading | Sending logon request message. | 2015-03-27 07:56:28 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 07:56:28 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 07:56:28 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 07:56:28 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 07:56:50 Rithmic Trading | Server Alert: Trading System Connection Broken | 2015-03-27 07:57:11 Rithmic Trading | Server Name: DTC Bridge. | 2015-03-27 07:57:11 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-03-27 07:57:11 Rithmic Trading | Logon error from server | 2015-03-27 07:57:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:57:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:57:11 Socket (9) | Shutdown and closed. | 2015-03-27 07:57:11 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:57:11 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:57:11 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:57:13 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50575 | 2015-03-27 07:57:15 Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:57:16 Socket (10) | Shutdown and closed. | 2015-03-27 07:57:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:57:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:57:16 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:57:16 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:57:16 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:57:18 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50575 | 2015-03-27 07:57:20 Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:57:21 Socket (11) | Shutdown and closed. | 2015-03-27 07:57:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:57:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:57:21 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:57:21 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:57:21 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:57:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50575 | 2015-03-27 07:57:25 Socket (12) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:57:26 Socket (12) | Shutdown and closed. | 2015-03-27 07:57:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:57:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:57:26 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:57:26 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:57:26 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:57:28 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50575 | 2015-03-27 07:57:30 Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:57:31 Socket (13) | Shutdown and closed. | 2015-03-27 07:57:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:57:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:57:31 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:57:31 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:57:31 Rithmic Trading | Port for executable: 50605 | 2015-03-27 07:57:33 Listening socket (1100), port 50605 | Closed. | 2015-03-27 07:57:33 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 07:57:33 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50605 | 2015-03-27 07:57:35 Socket (14) | Connected. | 2015-03-27 07:57:35 Rithmic Trading | Connected to server. | 2015-03-27 07:57:35 Rithmic Trading | Sending logon request message. | 2015-03-27 07:57:35 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 07:57:35 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 07:57:35 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 07:57:35 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 07:57:57 Rithmic Trading | Server Alert: Trading System Connection Broken | 2015-03-27 07:58:18 Rithmic Trading | Server Name: DTC Bridge. | 2015-03-27 07:58:18 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-03-27 07:58:18 Rithmic Trading | Logon error from server | 2015-03-27 07:58:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:58:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:58:18 Socket (14) | Shutdown and closed. | 2015-03-27 07:58:18 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:58:18 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:58:18 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:58:20 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50605 | 2015-03-27 07:58:22 Socket (15) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:58:23 Socket (15) | Shutdown and closed. | 2015-03-27 07:58:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:58:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:58:23 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:58:23 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:58:23 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:58:25 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50605 | 2015-03-27 07:58:27 Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:58:28 Socket (16) | Shutdown and closed. | 2015-03-27 07:58:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:58:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:58:28 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:58:28 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:58:28 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:58:30 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50605 | 2015-03-27 07:58:32 Socket (17) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:58:33 Socket (17) | Shutdown and closed. | 2015-03-27 07:58:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:58:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:58:33 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:58:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:58:33 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:58:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50605 | 2015-03-27 07:58:37 Socket (18) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:58:38 Socket (18) | Shutdown and closed. | 2015-03-27 07:58:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:58:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:58:38 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:58:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:58:38 Rithmic Trading | Port for executable: 50638 | 2015-03-27 07:58:40 Listening socket (1688), port 50638 | Closed. | 2015-03-27 07:58:40 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 07:58:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50638 | 2015-03-27 07:58:42 Socket (19) | Connected. | 2015-03-27 07:58:42 Rithmic Trading | Connected to server. | 2015-03-27 07:58:42 Rithmic Trading | Sending logon request message. | 2015-03-27 07:58:42 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 07:58:42 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 07:58:42 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 07:58:42 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 07:59:03 Rithmic Trading | Server Alert: Trading System Connection Broken | 2015-03-27 07:59:25 Rithmic Trading | Server Name: DTC Bridge. | 2015-03-27 07:59:25 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-03-27 07:59:25 Rithmic Trading | Logon error from server | 2015-03-27 07:59:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:59:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:59:25 Socket (19) | Shutdown and closed. | 2015-03-27 07:59:25 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:59:25 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:59:25 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:59:27 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50638 | 2015-03-27 07:59:29 Socket (20) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:59:30 Socket (20) | Shutdown and closed. | 2015-03-27 07:59:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:59:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:59:30 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:59:30 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:59:30 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:59:32 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50638 | 2015-03-27 07:59:34 Socket (21) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:59:35 Socket (21) | Shutdown and closed. | 2015-03-27 07:59:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:59:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:59:35 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:59:35 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:59:35 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:59:37 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50638 | 2015-03-27 07:59:39 Socket (22) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:59:40 Socket (22) | Shutdown and closed. | 2015-03-27 07:59:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:59:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:59:40 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:59:40 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:59:40 Rithmic Trading | Bridge process is still running. | 2015-03-27 07:59:42 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50638 | 2015-03-27 07:59:44 Socket (23) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 07:59:45 Socket (23) | Shutdown and closed. | 2015-03-27 07:59:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 07:59:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 07:59:45 Rithmic Trading | Disconnected from the server. | 2015-03-27 07:59:45 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 07:59:45 Rithmic Trading | Port for executable: 50664 | 2015-03-27 07:59:47 Listening socket (772), port 50664 | Closed. | 2015-03-27 07:59:47 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 07:59:47 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50664 | 2015-03-27 07:59:49 Socket (24) | Connected. | 2015-03-27 07:59:49 Rithmic Trading | Connected to server. | 2015-03-27 07:59:49 Rithmic Trading | Sending logon request message. | 2015-03-27 07:59:49 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 07:59:49 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 07:59:49 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 07:59:49 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 08:00:10 Rithmic Trading | Server Alert: Trading System Connection Broken | 2015-03-27 08:00:31 Rithmic Trading | Server Name: DTC Bridge. | 2015-03-27 08:00:31 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-03-27 08:00:31 Rithmic Trading | Logon error from server | 2015-03-27 08:00:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:00:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:00:31 Socket (24) | Shutdown and closed. | 2015-03-27 08:00:31 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:00:31 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:00:31 Rithmic Trading | Bridge process is still running. | 2015-03-27 08:00:33 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50664 | 2015-03-27 08:00:35 Socket (25) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 08:00:36 Socket (25) | Shutdown and closed. | 2015-03-27 08:00:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:00:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:00:36 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:00:36 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:00:36 Rithmic Trading | Bridge process is still running. | 2015-03-27 08:00:38 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50664 | 2015-03-27 08:00:40 Socket (26) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 08:00:41 Socket (26) | Shutdown and closed. | 2015-03-27 08:00:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:00:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:00:41 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:00:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:00:41 Rithmic Trading | Bridge process is still running. | 2015-03-27 08:00:43 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50664 | 2015-03-27 08:00:45 Socket (27) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 08:00:46 Socket (27) | Shutdown and closed. | 2015-03-27 08:00:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:00:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:00:46 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:00:46 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:00:46 Rithmic Trading | Bridge process is still running. | 2015-03-27 08:00:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50664 | 2015-03-27 08:00:50 Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 08:00:51 Socket (28) | Shutdown and closed. | 2015-03-27 08:00:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:00:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:00:51 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:00:51 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:00:51 Rithmic Trading | Port for executable: 50710 | 2015-03-27 08:00:53 Listening socket (1100), port 50710 | Closed. | 2015-03-27 08:00:53 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 08:00:53 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50710 | 2015-03-27 08:00:55 Socket (29) | Connected. | 2015-03-27 08:00:55 Rithmic Trading | Connected to server. | 2015-03-27 08:00:55 Rithmic Trading | Sending logon request message. | 2015-03-27 08:00:55 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 08:00:55 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 08:00:55 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 08:00:55 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 08:01:17 Rithmic Trading | Server Alert: Trading System Connection Broken | 2015-03-27 08:01:38 Rithmic Trading | Server Name: DTC Bridge. | 2015-03-27 08:01:38 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-03-27 08:01:38 Rithmic Trading | Logon error from server | 2015-03-27 08:01:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:01:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:01:38 Socket (29) | Shutdown and closed. | 2015-03-27 08:01:38 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:01:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:01:38 Rithmic Trading | Bridge process is still running. | 2015-03-27 08:01:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50710 | 2015-03-27 08:01:42 Socket (30) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 08:01:43 Socket (30) | Shutdown and closed. | 2015-03-27 08:01:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:01:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:01:43 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:01:43 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:01:43 Rithmic Trading | Bridge process is still running. | 2015-03-27 08:01:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50710 | 2015-03-27 08:01:47 Socket (31) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-03-27 08:01:48 Socket (31) | Shutdown and closed. | 2015-03-27 08:01:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:01:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:01:48 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:01:48 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:01:48 Rithmic Trading | Port for executable: 50795 | 2015-03-27 08:04:48 Listening socket (904), port 50795 | Closed. | 2015-03-27 08:04:48 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 08:04:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50795 | 2015-03-27 08:04:50 Socket (32) | Connected. | 2015-03-27 08:04:50 Rithmic Trading | Connected to server. | 2015-03-27 08:04:50 Rithmic Trading | Sending logon request message. | 2015-03-27 08:04:50 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 08:04:50 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 08:04:50 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 08:04:50 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 08:05:12 Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-03-27 08:05:12 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-03-27 08:05:12 Rithmic Trading | Server Alert: PnL Connection Broken | 2015-03-27 08:05:33 Rithmic Trading | Server Alert: Intraday History Connection Broken | 2015-03-27 08:05:55 Rithmic Trading | Server Alert: PnL Connection Opened | 2015-03-27 08:05:59 Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-03-27 08:05:59 Connection timed out. Will disconnect and retry. | 2015-03-27 08:06:48 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:06:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:06:48 Socket (32) | Shutdown and closed. | 2015-03-27 08:06:48 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:06:48 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:06:48 Rithmic Trading | Port for executable: 50859 | 2015-03-27 08:09:48 Listening socket (1984), port 50859 | Closed. | 2015-03-27 08:09:48 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 08:09:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50859 | 2015-03-27 08:09:50 Socket (33) | Connected. | 2015-03-27 08:09:50 Rithmic Trading | Connected to server. | 2015-03-27 08:09:50 Rithmic Trading | Sending logon request message. | 2015-03-27 08:09:50 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 08:09:50 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 08:09:50 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 08:09:50 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 08:10:12 Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-03-27 08:10:12 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-03-27 08:10:12 Rithmic Trading | Server Alert: PnL Connection Broken | 2015-03-27 08:10:33 Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-03-27 08:10:34 Rithmic Trading | Server Alert: PnL Connection Opened | 2015-03-27 08:10:34 Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-03-27 08:10:34 Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-03-27 08:10:34 Connection timed out. Will disconnect and retry. | 2015-03-27 08:11:48 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:11:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:11:48 Socket (33) | Shutdown and closed. | 2015-03-27 08:11:48 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:11:48 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:11:48 Rithmic Trading | Port for executable: 50908 | 2015-03-27 08:14:48 Listening socket (1944), port 50908 | Closed. | 2015-03-27 08:14:48 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 08:14:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50908 | 2015-03-27 08:14:50 Socket (34) | Connected. | 2015-03-27 08:14:50 Rithmic Trading | Connected to server. | 2015-03-27 08:14:50 Rithmic Trading | Sending logon request message. | 2015-03-27 08:14:50 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 08:14:50 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 08:14:50 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 08:14:50 Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 08:15:12 Rithmic Trading | Server Alert: Trading System Connection Broken | 2015-03-27 08:15:33 Rithmic Trading | Server Name: DTC Bridge. | 2015-03-27 08:15:33 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-03-27 08:15:33 Rithmic Trading | Logon error from server | 2015-03-27 08:15:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-27 08:15:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-27 08:15:33 Socket (34) | Shutdown and closed. | 2015-03-27 08:15:33 Rithmic Trading | Disconnected from the server. | 2015-03-27 08:15:33 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-27 08:15:33 The above has been sent to support. | 2015-03-27 08:17:40 * Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2015-03-27 08:17:43 Rithmic Trading | Port for executable: 50962 | 2015-03-27 08:18:33 Listening socket (2060), port 50962 | Closed. | 2015-03-27 08:18:33 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-03-27 08:18:33 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50962 | 2015-03-27 08:18:35 Socket (35) | Connected. | 2015-03-27 08:18:35 Rithmic Trading | Connected to server. | 2015-03-27 08:18:35 Rithmic Trading | Sending logon request message. | 2015-03-27 08:18:35 Rithmic Trading | Starting the connection process to data and trading service. | 2015-03-27 08:18:35 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-03-27 08:18:35 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-03-27 08:18:35 |
[2015-03-27 16:48:58] |
These are the relevant error messages: Rithmic Trading | Server Alert: Market Data Connection Broken | 2015-03-27 08:15:12 Rithmic Trading | Server Alert: Trading System Connection Broken | 2015-03-27 08:15:33 Not sure if it would make a difference but update Sierra Chart to the latest version. Here are the instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate If you still have a problem, our best guess is that this is due to possibly a firewall. It is hard to say because the connection is made through the Rithmic software which we do not develop or control. Refer to help topic 1.2: https://www.sierrachart.com/index.php?page=doc/helpdetails1.html#h1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-08 05:40:28] |
inverter - Posts: 42 |
I have the latest version of sierra 1243, but I have the same problem rithmic, often lost connection. I have no antivirus, and firewall is switched off,, what is the problem? thank you a lot of the graph is open and a lot of log data .. sorry but this Software version: 1243 | 2015-04-07 23:14:00 Uses New Spreadsheets | 2015-04-07 23:14:00 Enabled for: Advanced Features. | 2015-04-07 23:14:00 Enabled for: Sierra Chart Historical Data Service. | 2015-04-07 23:14:00 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-04-07 23:14:00 Active service: Rithmic Trading | 2015-04-07 23:14:00 Data/Trade Service Settings automatically set. | 2015-04-07 23:14:00 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2015-04-07 23:14:00 2015-04-07 23:14:00 Local computer clock time | 2015-04-07 23:14:00 2015-04-07 21:14:00 GMT time | 2015-04-07 23:14:00 2015-04-07 23:14:00 Time zone adjusted time | 2015-04-07 23:14:00 Time difference to server time: 0 seconds. | 2015-04-07 23:14:00 Program path: C:\SierraChart\ | 2015-04-07 23:14:00 Data Files path: C:\SierraChart\Data\ | 2015-04-07 23:14:00 OS Version Number: 6.1 | 2015-04-07 23:14:00 Locale Information: C | 2015-04-07 23:14:00 Checking for new symbol settings for rim | 2015-04-07 23:14:00 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-04-07 23:14:00 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-04-07 23:14:00 Symbol settings are up-to-date for rim | 2015-04-07 23:14:00 Files to Open on Start up | Opening file: RITMIC LIVE.cht | 2015-04-07 23:14:03 Date rule based rollover from NQH5-CME to next contract occurs at 2015-03-12. | 2015-04-07 23:14:03 Date rule based rollover from NQM5-CME to next contract occurs at 2015-06-11. | 2015-04-07 23:14:03 Checking Intraday data file for symbol NQH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:03 Checking Daily data file for symbol NQH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:03 Checking Intraday data file for symbol NQM5-CME for the date range from 2015-03-12 to 0. | 2015-04-07 23:14:03 Checking Daily data file for symbol NQM5-CME for the date range from 2015-03-12 to 2015-04-07. | 2015-04-07 23:14:03 NQM5-CME [CV] Renko 6-3-1 #7 | Symbols used for continuous contract chart: | 2015-04-07 23:14:03 NQH5-CME | 2015-04-07 23:14:03 NQM5-CME | 2015-04-07 23:14:03 NQM5-CME [CV] Renko 6-3-1 #7: Checking for volume based rollover dates. | 2015-04-07 23:14:03 NQM5-CME [CV] Renko 6-3-1 #7: Volume based rollover from NQH5-CME to NQM5-CME occurs at 2015-03-13 | 2015-04-07 23:14:03 Date rule based rollover from GCZ4-COMEX to next contract occurs at 2014-11-27. | 2015-04-07 23:14:03 Date rule based rollover from GCG5-COMEX to next contract occurs at 2015-01-29. | 2015-04-07 23:14:03 Date rule based rollover from GCJ5-COMEX to next contract occurs at 2015-03-30. | 2015-04-07 23:14:03 Date rule based rollover from GCM5-COMEX to next contract occurs at 2015-05-28. | 2015-04-07 23:14:03 Checking Intraday data file for symbol GCZ4-COMEX for the date range from 2014-07-30 to 2014-11-27. | 2015-04-07 23:14:03 Checking Daily data file for symbol GCZ4-COMEX for the date range from 2014-07-30 to 2014-11-27. | 2015-04-07 23:14:03 Checking Intraday data file for symbol GCG5-COMEX for the date range from 2014-11-27 to 2015-01-29. | 2015-04-07 23:14:03 Checking Daily data file for symbol GCG5-COMEX for the date range from 2014-11-27 to 2015-01-29. | 2015-04-07 23:14:03 Checking Intraday data file for symbol GCJ5-COMEX for the date range from 2015-01-29 to 2015-03-30. | 2015-04-07 23:14:04 Checking Daily data file for symbol GCJ5-COMEX for the date range from 2015-01-29 to 2015-03-30. | 2015-04-07 23:14:04 Checking Intraday data file for symbol GCM5-COMEX for the date range from 2015-03-30 to 0. | 2015-04-07 23:14:04 Checking Daily data file for symbol GCM5-COMEX for the date range from 2015-03-30 to 2015-04-07. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9 | Symbols used for continuous contract chart: | 2015-04-07 23:14:04 GCZ4-COMEX | 2015-04-07 23:14:04 GCG5-COMEX | 2015-04-07 23:14:04 GCJ5-COMEX | 2015-04-07 23:14:04 GCM5-COMEX | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: Checking for volume based rollover dates. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: Volume based rollover from GCZ4-COMEX to GCG5-COMEX occurs at 2014-11-26 | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: Volume based rollover from GCG5-COMEX to GCJ5-COMEX occurs at 2015-01-29 | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: Volume based rollover from GCJ5-COMEX to GCM5-COMEX occurs at 2015-03-30 | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: GCZ4-COMEX Open price on 2014-11-26 is 1200.5. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: GCG5-COMEX Open price on 2014-11-26 is 1201.6. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: GCZ4-COMEX price difference to GCG5-COMEX is 1.1. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: GCG5-COMEX Open price on 2015-01-29 is 1283.3. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: GCJ5-COMEX Open price on 2015-01-29 is 1284. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: GCG5-COMEX price difference to GCJ5-COMEX is 0.69999999. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: GCJ5-COMEX Open price on 2015-03-30 is 1198. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: GCM5-COMEX Open price on 2015-03-30 is 1198.6. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: GCJ5-COMEX price difference to GCM5-COMEX is 0.60000002. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: Back adjust amount for symbol GCZ4-COMEX is 2.4000001. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: Back adjust amount for symbol GCG5-COMEX is 1.3. | 2015-04-07 23:14:04 GCM5-COMEX [CBV] 30 Min #9: Back adjust amount for symbol GCJ5-COMEX is 0.60000002. | 2015-04-07 23:14:04 Date rule based rollover from HGU4-COMEX to next contract occurs at 2014-08-27. | 2015-04-07 23:14:04 Date rule based rollover from HGZ4-COMEX to next contract occurs at 2014-11-26. | 2015-04-07 23:14:04 Date rule based rollover from HGH5-COMEX to next contract occurs at 2015-02-25. | 2015-04-07 23:14:04 Date rule based rollover from HGK5-COMEX to next contract occurs at 2015-04-28. | 2015-04-07 23:14:04 Checking Intraday data file for symbol HGU4-COMEX for the date range from 2014-06-26 to 2014-08-27. | 2015-04-07 23:14:04 Checking Daily data file for symbol HGU4-COMEX for the date range from 2014-06-26 to 2014-08-27. | 2015-04-07 23:14:04 Checking Intraday data file for symbol HGZ4-COMEX for the date range from 2014-08-27 to 2014-11-26. | 2015-04-07 23:14:04 Checking Daily data file for symbol HGZ4-COMEX for the date range from 2014-08-27 to 2014-11-26. | 2015-04-07 23:14:04 Checking Intraday data file for symbol HGH5-COMEX for the date range from 2014-11-26 to 2015-02-25. | 2015-04-07 23:14:04 Checking Daily data file for symbol HGH5-COMEX for the date range from 2014-11-26 to 2015-02-25. | 2015-04-07 23:14:04 Checking Intraday data file for symbol HGK5-COMEX for the date range from 2015-02-25 to 0. | 2015-04-07 23:14:04 Checking Daily data file for symbol HGK5-COMEX for the date range from 2015-02-25 to 2015-04-07. | 2015-04-07 23:14:04 HGK5-COMEX [CV] Renko 5-3-1 #11 | Symbols used for continuous contract chart: | 2015-04-07 23:14:04 HGU4-COMEX | 2015-04-07 23:14:04 HGZ4-COMEX | 2015-04-07 23:14:04 HGH5-COMEX | 2015-04-07 23:14:04 HGK5-COMEX | 2015-04-07 23:14:04 HGK5-COMEX [CV] Renko 5-3-1 #11: Checking for volume based rollover dates. | 2015-04-07 23:14:04 HGK5-COMEX [CV] Renko 5-3-1 #11: Volume based rollover from HGU4-COMEX to HGZ4-COMEX occurs at 2014-08-27 | 2015-04-07 23:14:04 HGK5-COMEX [CV] Renko 5-3-1 #11: Volume based rollover from HGZ4-COMEX to HGH5-COMEX occurs at 2014-11-25 | 2015-04-07 23:14:05 HGK5-COMEX [CV] Renko 5-3-1 #11: Volume based rollover from HGH5-COMEX to HGK5-COMEX occurs at 2015-02-25 | 2015-04-07 23:14:05 Date rule based rollover from 6EU4-CME to next contract occurs at 2014-09-15. | 2015-04-07 23:14:05 Date rule based rollover from 6EZ4-CME to next contract occurs at 2014-12-15. | 2015-04-07 23:14:05 Date rule based rollover from 6EH5-CME to next contract occurs at 2015-03-16. | 2015-04-07 23:14:05 Date rule based rollover from 6EM5-CME to next contract occurs at 2015-06-15. | 2015-04-07 23:14:05 Checking Intraday data file for symbol 6EU4-CME for the date range from 2014-06-16 to 2014-09-15. | 2015-04-07 23:14:05 Checking Intraday data file for symbol 6EZ4-CME for the date range from 2014-09-15 to 2014-12-15. | 2015-04-07 23:14:05 Checking Intraday data file for symbol 6EH5-CME for the date range from 2014-12-15 to 2015-03-16. | 2015-04-07 23:14:05 Checking Intraday data file for symbol 6EM5-CME for the date range from 2015-03-16 to 0. | 2015-04-07 23:14:05 6EM5-CME [C] Renko 5-3-1 #13 | Symbols used for continuous contract chart: | 2015-04-07 23:14:05 6EU4-CME | 2015-04-07 23:14:05 6EZ4-CME | 2015-04-07 23:14:05 6EH5-CME | 2015-04-07 23:14:05 6EM5-CME | 2015-04-07 23:14:05 Date rule based rollover from 6BU4-CME to next contract occurs at 2014-09-15. | 2015-04-07 23:14:05 Date rule based rollover from 6BZ4-CME to next contract occurs at 2014-12-15. | 2015-04-07 23:14:05 Date rule based rollover from 6BH5-CME to next contract occurs at 2015-03-16. | 2015-04-07 23:14:05 Date rule based rollover from 6BM5-CME to next contract occurs at 2015-06-15. | 2015-04-07 23:14:05 Checking Intraday data file for symbol 6BU4-CME for the date range from 2014-06-16 to 2014-09-15. | 2015-04-07 23:14:05 Checking Intraday data file for symbol 6BZ4-CME for the date range from 2014-09-15 to 2014-12-15. | 2015-04-07 23:14:05 Checking Intraday data file for symbol 6BH5-CME for the date range from 2014-12-15 to 2015-03-16. | 2015-04-07 23:14:05 Checking Intraday data file for symbol 6BM5-CME for the date range from 2015-03-16 to 0. | 2015-04-07 23:14:05 6BM5-CME [C] Renko 5-3-1 #15 | Symbols used for continuous contract chart: | 2015-04-07 23:14:05 6BU4-CME | 2015-04-07 23:14:05 6BZ4-CME | 2015-04-07 23:14:05 6BH5-CME | 2015-04-07 23:14:05 6BM5-CME | 2015-04-07 23:14:05 Date rule based rollover from 6AU4-CME to next contract occurs at 2014-09-15. | 2015-04-07 23:14:06 Date rule based rollover from 6AZ4-CME to next contract occurs at 2014-12-15. | 2015-04-07 23:14:06 Date rule based rollover from 6AH5-CME to next contract occurs at 2015-03-16. | 2015-04-07 23:14:06 Date rule based rollover from 6AM5-CME to next contract occurs at 2015-06-15. | 2015-04-07 23:14:06 Checking Intraday data file for symbol 6AU4-CME for the date range from 2014-06-16 to 2014-09-15. | 2015-04-07 23:14:06 Checking Intraday data file for symbol 6AZ4-CME for the date range from 2014-09-15 to 2014-12-15. | 2015-04-07 23:14:06 Checking Intraday data file for symbol 6AH5-CME for the date range from 2014-12-15 to 2015-03-16. | 2015-04-07 23:14:07 Checking Intraday data file for symbol 6AM5-CME for the date range from 2015-03-16 to 0. | 2015-04-07 23:14:07 6AM5-CME [C] Renko 5-3-1 #17 | Symbols used for continuous contract chart: | 2015-04-07 23:14:07 6AU4-CME | 2015-04-07 23:14:07 6AZ4-CME | 2015-04-07 23:14:07 6AH5-CME | 2015-04-07 23:14:07 6AM5-CME | 2015-04-07 23:14:07 Date rule based rollover from CLM4-NYMEX to next contract occurs at 2014-05-19. | 2015-04-07 23:14:07 Date rule based rollover from CLN4-NYMEX to next contract occurs at 2014-06-19. | 2015-04-07 23:14:07 Date rule based rollover from CLQ4-NYMEX to next contract occurs at 2014-07-21. | 2015-04-07 23:14:07 Date rule based rollover from CLU4-NYMEX to next contract occurs at 2014-08-19. | 2015-04-07 23:14:07 Date rule based rollover from CLV4-NYMEX to next contract occurs at 2014-09-19. | 2015-04-07 23:14:07 Date rule based rollover from CLX4-NYMEX to next contract occurs at 2014-10-20. | 2015-04-07 23:14:07 Date rule based rollover from CLZ4-NYMEX to next contract occurs at 2014-11-19. | 2015-04-07 23:14:07 Date rule based rollover from CLF5-NYMEX to next contract occurs at 2014-12-19. | 2015-04-07 23:14:07 Date rule based rollover from CLG5-NYMEX to next contract occurs at 2015-01-19. | 2015-04-07 23:14:07 Date rule based rollover from CLH5-NYMEX to next contract occurs at 2015-02-19. | 2015-04-07 23:14:07 Date rule based rollover from CLJ5-NYMEX to next contract occurs at 2015-03-19. | 2015-04-07 23:14:07 Date rule based rollover from CLK5-NYMEX to next contract occurs at 2015-04-20. | 2015-04-07 23:14:07 Checking Intraday data file for symbol CLM4-NYMEX for the date range from 2014-04-21 to 2014-05-19. | 2015-04-07 23:14:07 Checking Daily data file for symbol CLM4-NYMEX for the date range from 2014-04-21 to 2014-05-19. | 2015-04-07 23:14:07 Checking Intraday data file for symbol CLN4-NYMEX for the date range from 2014-05-19 to 2014-06-19. | 2015-04-07 23:14:08 Checking Daily data file for symbol CLN4-NYMEX for the date range from 2014-05-19 to 2014-06-19. | 2015-04-07 23:14:08 Checking Intraday data file for symbol CLQ4-NYMEX for the date range from 2014-06-19 to 2014-07-21. | 2015-04-07 23:14:08 Checking Daily data file for symbol CLQ4-NYMEX for the date range from 2014-06-19 to 2014-07-21. | 2015-04-07 23:14:08 Checking Intraday data file for symbol CLU4-NYMEX for the date range from 2014-07-21 to 2014-08-19. | 2015-04-07 23:14:08 Checking Daily data file for symbol CLU4-NYMEX for the date range from 2014-07-21 to 2014-08-19. | 2015-04-07 23:14:08 Checking Intraday data file for symbol CLV4-NYMEX for the date range from 2014-08-19 to 2014-09-19. | 2015-04-07 23:14:08 Checking Daily data file for symbol CLV4-NYMEX for the date range from 2014-08-19 to 2014-09-19. | 2015-04-07 23:14:08 Checking Intraday data file for symbol CLX4-NYMEX for the date range from 2014-09-19 to 2014-10-20. | 2015-04-07 23:14:08 Checking Daily data file for symbol CLX4-NYMEX for the date range from 2014-09-19 to 2014-10-20. | 2015-04-07 23:14:08 Checking Intraday data file for symbol CLZ4-NYMEX for the date range from 2014-10-20 to 2014-11-19. | 2015-04-07 23:14:09 Checking Daily data file for symbol CLZ4-NYMEX for the date range from 2014-10-20 to 2014-11-19. | 2015-04-07 23:14:09 Checking Intraday data file for symbol CLF5-NYMEX for the date range from 2014-11-19 to 2014-12-19. | 2015-04-07 23:14:09 Checking Daily data file for symbol CLF5-NYMEX for the date range from 2014-11-19 to 2014-12-19. | 2015-04-07 23:14:09 Checking Intraday data file for symbol CLG5-NYMEX for the date range from 2014-12-19 to 2015-01-19. | 2015-04-07 23:14:09 Checking Daily data file for symbol CLG5-NYMEX for the date range from 2014-12-19 to 2015-01-19. | 2015-04-07 23:14:09 Checking Intraday data file for symbol CLH5-NYMEX for the date range from 2015-01-19 to 2015-02-19. | 2015-04-07 23:14:09 Checking Daily data file for symbol CLH5-NYMEX for the date range from 2015-01-19 to 2015-02-19. | 2015-04-07 23:14:09 Checking Intraday data file for symbol CLJ5-NYMEX for the date range from 2015-02-19 to 2015-03-19. | 2015-04-07 23:14:10 Checking Daily data file for symbol CLJ5-NYMEX for the date range from 2015-02-19 to 2015-03-19. | 2015-04-07 23:14:10 Checking Intraday data file for symbol CLK5-NYMEX for the date range from 2015-03-19 to 0. | 2015-04-07 23:14:10 Checking Daily data file for symbol CLK5-NYMEX for the date range from 2015-03-19 to 2015-04-07. | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21 | Symbols used for continuous contract chart: | 2015-04-07 23:14:10 CLM4-NYMEX | 2015-04-07 23:14:10 CLN4-NYMEX | 2015-04-07 23:14:10 CLQ4-NYMEX | 2015-04-07 23:14:10 CLU4-NYMEX | 2015-04-07 23:14:10 CLV4-NYMEX | 2015-04-07 23:14:10 CLX4-NYMEX | 2015-04-07 23:14:10 CLZ4-NYMEX | 2015-04-07 23:14:10 CLF5-NYMEX | 2015-04-07 23:14:10 CLG5-NYMEX | 2015-04-07 23:14:10 CLH5-NYMEX | 2015-04-07 23:14:10 CLJ5-NYMEX | 2015-04-07 23:14:10 CLK5-NYMEX | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Checking for volume based rollover dates. | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLM4-NYMEX to CLN4-NYMEX occurs at 2014-05-19 | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLN4-NYMEX to CLQ4-NYMEX occurs at 2014-06-18 | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLQ4-NYMEX to CLU4-NYMEX occurs at 2014-07-18 | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLU4-NYMEX to CLV4-NYMEX occurs at 2014-08-18 | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLV4-NYMEX to CLX4-NYMEX occurs at 2014-09-19 | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLX4-NYMEX to CLZ4-NYMEX occurs at 2014-10-17 | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLZ4-NYMEX to CLF5-NYMEX occurs at 2014-11-18 | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLF5-NYMEX to CLG5-NYMEX occurs at 2014-12-18 | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLG5-NYMEX to CLH5-NYMEX occurs at 2015-01-16 | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLH5-NYMEX to CLJ5-NYMEX occurs at 2015-02-18 | 2015-04-07 23:14:10 CLK5-NYMEX [CV] 240 Min #21: Volume based rollover from CLJ5-NYMEX to CLK5-NYMEX occurs at 2015-03-18 | 2015-04-07 23:14:10 Date rule based rollover from NGU4-NYMEX to next contract occurs at 2014-08-25. | 2015-04-07 23:14:10 Date rule based rollover from NGV4-NYMEX to next contract occurs at 2014-09-24. | 2015-04-07 23:14:10 Date rule based rollover from NGX4-NYMEX to next contract occurs at 2014-10-27. | 2015-04-07 23:14:10 Date rule based rollover from NGZ4-NYMEX to next contract occurs at 2014-11-24. | 2015-04-07 23:14:10 Date rule based rollover from NGF5-NYMEX to next contract occurs at 2014-12-25. | 2015-04-07 23:14:10 Date rule based rollover from NGG5-NYMEX to next contract occurs at 2015-01-26. | 2015-04-07 23:14:10 Date rule based rollover from NGH5-NYMEX to next contract occurs at 2015-02-23. | 2015-04-07 23:14:10 Date rule based rollover from NGJ5-NYMEX to next contract occurs at 2015-03-25. | 2015-04-07 23:14:10 Date rule based rollover from NGK5-NYMEX to next contract occurs at 2015-04-24. | 2015-04-07 23:14:10 Checking Intraday data file for symbol NGU4-NYMEX for the date range from 2014-07-25 to 2014-08-25. | 2015-04-07 23:14:11 Checking Daily data file for symbol NGU4-NYMEX for the date range from 2014-07-25 to 2014-08-25. | 2015-04-07 23:14:11 Checking Intraday data file for symbol NGV4-NYMEX for the date range from 2014-08-25 to 2014-09-24. | 2015-04-07 23:14:11 Checking Daily data file for symbol NGV4-NYMEX for the date range from 2014-08-25 to 2014-09-24. | 2015-04-07 23:14:11 Checking Intraday data file for symbol NGX4-NYMEX for the date range from 2014-09-24 to 2014-10-27. | 2015-04-07 23:14:11 Checking Daily data file for symbol NGX4-NYMEX for the date range from 2014-09-24 to 2014-10-27. | 2015-04-07 23:14:11 Checking Intraday data file for symbol NGZ4-NYMEX for the date range from 2014-10-27 to 2014-11-24. | 2015-04-07 23:14:11 Checking Daily data file for symbol NGZ4-NYMEX for the date range from 2014-10-27 to 2014-11-24. | 2015-04-07 23:14:11 Checking Intraday data file for symbol NGF5-NYMEX for the date range from 2014-11-24 to 2014-12-25. | 2015-04-07 23:14:12 Checking Daily data file for symbol NGF5-NYMEX for the date range from 2014-11-24 to 2014-12-25. | 2015-04-07 23:14:12 Checking Intraday data file for symbol NGG5-NYMEX for the date range from 2014-12-25 to 2015-01-26. | 2015-04-07 23:14:12 Checking Daily data file for symbol NGG5-NYMEX for the date range from 2014-12-25 to 2015-01-26. | 2015-04-07 23:14:12 Checking Intraday data file for symbol NGH5-NYMEX for the date range from 2015-01-26 to 2015-02-23. | 2015-04-07 23:14:12 Checking Daily data file for symbol NGH5-NYMEX for the date range from 2015-01-26 to 2015-02-23. | 2015-04-07 23:14:13 Checking Intraday data file for symbol NGJ5-NYMEX for the date range from 2015-02-23 to 2015-03-25. | 2015-04-07 23:14:13 Checking Daily data file for symbol NGJ5-NYMEX for the date range from 2015-02-23 to 2015-03-25. | 2015-04-07 23:14:13 Checking Intraday data file for symbol NGK5-NYMEX for the date range from 2015-03-25 to 0. | 2015-04-07 23:14:13 Checking Daily data file for symbol NGK5-NYMEX for the date range from 2015-03-25 to 2015-04-07. | 2015-04-07 23:14:13 NGK5-NYMEX [CBV] Renko 5-3-1 #23 | Symbols used for continuous contract chart: | 2015-04-07 23:14:13 NGU4-NYMEX | 2015-04-07 23:14:13 NGV4-NYMEX | 2015-04-07 23:14:13 NGX4-NYMEX | 2015-04-07 23:14:13 NGZ4-NYMEX | 2015-04-07 23:14:13 NGF5-NYMEX | 2015-04-07 23:14:13 NGG5-NYMEX | 2015-04-07 23:14:13 NGH5-NYMEX | 2015-04-07 23:14:13 NGJ5-NYMEX | 2015-04-07 23:14:13 NGK5-NYMEX | 2015-04-07 23:14:13 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Checking for volume based rollover dates. | 2015-04-07 23:14:13 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Volume based rollover from NGU4-NYMEX to NGV4-NYMEX occurs at 2014-08-25 | 2015-04-07 23:14:13 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Volume based rollover from NGV4-NYMEX to NGX4-NYMEX occurs at 2014-09-24 | 2015-04-07 23:14:13 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Volume based rollover from NGX4-NYMEX to NGZ4-NYMEX occurs at 2014-10-27 | 2015-04-07 23:14:13 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Volume based rollover from NGZ4-NYMEX to NGF5-NYMEX occurs at 2014-11-21 | 2015-04-07 23:14:13 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Volume based rollover from NGF5-NYMEX to NGG5-NYMEX occurs at 2014-12-24 | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Volume based rollover from NGG5-NYMEX to NGH5-NYMEX occurs at 2015-01-23 | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Volume based rollover from NGH5-NYMEX to NGJ5-NYMEX occurs at 2015-02-20 | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Volume based rollover from NGJ5-NYMEX to NGK5-NYMEX occurs at 2015-03-25 | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Performing continuous futures contract back adjustment calculations. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGU4-NYMEX Open price on 2014-08-25 is 3.869. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGV4-NYMEX Open price on 2014-08-25 is 3.898. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGU4-NYMEX price difference to NGV4-NYMEX is 0.028999999. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGV4-NYMEX Open price on 2014-09-24 is 3.833. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGX4-NYMEX Open price on 2014-09-24 is 3.886. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGV4-NYMEX price difference to NGX4-NYMEX is 0.052999999. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGX4-NYMEX Open price on 2014-10-27 is 3.62. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGZ4-NYMEX Open price on 2014-10-27 is 3.644. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGX4-NYMEX price difference to NGZ4-NYMEX is 0.024. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGZ4-NYMEX Open price on 2014-11-21 is 4.46. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGF5-NYMEX Open price on 2014-11-21 is 4.62. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGZ4-NYMEX price difference to NGF5-NYMEX is 0.16. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGF5-NYMEX Open price on 2014-12-24 is 3.17. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGG5-NYMEX Open price on 2014-12-24 is 3.196. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGF5-NYMEX price difference to NGG5-NYMEX is 0.026000001. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGG5-NYMEX Open price on 2015-01-23 is 2.858. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGH5-NYMEX Open price on 2015-01-23 is 2.842. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGG5-NYMEX price difference to NGH5-NYMEX is -0.016000001. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGH5-NYMEX Open price on 2015-02-20 is 2.815. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGJ5-NYMEX Open price on 2015-02-20 is 2.852. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGH5-NYMEX price difference to NGJ5-NYMEX is 0.037. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGJ5-NYMEX Open price on 2015-03-25 is 2.784. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGK5-NYMEX Open price on 2015-03-25 is 2.806. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: NGJ5-NYMEX price difference to NGK5-NYMEX is 0.022. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Back adjust amount for symbol NGU4-NYMEX is 0.33499998. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Back adjust amount for symbol NGV4-NYMEX is 0.30599999. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Back adjust amount for symbol NGX4-NYMEX is 0.25300002. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Back adjust amount for symbol NGZ4-NYMEX is 0.22899999. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Back adjust amount for symbol NGF5-NYMEX is 0.068999998. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Back adjust amount for symbol NGG5-NYMEX is 0.042999998. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Back adjust amount for symbol NGH5-NYMEX is 0.059. | 2015-04-07 23:14:14 NGK5-NYMEX [CBV] Renko 5-3-1 #23: Back adjust amount for symbol NGJ5-NYMEX is 0.022. | 2015-04-07 23:14:14 Date rule based rollover from 6JH5-CME to next contract occurs at 2015-03-16. | 2015-04-07 23:14:15 Date rule based rollover from 6JM5-CME to next contract occurs at 2015-06-15. | 2015-04-07 23:14:15 Checking Intraday data file for symbol 6JH5-CME for the date range from 2014-12-15 to 2015-03-16. | 2015-04-07 23:14:15 Checking Daily data file for symbol 6JH5-CME for the date range from 2014-12-15 to 2015-03-16. | 2015-04-07 23:14:16 Checking Intraday data file for symbol 6JM5-CME for the date range from 2015-03-16 to 0. | 2015-04-07 23:14:16 Checking Daily data file for symbol 6JM5-CME for the date range from 2015-03-16 to 2015-04-07. | 2015-04-07 23:14:16 6JM5-CME [CV] 60 Min #25 | Symbols used for continuous contract chart: | 2015-04-07 23:14:16 6JH5-CME | 2015-04-07 23:14:16 6JM5-CME | 2015-04-07 23:14:16 6JM5-CME [CV] 60 Min #25: Checking for volume based rollover dates. | 2015-04-07 23:14:16 6JM5-CME [CV] 60 Min #25: Volume based rollover from 6JH5-CME to 6JM5-CME occurs at 2015-03-13 | 2015-04-07 23:14:16 Limiting the number of years back for the continuous futures chart to 4.9993155. Reason: Single-digit year in symbol. | 2015-04-07 23:14:16 Date rule based rollover from ZNM0-CBOT to next contract occurs at 2010-05-31. | 2015-04-07 23:14:16 Date rule based rollover from ZNU0-CBOT to next contract occurs at 2010-08-31. | 2015-04-07 23:14:16 Date rule based rollover from ZNZ0-CBOT to next contract occurs at 2010-11-30. | 2015-04-07 23:14:16 Date rule based rollover from ZNH1-CBOT to next contract occurs at 2011-02-28. | 2015-04-07 23:14:16 Date rule based rollover from ZNM1-CBOT to next contract occurs at 2011-05-31. | 2015-04-07 23:14:16 Date rule based rollover from ZNU1-CBOT to next contract occurs at 2011-08-31. | 2015-04-07 23:14:16 Date rule based rollover from ZNZ1-CBOT to next contract occurs at 2011-11-30. | 2015-04-07 23:14:16 Date rule based rollover from ZNH2-CBOT to next contract occurs at 2012-02-29. | 2015-04-07 23:14:16 Date rule based rollover from ZNM2-CBOT to next contract occurs at 2012-05-31. | 2015-04-07 23:14:16 Date rule based rollover from ZNU2-CBOT to next contract occurs at 2012-08-31. | 2015-04-07 23:14:16 Date rule based rollover from ZNZ2-CBOT to next contract occurs at 2012-11-30. | 2015-04-07 23:14:16 Date rule based rollover from ZNH3-CBOT to next contract occurs at 2013-02-28. | 2015-04-07 23:14:16 Date rule based rollover from ZNM3-CBOT to next contract occurs at 2013-05-31. | 2015-04-07 23:14:16 Date rule based rollover from ZNU3-CBOT to next contract occurs at 2013-08-30. | 2015-04-07 23:14:16 Date rule based rollover from ZNZ3-CBOT to next contract occurs at 2013-11-29. | 2015-04-07 23:14:16 Date rule based rollover from ZNH4-CBOT to next contract occurs at 2014-02-28. | 2015-04-07 23:14:16 Date rule based rollover from ZNM4-CBOT to next contract occurs at 2014-05-30. | 2015-04-07 23:14:16 Date rule based rollover from ZNU4-CBOT to next contract occurs at 2014-08-29. | 2015-04-07 23:14:16 Date rule based rollover from ZNZ4-CBOT to next contract occurs at 2014-11-28. | 2015-04-07 23:14:16 Date rule based rollover from ZNH5-CBOT to next contract occurs at 2015-02-27. | 2015-04-07 23:14:16 Date rule based rollover from ZNM5-CBOT to next contract occurs at 2015-05-29. | 2015-04-07 23:14:16 Intraday data file for ZNM0-CBOT exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:16 Intraday data file for ZNU0-CBOT exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:16 Intraday data file for ZNZ0-CBOT exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:16 Checking Intraday data file for symbol ZNH1-CBOT for the date range from 2010-11-30 to 2011-02-28. | 2015-04-07 23:14:17 Checking Intraday data file for symbol ZNM1-CBOT for the date range from 2011-02-28 to 2011-05-31. | 2015-04-07 23:14:17 Checking Intraday data file for symbol ZNU1-CBOT for the date range from 2011-05-31 to 2011-08-31. | 2015-04-07 23:14:17 Checking Intraday data file for symbol ZNZ1-CBOT for the date range from 2011-08-31 to 2011-11-30. | 2015-04-07 23:14:18 Checking Intraday data file for symbol ZNH2-CBOT for the date range from 2011-11-30 to 2012-02-29. | 2015-04-07 23:14:18 Checking Intraday data file for symbol ZNM2-CBOT for the date range from 2012-02-29 to 2012-05-31. | 2015-04-07 23:14:18 Checking Intraday data file for symbol ZNU2-CBOT for the date range from 2012-05-31 to 2012-08-31. | 2015-04-07 23:14:19 Checking Intraday data file for symbol ZNZ2-CBOT for the date range from 2012-08-31 to 2012-11-30. | 2015-04-07 23:14:19 Checking Intraday data file for symbol ZNH3-CBOT for the date range from 2012-11-30 to 2013-02-28. | 2015-04-07 23:14:19 Checking Intraday data file for symbol ZNM3-CBOT for the date range from 2013-02-28 to 2013-05-31. | 2015-04-07 23:14:19 Checking Intraday data file for symbol ZNU3-CBOT for the date range from 2013-05-31 to 2013-08-30. | 2015-04-07 23:14:20 Checking Intraday data file for symbol ZNZ3-CBOT for the date range from 2013-08-30 to 2013-11-29. | 2015-04-07 23:14:20 Checking Intraday data file for symbol ZNH4-CBOT for the date range from 2013-11-29 to 2014-02-28. | 2015-04-07 23:14:20 Checking Intraday data file for symbol ZNM4-CBOT for the date range from 2014-02-28 to 2014-05-30. | 2015-04-07 23:14:20 Checking Intraday data file for symbol ZNU4-CBOT for the date range from 2014-05-30 to 2014-08-29. | 2015-04-07 23:14:21 Checking Intraday data file for symbol ZNZ4-CBOT for the date range from 2014-08-29 to 2014-11-28. | 2015-04-07 23:14:21 Checking Intraday data file for symbol ZNH5-CBOT for the date range from 2014-11-28 to 2015-02-27. | 2015-04-07 23:14:21 Checking Intraday data file for symbol ZNM5-CBOT for the date range from 2015-02-27 to 0. | 2015-04-07 23:14:21 ZNM5-CBOT [C] Renko 5-3-1 #30 | Symbols used for continuous contract chart: | 2015-04-07 23:14:21 ZNM0-CBOT | 2015-04-07 23:14:21 ZNU0-CBOT | 2015-04-07 23:14:21 ZNZ0-CBOT | 2015-04-07 23:14:21 ZNH1-CBOT | 2015-04-07 23:14:21 ZNM1-CBOT | 2015-04-07 23:14:21 ZNU1-CBOT | 2015-04-07 23:14:21 ZNZ1-CBOT | 2015-04-07 23:14:21 ZNH2-CBOT | 2015-04-07 23:14:21 ZNM2-CBOT | 2015-04-07 23:14:21 ZNU2-CBOT | 2015-04-07 23:14:21 ZNZ2-CBOT | 2015-04-07 23:14:21 ZNH3-CBOT | 2015-04-07 23:14:21 ZNM3-CBOT | 2015-04-07 23:14:21 ZNU3-CBOT | 2015-04-07 23:14:21 ZNZ3-CBOT | 2015-04-07 23:14:21 ZNH4-CBOT | 2015-04-07 23:14:21 ZNM4-CBOT | 2015-04-07 23:14:21 ZNU4-CBOT | 2015-04-07 23:14:21 ZNZ4-CBOT | 2015-04-07 23:14:21 ZNH5-CBOT | 2015-04-07 23:14:21 ZNM5-CBOT | 2015-04-07 23:14:21 Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-04-07 23:14:21 Date rule based rollover from TF FMM0015!-NYBOT to next contract occurs at 2015-06-11. | 2015-04-07 23:14:21 Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:21 Checking Intraday data file for symbol TF FMM0015!-NYBOT for the date range from 2015-03-12 to 0. | 2015-04-07 23:14:21 TF FMM0015!-NYBOT [C] Renko 5-3-1 #28 | Symbols used for continuous contract chart: | 2015-04-07 23:14:21 TF FMH0015!-NYBOT | 2015-04-07 23:14:21 TF FMM0015!-NYBOT | 2015-04-07 23:14:21 Date rule based rollover from NGU4-NYMEX to next contract occurs at 2014-08-25. | 2015-04-07 23:14:21 Date rule based rollover from NGV4-NYMEX to next contract occurs at 2014-09-24. | 2015-04-07 23:14:21 Date rule based rollover from NGX4-NYMEX to next contract occurs at 2014-10-27. | 2015-04-07 23:14:21 Date rule based rollover from NGZ4-NYMEX to next contract occurs at 2014-11-24. | 2015-04-07 23:14:21 Date rule based rollover from NGF5-NYMEX to next contract occurs at 2014-12-25. | 2015-04-07 23:14:21 Date rule based rollover from NGG5-NYMEX to next contract occurs at 2015-01-26. | 2015-04-07 23:14:21 Date rule based rollover from NGH5-NYMEX to next contract occurs at 2015-02-23. | 2015-04-07 23:14:21 Date rule based rollover from NGJ5-NYMEX to next contract occurs at 2015-03-25. | 2015-04-07 23:14:21 Date rule based rollover from NGK5-NYMEX to next contract occurs at 2015-04-24. | 2015-04-07 23:14:21 Checking Intraday data file for symbol NGU4-NYMEX for the date range from 2014-07-25 to 2014-08-25. | 2015-04-07 23:14:21 Checking Daily data file for symbol NGU4-NYMEX for the date range from 2014-07-25 to 2014-08-25. | 2015-04-07 23:14:21 Checking Intraday data file for symbol NGV4-NYMEX for the date range from 2014-08-25 to 2014-09-24. | 2015-04-07 23:14:21 Checking Daily data file for symbol NGV4-NYMEX for the date range from 2014-08-25 to 2014-09-24. | 2015-04-07 23:14:21 Checking Intraday data file for symbol NGX4-NYMEX for the date range from 2014-09-24 to 2014-10-27. | 2015-04-07 23:14:21 Checking Daily data file for symbol NGX4-NYMEX for the date range from 2014-09-24 to 2014-10-27. | 2015-04-07 23:14:21 Checking Intraday data file for symbol NGZ4-NYMEX for the date range from 2014-10-27 to 2014-11-24. | 2015-04-07 23:14:21 Checking Daily data file for symbol NGZ4-NYMEX for the date range from 2014-10-27 to 2014-11-24. | 2015-04-07 23:14:21 Checking Intraday data file for symbol NGF5-NYMEX for the date range from 2014-11-24 to 2014-12-25. | 2015-04-07 23:14:21 Checking Daily data file for symbol NGF5-NYMEX for the date range from 2014-11-24 to 2014-12-25. | 2015-04-07 23:14:21 Checking Intraday data file for symbol NGG5-NYMEX for the date range from 2014-12-25 to 2015-01-26. | 2015-04-07 23:14:21 Checking Daily data file for symbol NGG5-NYMEX for the date range from 2014-12-25 to 2015-01-26. | 2015-04-07 23:14:21 Checking Intraday data file for symbol NGH5-NYMEX for the date range from 2015-01-26 to 2015-02-23. | 2015-04-07 23:14:21 Checking Daily data file for symbol NGH5-NYMEX for the date range from 2015-01-26 to 2015-02-23. | 2015-04-07 23:14:21 Checking Intraday data file for symbol NGJ5-NYMEX for the date range from 2015-02-23 to 2015-03-25. | 2015-04-07 23:14:21 Checking Daily data file for symbol NGJ5-NYMEX for the date range from 2015-02-23 to 2015-03-25. | 2015-04-07 23:14:21 Checking Intraday data file for symbol NGK5-NYMEX for the date range from 2015-03-25 to 0. | 2015-04-07 23:14:21 Checking Daily data file for symbol NGK5-NYMEX for the date range from 2015-03-25 to 2015-04-07. | 2015-04-07 23:14:21 NGK5-NYMEX [CBV] 60 Min #32 | Symbols used for continuous contract chart: | 2015-04-07 23:14:21 NGU4-NYMEX | 2015-04-07 23:14:21 NGV4-NYMEX | 2015-04-07 23:14:21 NGX4-NYMEX | 2015-04-07 23:14:21 NGZ4-NYMEX | 2015-04-07 23:14:21 NGF5-NYMEX | 2015-04-07 23:14:21 NGG5-NYMEX | 2015-04-07 23:14:21 NGH5-NYMEX | 2015-04-07 23:14:21 NGJ5-NYMEX | 2015-04-07 23:14:21 NGK5-NYMEX | 2015-04-07 23:14:21 NGK5-NYMEX [CBV] 60 Min #32: Checking for volume based rollover dates. | 2015-04-07 23:14:21 NGK5-NYMEX [CBV] 60 Min #32: Volume based rollover from NGU4-NYMEX to NGV4-NYMEX occurs at 2014-08-25 | 2015-04-07 23:14:21 NGK5-NYMEX [CBV] 60 Min #32: Volume based rollover from NGV4-NYMEX to NGX4-NYMEX occurs at 2014-09-24 | 2015-04-07 23:14:21 NGK5-NYMEX [CBV] 60 Min #32: Volume based rollover from NGX4-NYMEX to NGZ4-NYMEX occurs at 2014-10-27 | 2015-04-07 23:14:21 NGK5-NYMEX [CBV] 60 Min #32: Volume based rollover from NGZ4-NYMEX to NGF5-NYMEX occurs at 2014-11-21 | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Volume based rollover from NGF5-NYMEX to NGG5-NYMEX occurs at 2014-12-24 | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Volume based rollover from NGG5-NYMEX to NGH5-NYMEX occurs at 2015-01-23 | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Volume based rollover from NGH5-NYMEX to NGJ5-NYMEX occurs at 2015-02-20 | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Volume based rollover from NGJ5-NYMEX to NGK5-NYMEX occurs at 2015-03-25 | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Performing continuous futures contract back adjustment calculations. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGU4-NYMEX Open price on 2014-08-25 is 3.869. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGV4-NYMEX Open price on 2014-08-25 is 3.898. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGU4-NYMEX price difference to NGV4-NYMEX is 0.028999999. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGV4-NYMEX Open price on 2014-09-24 is 3.833. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGX4-NYMEX Open price on 2014-09-24 is 3.886. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGV4-NYMEX price difference to NGX4-NYMEX is 0.052999999. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGX4-NYMEX Open price on 2014-10-27 is 3.62. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGZ4-NYMEX Open price on 2014-10-27 is 3.644. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGX4-NYMEX price difference to NGZ4-NYMEX is 0.024. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGZ4-NYMEX Open price on 2014-11-21 is 4.46. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGF5-NYMEX Open price on 2014-11-21 is 4.62. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGZ4-NYMEX price difference to NGF5-NYMEX is 0.16. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGF5-NYMEX Open price on 2014-12-24 is 3.17. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGG5-NYMEX Open price on 2014-12-24 is 3.196. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGF5-NYMEX price difference to NGG5-NYMEX is 0.026000001. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGG5-NYMEX Open price on 2015-01-23 is 2.858. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGH5-NYMEX Open price on 2015-01-23 is 2.842. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGG5-NYMEX price difference to NGH5-NYMEX is -0.016000001. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGH5-NYMEX Open price on 2015-02-20 is 2.815. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGJ5-NYMEX Open price on 2015-02-20 is 2.852. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGH5-NYMEX price difference to NGJ5-NYMEX is 0.037. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGJ5-NYMEX Open price on 2015-03-25 is 2.784. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGK5-NYMEX Open price on 2015-03-25 is 2.806. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: NGJ5-NYMEX price difference to NGK5-NYMEX is 0.022. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Back adjust amount for symbol NGU4-NYMEX is 0.33499998. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Back adjust amount for symbol NGV4-NYMEX is 0.30599999. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Back adjust amount for symbol NGX4-NYMEX is 0.25300002. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Back adjust amount for symbol NGZ4-NYMEX is 0.22899999. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Back adjust amount for symbol NGF5-NYMEX is 0.068999998. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Back adjust amount for symbol NGG5-NYMEX is 0.042999998. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Back adjust amount for symbol NGH5-NYMEX is 0.059. | 2015-04-07 23:14:22 NGK5-NYMEX [CBV] 60 Min #32: Back adjust amount for symbol NGJ5-NYMEX is 0.022. | 2015-04-07 23:14:22 Date rule based rollover from GCZ4-COMEX to next contract occurs at 2014-11-27. | 2015-04-07 23:14:22 Date rule based rollover from GCG5-COMEX to next contract occurs at 2015-01-29. | 2015-04-07 23:14:22 Date rule based rollover from GCJ5-COMEX to next contract occurs at 2015-03-30. | 2015-04-07 23:14:22 Date rule based rollover from GCM5-COMEX to next contract occurs at 2015-05-28. | 2015-04-07 23:14:22 Checking Intraday data file for symbol GCZ4-COMEX for the date range from 2014-07-30 to 2014-11-27. | 2015-04-07 23:14:22 Checking Intraday data file for symbol GCG5-COMEX for the date range from 2014-11-27 to 2015-01-29. | 2015-04-07 23:14:22 Checking Intraday data file for symbol GCJ5-COMEX for the date range from 2015-01-29 to 2015-03-30. | 2015-04-07 23:14:22 Checking Intraday data file for symbol GCM5-COMEX for the date range from 2015-03-30 to 0. | 2015-04-07 23:14:22 GCM5-COMEX [C] Renko 5-3-1 #33 | Symbols used for continuous contract chart: | 2015-04-07 23:14:22 GCZ4-COMEX | 2015-04-07 23:14:22 GCG5-COMEX | 2015-04-07 23:14:22 GCJ5-COMEX | 2015-04-07 23:14:22 GCM5-COMEX | 2015-04-07 23:14:22 Date rule based rollover from TF FMU0014!-NYBOT to next contract occurs at 2014-09-11. | 2015-04-07 23:14:22 Date rule based rollover from TF FMZ0014!-NYBOT to next contract occurs at 2014-12-11. | 2015-04-07 23:14:22 Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-04-07 23:14:22 Date rule based rollover from TF FMM0015!-NYBOT to next contract occurs at 2015-06-11. | 2015-04-07 23:14:22 Checking Intraday data file for symbol TF FMU0014!-NYBOT for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:14:22 Checking Daily data file for symbol TF FMU0014!-NYBOT for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:14:23 Checking Intraday data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:14:23 Checking Daily data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:14:23 Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:23 Checking Daily data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:23 Checking Intraday data file for symbol TF FMM0015!-NYBOT for the date range from 2015-03-12 to 0. | 2015-04-07 23:14:24 Checking Daily data file for symbol TF FMM0015!-NYBOT for the date range from 2015-03-12 to 2015-04-07. | 2015-04-07 23:14:24 TF FMM0015!-NYBOT [CV] Renko 6-3-1 #37 | Symbols used for continuous contract chart: | 2015-04-07 23:14:24 TF FMU0014!-NYBOT | 2015-04-07 23:14:24 TF FMZ0014!-NYBOT | 2015-04-07 23:14:24 TF FMH0015!-NYBOT | 2015-04-07 23:14:24 TF FMM0015!-NYBOT | 2015-04-07 23:14:24 TF FMM0015!-NYBOT [CV] Renko 6-3-1 #37: Checking for volume based rollover dates. | 2015-04-07 23:14:24 TF FMM0015!-NYBOT [CV] Renko 6-3-1 #37: Volume based rollover from TF FMU0014!-NYBOT to TF FMZ0014!-NYBOT occurs at 2014-09-12 | 2015-04-07 23:14:24 TF FMM0015!-NYBOT [CV] Renko 6-3-1 #37: Volume based rollover from TF FMZ0014!-NYBOT to TF FMH0015!-NYBOT occurs at 2014-12-12 | 2015-04-07 23:14:24 TF FMM0015!-NYBOT [CV] Renko 6-3-1 #37: Volume based rollover from TF FMH0015!-NYBOT to TF FMM0015!-NYBOT occurs at 2015-03-13 | 2015-04-07 23:14:24 Date rule based rollover from QMU4-NYMEX to next contract occurs at 2014-08-20. | 2015-04-07 23:14:25 Date rule based rollover from QMV4-NYMEX to next contract occurs at 2014-09-22. | 2015-04-07 23:14:25 Date rule based rollover from QMX4-NYMEX to next contract occurs at 2014-10-21. | 2015-04-07 23:14:25 Date rule based rollover from QMZ4-NYMEX to next contract occurs at 2014-11-20. | 2015-04-07 23:14:25 Date rule based rollover from QMF5-NYMEX to next contract occurs at 2014-12-22. | 2015-04-07 23:14:25 Date rule based rollover from QMG5-NYMEX to next contract occurs at 2015-01-20. | 2015-04-07 23:14:25 Date rule based rollover from QMH5-NYMEX to next contract occurs at 2015-02-20. | 2015-04-07 23:14:25 Date rule based rollover from QMJ5-NYMEX to next contract occurs at 2015-03-20. | 2015-04-07 23:14:25 Date rule based rollover from QMK5-NYMEX to next contract occurs at 2015-04-21. | 2015-04-07 23:14:25 Checking Intraday data file for symbol QMU4-NYMEX for the date range from 2014-07-22 to 2014-08-20. | 2015-04-07 23:14:25 Rithmic Trading | Port for executable: 63352 | 2015-04-07 23:14:25 Listening socket (1728), port 63352 | Closed. | 2015-04-07 23:14:25 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-04-07 23:14:25 Checking Intraday data file for symbol QMV4-NYMEX for the date range from 2014-08-20 to 2014-09-22. | 2015-04-07 23:14:25 Checking Intraday data file for symbol QMX4-NYMEX for the date range from 2014-09-22 to 2014-10-21. | 2015-04-07 23:14:26 Checking Intraday data file for symbol QMZ4-NYMEX for the date range from 2014-10-21 to 2014-11-20. | 2015-04-07 23:14:26 Checking Intraday data file for symbol QMF5-NYMEX for the date range from 2014-11-20 to 2014-12-22. | 2015-04-07 23:14:26 Checking Intraday data file for symbol QMG5-NYMEX for the date range from 2014-12-22 to 2015-01-20. | 2015-04-07 23:14:26 Checking Intraday data file for symbol QMH5-NYMEX for the date range from 2015-01-20 to 2015-02-20. | 2015-04-07 23:14:27 Checking Intraday data file for symbol QMJ5-NYMEX for the date range from 2015-02-20 to 2015-03-20. | 2015-04-07 23:14:27 Checking Intraday data file for symbol QMK5-NYMEX for the date range from 2015-03-20 to 0. | 2015-04-07 23:14:27 QMK5-NYMEX [C] Renko 4-3-3 #6 | Symbols used for continuous contract chart: | 2015-04-07 23:14:27 QMU4-NYMEX | 2015-04-07 23:14:27 QMV4-NYMEX | 2015-04-07 23:14:27 QMX4-NYMEX | 2015-04-07 23:14:27 QMZ4-NYMEX | 2015-04-07 23:14:27 QMF5-NYMEX | 2015-04-07 23:14:27 QMG5-NYMEX | 2015-04-07 23:14:27 QMH5-NYMEX | 2015-04-07 23:14:27 QMJ5-NYMEX | 2015-04-07 23:14:27 QMK5-NYMEX | 2015-04-07 23:14:27 QMK5-NYMEX [C] Renko 4-3-3 #6 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, 7, 8, | 2015-04-07 23:14:27 Date rule based rollover from CLM4-NYMEX to next contract occurs at 2014-05-19. | 2015-04-07 23:14:27 Date rule based rollover from CLN4-NYMEX to next contract occurs at 2014-06-19. | 2015-04-07 23:14:27 Date rule based rollover from CLQ4-NYMEX to next contract occurs at 2014-07-21. | 2015-04-07 23:14:27 Date rule based rollover from CLU4-NYMEX to next contract occurs at 2014-08-19. | 2015-04-07 23:14:27 Date rule based rollover from CLV4-NYMEX to next contract occurs at 2014-09-19. | 2015-04-07 23:14:27 Date rule based rollover from CLX4-NYMEX to next contract occurs at 2014-10-20. | 2015-04-07 23:14:27 Date rule based rollover from CLZ4-NYMEX to next contract occurs at 2014-11-19. | 2015-04-07 23:14:27 Date rule based rollover from CLF5-NYMEX to next contract occurs at 2014-12-19. | 2015-04-07 23:14:27 Date rule based rollover from CLG5-NYMEX to next contract occurs at 2015-01-19. | 2015-04-07 23:14:27 Date rule based rollover from CLH5-NYMEX to next contract occurs at 2015-02-19. | 2015-04-07 23:14:27 Date rule based rollover from CLJ5-NYMEX to next contract occurs at 2015-03-19. | 2015-04-07 23:14:27 Date rule based rollover from CLK5-NYMEX to next contract occurs at 2015-04-20. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLM4-NYMEX for the date range from 2014-04-21 to 2014-05-19. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLM4-NYMEX for the date range from 2014-04-21 to 2014-05-19. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLN4-NYMEX for the date range from 2014-05-19 to 2014-06-19. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLN4-NYMEX for the date range from 2014-05-19 to 2014-06-19. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLQ4-NYMEX for the date range from 2014-06-19 to 2014-07-21. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLQ4-NYMEX for the date range from 2014-06-19 to 2014-07-21. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLU4-NYMEX for the date range from 2014-07-21 to 2014-08-19. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLU4-NYMEX for the date range from 2014-07-21 to 2014-08-19. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLV4-NYMEX for the date range from 2014-08-19 to 2014-09-19. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLV4-NYMEX for the date range from 2014-08-19 to 2014-09-19. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLX4-NYMEX for the date range from 2014-09-19 to 2014-10-20. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLX4-NYMEX for the date range from 2014-09-19 to 2014-10-20. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLZ4-NYMEX for the date range from 2014-10-20 to 2014-11-19. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLZ4-NYMEX for the date range from 2014-10-20 to 2014-11-19. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLF5-NYMEX for the date range from 2014-11-19 to 2014-12-19. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLF5-NYMEX for the date range from 2014-11-19 to 2014-12-19. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLG5-NYMEX for the date range from 2014-12-19 to 2015-01-19. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLG5-NYMEX for the date range from 2014-12-19 to 2015-01-19. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLH5-NYMEX for the date range from 2015-01-19 to 2015-02-19. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLH5-NYMEX for the date range from 2015-01-19 to 2015-02-19. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLJ5-NYMEX for the date range from 2015-02-19 to 2015-03-19. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLJ5-NYMEX for the date range from 2015-02-19 to 2015-03-19. | 2015-04-07 23:14:27 Checking Intraday data file for symbol CLK5-NYMEX for the date range from 2015-03-19 to 0. | 2015-04-07 23:14:27 Checking Daily data file for symbol CLK5-NYMEX for the date range from 2015-03-19 to 2015-04-07. | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35 | Symbols used for continuous contract chart: | 2015-04-07 23:14:27 CLM4-NYMEX | 2015-04-07 23:14:27 CLN4-NYMEX | 2015-04-07 23:14:27 CLQ4-NYMEX | 2015-04-07 23:14:27 CLU4-NYMEX | 2015-04-07 23:14:27 CLV4-NYMEX | 2015-04-07 23:14:27 CLX4-NYMEX | 2015-04-07 23:14:27 CLZ4-NYMEX | 2015-04-07 23:14:27 CLF5-NYMEX | 2015-04-07 23:14:27 CLG5-NYMEX | 2015-04-07 23:14:27 CLH5-NYMEX | 2015-04-07 23:14:27 CLJ5-NYMEX | 2015-04-07 23:14:27 CLK5-NYMEX | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Checking for volume based rollover dates. | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLM4-NYMEX to CLN4-NYMEX occurs at 2014-05-19 | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLN4-NYMEX to CLQ4-NYMEX occurs at 2014-06-18 | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLQ4-NYMEX to CLU4-NYMEX occurs at 2014-07-18 | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLU4-NYMEX to CLV4-NYMEX occurs at 2014-08-18 | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLV4-NYMEX to CLX4-NYMEX occurs at 2014-09-19 | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLX4-NYMEX to CLZ4-NYMEX occurs at 2014-10-17 | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLZ4-NYMEX to CLF5-NYMEX occurs at 2014-11-18 | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLF5-NYMEX to CLG5-NYMEX occurs at 2014-12-18 | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLG5-NYMEX to CLH5-NYMEX occurs at 2015-01-16 | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLH5-NYMEX to CLJ5-NYMEX occurs at 2015-02-18 | 2015-04-07 23:14:27 CLK5-NYMEX [CV] Renko 20-14-6 #35: Volume based rollover from CLJ5-NYMEX to CLK5-NYMEX occurs at 2015-03-18 | 2015-04-07 23:14:27 Date rule based rollover from YMH5-CBOT to next contract occurs at 2015-03-12. | 2015-04-07 23:14:28 Date rule based rollover from YMM5-CBOT to next contract occurs at 2015-06-11. | 2015-04-07 23:14:28 Checking Intraday data file for symbol YMH5-CBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:28 Checking Daily data file for symbol YMH5-CBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:28 Checking Intraday data file for symbol YMM5-CBOT for the date range from 2015-03-12 to 0. | 2015-04-07 23:14:28 Checking Daily data file for symbol YMM5-CBOT for the date range from 2015-03-12 to 2015-04-07. | 2015-04-07 23:14:28 YMM5-CBOT [CBV] Renko 5-3-1 #34 | Symbols used for continuous contract chart: | 2015-04-07 23:14:28 YMH5-CBOT | 2015-04-07 23:14:28 YMM5-CBOT | 2015-04-07 23:14:28 YMM5-CBOT [CBV] Renko 5-3-1 #34: Checking for volume based rollover dates. | 2015-04-07 23:14:28 YMM5-CBOT [CBV] Renko 5-3-1 #34: Volume based rollover from YMH5-CBOT to YMM5-CBOT occurs at 2015-03-13 | 2015-04-07 23:14:28 YMM5-CBOT [CBV] Renko 5-3-1 #34: Performing continuous futures contract back adjustment calculations. | 2015-04-07 23:14:28 YMM5-CBOT [CBV] Renko 5-3-1 #34: YMH5-CBOT Open price on 2015-03-13 is 17869. | 2015-04-07 23:14:28 YMM5-CBOT [CBV] Renko 5-3-1 #34: YMM5-CBOT Open price on 2015-03-13 is 17792. | 2015-04-07 23:14:28 YMM5-CBOT [CBV] Renko 5-3-1 #34: YMH5-CBOT price difference to YMM5-CBOT is -77. | 2015-04-07 23:14:28 YMM5-CBOT [CBV] Renko 5-3-1 #34: Back adjust amount for symbol YMH5-CBOT is -77. | 2015-04-07 23:14:28 Date rule based rollover from CLM4-NYMEX to next contract occurs at 2014-05-19. | 2015-04-07 23:14:28 Date rule based rollover from CLN4-NYMEX to next contract occurs at 2014-06-19. | 2015-04-07 23:14:28 Date rule based rollover from CLQ4-NYMEX to next contract occurs at 2014-07-21. | 2015-04-07 23:14:28 Date rule based rollover from CLU4-NYMEX to next contract occurs at 2014-08-19. | 2015-04-07 23:14:28 Date rule based rollover from CLV4-NYMEX to next contract occurs at 2014-09-19. | 2015-04-07 23:14:28 Date rule based rollover from CLX4-NYMEX to next contract occurs at 2014-10-20. | 2015-04-07 23:14:28 Date rule based rollover from CLZ4-NYMEX to next contract occurs at 2014-11-19. | 2015-04-07 23:14:28 Date rule based rollover from CLF5-NYMEX to next contract occurs at 2014-12-19. | 2015-04-07 23:14:28 Date rule based rollover from CLG5-NYMEX to next contract occurs at 2015-01-19. | 2015-04-07 23:14:28 Date rule based rollover from CLH5-NYMEX to next contract occurs at 2015-02-19. | 2015-04-07 23:14:28 Date rule based rollover from CLJ5-NYMEX to next contract occurs at 2015-03-19. | 2015-04-07 23:14:28 Date rule based rollover from CLK5-NYMEX to next contract occurs at 2015-04-20. | 2015-04-07 23:14:28 Checking Intraday data file for symbol CLM4-NYMEX for the date range from 2014-04-21 to 2014-05-19. | 2015-04-07 23:14:28 Checking Daily data file for symbol CLM4-NYMEX for the date range from 2014-04-21 to 2014-05-19. | 2015-04-07 23:14:28 Checking Intraday data file for symbol CLN4-NYMEX for the date range from 2014-05-19 to 2014-06-19. | 2015-04-07 23:14:28 Checking Daily data file for symbol CLN4-NYMEX for the date range from 2014-05-19 to 2014-06-19. | 2015-04-07 23:14:28 Checking Intraday data file for symbol CLQ4-NYMEX for the date range from 2014-06-19 to 2014-07-21. | 2015-04-07 23:14:28 Checking Daily data file for symbol CLQ4-NYMEX for the date range from 2014-06-19 to 2014-07-21. | 2015-04-07 23:14:28 Checking Intraday data file for symbol CLU4-NYMEX for the date range from 2014-07-21 to 2014-08-19. | 2015-04-07 23:14:28 Checking Daily data file for symbol CLU4-NYMEX for the date range from 2014-07-21 to 2014-08-19. | 2015-04-07 23:14:28 Checking Intraday data file for symbol CLV4-NYMEX for the date range from 2014-08-19 to 2014-09-19. | 2015-04-07 23:14:28 Checking Daily data file for symbol CLV4-NYMEX for the date range from 2014-08-19 to 2014-09-19. | 2015-04-07 23:14:28 Checking Intraday data file for symbol CLX4-NYMEX for the date range from 2014-09-19 to 2014-10-20. | 2015-04-07 23:14:28 Checking Daily data file for symbol CLX4-NYMEX for the date range from 2014-09-19 to 2014-10-20. | 2015-04-07 23:14:28 Checking Intraday data file for symbol CLZ4-NYMEX for the date range from 2014-10-20 to 2014-11-19. | 2015-04-07 23:14:28 Checking Daily data file for symbol CLZ4-NYMEX for the date range from 2014-10-20 to 2014-11-19. | 2015-04-07 23:14:29 Checking Intraday data file for symbol CLF5-NYMEX for the date range from 2014-11-19 to 2014-12-19. | 2015-04-07 23:14:29 Checking Daily data file for symbol CLF5-NYMEX for the date range from 2014-11-19 to 2014-12-19. | 2015-04-07 23:14:29 Checking Intraday data file for symbol CLG5-NYMEX for the date range from 2014-12-19 to 2015-01-19. | 2015-04-07 23:14:29 Checking Daily data file for symbol CLG5-NYMEX for the date range from 2014-12-19 to 2015-01-19. | 2015-04-07 23:14:29 Checking Intraday data file for symbol CLH5-NYMEX for the date range from 2015-01-19 to 2015-02-19. | 2015-04-07 23:14:29 Checking Daily data file for symbol CLH5-NYMEX for the date range from 2015-01-19 to 2015-02-19. | 2015-04-07 23:14:29 Checking Intraday data file for symbol CLJ5-NYMEX for the date range from 2015-02-19 to 2015-03-19. | 2015-04-07 23:14:29 Checking Daily data file for symbol CLJ5-NYMEX for the date range from 2015-02-19 to 2015-03-19. | 2015-04-07 23:14:29 Checking Intraday data file for symbol CLK5-NYMEX for the date range from 2015-03-19 to 0. | 2015-04-07 23:14:29 Checking Daily data file for symbol CLK5-NYMEX for the date range from 2015-03-19 to 2015-04-07. | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3 | Symbols used for continuous contract chart: | 2015-04-07 23:14:29 CLM4-NYMEX | 2015-04-07 23:14:29 CLN4-NYMEX | 2015-04-07 23:14:29 CLQ4-NYMEX | 2015-04-07 23:14:29 CLU4-NYMEX | 2015-04-07 23:14:29 CLV4-NYMEX | 2015-04-07 23:14:29 CLX4-NYMEX | 2015-04-07 23:14:29 CLZ4-NYMEX | 2015-04-07 23:14:29 CLF5-NYMEX | 2015-04-07 23:14:29 CLG5-NYMEX | 2015-04-07 23:14:29 CLH5-NYMEX | 2015-04-07 23:14:29 CLJ5-NYMEX | 2015-04-07 23:14:29 CLK5-NYMEX | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Checking for volume based rollover dates. | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLM4-NYMEX to CLN4-NYMEX occurs at 2014-05-19 | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLN4-NYMEX to CLQ4-NYMEX occurs at 2014-06-18 | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLQ4-NYMEX to CLU4-NYMEX occurs at 2014-07-18 | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLU4-NYMEX to CLV4-NYMEX occurs at 2014-08-18 | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLV4-NYMEX to CLX4-NYMEX occurs at 2014-09-19 | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLX4-NYMEX to CLZ4-NYMEX occurs at 2014-10-17 | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLZ4-NYMEX to CLF5-NYMEX occurs at 2014-11-18 | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLF5-NYMEX to CLG5-NYMEX occurs at 2014-12-18 | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLG5-NYMEX to CLH5-NYMEX occurs at 2015-01-16 | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLH5-NYMEX to CLJ5-NYMEX occurs at 2015-02-18 | 2015-04-07 23:14:29 CLK5-NYMEX [CV] Renko 6-3-1 #3: Volume based rollover from CLJ5-NYMEX to CLK5-NYMEX occurs at 2015-03-18 | 2015-04-07 23:14:29 Date rule based rollover from 6EU4-CME to next contract occurs at 2014-09-15. | 2015-04-07 23:14:29 Date rule based rollover from 6EZ4-CME to next contract occurs at 2014-12-15. | 2015-04-07 23:14:29 Date rule based rollover from 6EH5-CME to next contract occurs at 2015-03-16. | 2015-04-07 23:14:29 Date rule based rollover from 6EM5-CME to next contract occurs at 2015-06-15. | 2015-04-07 23:14:29 Checking Intraday data file for symbol 6EU4-CME for the date range from 2014-06-16 to 2014-09-15. | 2015-04-07 23:14:29 Checking Intraday data file for symbol 6EZ4-CME for the date range from 2014-09-15 to 2014-12-15. | 2015-04-07 23:14:30 Checking Intraday data file for symbol 6EH5-CME for the date range from 2014-12-15 to 2015-03-16. | 2015-04-07 23:14:30 Checking Intraday data file for symbol 6EM5-CME for the date range from 2015-03-16 to 0. | 2015-04-07 23:14:30 6EM5-CME [C] Renko 8-3-1 #36 | Symbols used for continuous contract chart: | 2015-04-07 23:14:30 6EU4-CME | 2015-04-07 23:14:30 6EZ4-CME | 2015-04-07 23:14:30 6EH5-CME | 2015-04-07 23:14:30 6EM5-CME | 2015-04-07 23:14:30 Files to Open on Start up | Opening file: SPX -NAFTA-DOW-BAKAR.cht | 2015-04-07 23:14:30 Date rule based rollover from TF FMU0008!-NYBOT to next contract occurs at 2008-09-11. | 2015-04-07 23:14:30 Date rule based rollover from TF FMZ0008!-NYBOT to next contract occurs at 2008-12-11. | 2015-04-07 23:14:30 Date rule based rollover from TF FMH0009!-NYBOT to next contract occurs at 2009-03-12. | 2015-04-07 23:14:30 Date rule based rollover from TF FMM0009!-NYBOT to next contract occurs at 2009-06-11. | 2015-04-07 23:14:30 Date rule based rollover from TF FMU0009!-NYBOT to next contract occurs at 2009-09-10. | 2015-04-07 23:14:30 Date rule based rollover from TF FMZ0009!-NYBOT to next contract occurs at 2009-12-10. | 2015-04-07 23:14:30 Date rule based rollover from TF FMH0010!-NYBOT to next contract occurs at 2010-03-11. | 2015-04-07 23:14:30 Date rule based rollover from TF FMM0010!-NYBOT to next contract occurs at 2010-06-10. | 2015-04-07 23:14:30 Date rule based rollover from TF FMU0010!-NYBOT to next contract occurs at 2010-09-09. | 2015-04-07 23:14:30 Date rule based rollover from TF FMZ0010!-NYBOT to next contract occurs at 2010-12-09. | 2015-04-07 23:14:30 Date rule based rollover from TF FMH0011!-NYBOT to next contract occurs at 2011-03-10. | 2015-04-07 23:14:30 Date rule based rollover from TF FMM0011!-NYBOT to next contract occurs at 2011-06-09. | 2015-04-07 23:14:30 Date rule based rollover from TF FMU0011!-NYBOT to next contract occurs at 2011-09-08. | 2015-04-07 23:14:30 Date rule based rollover from TF FMZ0011!-NYBOT to next contract occurs at 2011-12-08. | 2015-04-07 23:14:30 Date rule based rollover from TF FMH0012!-NYBOT to next contract occurs at 2012-03-08. | 2015-04-07 23:14:30 Date rule based rollover from TF FMM0012!-NYBOT to next contract occurs at 2012-06-07. | 2015-04-07 23:14:30 Date rule based rollover from TF FMU0012!-NYBOT to next contract occurs at 2012-09-13. | 2015-04-07 23:14:30 Date rule based rollover from TF FMZ0012!-NYBOT to next contract occurs at 2012-12-13. | 2015-04-07 23:14:30 Date rule based rollover from TF FMH0013!-NYBOT to next contract occurs at 2013-03-07. | 2015-04-07 23:14:30 Date rule based rollover from TF FMM0013!-NYBOT to next contract occurs at 2013-06-13. | 2015-04-07 23:14:30 Date rule based rollover from TF FMU0013!-NYBOT to next contract occurs at 2013-09-12. | 2015-04-07 23:14:30 Date rule based rollover from TF FMZ0013!-NYBOT to next contract occurs at 2013-12-12. | 2015-04-07 23:14:30 Date rule based rollover from TF FMH0014!-NYBOT to next contract occurs at 2014-03-13. | 2015-04-07 23:14:30 Date rule based rollover from TF FMM0014!-NYBOT to next contract occurs at 2014-06-12. | 2015-04-07 23:14:30 Date rule based rollover from TF FMU0014!-NYBOT to next contract occurs at 2014-09-11. | 2015-04-07 23:14:30 Date rule based rollover from TF FMZ0014!-NYBOT to next contract occurs at 2014-12-11. | 2015-04-07 23:14:30 Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-04-07 23:14:30 Date rule based rollover from TF FMM0015!-NYBOT to next contract occurs at 2015-06-11. | 2015-04-07 23:14:30 Intraday data file for TF FMU0008!-NYBOT exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:30 Intraday data file for TF FMZ0008!-NYBOT exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:30 Checking Intraday data file for symbol TF FMH0009!-NYBOT for the date range from 2008-12-11 to 2009-03-12. | 2015-04-07 23:14:30 Checking Intraday data file for symbol TF FMM0009!-NYBOT for the date range from 2009-03-12 to 2009-06-11. | 2015-04-07 23:14:30 Checking Intraday data file for symbol TF FMU0009!-NYBOT for the date range from 2009-06-11 to 2009-09-10. | 2015-04-07 23:14:30 Checking Intraday data file for symbol TF FMZ0009!-NYBOT for the date range from 2009-09-10 to 2009-12-10. | 2015-04-07 23:14:30 Checking Intraday data file for symbol TF FMH0010!-NYBOT for the date range from 2009-12-10 to 2010-03-11. | 2015-04-07 23:14:31 Checking Intraday data file for symbol TF FMM0010!-NYBOT for the date range from 2010-03-11 to 2010-06-10. | 2015-04-07 23:14:31 Checking Intraday data file for symbol TF FMU0010!-NYBOT for the date range from 2010-06-10 to 2010-09-09. | 2015-04-07 23:14:31 Checking Intraday data file for symbol TF FMZ0010!-NYBOT for the date range from 2010-09-09 to 2010-12-09. | 2015-04-07 23:14:31 Checking Intraday data file for symbol TF FMH0011!-NYBOT for the date range from 2010-12-09 to 2011-03-10. | 2015-04-07 23:14:31 Checking Intraday data file for symbol TF FMM0011!-NYBOT for the date range from 2011-03-10 to 2011-06-09. | 2015-04-07 23:14:31 Checking Intraday data file for symbol TF FMU0011!-NYBOT for the date range from 2011-06-09 to 2011-09-08. | 2015-04-07 23:14:31 Checking Intraday data file for symbol TF FMZ0011!-NYBOT for the date range from 2011-09-08 to 2011-12-08. | 2015-04-07 23:14:31 Checking Intraday data file for symbol TF FMH0012!-NYBOT for the date range from 2011-12-08 to 2012-03-08. | 2015-04-07 23:14:32 Checking Intraday data file for symbol TF FMM0012!-NYBOT for the date range from 2012-03-08 to 2012-06-07. | 2015-04-07 23:14:32 Checking Intraday data file for symbol TF FMU0012!-NYBOT for the date range from 2012-06-07 to 2012-09-13. | 2015-04-07 23:14:32 Checking Intraday data file for symbol TF FMZ0012!-NYBOT for the date range from 2012-09-13 to 2012-12-13. | 2015-04-07 23:14:32 Checking Intraday data file for symbol TF FMH0013!-NYBOT for the date range from 2012-12-13 to 2013-03-07. | 2015-04-07 23:14:32 Checking Intraday data file for symbol TF FMM0013!-NYBOT for the date range from 2013-03-07 to 2013-06-13. | 2015-04-07 23:14:32 Checking Intraday data file for symbol TF FMU0013!-NYBOT for the date range from 2013-06-13 to 2013-09-12. | 2015-04-07 23:14:32 Checking Intraday data file for symbol TF FMZ0013!-NYBOT for the date range from 2013-09-12 to 2013-12-12. | 2015-04-07 23:14:33 Checking Intraday data file for symbol TF FMH0014!-NYBOT for the date range from 2013-12-12 to 2014-03-13. | 2015-04-07 23:14:33 Checking Intraday data file for symbol TF FMM0014!-NYBOT for the date range from 2014-03-13 to 2014-06-12. | 2015-04-07 23:14:33 Checking Intraday data file for symbol TF FMU0014!-NYBOT for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:14:33 Checking Intraday data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:14:33 Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:33 Checking Intraday data file for symbol TF FMM0015!-NYBOT for the date range from 2015-03-12 to 0. | 2015-04-07 23:14:33 TF FMM0015!-NYBOT [C] 60 Min #20 | Symbols used for continuous contract chart: | 2015-04-07 23:14:33 TF FMU0008!-NYBOT | 2015-04-07 23:14:33 TF FMZ0008!-NYBOT | 2015-04-07 23:14:33 TF FMH0009!-NYBOT | 2015-04-07 23:14:33 TF FMM0009!-NYBOT | 2015-04-07 23:14:33 TF FMU0009!-NYBOT | 2015-04-07 23:14:33 TF FMZ0009!-NYBOT | 2015-04-07 23:14:33 TF FMH0010!-NYBOT | 2015-04-07 23:14:33 TF FMM0010!-NYBOT | 2015-04-07 23:14:33 TF FMU0010!-NYBOT | 2015-04-07 23:14:33 TF FMZ0010!-NYBOT | 2015-04-07 23:14:33 TF FMH0011!-NYBOT | 2015-04-07 23:14:33 TF FMM0011!-NYBOT | 2015-04-07 23:14:33 TF FMU0011!-NYBOT | 2015-04-07 23:14:33 TF FMZ0011!-NYBOT | 2015-04-07 23:14:33 TF FMH0012!-NYBOT | 2015-04-07 23:14:33 TF FMM0012!-NYBOT | 2015-04-07 23:14:33 TF FMU0012!-NYBOT | 2015-04-07 23:14:33 TF FMZ0012!-NYBOT | 2015-04-07 23:14:33 TF FMH0013!-NYBOT | 2015-04-07 23:14:33 TF FMM0013!-NYBOT | 2015-04-07 23:14:33 TF FMU0013!-NYBOT | 2015-04-07 23:14:33 TF FMZ0013!-NYBOT | 2015-04-07 23:14:33 TF FMH0014!-NYBOT | 2015-04-07 23:14:33 TF FMM0014!-NYBOT | 2015-04-07 23:14:33 TF FMU0014!-NYBOT | 2015-04-07 23:14:33 TF FMZ0014!-NYBOT | 2015-04-07 23:14:33 TF FMH0015!-NYBOT | 2015-04-07 23:14:33 TF FMM0015!-NYBOT | 2015-04-07 23:14:33 Date rule based rollover from YMU4-CBOT to next contract occurs at 2014-09-11. | 2015-04-07 23:14:33 Date rule based rollover from YMZ4-CBOT to next contract occurs at 2014-12-11. | 2015-04-07 23:14:33 Date rule based rollover from YMH5-CBOT to next contract occurs at 2015-03-12. | 2015-04-07 23:14:33 Date rule based rollover from YMM5-CBOT to next contract occurs at 2015-06-11. | 2015-04-07 23:14:33 Checking Intraday data file for symbol YMU4-CBOT for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:14:33 Checking Daily data file for symbol YMU4-CBOT for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:14:33 Checking Intraday data file for symbol YMZ4-CBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:14:34 Checking Daily data file for symbol YMZ4-CBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:14:34 Checking Intraday data file for symbol YMH5-CBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:34 Checking Daily data file for symbol YMH5-CBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:34 Checking Intraday data file for symbol YMM5-CBOT for the date range from 2015-03-12 to 0. | 2015-04-07 23:14:34 Checking Daily data file for symbol YMM5-CBOT for the date range from 2015-03-12 to 2015-04-07. | 2015-04-07 23:14:34 YMM5-CBOT [CV] 240 Min #11 | Symbols used for continuous contract chart: | 2015-04-07 23:14:34 YMU4-CBOT | 2015-04-07 23:14:34 YMZ4-CBOT | 2015-04-07 23:14:34 YMH5-CBOT | 2015-04-07 23:14:34 YMM5-CBOT | 2015-04-07 23:14:34 YMM5-CBOT [CV] 240 Min #11: Checking for volume based rollover dates. | 2015-04-07 23:14:34 YMM5-CBOT [CV] 240 Min #11: Volume based rollover from YMU4-CBOT to YMZ4-CBOT occurs at 2014-09-12 | 2015-04-07 23:14:34 YMM5-CBOT [CV] 240 Min #11: Volume based rollover from YMZ4-CBOT to YMH5-CBOT occurs at 2014-12-12 | 2015-04-07 23:14:34 YMM5-CBOT [CV] 240 Min #11: Volume based rollover from YMH5-CBOT to YMM5-CBOT occurs at 2015-03-13 | 2015-04-07 23:14:34 Date rule based rollover from NQH5-CME to next contract occurs at 2015-03-12. | 2015-04-07 23:14:34 Date rule based rollover from NQM5-CME to next contract occurs at 2015-06-11. | 2015-04-07 23:14:34 Checking Intraday data file for symbol NQH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:34 Checking Daily data file for symbol NQH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:34 Checking Intraday data file for symbol NQM5-CME for the date range from 2015-03-12 to 0. | 2015-04-07 23:14:34 Checking Daily data file for symbol NQM5-CME for the date range from 2015-03-12 to 2015-04-07. | 2015-04-07 23:14:34 NQM5-CME [CV] 60 Min #25 | Symbols used for continuous contract chart: | 2015-04-07 23:14:34 NQH5-CME | 2015-04-07 23:14:34 NQM5-CME | 2015-04-07 23:14:34 NQM5-CME [CV] 60 Min #25: Checking for volume based rollover dates. | 2015-04-07 23:14:34 NQM5-CME [CV] 60 Min #25: Volume based rollover from NQH5-CME to NQM5-CME occurs at 2015-03-13 | 2015-04-07 23:14:34 Limiting the number of years back for the continuous futures chart to 4.9993155. Reason: Single-digit year in symbol. | 2015-04-07 23:14:34 Date rule based rollover from YMM0-CBOT to next contract occurs at 2010-06-10. | 2015-04-07 23:14:34 Date rule based rollover from YMU0-CBOT to next contract occurs at 2010-09-09. | 2015-04-07 23:14:34 Date rule based rollover from YMZ0-CBOT to next contract occurs at 2010-12-09. | 2015-04-07 23:14:34 Date rule based rollover from YMH1-CBOT to next contract occurs at 2011-03-10. | 2015-04-07 23:14:34 Date rule based rollover from YMM1-CBOT to next contract occurs at 2011-06-09. | 2015-04-07 23:14:34 Date rule based rollover from YMU1-CBOT to next contract occurs at 2011-09-08. | 2015-04-07 23:14:34 Date rule based rollover from YMZ1-CBOT to next contract occurs at 2011-12-08. | 2015-04-07 23:14:34 Date rule based rollover from YMH2-CBOT to next contract occurs at 2012-03-08. | 2015-04-07 23:14:34 Date rule based rollover from YMM2-CBOT to next contract occurs at 2012-06-07. | 2015-04-07 23:14:34 Date rule based rollover from YMU2-CBOT to next contract occurs at 2012-09-13. | 2015-04-07 23:14:34 Date rule based rollover from YMZ2-CBOT to next contract occurs at 2012-12-13. | 2015-04-07 23:14:34 Date rule based rollover from YMH3-CBOT to next contract occurs at 2013-03-07. | 2015-04-07 23:14:34 Date rule based rollover from YMM3-CBOT to next contract occurs at 2013-06-13. | 2015-04-07 23:14:34 Date rule based rollover from YMU3-CBOT to next contract occurs at 2013-09-12. | 2015-04-07 23:14:34 Date rule based rollover from YMZ3-CBOT to next contract occurs at 2013-12-12. | 2015-04-07 23:14:34 Date rule based rollover from YMH4-CBOT to next contract occurs at 2014-03-13. | 2015-04-07 23:14:34 Date rule based rollover from YMM4-CBOT to next contract occurs at 2014-06-12. | 2015-04-07 23:14:34 Date rule based rollover from YMU4-CBOT to next contract occurs at 2014-09-11. | 2015-04-07 23:14:34 Date rule based rollover from YMZ4-CBOT to next contract occurs at 2014-12-11. | 2015-04-07 23:14:34 Date rule based rollover from YMH5-CBOT to next contract occurs at 2015-03-12. | 2015-04-07 23:14:34 Date rule based rollover from YMM5-CBOT to next contract occurs at 2015-06-11. | 2015-04-07 23:14:34 Checking Daily data file for symbol YMM0-CBOT for the date range from 2010-03-11 to 2010-06-10. | 2015-04-07 23:14:34 Checking Daily data file for symbol YMU0-CBOT for the date range from 2010-06-10 to 2010-09-09. | 2015-04-07 23:14:34 Checking Daily data file for symbol YMZ0-CBOT for the date range from 2010-09-09 to 2010-12-09. | 2015-04-07 23:14:34 Checking Daily data file for symbol YMH1-CBOT for the date range from 2010-12-09 to 2011-03-10. | 2015-04-07 23:14:35 Checking Daily data file for symbol YMM1-CBOT for the date range from 2011-03-10 to 2011-06-09. | 2015-04-07 23:14:35 Checking Daily data file for symbol YMU1-CBOT for the date range from 2011-06-09 to 2011-09-08. | 2015-04-07 23:14:35 Checking Daily data file for symbol YMZ1-CBOT for the date range from 2011-09-08 to 2011-12-08. | 2015-04-07 23:14:35 Checking Daily data file for symbol YMH2-CBOT for the date range from 2011-12-08 to 2012-03-08. | 2015-04-07 23:14:35 Checking Daily data file for symbol YMM2-CBOT for the date range from 2012-03-08 to 2012-06-07. | 2015-04-07 23:14:36 Checking Daily data file for symbol YMU2-CBOT for the date range from 2012-06-07 to 2012-09-13. | 2015-04-07 23:14:36 Checking Daily data file for symbol YMZ2-CBOT for the date range from 2012-09-13 to 2012-12-13. | 2015-04-07 23:14:36 Checking Daily data file for symbol YMH3-CBOT for the date range from 2012-12-13 to 2013-03-07. | 2015-04-07 23:14:36 Checking Daily data file for symbol YMM3-CBOT for the date range from 2013-03-07 to 2013-06-13. | 2015-04-07 23:14:36 Checking Daily data file for symbol YMU3-CBOT for the date range from 2013-06-13 to 2013-09-12. | 2015-04-07 23:14:36 Checking Daily data file for symbol YMZ3-CBOT for the date range from 2013-09-12 to 2013-12-12. | 2015-04-07 23:14:36 Checking Daily data file for symbol YMH4-CBOT for the date range from 2013-12-12 to 2014-03-13. | 2015-04-07 23:14:36 Checking Daily data file for symbol YMM4-CBOT for the date range from 2014-03-13 to 2014-06-12. | 2015-04-07 23:14:37 Checking Daily data file for symbol YMU4-CBOT for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:14:37 Checking Daily data file for symbol YMZ4-CBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:14:37 Checking Daily data file for symbol YMH5-CBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:37 Checking Daily data file for symbol YMM5-CBOT for the date range from 2015-03-12 to 2015-04-07. | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27 | Symbols used for continuous contract chart: | 2015-04-07 23:14:37 YMM0-CBOT | 2015-04-07 23:14:37 YMU0-CBOT | 2015-04-07 23:14:37 YMZ0-CBOT | 2015-04-07 23:14:37 YMH1-CBOT | 2015-04-07 23:14:37 YMM1-CBOT | 2015-04-07 23:14:37 YMU1-CBOT | 2015-04-07 23:14:37 YMZ1-CBOT | 2015-04-07 23:14:37 YMH2-CBOT | 2015-04-07 23:14:37 YMM2-CBOT | 2015-04-07 23:14:37 YMU2-CBOT | 2015-04-07 23:14:37 YMZ2-CBOT | 2015-04-07 23:14:37 YMH3-CBOT | 2015-04-07 23:14:37 YMM3-CBOT | 2015-04-07 23:14:37 YMU3-CBOT | 2015-04-07 23:14:37 YMZ3-CBOT | 2015-04-07 23:14:37 YMH4-CBOT | 2015-04-07 23:14:37 YMM4-CBOT | 2015-04-07 23:14:37 YMU4-CBOT | 2015-04-07 23:14:37 YMZ4-CBOT | 2015-04-07 23:14:37 YMH5-CBOT | 2015-04-07 23:14:37 YMM5-CBOT | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Checking for volume based rollover dates. | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMM0-CBOT to YMU0-CBOT occurs at 2010-06-11 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMU0-CBOT to YMZ0-CBOT occurs at 2010-09-10 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMZ0-CBOT to YMH1-CBOT occurs at 2010-12-10 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMH1-CBOT to YMM1-CBOT occurs at 2011-03-11 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMM1-CBOT to YMU1-CBOT occurs at 2011-06-10 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMU1-CBOT to YMZ1-CBOT occurs at 2011-09-09 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMZ1-CBOT to YMH2-CBOT occurs at 2011-12-09 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMH2-CBOT to YMM2-CBOT occurs at 2012-03-09 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMM2-CBOT to YMU2-CBOT occurs at 2012-06-08 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMU2-CBOT to YMZ2-CBOT occurs at 2012-09-14 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMZ2-CBOT to YMH3-CBOT occurs at 2012-12-14 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMH3-CBOT to YMM3-CBOT occurs at 2013-03-08 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMM3-CBOT to YMU3-CBOT occurs at 2013-06-14 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMU3-CBOT to YMZ3-CBOT occurs at 2013-09-13 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMZ3-CBOT to YMH4-CBOT occurs at 2013-12-13 | 2015-04-07 23:14:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMH4-CBOT to YMM4-CBOT occurs at 2014-03-14 | 2015-04-07 23:14:38 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMM4-CBOT to YMU4-CBOT occurs at 2014-06-13 | 2015-04-07 23:14:38 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMU4-CBOT to YMZ4-CBOT occurs at 2014-09-12 | 2015-04-07 23:14:38 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMZ4-CBOT to YMH5-CBOT occurs at 2014-12-12 | 2015-04-07 23:14:38 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMH5-CBOT to YMM5-CBOT occurs at 2015-03-13 | 2015-04-07 23:14:38 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-04-07 23:14:38 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-04-07 23:14:38 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-04-07 23:14:38 Date rule based rollover from ESM5-CME to next contract occurs at 2015-06-11. | 2015-04-07 23:14:38 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:14:38 Checking Daily data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:14:38 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:14:38 Checking Daily data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:14:39 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:39 Checking Daily data file for symbol ESH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:14:39 Checking Intraday data file for symbol ESM5-CME for the date range from 2015-03-12 to 0. | 2015-04-07 23:14:40 Checking Daily data file for symbol ESM5-CME for the date range from 2015-03-12 to 2015-04-07. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2 | Symbols used for continuous contract chart: | 2015-04-07 23:14:40 ESU4-CME | 2015-04-07 23:14:40 ESZ4-CME | 2015-04-07 23:14:40 ESH5-CME | 2015-04-07 23:14:40 ESM5-CME | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: Checking for volume based rollover dates. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: Volume based rollover from ESZ4-CME to ESH5-CME occurs at 2014-12-12 | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: Volume based rollover from ESH5-CME to ESM5-CME occurs at 2015-03-13 | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: Performing continuous futures contract back adjustment calculations. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: ESU4-CME Open price on 2014-09-12 is 1999.25. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: ESZ4-CME Open price on 2014-09-12 is 1991.25. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: ESU4-CME price difference to ESZ4-CME is -8. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: ESZ4-CME Open price on 2014-12-12 is 2029.5. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: ESH5-CME Open price on 2014-12-12 is 2022.5. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: ESZ4-CME price difference to ESH5-CME is -7. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: ESH5-CME Open price on 2015-03-13 is 2064.25. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: ESM5-CME Open price on 2015-03-13 is 2056.5. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: ESH5-CME price difference to ESM5-CME is -7.75. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: Back adjust amount for symbol ESU4-CME is -22.75. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: Back adjust amount for symbol ESZ4-CME is -14.75. | 2015-04-07 23:14:40 ESM5-CME [CBV] 480 Min #2: Back adjust amount for symbol ESH5-CME is -7.75. | 2015-04-07 23:14:40 Date rule based rollover from SB FMV0014!-NYBOT to next contract occurs at 2014-09-29. | 2015-04-07 23:14:40 Date rule based rollover from SB FMH0015!-NYBOT to next contract occurs at 2015-02-26. | 2015-04-07 23:14:40 Date rule based rollover from SB FMK0015!-NYBOT to next contract occurs at 2015-04-29. | 2015-04-07 23:14:40 Date rule based rollover from SB FMN0015!-NYBOT to next contract occurs at 2015-06-29. | 2015-04-07 23:14:40 Checking Intraday data file for symbol SB FMV0014!-NYBOT for the date range from 2014-06-27 to 2014-09-29. | 2015-04-07 23:14:41 Checking Daily data file for symbol SB FMV0014!-NYBOT for the date range from 2014-06-27 to 2014-09-29. | 2015-04-07 23:14:41 Checking Intraday data file for symbol SB FMH0015!-NYBOT for the date range from 2014-09-29 to 2015-02-26. | 2015-04-07 23:14:41 Checking Daily data file for symbol SB FMH0015!-NYBOT for the date range from 2014-09-29 to 2015-02-26. | 2015-04-07 23:14:41 Checking Intraday data file for symbol SB FMK0015!-NYBOT for the date range from 2015-02-26 to 2015-04-07. | 2015-04-07 23:14:41 Checking Daily data file for symbol SB FMK0015!-NYBOT for the date range from 2015-02-26 to 2015-04-07. | 2015-04-07 23:14:41 Checking Intraday data file for symbol SB FMN0015!-NYBOT for the date range from 2015-04-07 to 0. | 2015-04-07 23:14:41 Checking Daily data file for symbol SB FMN0015!-NYBOT for the date range from 2015-04-07 to 2015-04-07. | 2015-04-07 23:14:41 SB FMN0015!-NYBOT [CBV] 60 Min #6 | Symbols used for continuous contract chart: | 2015-04-07 23:14:41 SB FMV0014!-NYBOT | 2015-04-07 23:14:41 SB FMH0015!-NYBOT | 2015-04-07 23:14:41 SB FMK0015!-NYBOT | 2015-04-07 23:14:41 SB FMN0015!-NYBOT | 2015-04-07 23:14:41 SB FMN0015!-NYBOT [CBV] 60 Min #6: Checking for volume based rollover dates. | 2015-04-07 23:14:41 SB FMN0015!-NYBOT [CBV] 60 Min #6: Volume based rollover from SB FMV0014!-NYBOT to SB FMH0015!-NYBOT occurs at 2014-09-18 | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: Volume based rollover from SB FMH0015!-NYBOT to SB FMK0015!-NYBOT occurs at 2015-02-10 | 2015-04-07 23:14:42 Unable to determine transition date based on volume from files: SB FMK0015!-NYBOT.dly, SB FMN0015!-NYBOT.dly | 2015-04-07 23:14:42 * The SB FMN0015!-NYBOT.dly symbol may not be the active contract month. | 2015-04-07 23:14:42 * SB FMN0015!-NYBOT [CBV] 60 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: SB FMV0014!-NYBOT Open price on 2014-09-18 is 13.94. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: SB FMH0015!-NYBOT Open price on 2014-09-18 is 16.25. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: SB FMV0014!-NYBOT price difference to SB FMH0015!-NYBOT is 2.3099999. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: SB FMH0015!-NYBOT Open price on 2015-02-10 is 14.82. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: SB FMK0015!-NYBOT Open price on 2015-02-10 is 14.85. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: SB FMH0015!-NYBOT price difference to SB FMK0015!-NYBOT is 0.029999999. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: SB FMK0015!-NYBOT Open price on 2015-04-07 is 12.54. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: SB FMN0015!-NYBOT Open price on 2015-04-07 is 12.63. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: SB FMK0015!-NYBOT price difference to SB FMN0015!-NYBOT is 0.090000004. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: Back adjust amount for symbol SB FMV0014!-NYBOT is 2.4299998. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: Back adjust amount for symbol SB FMH0015!-NYBOT is 0.12. | 2015-04-07 23:14:42 SB FMN0015!-NYBOT [CBV] 60 Min #6: Back adjust amount for symbol SB FMK0015!-NYBOT is 0.090000004. | 2015-04-07 23:14:42 Date rule based rollover from DX FMM0012!-NYBOT to next contract occurs at 2012-06-15. | 2015-04-07 23:14:42 Date rule based rollover from DX FMU0012!-NYBOT to next contract occurs at 2012-09-14. | 2015-04-07 23:14:42 Date rule based rollover from DX FMZ0012!-NYBOT to next contract occurs at 2012-12-14. | 2015-04-07 23:14:42 Date rule based rollover from DX FMH0013!-NYBOT to next contract occurs at 2013-03-15. | 2015-04-07 23:14:42 Date rule based rollover from DX FMM0013!-NYBOT to next contract occurs at 2013-06-14. | 2015-04-07 23:14:42 Date rule based rollover from DX FMU0013!-NYBOT to next contract occurs at 2013-09-13. | 2015-04-07 23:14:42 Date rule based rollover from DX FMZ0013!-NYBOT to next contract occurs at 2013-12-13. | 2015-04-07 23:14:42 Date rule based rollover from DX FMH0014!-NYBOT to next contract occurs at 2014-03-14. | 2015-04-07 23:14:42 Date rule based rollover from DX FMM0014!-NYBOT to next contract occurs at 2014-06-13. | 2015-04-07 23:14:42 Date rule based rollover from DX FMU0014!-NYBOT to next contract occurs at 2014-09-12. | 2015-04-07 23:14:42 Date rule based rollover from DX FMZ0014!-NYBOT to next contract occurs at 2014-12-12. | 2015-04-07 23:14:42 Date rule based rollover from DX FMH0015!-NYBOT to next contract occurs at 2015-03-13. | 2015-04-07 23:14:42 Date rule based rollover from DX FMM0015!-NYBOT to next contract occurs at 2015-06-12. | 2015-04-07 23:14:42 Checking Daily data file for symbol DX FMM0012!-NYBOT for the date range from 2012-03-16 to 2012-06-15. | 2015-04-07 23:14:42 Checking Daily data file for symbol DX FMU0012!-NYBOT for the date range from 2012-06-15 to 2012-09-14. | 2015-04-07 23:14:43 Checking Daily data file for symbol DX FMZ0012!-NYBOT for the date range from 2012-09-14 to 2012-12-14. | 2015-04-07 23:14:43 Checking Daily data file for symbol DX FMH0013!-NYBOT for the date range from 2012-12-14 to 2013-03-15. | 2015-04-07 23:14:43 Checking Daily data file for symbol DX FMM0013!-NYBOT for the date range from 2013-03-15 to 2013-06-14. | 2015-04-07 23:14:43 Checking Daily data file for symbol DX FMU0013!-NYBOT for the date range from 2013-06-14 to 2013-09-13. | 2015-04-07 23:14:43 Checking Daily data file for symbol DX FMZ0013!-NYBOT for the date range from 2013-09-13 to 2013-12-13. | 2015-04-07 23:14:43 Checking Daily data file for symbol DX FMH0014!-NYBOT for the date range from 2013-12-13 to 2014-03-14. | 2015-04-07 23:14:43 Checking Daily data file for symbol DX FMM0014!-NYBOT for the date range from 2014-03-14 to 2014-06-13. | 2015-04-07 23:14:43 Checking Daily data file for symbol DX FMU0014!-NYBOT for the date range from 2014-06-13 to 2014-09-12. | 2015-04-07 23:14:43 Checking Daily data file for symbol DX FMZ0014!-NYBOT for the date range from 2014-09-12 to 2014-12-12. | 2015-04-07 23:14:44 Checking Daily data file for symbol DX FMH0015!-NYBOT for the date range from 2014-12-12 to 2015-03-13. | 2015-04-07 23:14:44 Checking Daily data file for symbol DX FMM0015!-NYBOT for the date range from 2015-03-13 to 2015-04-07. | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1 | Symbols used for continuous contract chart: | 2015-04-07 23:14:44 DX FMM0012!-NYBOT | 2015-04-07 23:14:44 DX FMU0012!-NYBOT | 2015-04-07 23:14:44 DX FMZ0012!-NYBOT | 2015-04-07 23:14:44 DX FMH0013!-NYBOT | 2015-04-07 23:14:44 DX FMM0013!-NYBOT | 2015-04-07 23:14:44 DX FMU0013!-NYBOT | 2015-04-07 23:14:44 DX FMZ0013!-NYBOT | 2015-04-07 23:14:44 DX FMH0014!-NYBOT | 2015-04-07 23:14:44 DX FMM0014!-NYBOT | 2015-04-07 23:14:44 DX FMU0014!-NYBOT | 2015-04-07 23:14:44 DX FMZ0014!-NYBOT | 2015-04-07 23:14:44 DX FMH0015!-NYBOT | 2015-04-07 23:14:44 DX FMM0015!-NYBOT | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Checking for volume based rollover dates. | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMM0012!-NYBOT to DX FMU0012!-NYBOT occurs at 2012-06-15 | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMU0012!-NYBOT to DX FMZ0012!-NYBOT occurs at 2012-09-14 | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMZ0012!-NYBOT to DX FMH0013!-NYBOT occurs at 2012-12-13 | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMH0013!-NYBOT to DX FMM0013!-NYBOT occurs at 2013-03-14 | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMM0013!-NYBOT to DX FMU0013!-NYBOT occurs at 2013-06-13 | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMU0013!-NYBOT to DX FMZ0013!-NYBOT occurs at 2013-09-12 | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMZ0013!-NYBOT to DX FMH0014!-NYBOT occurs at 2013-12-12 | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMH0014!-NYBOT to DX FMM0014!-NYBOT occurs at 2014-03-13 | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMM0014!-NYBOT to DX FMU0014!-NYBOT occurs at 2014-06-12 | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMU0014!-NYBOT to DX FMZ0014!-NYBOT occurs at 2014-09-11 | 2015-04-07 23:14:44 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMZ0014!-NYBOT to DX FMH0015!-NYBOT occurs at 2014-12-11 | 2015-04-07 23:14:45 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMH0015!-NYBOT to DX FMM0015!-NYBOT occurs at 2015-03-12 | 2015-04-07 23:14:45 M6EM5-CME [CV] Renko 5-3-3 #12: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2015-04-07 23:14:45 M6EM5-CME [CV] Renko 5-3-3 #12: There are no continuous futures contract symbols. Loading data normally. | 2015-04-07 23:14:45 Files to Open on Start up | Opening file: DAX.cht | 2015-04-07 23:14:46 Limiting the number of years back for the continuous futures chart to 5.0924025. Reason: Account limitation. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0310-EUREX to next contract occurs at 2010-03-19. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0610-EUREX to next contract occurs at 2010-06-18. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0910-EUREX to next contract occurs at 2010-09-17. | 2015-04-07 23:14:46 Date rule based rollover from FDAX1210-EUREX to next contract occurs at 2010-12-17. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0311-EUREX to next contract occurs at 2011-03-18. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0611-EUREX to next contract occurs at 2011-06-17. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0911-EUREX to next contract occurs at 2011-09-16. | 2015-04-07 23:14:46 Date rule based rollover from FDAX1211-EUREX to next contract occurs at 2011-12-16. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0312-EUREX to next contract occurs at 2012-03-16. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0612-EUREX to next contract occurs at 2012-06-15. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0912-EUREX to next contract occurs at 2012-09-21. | 2015-04-07 23:14:46 Date rule based rollover from FDAX1212-EUREX to next contract occurs at 2012-12-21. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0313-EUREX to next contract occurs at 2013-03-15. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0613-EUREX to next contract occurs at 2013-06-21. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0913-EUREX to next contract occurs at 2013-09-20. | 2015-04-07 23:14:46 Date rule based rollover from FDAX1213-EUREX to next contract occurs at 2013-12-20. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0314-EUREX to next contract occurs at 2014-03-21. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0614-EUREX to next contract occurs at 2014-06-20. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0914-EUREX to next contract occurs at 2014-09-19. | 2015-04-07 23:14:46 Date rule based rollover from FDAX1214-EUREX to next contract occurs at 2014-12-19. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0315-EUREX to next contract occurs at 2015-03-20. | 2015-04-07 23:14:46 Date rule based rollover from FDAX0615-EUREX to next contract occurs at 2015-06-19. | 2015-04-07 23:14:46 Checking Daily data file for symbol FDAX0310-EUREX for the date range from 2009-12-18 to 2010-03-19. | 2015-04-07 23:14:46 Checking Daily data file for symbol FDAX0610-EUREX for the date range from 2010-03-19 to 2010-06-18. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0910-EUREX for the date range from 2010-06-18 to 2010-09-17. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX1210-EUREX for the date range from 2010-09-17 to 2010-12-17. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0311-EUREX for the date range from 2010-12-17 to 2011-03-18. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0611-EUREX for the date range from 2011-03-18 to 2011-06-17. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0911-EUREX for the date range from 2011-06-17 to 2011-09-16. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX1211-EUREX for the date range from 2011-09-16 to 2011-12-16. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0312-EUREX for the date range from 2011-12-16 to 2012-03-16. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0612-EUREX for the date range from 2012-03-16 to 2012-06-15. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0912-EUREX for the date range from 2012-06-15 to 2012-09-21. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX1212-EUREX for the date range from 2012-09-21 to 2012-12-21. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0313-EUREX for the date range from 2012-12-21 to 2013-03-15. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0613-EUREX for the date range from 2013-03-15 to 2013-06-21. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0913-EUREX for the date range from 2013-06-21 to 2013-09-20. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX1213-EUREX for the date range from 2013-09-20 to 2013-12-20. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0314-EUREX for the date range from 2013-12-20 to 2014-03-21. | 2015-04-07 23:14:47 Checking Daily data file for symbol FDAX0614-EUREX for the date range from 2014-03-21 to 2014-06-20. | 2015-04-07 23:14:48 Checking Daily data file for symbol FDAX0914-EUREX for the date range from 2014-06-20 to 2014-09-19. | 2015-04-07 23:14:48 Checking Daily data file for symbol FDAX1214-EUREX for the date range from 2014-09-19 to 2014-12-19. | 2015-04-07 23:14:48 Checking Daily data file for symbol FDAX0315-EUREX for the date range from 2014-12-19 to 2015-03-20. | 2015-04-07 23:14:48 Checking Daily data file for symbol FDAX0615-EUREX for the date range from 2015-03-20 to 2015-04-07. | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8 | Symbols used for continuous contract chart: | 2015-04-07 23:14:48 FDAX0310-EUREX | 2015-04-07 23:14:48 FDAX0610-EUREX | 2015-04-07 23:14:48 FDAX0910-EUREX | 2015-04-07 23:14:48 FDAX1210-EUREX | 2015-04-07 23:14:48 FDAX0311-EUREX | 2015-04-07 23:14:48 FDAX0611-EUREX | 2015-04-07 23:14:48 FDAX0911-EUREX | 2015-04-07 23:14:48 FDAX1211-EUREX | 2015-04-07 23:14:48 FDAX0312-EUREX | 2015-04-07 23:14:48 FDAX0612-EUREX | 2015-04-07 23:14:48 FDAX0912-EUREX | 2015-04-07 23:14:48 FDAX1212-EUREX | 2015-04-07 23:14:48 FDAX0313-EUREX | 2015-04-07 23:14:48 FDAX0613-EUREX | 2015-04-07 23:14:48 FDAX0913-EUREX | 2015-04-07 23:14:48 FDAX1213-EUREX | 2015-04-07 23:14:48 FDAX0314-EUREX | 2015-04-07 23:14:48 FDAX0614-EUREX | 2015-04-07 23:14:48 FDAX0914-EUREX | 2015-04-07 23:14:48 FDAX1214-EUREX | 2015-04-07 23:14:48 FDAX0315-EUREX | 2015-04-07 23:14:48 FDAX0615-EUREX | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Checking for volume based rollover dates. | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0310-EUREX to FDAX0610-EUREX occurs at 2010-03-18 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0610-EUREX to FDAX0910-EUREX occurs at 2010-06-17 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0910-EUREX to FDAX1210-EUREX occurs at 2010-09-16 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX1210-EUREX to FDAX0311-EUREX occurs at 2010-12-16 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0311-EUREX to FDAX0611-EUREX occurs at 2011-03-17 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0611-EUREX to FDAX0911-EUREX occurs at 2011-06-16 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0911-EUREX to FDAX1211-EUREX occurs at 2011-09-15 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX1211-EUREX to FDAX0312-EUREX occurs at 2011-12-15 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0312-EUREX to FDAX0612-EUREX occurs at 2012-03-15 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0612-EUREX to FDAX0912-EUREX occurs at 2012-06-14 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0912-EUREX to FDAX1212-EUREX occurs at 2012-09-21 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX1212-EUREX to FDAX0313-EUREX occurs at 2012-12-20 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0313-EUREX to FDAX0613-EUREX occurs at 2013-03-14 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0613-EUREX to FDAX0913-EUREX occurs at 2013-06-20 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0913-EUREX to FDAX1213-EUREX occurs at 2013-09-19 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX1213-EUREX to FDAX0314-EUREX occurs at 2013-12-19 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0314-EUREX to FDAX0614-EUREX occurs at 2014-03-21 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0614-EUREX to FDAX0914-EUREX occurs at 2014-06-19 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0914-EUREX to FDAX1214-EUREX occurs at 2014-09-18 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX1214-EUREX to FDAX0315-EUREX occurs at 2014-12-18 | 2015-04-07 23:14:48 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0315-EUREX to FDAX0615-EUREX occurs at 2015-03-20 | 2015-04-07 23:14:48 Date rule based rollover from FGBL1213-EUREX to next contract occurs at 2013-12-06. | 2015-04-07 23:14:48 Date rule based rollover from FGBL0314-EUREX to next contract occurs at 2014-03-06. | 2015-04-07 23:14:48 Date rule based rollover from FGBL0614-EUREX to next contract occurs at 2014-06-06. | 2015-04-07 23:14:48 Date rule based rollover from FGBL0914-EUREX to next contract occurs at 2014-09-08. | 2015-04-07 23:14:48 Date rule based rollover from FGBL1214-EUREX to next contract occurs at 2014-12-08. | 2015-04-07 23:14:48 Date rule based rollover from FGBL0315-EUREX to next contract occurs at 2015-03-06. | 2015-04-07 23:14:48 Date rule based rollover from FGBL0615-EUREX to next contract occurs at 2015-06-08. | 2015-04-07 23:14:48 Checking Intraday data file for symbol FGBL1213-EUREX for the date range from 2013-09-06 to 2013-12-06. | 2015-04-07 23:14:48 Checking Daily data file for symbol FGBL1213-EUREX for the date range from 2013-09-06 to 2013-12-06. | 2015-04-07 23:14:49 Checking Intraday data file for symbol FGBL0314-EUREX for the date range from 2013-12-06 to 2014-03-06. | 2015-04-07 23:14:49 Checking Daily data file for symbol FGBL0314-EUREX for the date range from 2013-12-06 to 2014-03-06. | 2015-04-07 23:14:49 Checking Intraday data file for symbol FGBL0614-EUREX for the date range from 2014-03-06 to 2014-06-06. | 2015-04-07 23:14:49 Checking Daily data file for symbol FGBL0614-EUREX for the date range from 2014-03-06 to 2014-06-06. | 2015-04-07 23:14:49 Checking Intraday data file for symbol FGBL0914-EUREX for the date range from 2014-06-06 to 2014-09-08. | 2015-04-07 23:14:50 Checking Daily data file for symbol FGBL0914-EUREX for the date range from 2014-06-06 to 2014-09-08. | 2015-04-07 23:14:50 Checking Intraday data file for symbol FGBL1214-EUREX for the date range from 2014-09-08 to 2014-12-08. | 2015-04-07 23:14:50 Checking Daily data file for symbol FGBL1214-EUREX for the date range from 2014-09-08 to 2014-12-08. | 2015-04-07 23:14:50 Checking Intraday data file for symbol FGBL0315-EUREX for the date range from 2014-12-08 to 2015-03-06. | 2015-04-07 23:14:50 Checking Daily data file for symbol FGBL0315-EUREX for the date range from 2014-12-08 to 2015-03-06. | 2015-04-07 23:14:50 Checking Intraday data file for symbol FGBL0615-EUREX for the date range from 2015-03-06 to 0. | 2015-04-07 23:14:50 Checking Daily data file for symbol FGBL0615-EUREX for the date range from 2015-03-06 to 2015-04-07. | 2015-04-07 23:14:50 FGBL0615-EUREX [CV] Renko 5-3-1 #4 | Symbols used for continuous contract chart: | 2015-04-07 23:14:50 FGBL1213-EUREX | 2015-04-07 23:14:50 FGBL0314-EUREX | 2015-04-07 23:14:50 FGBL0614-EUREX | 2015-04-07 23:14:50 FGBL0914-EUREX | 2015-04-07 23:14:50 FGBL1214-EUREX | 2015-04-07 23:14:50 FGBL0315-EUREX | 2015-04-07 23:14:50 FGBL0615-EUREX | 2015-04-07 23:14:50 FGBL0615-EUREX [CV] Renko 5-3-1 #4: Checking for volume based rollover dates. | 2015-04-07 23:14:50 FGBL0615-EUREX [CV] Renko 5-3-1 #4: Volume based rollover from FGBL1213-EUREX to FGBL0314-EUREX occurs at 2013-12-04 | 2015-04-07 23:14:50 FGBL0615-EUREX [CV] Renko 5-3-1 #4: Volume based rollover from FGBL0314-EUREX to FGBL0614-EUREX occurs at 2014-03-04 | 2015-04-07 23:14:50 FGBL0615-EUREX [CV] Renko 5-3-1 #4: Volume based rollover from FGBL0614-EUREX to FGBL0914-EUREX occurs at 2014-06-04 | 2015-04-07 23:14:51 FGBL0615-EUREX [CV] Renko 5-3-1 #4: Volume based rollover from FGBL0914-EUREX to FGBL1214-EUREX occurs at 2014-09-04 | 2015-04-07 23:14:51 FGBL0615-EUREX [CV] Renko 5-3-1 #4: Volume based rollover from FGBL1214-EUREX to FGBL0315-EUREX occurs at 2014-12-04 | 2015-04-07 23:14:51 FGBL0615-EUREX [CV] Renko 5-3-1 #4: Volume based rollover from FGBL0315-EUREX to FGBL0615-EUREX occurs at 2015-03-04 | 2015-04-07 23:14:51 Date rule based rollover from FDAX0914-EUREX to next contract occurs at 2014-09-19. | 2015-04-07 23:14:51 Date rule based rollover from FDAX1214-EUREX to next contract occurs at 2014-12-19. | 2015-04-07 23:14:51 Date rule based rollover from FDAX0315-EUREX to next contract occurs at 2015-03-20. | 2015-04-07 23:14:51 Date rule based rollover from FDAX0615-EUREX to next contract occurs at 2015-06-19. | 2015-04-07 23:14:51 Checking Intraday data file for symbol FDAX0914-EUREX for the date range from 2014-06-20 to 2014-09-19. | 2015-04-07 23:14:52 Checking Intraday data file for symbol FDAX1214-EUREX for the date range from 2014-09-19 to 2014-12-19. | 2015-04-07 23:14:52 Checking Intraday data file for symbol FDAX0315-EUREX for the date range from 2014-12-19 to 2015-03-20. | 2015-04-07 23:14:52 Checking Intraday data file for symbol FDAX0615-EUREX for the date range from 2015-03-20 to 0. | 2015-04-07 23:14:54 FDAX0615-EUREX [C] Renko 40-25-2 #9 | Symbols used for continuous contract chart: | 2015-04-07 23:14:54 FDAX0914-EUREX | 2015-04-07 23:14:54 FDAX1214-EUREX | 2015-04-07 23:14:54 FDAX0315-EUREX | 2015-04-07 23:14:54 FDAX0615-EUREX | 2015-04-07 23:14:54 Limiting the number of years back for the continuous futures chart to 6.9979466. Reason: 7 years maximum for Intraday charts. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0608-EUREX to next contract occurs at 2008-06-06. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0908-EUREX to next contract occurs at 2008-09-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL1208-EUREX to next contract occurs at 2008-12-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0309-EUREX to next contract occurs at 2009-03-06. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0609-EUREX to next contract occurs at 2009-06-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0909-EUREX to next contract occurs at 2009-09-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL1209-EUREX to next contract occurs at 2009-12-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0310-EUREX to next contract occurs at 2010-03-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0610-EUREX to next contract occurs at 2010-06-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0910-EUREX to next contract occurs at 2010-09-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL1210-EUREX to next contract occurs at 2010-12-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0311-EUREX to next contract occurs at 2011-03-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0611-EUREX to next contract occurs at 2011-06-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0911-EUREX to next contract occurs at 2011-09-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL1211-EUREX to next contract occurs at 2011-12-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0312-EUREX to next contract occurs at 2012-03-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0612-EUREX to next contract occurs at 2012-06-07. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0912-EUREX to next contract occurs at 2012-09-06. | 2015-04-07 23:14:55 Date rule based rollover from FGBL1212-EUREX to next contract occurs at 2012-12-06. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0313-EUREX to next contract occurs at 2013-03-07. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0613-EUREX to next contract occurs at 2013-06-06. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0913-EUREX to next contract occurs at 2013-09-06. | 2015-04-07 23:14:55 Date rule based rollover from FGBL1213-EUREX to next contract occurs at 2013-12-06. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0314-EUREX to next contract occurs at 2014-03-06. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0614-EUREX to next contract occurs at 2014-06-06. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0914-EUREX to next contract occurs at 2014-09-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL1214-EUREX to next contract occurs at 2014-12-08. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0315-EUREX to next contract occurs at 2015-03-06. | 2015-04-07 23:14:55 Date rule based rollover from FGBL0615-EUREX to next contract occurs at 2015-06-08. | 2015-04-07 23:14:55 Intraday data file for FGBL0608-EUREX exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:55 Checking Daily data file for symbol FGBL0608-EUREX for the date range from 2008-03-06 to 2008-06-06. | 2015-04-07 23:14:55 Intraday data file for FGBL0908-EUREX exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:55 Checking Daily data file for symbol FGBL0908-EUREX for the date range from 2008-06-06 to 2008-09-08. | 2015-04-07 23:14:55 Intraday data file for FGBL1208-EUREX exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:55 Checking Daily data file for symbol FGBL1208-EUREX for the date range from 2008-09-08 to 2008-12-08. | 2015-04-07 23:14:55 Intraday data file for FGBL0309-EUREX exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:55 Checking Daily data file for symbol FGBL0309-EUREX for the date range from 2008-12-08 to 2009-03-06. | 2015-04-07 23:14:55 Intraday data file for FGBL0609-EUREX exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:55 Checking Daily data file for symbol FGBL0609-EUREX for the date range from 2009-03-06 to 2009-06-08. | 2015-04-07 23:14:56 Intraday data file for FGBL0909-EUREX exists and is empty. Skipping Intraday data download. | 2015-04-07 23:14:56 Checking Daily data file for symbol FGBL0909-EUREX for the date range from 2009-06-08 to 2009-09-08. | 2015-04-07 23:14:56 Checking Intraday data file for symbol FGBL1209-EUREX for the date range from 2009-09-08 to 2009-12-08. | 2015-04-07 23:14:56 Checking Daily data file for symbol FGBL1209-EUREX for the date range from 2009-09-08 to 2009-12-08. | 2015-04-07 23:14:56 Checking Intraday data file for symbol FGBL0310-EUREX for the date range from 2009-12-08 to 2010-03-08. | 2015-04-07 23:14:56 Checking Daily data file for symbol FGBL0310-EUREX for the date range from 2009-12-08 to 2010-03-08. | 2015-04-07 23:14:56 Checking Intraday data file for symbol FGBL0610-EUREX for the date range from 2010-03-08 to 2010-06-08. | 2015-04-07 23:14:56 Checking Daily data file for symbol FGBL0610-EUREX for the date range from 2010-03-08 to 2010-06-08. | 2015-04-07 23:14:56 Checking Intraday data file for symbol FGBL0910-EUREX for the date range from 2010-06-08 to 2010-09-08. | 2015-04-07 23:14:56 Checking Daily data file for symbol FGBL0910-EUREX for the date range from 2010-06-08 to 2010-09-08. | 2015-04-07 23:14:56 Checking Intraday data file for symbol FGBL1210-EUREX for the date range from 2010-09-08 to 2010-12-08. | 2015-04-07 23:14:56 Checking Daily data file for symbol FGBL1210-EUREX for the date range from 2010-09-08 to 2010-12-08. | 2015-04-07 23:14:57 Checking Intraday data file for symbol FGBL0311-EUREX for the date range from 2010-12-08 to 2011-03-08. | 2015-04-07 23:14:57 Checking Daily data file for symbol FGBL0311-EUREX for the date range from 2010-12-08 to 2011-03-08. | 2015-04-07 23:14:57 Checking Intraday data file for symbol FGBL0611-EUREX for the date range from 2011-03-08 to 2011-06-08. | 2015-04-07 23:14:57 Checking Daily data file for symbol FGBL0611-EUREX for the date range from 2011-03-08 to 2011-06-08. | 2015-04-07 23:14:57 Checking Intraday data file for symbol FGBL0911-EUREX for the date range from 2011-06-08 to 2011-09-08. | 2015-04-07 23:14:57 Checking Daily data file for symbol FGBL0911-EUREX for the date range from 2011-06-08 to 2011-09-08. | 2015-04-07 23:14:57 Checking Intraday data file for symbol FGBL1211-EUREX for the date range from 2011-09-08 to 2011-12-08. | 2015-04-07 23:14:57 Checking Daily data file for symbol FGBL1211-EUREX for the date range from 2011-09-08 to 2011-12-08. | 2015-04-07 23:14:57 Checking Intraday data file for symbol FGBL0312-EUREX for the date range from 2011-12-08 to 2012-03-08. | 2015-04-07 23:14:57 Checking Daily data file for symbol FGBL0312-EUREX for the date range from 2011-12-08 to 2012-03-08. | 2015-04-07 23:14:58 Checking Intraday data file for symbol FGBL0612-EUREX for the date range from 2012-03-08 to 2012-06-07. | 2015-04-07 23:14:58 Checking Daily data file for symbol FGBL0612-EUREX for the date range from 2012-03-08 to 2012-06-07. | 2015-04-07 23:14:58 Checking Intraday data file for symbol FGBL0912-EUREX for the date range from 2012-06-07 to 2012-09-06. | 2015-04-07 23:14:58 Checking Daily data file for symbol FGBL0912-EUREX for the date range from 2012-06-07 to 2012-09-06. | 2015-04-07 23:14:58 Checking Intraday data file for symbol FGBL1212-EUREX for the date range from 2012-09-06 to 2012-12-06. | 2015-04-07 23:14:58 Checking Daily data file for symbol FGBL1212-EUREX for the date range from 2012-09-06 to 2012-12-06. | 2015-04-07 23:14:58 Checking Intraday data file for symbol FGBL0313-EUREX for the date range from 2012-12-06 to 2013-03-07. | 2015-04-07 23:14:58 Checking Daily data file for symbol FGBL0313-EUREX for the date range from 2012-12-06 to 2013-03-07. | 2015-04-07 23:14:58 Checking Intraday data file for symbol FGBL0613-EUREX for the date range from 2013-03-07 to 2013-06-06. | 2015-04-07 23:14:59 Checking Daily data file for symbol FGBL0613-EUREX for the date range from 2013-03-07 to 2013-06-06. | 2015-04-07 23:14:59 Checking Intraday data file for symbol FGBL0913-EUREX for the date range from 2013-06-06 to 2013-09-06. | 2015-04-07 23:14:59 Checking Daily data file for symbol FGBL0913-EUREX for the date range from 2013-06-06 to 2013-09-06. | 2015-04-07 23:14:59 Checking Intraday data file for symbol FGBL1213-EUREX for the date range from 2013-09-06 to 2013-12-06. | 2015-04-07 23:14:59 Checking Daily data file for symbol FGBL1213-EUREX for the date range from 2013-09-06 to 2013-12-06. | 2015-04-07 23:14:59 Checking Intraday data file for symbol FGBL0314-EUREX for the date range from 2013-12-06 to 2014-03-06. | 2015-04-07 23:15:00 Checking Daily data file for symbol FGBL0314-EUREX for the date range from 2013-12-06 to 2014-03-06. | 2015-04-07 23:15:00 Checking Intraday data file for symbol FGBL0614-EUREX for the date range from 2014-03-06 to 2014-06-06. | 2015-04-07 23:15:00 Checking Daily data file for symbol FGBL0614-EUREX for the date range from 2014-03-06 to 2014-06-06. | 2015-04-07 23:15:00 Checking Intraday data file for symbol FGBL0914-EUREX for the date range from 2014-06-06 to 2014-09-08. | 2015-04-07 23:15:00 Checking Daily data file for symbol FGBL0914-EUREX for the date range from 2014-06-06 to 2014-09-08. | 2015-04-07 23:15:00 Checking Intraday data file for symbol FGBL1214-EUREX for the date range from 2014-09-08 to 2014-12-08. | 2015-04-07 23:15:00 Checking Daily data file for symbol FGBL1214-EUREX for the date range from 2014-09-08 to 2014-12-08. | 2015-04-07 23:15:00 Checking Intraday data file for symbol FGBL0315-EUREX for the date range from 2014-12-08 to 2015-03-06. | 2015-04-07 23:15:00 Checking Daily data file for symbol FGBL0315-EUREX for the date range from 2014-12-08 to 2015-03-06. | 2015-04-07 23:15:00 Checking Intraday data file for symbol FGBL0615-EUREX for the date range from 2015-03-06 to 0. | 2015-04-07 23:15:00 Checking Daily data file for symbol FGBL0615-EUREX for the date range from 2015-03-06 to 2015-04-07. | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7 | Symbols used for continuous contract chart: | 2015-04-07 23:15:00 FGBL0608-EUREX | 2015-04-07 23:15:00 FGBL0908-EUREX | 2015-04-07 23:15:00 FGBL1208-EUREX | 2015-04-07 23:15:00 FGBL0309-EUREX | 2015-04-07 23:15:00 FGBL0609-EUREX | 2015-04-07 23:15:00 FGBL0909-EUREX | 2015-04-07 23:15:00 FGBL1209-EUREX | 2015-04-07 23:15:00 FGBL0310-EUREX | 2015-04-07 23:15:00 FGBL0610-EUREX | 2015-04-07 23:15:00 FGBL0910-EUREX | 2015-04-07 23:15:00 FGBL1210-EUREX | 2015-04-07 23:15:00 FGBL0311-EUREX | 2015-04-07 23:15:00 FGBL0611-EUREX | 2015-04-07 23:15:00 FGBL0911-EUREX | 2015-04-07 23:15:00 FGBL1211-EUREX | 2015-04-07 23:15:00 FGBL0312-EUREX | 2015-04-07 23:15:00 FGBL0612-EUREX | 2015-04-07 23:15:00 FGBL0912-EUREX | 2015-04-07 23:15:00 FGBL1212-EUREX | 2015-04-07 23:15:00 FGBL0313-EUREX | 2015-04-07 23:15:00 FGBL0613-EUREX | 2015-04-07 23:15:00 FGBL0913-EUREX | 2015-04-07 23:15:00 FGBL1213-EUREX | 2015-04-07 23:15:00 FGBL0314-EUREX | 2015-04-07 23:15:00 FGBL0614-EUREX | 2015-04-07 23:15:00 FGBL0914-EUREX | 2015-04-07 23:15:00 FGBL1214-EUREX | 2015-04-07 23:15:00 FGBL0315-EUREX | 2015-04-07 23:15:00 FGBL0615-EUREX | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Checking for volume based rollover dates. | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0608-EUREX to FGBL0908-EUREX occurs at 2008-06-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0908-EUREX to FGBL1208-EUREX occurs at 2008-09-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL1208-EUREX to FGBL0309-EUREX occurs at 2008-12-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0309-EUREX to FGBL0609-EUREX occurs at 2009-03-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0609-EUREX to FGBL0909-EUREX occurs at 2009-06-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0909-EUREX to FGBL1209-EUREX occurs at 2009-09-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL1209-EUREX to FGBL0310-EUREX occurs at 2009-12-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0310-EUREX to FGBL0610-EUREX occurs at 2010-03-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0610-EUREX to FGBL0910-EUREX occurs at 2010-06-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0910-EUREX to FGBL1210-EUREX occurs at 2010-09-06 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL1210-EUREX to FGBL0311-EUREX occurs at 2010-12-06 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0311-EUREX to FGBL0611-EUREX occurs at 2011-03-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0611-EUREX to FGBL0911-EUREX occurs at 2011-06-06 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0911-EUREX to FGBL1211-EUREX occurs at 2011-09-06 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL1211-EUREX to FGBL0312-EUREX occurs at 2011-12-06 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0312-EUREX to FGBL0612-EUREX occurs at 2012-03-06 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0612-EUREX to FGBL0912-EUREX occurs at 2012-06-05 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0912-EUREX to FGBL1212-EUREX occurs at 2012-09-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL1212-EUREX to FGBL0313-EUREX occurs at 2012-12-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0313-EUREX to FGBL0613-EUREX occurs at 2013-03-05 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0613-EUREX to FGBL0913-EUREX occurs at 2013-06-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0913-EUREX to FGBL1213-EUREX occurs at 2013-09-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL1213-EUREX to FGBL0314-EUREX occurs at 2013-12-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0314-EUREX to FGBL0614-EUREX occurs at 2014-03-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0614-EUREX to FGBL0914-EUREX occurs at 2014-06-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0914-EUREX to FGBL1214-EUREX occurs at 2014-09-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL1214-EUREX to FGBL0315-EUREX occurs at 2014-12-04 | 2015-04-07 23:15:00 FGBL0615-EUREX [CV] 150 Min #7: Volume based rollover from FGBL0315-EUREX to FGBL0615-EUREX occurs at 2015-03-04 | 2015-04-07 23:15:00 Files to Open on Start up | Opening file: DAX tick.cht | 2015-04-07 23:15:00 Files to Open on Start up | Opening file: NASDAQ tick.cht | 2015-04-07 23:15:00 Date rule based rollover from NQU4-CME to next contract occurs at 2014-09-11. | 2015-04-07 23:15:01 Date rule based rollover from NQZ4-CME to next contract occurs at 2014-12-11. | 2015-04-07 23:15:01 Date rule based rollover from NQH5-CME to next contract occurs at 2015-03-12. | 2015-04-07 23:15:01 Date rule based rollover from NQM5-CME to next contract occurs at 2015-06-11. | 2015-04-07 23:15:01 Checking Intraday data file for symbol NQU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:15:01 Checking Intraday data file for symbol NQZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:15:01 Checking Intraday data file for symbol NQH5-CME for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:15:01 Checking Intraday data file for symbol NQM5-CME for the date range from 2015-03-12 to 0. | 2015-04-07 23:15:01 NQM5-CME [C] Renko 5-3-1 #4 | Symbols used for continuous contract chart: | 2015-04-07 23:15:01 NQU4-CME | 2015-04-07 23:15:01 NQZ4-CME | 2015-04-07 23:15:01 NQH5-CME | 2015-04-07 23:15:01 NQM5-CME | 2015-04-07 23:15:01 Files to Open on Start up | Opening file: DOW +tick.cht | 2015-04-07 23:15:01 Date rule based rollover from YMH5-CBOT to next contract occurs at 2015-03-12. | 2015-04-07 23:15:01 Date rule based rollover from YMM5-CBOT to next contract occurs at 2015-06-11. | 2015-04-07 23:15:01 Checking Intraday data file for symbol YMH5-CBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:15:01 Checking Daily data file for symbol YMH5-CBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:15:01 Checking Intraday data file for symbol YMM5-CBOT for the date range from 2015-03-12 to 0. | 2015-04-07 23:15:01 Checking Daily data file for symbol YMM5-CBOT for the date range from 2015-03-12 to 2015-04-07. | 2015-04-07 23:15:01 YMM5-CBOT [CBV] Renko 5-3-1 #1 | Symbols used for continuous contract chart: | 2015-04-07 23:15:01 YMH5-CBOT | 2015-04-07 23:15:01 YMM5-CBOT | 2015-04-07 23:15:01 YMM5-CBOT [CBV] Renko 5-3-1 #1: Checking for volume based rollover dates. | 2015-04-07 23:15:01 YMM5-CBOT [CBV] Renko 5-3-1 #1: Volume based rollover from YMH5-CBOT to YMM5-CBOT occurs at 2015-03-13 | 2015-04-07 23:15:01 YMM5-CBOT [CBV] Renko 5-3-1 #1: Performing continuous futures contract back adjustment calculations. | 2015-04-07 23:15:01 YMM5-CBOT [CBV] Renko 5-3-1 #1: YMH5-CBOT Open price on 2015-03-13 is 17869. | 2015-04-07 23:15:01 YMM5-CBOT [CBV] Renko 5-3-1 #1: YMM5-CBOT Open price on 2015-03-13 is 17792. | 2015-04-07 23:15:01 YMM5-CBOT [CBV] Renko 5-3-1 #1: YMH5-CBOT price difference to YMM5-CBOT is -77. | 2015-04-07 23:15:01 YMM5-CBOT [CBV] Renko 5-3-1 #1: Back adjust amount for symbol YMH5-CBOT is -77. | 2015-04-07 23:15:01 Files to Open on Start up | Opening file: russ tick.cht | 2015-04-07 23:15:01 Date rule based rollover from TF FMU0014!-NYBOT to next contract occurs at 2014-09-11. | 2015-04-07 23:15:01 Date rule based rollover from TF FMZ0014!-NYBOT to next contract occurs at 2014-12-11. | 2015-04-07 23:15:01 Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-04-07 23:15:01 Date rule based rollover from TF FMM0015!-NYBOT to next contract occurs at 2015-06-11. | 2015-04-07 23:15:01 Checking Intraday data file for symbol TF FMU0014!-NYBOT for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:15:01 Checking Intraday data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:15:01 Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:15:03 Checking Intraday data file for symbol TF FMM0015!-NYBOT for the date range from 2015-03-12 to 0. | 2015-04-07 23:15:03 TF FMM0015!-NYBOT [C] Renko 5-3-1 #1 | Symbols used for continuous contract chart: | 2015-04-07 23:15:03 TF FMU0014!-NYBOT | 2015-04-07 23:15:03 TF FMZ0014!-NYBOT | 2015-04-07 23:15:03 TF FMH0015!-NYBOT | 2015-04-07 23:15:03 TF FMM0015!-NYBOT | 2015-04-07 23:15:03 Files to Open on Start up | Opening file: NAFTA TICK.cht | 2015-04-07 23:15:03 Date rule based rollover from CLM4-NYMEX to next contract occurs at 2014-05-19. | 2015-04-07 23:15:03 Date rule based rollover from CLN4-NYMEX to next contract occurs at 2014-06-19. | 2015-04-07 23:15:03 Date rule based rollover from CLQ4-NYMEX to next contract occurs at 2014-07-21. | 2015-04-07 23:15:03 Date rule based rollover from CLU4-NYMEX to next contract occurs at 2014-08-19. | 2015-04-07 23:15:03 Date rule based rollover from CLV4-NYMEX to next contract occurs at 2014-09-19. | 2015-04-07 23:15:03 Date rule based rollover from CLX4-NYMEX to next contract occurs at 2014-10-20. | 2015-04-07 23:15:03 Date rule based rollover from CLZ4-NYMEX to next contract occurs at 2014-11-19. | 2015-04-07 23:15:03 Date rule based rollover from CLF5-NYMEX to next contract occurs at 2014-12-19. | 2015-04-07 23:15:03 Date rule based rollover from CLG5-NYMEX to next contract occurs at 2015-01-19. | 2015-04-07 23:15:03 Date rule based rollover from CLH5-NYMEX to next contract occurs at 2015-02-19. | 2015-04-07 23:15:03 Date rule based rollover from CLJ5-NYMEX to next contract occurs at 2015-03-19. | 2015-04-07 23:15:03 Date rule based rollover from CLK5-NYMEX to next contract occurs at 2015-04-20. | 2015-04-07 23:15:03 Checking Intraday data file for symbol CLM4-NYMEX for the date range from 2014-04-21 to 2014-05-19. | 2015-04-07 23:15:03 Checking Daily data file for symbol CLM4-NYMEX for the date range from 2014-04-21 to 2014-05-19. | 2015-04-07 23:15:03 Checking Intraday data file for symbol CLN4-NYMEX for the date range from 2014-05-19 to 2014-06-19. | 2015-04-07 23:15:03 Checking Daily data file for symbol CLN4-NYMEX for the date range from 2014-05-19 to 2014-06-19. | 2015-04-07 23:15:03 Checking Intraday data file for symbol CLQ4-NYMEX for the date range from 2014-06-19 to 2014-07-21. | 2015-04-07 23:15:03 Checking Daily data file for symbol CLQ4-NYMEX for the date range from 2014-06-19 to 2014-07-21. | 2015-04-07 23:15:03 Checking Intraday data file for symbol CLU4-NYMEX for the date range from 2014-07-21 to 2014-08-19. | 2015-04-07 23:15:03 Checking Daily data file for symbol CLU4-NYMEX for the date range from 2014-07-21 to 2014-08-19. | 2015-04-07 23:15:03 Checking Intraday data file for symbol CLV4-NYMEX for the date range from 2014-08-19 to 2014-09-19. | 2015-04-07 23:15:03 Checking Daily data file for symbol CLV4-NYMEX for the date range from 2014-08-19 to 2014-09-19. | 2015-04-07 23:15:03 Checking Intraday data file for symbol CLX4-NYMEX for the date range from 2014-09-19 to 2014-10-20. | 2015-04-07 23:15:03 Checking Daily data file for symbol CLX4-NYMEX for the date range from 2014-09-19 to 2014-10-20. | 2015-04-07 23:15:03 Checking Intraday data file for symbol CLZ4-NYMEX for the date range from 2014-10-20 to 2014-11-19. | 2015-04-07 23:15:03 Checking Daily data file for symbol CLZ4-NYMEX for the date range from 2014-10-20 to 2014-11-19. | 2015-04-07 23:15:03 Checking Intraday data file for symbol CLF5-NYMEX for the date range from 2014-11-19 to 2014-12-19. | 2015-04-07 23:15:04 Checking Daily data file for symbol CLF5-NYMEX for the date range from 2014-11-19 to 2014-12-19. | 2015-04-07 23:15:04 Checking Intraday data file for symbol CLG5-NYMEX for the date range from 2014-12-19 to 2015-01-19. | 2015-04-07 23:15:04 Checking Daily data file for symbol CLG5-NYMEX for the date range from 2014-12-19 to 2015-01-19. | 2015-04-07 23:15:04 Checking Intraday data file for symbol CLH5-NYMEX for the date range from 2015-01-19 to 2015-02-19. | 2015-04-07 23:15:04 Checking Daily data file for symbol CLH5-NYMEX for the date range from 2015-01-19 to 2015-02-19. | 2015-04-07 23:15:04 Checking Intraday data file for symbol CLJ5-NYMEX for the date range from 2015-02-19 to 2015-03-19. | 2015-04-07 23:15:04 Checking Daily data file for symbol CLJ5-NYMEX for the date range from 2015-02-19 to 2015-03-19. | 2015-04-07 23:15:04 Checking Intraday data file for symbol CLK5-NYMEX for the date range from 2015-03-19 to 0. | 2015-04-07 23:15:04 Checking Daily data file for symbol CLK5-NYMEX for the date range from 2015-03-19 to 2015-04-07. | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1 | Symbols used for continuous contract chart: | 2015-04-07 23:15:04 CLM4-NYMEX | 2015-04-07 23:15:04 CLN4-NYMEX | 2015-04-07 23:15:04 CLQ4-NYMEX | 2015-04-07 23:15:04 CLU4-NYMEX | 2015-04-07 23:15:04 CLV4-NYMEX | 2015-04-07 23:15:04 CLX4-NYMEX | 2015-04-07 23:15:04 CLZ4-NYMEX | 2015-04-07 23:15:04 CLF5-NYMEX | 2015-04-07 23:15:04 CLG5-NYMEX | 2015-04-07 23:15:04 CLH5-NYMEX | 2015-04-07 23:15:04 CLJ5-NYMEX | 2015-04-07 23:15:04 CLK5-NYMEX | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Checking for volume based rollover dates. | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLM4-NYMEX to CLN4-NYMEX occurs at 2014-05-19 | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLN4-NYMEX to CLQ4-NYMEX occurs at 2014-06-18 | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLQ4-NYMEX to CLU4-NYMEX occurs at 2014-07-18 | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLU4-NYMEX to CLV4-NYMEX occurs at 2014-08-18 | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLV4-NYMEX to CLX4-NYMEX occurs at 2014-09-19 | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLX4-NYMEX to CLZ4-NYMEX occurs at 2014-10-17 | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLZ4-NYMEX to CLF5-NYMEX occurs at 2014-11-18 | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLF5-NYMEX to CLG5-NYMEX occurs at 2014-12-18 | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLG5-NYMEX to CLH5-NYMEX occurs at 2015-01-16 | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLH5-NYMEX to CLJ5-NYMEX occurs at 2015-02-18 | 2015-04-07 23:15:04 CLK5-NYMEX [CV] Renko 5-3-1 #1: Volume based rollover from CLJ5-NYMEX to CLK5-NYMEX occurs at 2015-03-18 | 2015-04-07 23:15:04 Files to Open on Start up | Opening file: NAFTA MINI tick.cht | 2015-04-07 23:15:05 Date rule based rollover from QMU4-NYMEX to next contract occurs at 2014-08-20. | 2015-04-07 23:15:05 Date rule based rollover from QMV4-NYMEX to next contract occurs at 2014-09-22. | 2015-04-07 23:15:05 Date rule based rollover from QMX4-NYMEX to next contract occurs at 2014-10-21. | 2015-04-07 23:15:05 Date rule based rollover from QMZ4-NYMEX to next contract occurs at 2014-11-20. | 2015-04-07 23:15:05 Date rule based rollover from QMF5-NYMEX to next contract occurs at 2014-12-22. | 2015-04-07 23:15:05 Date rule based rollover from QMG5-NYMEX to next contract occurs at 2015-01-20. | 2015-04-07 23:15:05 Date rule based rollover from QMH5-NYMEX to next contract occurs at 2015-02-20. | 2015-04-07 23:15:05 Date rule based rollover from QMJ5-NYMEX to next contract occurs at 2015-03-20. | 2015-04-07 23:15:05 Date rule based rollover from QMK5-NYMEX to next contract occurs at 2015-04-21. | 2015-04-07 23:15:05 Checking Intraday data file for symbol QMU4-NYMEX for the date range from 2014-07-22 to 2014-08-20. | 2015-04-07 23:15:05 Checking Intraday data file for symbol QMV4-NYMEX for the date range from 2014-08-20 to 2014-09-22. | 2015-04-07 23:15:05 Checking Intraday data file for symbol QMX4-NYMEX for the date range from 2014-09-22 to 2014-10-21. | 2015-04-07 23:15:05 Checking Intraday data file for symbol QMZ4-NYMEX for the date range from 2014-10-21 to 2014-11-20. | 2015-04-07 23:15:05 Checking Intraday data file for symbol QMF5-NYMEX for the date range from 2014-11-20 to 2014-12-22. | 2015-04-07 23:15:05 Checking Intraday data file for symbol QMG5-NYMEX for the date range from 2014-12-22 to 2015-01-20. | 2015-04-07 23:15:05 Checking Intraday data file for symbol QMH5-NYMEX for the date range from 2015-01-20 to 2015-02-20. | 2015-04-07 23:15:05 Checking Intraday data file for symbol QMJ5-NYMEX for the date range from 2015-02-20 to 2015-03-20. | 2015-04-07 23:15:05 Checking Intraday data file for symbol QMK5-NYMEX for the date range from 2015-03-20 to 0. | 2015-04-07 23:15:05 QMK5-NYMEX [C] Renko 4-3-3 #1 | Symbols used for continuous contract chart: | 2015-04-07 23:15:05 QMU4-NYMEX | 2015-04-07 23:15:05 QMV4-NYMEX | 2015-04-07 23:15:05 QMX4-NYMEX | 2015-04-07 23:15:05 QMZ4-NYMEX | 2015-04-07 23:15:05 QMF5-NYMEX | 2015-04-07 23:15:05 QMG5-NYMEX | 2015-04-07 23:15:05 QMH5-NYMEX | 2015-04-07 23:15:05 QMJ5-NYMEX | 2015-04-07 23:15:05 QMK5-NYMEX | 2015-04-07 23:15:05 QMK5-NYMEX [C] Renko 4-3-3 #1 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, 7, 8, | 2015-04-07 23:15:05 Files to Open on Start up | Opening file: EURO TICK .cht | 2015-04-07 23:15:05 Date rule based rollover from 6EU4-CME to next contract occurs at 2014-09-15. | 2015-04-07 23:15:05 Date rule based rollover from 6EZ4-CME to next contract occurs at 2014-12-15. | 2015-04-07 23:15:05 Date rule based rollover from 6EH5-CME to next contract occurs at 2015-03-16. | 2015-04-07 23:15:05 Date rule based rollover from 6EM5-CME to next contract occurs at 2015-06-15. | 2015-04-07 23:15:05 Checking Intraday data file for symbol 6EU4-CME for the date range from 2014-06-16 to 2014-09-15. | 2015-04-07 23:15:05 Checking Intraday data file for symbol 6EZ4-CME for the date range from 2014-09-15 to 2014-12-15. | 2015-04-07 23:15:05 Checking Intraday data file for symbol 6EH5-CME for the date range from 2014-12-15 to 2015-03-16. | 2015-04-07 23:15:08 Checking Intraday data file for symbol 6EM5-CME for the date range from 2015-03-16 to 0. | 2015-04-07 23:15:08 6EM5-CME [C] Renko 5-3-1 #4 | Symbols used for continuous contract chart: | 2015-04-07 23:15:08 6EU4-CME | 2015-04-07 23:15:08 6EZ4-CME | 2015-04-07 23:15:08 6EH5-CME | 2015-04-07 23:15:08 6EM5-CME | 2015-04-07 23:15:08 Files to Open on Start up | Opening file: EURO MICRO .cht | 2015-04-07 23:15:09 M6EM5-CME [C] Renko 5-3-3 #1: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2015-04-07 23:15:09 M6EM5-CME [C] Renko 5-3-3 #1: There are no continuous futures contract symbols. Loading data normally. | 2015-04-07 23:15:09 Files to Open on Start up | Opening file: GOLD tick.cht | 2015-04-07 23:15:09 Date rule based rollover from GCZ4-COMEX to next contract occurs at 2014-11-27. | 2015-04-07 23:15:12 Date rule based rollover from GCG5-COMEX to next contract occurs at 2015-01-29. | 2015-04-07 23:15:12 Date rule based rollover from GCJ5-COMEX to next contract occurs at 2015-03-30. | 2015-04-07 23:15:12 Date rule based rollover from GCM5-COMEX to next contract occurs at 2015-05-28. | 2015-04-07 23:15:12 Checking Intraday data file for symbol GCZ4-COMEX for the date range from 2014-07-30 to 2014-11-27. | 2015-04-07 23:15:12 Checking Intraday data file for symbol GCG5-COMEX for the date range from 2014-11-27 to 2015-01-29. | 2015-04-07 23:15:12 Checking Intraday data file for symbol GCJ5-COMEX for the date range from 2015-01-29 to 2015-03-30. | 2015-04-07 23:15:12 Checking Intraday data file for symbol GCM5-COMEX for the date range from 2015-03-30 to 0. | 2015-04-07 23:15:13 GCM5-COMEX [C] Renko 5-3-1 #3 | Symbols used for continuous contract chart: | 2015-04-07 23:15:13 GCZ4-COMEX | 2015-04-07 23:15:13 GCG5-COMEX | 2015-04-07 23:15:13 GCJ5-COMEX | 2015-04-07 23:15:13 GCM5-COMEX | 2015-04-07 23:15:13 Files to Open on Start up | Opening file: SPX tick .cht | 2015-04-07 23:15:13 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-04-07 23:15:14 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-04-07 23:15:14 HD Request # 2 | Downloading Intraday chart data for QMU4-NYMEX to the file QMU4-NYMEX.scid. Service: nymex | 2015-04-07 23:15:15 HD Request # 2 | Download start Date-Time: 2014-08-19 20:29:26.0 | 2015-04-07 23:15:15 HD Request # 2 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:15:15 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:15:16 Socket (2) | Connected. | 2015-04-07 23:15:16 HD Request # 2 | Sending historical data logon request message. | 2015-04-07 23:15:16 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2014-08-19 20:29:26. Record interval: 1. Symbol: QMU14 | 2015-04-07 23:15:16 HD Request # 2 | Decompressing data. | 2015-04-07 23:15:17 HD Request # 2 | Receiving Intraday data for QMU4-NYMEX starting at 2014-08-19 20:29:26 | 2015-04-07 23:15:17 HD Request # 2 | Timestamp of first Intraday data file record written: 2014-08-19 20:29:26 | 2015-04-07 23:15:17 Socket (2) | Shutdown and closed. | 2015-04-07 23:15:17 The network socket for historical data has been closed. | 2015-04-07 23:15:17 HD Request # 2 | Historical data for QMU4-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:19 HD Request # 2 | Received 1 record from 2014-08-19 20:29:26 to 2014-08-19 20:29:26 (0.0 seconds) and wrote 1 record for QMU4-NYMEX | 2015-04-07 23:15:19 HD Request # 2 | Intraday download COMPLETE for QMU4-NYMEX. Completion time: 4s. Unique request ID: 1 | 2015-04-07 23:15:19 Removed historical data download ID 1 | 2015-04-07 23:15:19 HD Request # 3 | Downloading Intraday chart data for QMV4-NYMEX to the file QMV4-NYMEX.scid. Service: nymex | 2015-04-07 23:15:19 HD Request # 3 | Download start Date-Time: 2014-09-19 20:29:52.0 | 2015-04-07 23:15:19 HD Request # 3 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:15:19 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:15:19 Socket (3) | Connected. | 2015-04-07 23:15:19 HD Request # 3 | Sending historical data logon request message. | 2015-04-07 23:15:19 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2014-09-19 20:29:52. Record interval: 1. Symbol: QMV14 | 2015-04-07 23:15:19 HD Request # 3 | Decompressing data. | 2015-04-07 23:15:20 HD Request # 3 | Receiving Intraday data for QMV4-NYMEX starting at 2014-09-19 20:29:52 | 2015-04-07 23:15:20 HD Request # 3 | Timestamp of first Intraday data file record written: 2014-09-19 20:29:52 | 2015-04-07 23:15:20 Socket (3) | Shutdown and closed. | 2015-04-07 23:15:20 The network socket for historical data has been closed. | 2015-04-07 23:15:20 HD Request # 3 | Historical data for QMV4-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:20 HD Request # 3 | Received 1 record from 2014-09-19 20:29:52 to 2014-09-19 20:29:52 (0.0 seconds) and wrote 1 record for QMV4-NYMEX | 2015-04-07 23:15:20 HD Request # 3 | Intraday download COMPLETE for QMV4-NYMEX. Completion time: 1s. Unique request ID: 2 | 2015-04-07 23:15:20 Removed historical data download ID 2 | 2015-04-07 23:15:20 HD Request # 4 | Downloading Intraday chart data for QMX4-NYMEX to the file QMX4-NYMEX.scid. Service: nymex | 2015-04-07 23:15:20 HD Request # 4 | Download start Date-Time: 2014-10-20 20:27:55.0 | 2015-04-07 23:15:20 HD Request # 4 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:15:20 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:15:20 Socket (4) | Connected. | 2015-04-07 23:15:20 HD Request # 4 | Sending historical data logon request message. | 2015-04-07 23:15:20 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2014-10-20 20:27:55. Record interval: 1. Symbol: QMX14 | 2015-04-07 23:15:20 HD Request # 4 | Decompressing data. | 2015-04-07 23:15:20 HD Request # 4 | Receiving Intraday data for QMX4-NYMEX starting at 2014-10-20 20:27:55 | 2015-04-07 23:15:20 HD Request # 4 | Timestamp of first Intraday data file record written: 2014-10-20 20:27:55 | 2015-04-07 23:15:20 Socket (4) | Shutdown and closed. | 2015-04-07 23:15:20 The network socket for historical data has been closed. | 2015-04-07 23:15:20 HD Request # 4 | Historical data for QMX4-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:20 HD Request # 4 | Received 1 record from 2014-10-20 20:27:55 to 2014-10-20 20:27:55 (0.0 seconds) and wrote 1 record for QMX4-NYMEX | 2015-04-07 23:15:20 HD Request # 4 | Intraday download COMPLETE for QMX4-NYMEX. Completion time: 0s. Unique request ID: 3 | 2015-04-07 23:15:20 Removed historical data download ID 3 | 2015-04-07 23:15:20 HD Request # 5 | Downloading Intraday chart data for QMZ4-NYMEX to the file QMZ4-NYMEX.scid. Service: nymex | 2015-04-07 23:15:20 HD Request # 5 | Download start Date-Time: 2014-11-19 20:29:23.0 | 2015-04-07 23:15:20 HD Request # 5 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:15:20 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:15:20 Socket (5) | Connected. | 2015-04-07 23:15:21 HD Request # 5 | Sending historical data logon request message. | 2015-04-07 23:15:21 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2014-11-19 20:29:23. Record interval: 1. Symbol: QMZ14 | 2015-04-07 23:15:21 HD Request # 5 | Decompressing data. | 2015-04-07 23:15:21 HD Request # 5 | Receiving Intraday data for QMZ4-NYMEX starting at 2014-11-19 20:29:23 | 2015-04-07 23:15:21 HD Request # 5 | Timestamp of first Intraday data file record written: 2014-11-19 20:29:23 | 2015-04-07 23:15:21 Socket (5) | Shutdown and closed. | 2015-04-07 23:15:21 The network socket for historical data has been closed. | 2015-04-07 23:15:21 HD Request # 5 | Historical data for QMZ4-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:23 HD Request # 5 | Received 1 record from 2014-11-19 20:29:23 to 2014-11-19 20:29:23 (0.0 seconds) and wrote 1 record for QMZ4-NYMEX | 2015-04-07 23:15:23 HD Request # 5 | Intraday download COMPLETE for QMZ4-NYMEX. Completion time: 3s. Unique request ID: 4 | 2015-04-07 23:15:23 Removed historical data download ID 4 | 2015-04-07 23:15:23 HD Request # 6 | Downloading Intraday chart data for QMF5-NYMEX to the file QMF5-NYMEX.scid. Service: nymex | 2015-04-07 23:15:23 HD Request # 6 | Download start Date-Time: 2014-12-18 20:29:37.0 | 2015-04-07 23:15:23 HD Request # 6 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:15:23 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:15:23 Socket (6) | Connected. | 2015-04-07 23:15:23 HD Request # 6 | Sending historical data logon request message. | 2015-04-07 23:15:23 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2014-12-18 20:29:37. Record interval: 1. Symbol: QMF15 | 2015-04-07 23:15:23 HD Request # 6 | Decompressing data. | 2015-04-07 23:15:24 HD Request # 6 | Receiving Intraday data for QMF5-NYMEX starting at 2014-12-18 20:29:37 | 2015-04-07 23:15:24 HD Request # 6 | Timestamp of first Intraday data file record written: 2014-12-18 20:29:37 | 2015-04-07 23:15:24 Socket (6) | Shutdown and closed. | 2015-04-07 23:15:24 The network socket for historical data has been closed. | 2015-04-07 23:15:24 HD Request # 6 | Historical data for QMF5-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:24 HD Request # 6 | Received 1 record from 2014-12-18 20:29:37 to 2014-12-18 20:29:37 (0.0 seconds) and wrote 1 record for QMF5-NYMEX | 2015-04-07 23:15:24 HD Request # 6 | Intraday download COMPLETE for QMF5-NYMEX. Completion time: 0s. Unique request ID: 5 | 2015-04-07 23:15:24 Removed historical data download ID 5 | 2015-04-07 23:15:24 HD Request # 7 | Downloading Intraday chart data for QMG5-NYMEX to the file QMG5-NYMEX.scid. Service: nymex | 2015-04-07 23:15:24 HD Request # 7 | Download start Date-Time: 2015-01-16 20:29:57.0 | 2015-04-07 23:15:24 HD Request # 7 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:15:24 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:15:24 Socket (7) | Connected. | 2015-04-07 23:15:24 HD Request # 7 | Sending historical data logon request message. | 2015-04-07 23:15:24 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-01-16 20:29:57. Record interval: 1. Symbol: QMG15 | 2015-04-07 23:15:24 HD Request # 7 | Decompressing data. | 2015-04-07 23:15:25 HD Request # 7 | Receiving Intraday data for QMG5-NYMEX starting at 2015-01-16 20:29:57 | 2015-04-07 23:15:25 HD Request # 7 | Timestamp of first Intraday data file record written: 2015-01-16 20:29:57 | 2015-04-07 23:15:25 Socket (7) | Shutdown and closed. | 2015-04-07 23:15:25 The network socket for historical data has been closed. | 2015-04-07 23:15:25 HD Request # 7 | Historical data for QMG5-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:25 HD Request # 7 | Received 1 record from 2015-01-16 20:29:57 to 2015-01-16 20:29:57 (0.0 seconds) and wrote 1 record for QMG5-NYMEX | 2015-04-07 23:15:25 HD Request # 7 | Intraday download COMPLETE for QMG5-NYMEX. Completion time: 1s. Unique request ID: 6 | 2015-04-07 23:15:25 Removed historical data download ID 6 | 2015-04-07 23:15:25 HD Request # 8 | Downloading Intraday chart data for QMH5-NYMEX to the file QMH5-NYMEX.scid. Service: nymex | 2015-04-07 23:15:25 HD Request # 8 | Download start Date-Time: 2015-02-19 20:29:25.0 | 2015-04-07 23:15:25 HD Request # 8 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:15:25 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:15:25 Intraday data recording state for symbol NTCK-NYSE is set to download pending. | 2015-04-07 23:15:25 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63352 | 2015-04-07 23:15:25 Socket (8) | Connected. | 2015-04-07 23:15:25 HD Request # 8 | Sending historical data logon request message. | 2015-04-07 23:15:25 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-02-19 20:29:25. Record interval: 1. Symbol: QMH15 | 2015-04-07 23:15:25 HD Request # 8 | Decompressing data. | 2015-04-07 23:15:25 HD Request # 8 | Receiving Intraday data for QMH5-NYMEX starting at 2015-02-19 20:29:25 | 2015-04-07 23:15:25 HD Request # 8 | Timestamp of first Intraday data file record written: 2015-02-19 20:29:25 | 2015-04-07 23:15:25 Socket (8) | Shutdown and closed. | 2015-04-07 23:15:25 The network socket for historical data has been closed. | 2015-04-07 23:15:25 HD Request # 8 | Historical data for QMH5-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:26 HD Request # 8 | Received 1 record from 2015-02-19 20:29:25 to 2015-02-19 20:29:25 (0.0 seconds) and wrote 1 record for QMH5-NYMEX | 2015-04-07 23:15:26 HD Request # 8 | Intraday download COMPLETE for QMH5-NYMEX. Completion time: 1s. Unique request ID: 7 | 2015-04-07 23:15:26 Removed historical data download ID 7 | 2015-04-07 23:15:26 HD Request # 9 | Downloading Intraday chart data for QMJ5-NYMEX to the file QMJ5-NYMEX.scid. Service: nymex | 2015-04-07 23:15:26 HD Request # 9 | Download start Date-Time: 2015-03-19 19:29:28.0 | 2015-04-07 23:15:26 HD Request # 9 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:15:26 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:15:26 HD Request # 10 | Downloading Historical Daily chart data for YMM5-CBOT. Starting date: 2015-04-06. Service: rim | 2015-04-07 23:15:26 HD Request # 10 | Requesting historical Daily data for YMM15 starting at 2015-04-05 | 2015-04-07 23:15:26 Using proxy for http request. | 2015-04-07 23:15:26 Socket (10) | Connected. | 2015-04-07 23:15:26 HD Request # 9 | Sending historical data logon request message. | 2015-04-07 23:15:26 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2015-03-19 19:29:28. Record interval: 1. Symbol: QMJ15 | 2015-04-07 23:15:26 HD Request # 9 | Decompressing data. | 2015-04-07 23:15:27 HD Request # 9 | Receiving Intraday data for QMJ5-NYMEX starting at 2015-03-19 19:29:28 | 2015-04-07 23:15:27 HD Request # 9 | Timestamp of first Intraday data file record written: 2015-03-19 19:29:28 | 2015-04-07 23:15:27 Socket (10) | Shutdown and closed. | 2015-04-07 23:15:27 The network socket for historical data has been closed. | 2015-04-07 23:15:27 Intraday data recording state for symbol TICK-TF is set to download pending. | 2015-04-07 23:15:29 Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-04-07 23:15:29 Socket (9) | Shutdown and closed. | 2015-04-07 23:15:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-07 23:15:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-07 23:15:29 HD Request # 10 | Receiving historical Daily data for YMM5-CBOT starting at 2015-04-06 | 2015-04-07 23:15:29 Writing historical Daily data for YMM5-CBOT to the file YMM5-CBOT.dly | 2015-04-07 23:15:29 HD Request # 10 | Received 2 records from 2015-04-06 00:00:00 to 2015-04-07 00:00:00 (2.0 days) and wrote 2 records for YMM5-CBOT | 2015-04-07 23:15:29 HD Request # 10 | Daily download COMPLETE for YMM5-CBOT. Completion time: 3s. Unique request ID: 18 | 2015-04-07 23:15:29 Removed historical data download ID 18 | 2015-04-07 23:15:29 HD Request # 9 | Historical data for QMJ5-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:29 HD Request # 9 | Received 1 record from 2015-03-19 19:29:28 to 2015-03-19 19:29:28 (0.0 seconds) and wrote 1 record for QMJ5-NYMEX | 2015-04-07 23:15:29 HD Request # 9 | Intraday download COMPLETE for QMJ5-NYMEX. Completion time: 3s. Unique request ID: 8 | 2015-04-07 23:15:29 Removed historical data download ID 8 | 2015-04-07 23:15:29 HD Request # 11 | Downloading Intraday chart data for NTCK-NYSE to the file NTCK-NYSE.scid. Service: statscalc | 2015-04-07 23:15:29 HD Request # 11 | Download start Date-Time: 2015-04-07 23:11:32.0 | 2015-04-07 23:15:30 HD Request # 11 | Using server: ds5.sierracharts.com port 10149 | 2015-04-07 23:15:30 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-04-07 23:15:30 HD Request # 12 | Downloading Historical Daily chart data for DX FMM0015!-NYBOT. Starting date: 2015-04-06. Service: rim | 2015-04-07 23:15:30 HD Request # 12 | Requesting historical Daily data for DXM15 starting at 2015-04-05 | 2015-04-07 23:15:30 Socket (11) | Connected. | 2015-04-07 23:15:30 HD Request # 11 | Sending historical data logon request message. | 2015-04-07 23:15:30 Intraday data recording state for symbol NTCK-TF is set to download pending. | 2015-04-07 23:15:30 HD Request # 12 | Receiving historical Daily data for DX FMM0015!-NYBOT starting at 2015-04-06 | 2015-04-07 23:15:30 Writing historical Daily data for DX FMM0015!-NYBOT to the file DX FMM0015!-NYBOT.dly | 2015-04-07 23:15:30 HD Request # 12 | Received 2 records from 2015-04-06 00:00:00 to 2015-04-07 00:00:00 (2.0 days) and wrote 2 records for DX FMM0015!-NYBOT | 2015-04-07 23:15:30 HD Request # 12 | Daily download COMPLETE for DX FMM0015!-NYBOT. Completion time: 1s. Unique request ID: 19 | 2015-04-07 23:15:31 Removed historical data download ID 19 | 2015-04-07 23:15:31 HD Request # 13 | Downloading Historical Daily chart data for FDAX0615-EUREX. Starting date: 2015-04-02. Service: rim | 2015-04-07 23:15:31 HD Request # 13 | Requesting historical Daily data for DYM15 starting at 2015-04-01 | 2015-04-07 23:15:31 Rithmic Trading | There has been no activity on the network socket. Will reconnect. | 2015-04-07 23:15:31 * QMK5-NYMEX [C] Renko 4-3-3 #1: Download is complete for all contract months in chart. Proceeding with data load. | 2015-04-07 23:15:31 HD Request # 13 | Receiving historical Daily data for FDAX0615-EUREX starting at 2015-04-01 | 2015-04-07 23:15:31 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:11:32. Record interval: 1. Symbol: NTCK-NYSE | 2015-04-07 23:15:31 Writing historical Daily data for FDAX0615-EUREX to the file FDAX0615-EUREX.dly | 2015-04-07 23:15:31 HD Request # 13 | Received 3 records from 2015-04-01 00:00:00 to 2015-04-07 00:00:00 (7.0 days) and wrote 2 records for FDAX0615-EUREX | 2015-04-07 23:15:31 HD Request # 11 | Decompressing data. | 2015-04-07 23:15:31 HD Request # 11 | Receiving Intraday data for NTCK-NYSE starting at 2015-04-07 23:11:32 | 2015-04-07 23:15:31 HD Request # 13 | Daily download COMPLETE for FDAX0615-EUREX. Completion time: 0s. Unique request ID: 20 | 2015-04-07 23:15:32 Removed historical data download ID 20 | 2015-04-07 23:15:32 HD Request # 11 | Timestamp of first Intraday data file record written: 2015-04-07 23:11:32 | 2015-04-07 23:15:34 Socket (11) | Shutdown and closed. | 2015-04-07 23:15:34 The network socket for historical data has been closed. | 2015-04-07 23:15:34 HD Request # 11 | Historical data for NTCK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:34 HD Request # 11 | Received 65 records from 2015-04-07 23:11:32 to 2015-04-07 23:15:27 (3.9 minutes) and wrote 65 records for NTCK-NYSE | 2015-04-07 23:15:36 HD Request # 11 | Intraday download COMPLETE for NTCK-NYSE. Completion time: 7s. Unique request ID: 17 | 2015-04-07 23:15:36 Removed historical data download ID 17 | 2015-04-07 23:15:36 HD Request # 14 | Downloading Intraday chart data for TICK-TF to the file TICK-TF.scid. Service: statscalc | 2015-04-07 23:15:36 HD Request # 14 | Download start Date-Time: 2015-04-07 23:11:32.0 | 2015-04-07 23:15:36 HD Request # 14 | Using server: ds4.sierracharts.com port 10149 | 2015-04-07 23:15:36 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-04-07 23:15:36 Socket (12) | Connected. | 2015-04-07 23:15:36 HD Request # 14 | Sending historical data logon request message. | 2015-04-07 23:15:36 QMK5-NYMEX [C] Renko 4-3-3 #6: Download is complete for all contract months in chart. Proceeding with data load. | 2015-04-07 23:15:37 Limiting the number of years back for the continuous futures chart to 5.0924025. Reason: Account limitation. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0310-EUREX to next contract occurs at 2010-03-19. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0610-EUREX to next contract occurs at 2010-06-18. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0910-EUREX to next contract occurs at 2010-09-17. | 2015-04-07 23:15:37 Date rule based rollover from FDAX1210-EUREX to next contract occurs at 2010-12-17. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0311-EUREX to next contract occurs at 2011-03-18. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0611-EUREX to next contract occurs at 2011-06-17. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0911-EUREX to next contract occurs at 2011-09-16. | 2015-04-07 23:15:37 Date rule based rollover from FDAX1211-EUREX to next contract occurs at 2011-12-16. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0312-EUREX to next contract occurs at 2012-03-16. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0612-EUREX to next contract occurs at 2012-06-15. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0912-EUREX to next contract occurs at 2012-09-21. | 2015-04-07 23:15:37 Date rule based rollover from FDAX1212-EUREX to next contract occurs at 2012-12-21. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0313-EUREX to next contract occurs at 2013-03-15. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0613-EUREX to next contract occurs at 2013-06-21. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0913-EUREX to next contract occurs at 2013-09-20. | 2015-04-07 23:15:37 Date rule based rollover from FDAX1213-EUREX to next contract occurs at 2013-12-20. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0314-EUREX to next contract occurs at 2014-03-21. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0614-EUREX to next contract occurs at 2014-06-20. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0914-EUREX to next contract occurs at 2014-09-19. | 2015-04-07 23:15:37 Date rule based rollover from FDAX1214-EUREX to next contract occurs at 2014-12-19. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0315-EUREX to next contract occurs at 2015-03-20. | 2015-04-07 23:15:37 Date rule based rollover from FDAX0615-EUREX to next contract occurs at 2015-06-19. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0310-EUREX for the date range from 2009-12-18 to 2010-03-19. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0610-EUREX for the date range from 2010-03-19 to 2010-06-18. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0910-EUREX for the date range from 2010-06-18 to 2010-09-17. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX1210-EUREX for the date range from 2010-09-17 to 2010-12-17. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0311-EUREX for the date range from 2010-12-17 to 2011-03-18. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0611-EUREX for the date range from 2011-03-18 to 2011-06-17. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0911-EUREX for the date range from 2011-06-17 to 2011-09-16. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX1211-EUREX for the date range from 2011-09-16 to 2011-12-16. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0312-EUREX for the date range from 2011-12-16 to 2012-03-16. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0612-EUREX for the date range from 2012-03-16 to 2012-06-15. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0912-EUREX for the date range from 2012-06-15 to 2012-09-21. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX1212-EUREX for the date range from 2012-09-21 to 2012-12-21. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0313-EUREX for the date range from 2012-12-21 to 2013-03-15. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0613-EUREX for the date range from 2013-03-15 to 2013-06-21. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0913-EUREX for the date range from 2013-06-21 to 2013-09-20. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX1213-EUREX for the date range from 2013-09-20 to 2013-12-20. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0314-EUREX for the date range from 2013-12-20 to 2014-03-21. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0614-EUREX for the date range from 2014-03-21 to 2014-06-20. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0914-EUREX for the date range from 2014-06-20 to 2014-09-19. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX1214-EUREX for the date range from 2014-09-19 to 2014-12-19. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0315-EUREX for the date range from 2014-12-19 to 2015-03-20. | 2015-04-07 23:15:37 Checking Daily data file for symbol FDAX0615-EUREX for the date range from 2015-03-20 to 2015-04-07. | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8 | Symbols used for continuous contract chart: | 2015-04-07 23:15:37 FDAX0310-EUREX | 2015-04-07 23:15:37 FDAX0610-EUREX | 2015-04-07 23:15:37 FDAX0910-EUREX | 2015-04-07 23:15:37 FDAX1210-EUREX | 2015-04-07 23:15:37 FDAX0311-EUREX | 2015-04-07 23:15:37 FDAX0611-EUREX | 2015-04-07 23:15:37 FDAX0911-EUREX | 2015-04-07 23:15:37 FDAX1211-EUREX | 2015-04-07 23:15:37 FDAX0312-EUREX | 2015-04-07 23:15:37 FDAX0612-EUREX | 2015-04-07 23:15:37 FDAX0912-EUREX | 2015-04-07 23:15:37 FDAX1212-EUREX | 2015-04-07 23:15:37 FDAX0313-EUREX | 2015-04-07 23:15:37 FDAX0613-EUREX | 2015-04-07 23:15:37 FDAX0913-EUREX | 2015-04-07 23:15:37 FDAX1213-EUREX | 2015-04-07 23:15:37 FDAX0314-EUREX | 2015-04-07 23:15:37 FDAX0614-EUREX | 2015-04-07 23:15:37 FDAX0914-EUREX | 2015-04-07 23:15:37 FDAX1214-EUREX | 2015-04-07 23:15:37 FDAX0315-EUREX | 2015-04-07 23:15:37 FDAX0615-EUREX | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Checking for volume based rollover dates. | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0310-EUREX to FDAX0610-EUREX occurs at 2010-03-18 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0610-EUREX to FDAX0910-EUREX occurs at 2010-06-17 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0910-EUREX to FDAX1210-EUREX occurs at 2010-09-16 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX1210-EUREX to FDAX0311-EUREX occurs at 2010-12-16 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0311-EUREX to FDAX0611-EUREX occurs at 2011-03-17 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0611-EUREX to FDAX0911-EUREX occurs at 2011-06-16 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0911-EUREX to FDAX1211-EUREX occurs at 2011-09-15 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX1211-EUREX to FDAX0312-EUREX occurs at 2011-12-15 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0312-EUREX to FDAX0612-EUREX occurs at 2012-03-15 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0612-EUREX to FDAX0912-EUREX occurs at 2012-06-14 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0912-EUREX to FDAX1212-EUREX occurs at 2012-09-21 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX1212-EUREX to FDAX0313-EUREX occurs at 2012-12-20 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0313-EUREX to FDAX0613-EUREX occurs at 2013-03-14 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0613-EUREX to FDAX0913-EUREX occurs at 2013-06-20 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0913-EUREX to FDAX1213-EUREX occurs at 2013-09-19 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX1213-EUREX to FDAX0314-EUREX occurs at 2013-12-19 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0314-EUREX to FDAX0614-EUREX occurs at 2014-03-21 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0614-EUREX to FDAX0914-EUREX occurs at 2014-06-19 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0914-EUREX to FDAX1214-EUREX occurs at 2014-09-18 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX1214-EUREX to FDAX0315-EUREX occurs at 2014-12-18 | 2015-04-07 23:15:37 FDAX0615-EUREX [CV] Daily #8: Volume based rollover from FDAX0315-EUREX to FDAX0615-EUREX occurs at 2015-03-20 | 2015-04-07 23:15:37 Limiting the number of years back for the continuous futures chart to 4.9993155. Reason: Single-digit year in symbol. | 2015-04-07 23:15:37 Date rule based rollover from YMM0-CBOT to next contract occurs at 2010-06-10. | 2015-04-07 23:15:37 Date rule based rollover from YMU0-CBOT to next contract occurs at 2010-09-09. | 2015-04-07 23:15:37 Date rule based rollover from YMZ0-CBOT to next contract occurs at 2010-12-09. | 2015-04-07 23:15:37 Date rule based rollover from YMH1-CBOT to next contract occurs at 2011-03-10. | 2015-04-07 23:15:37 Date rule based rollover from YMM1-CBOT to next contract occurs at 2011-06-09. | 2015-04-07 23:15:37 Date rule based rollover from YMU1-CBOT to next contract occurs at 2011-09-08. | 2015-04-07 23:15:37 Date rule based rollover from YMZ1-CBOT to next contract occurs at 2011-12-08. | 2015-04-07 23:15:37 Date rule based rollover from YMH2-CBOT to next contract occurs at 2012-03-08. | 2015-04-07 23:15:37 Date rule based rollover from YMM2-CBOT to next contract occurs at 2012-06-07. | 2015-04-07 23:15:37 Date rule based rollover from YMU2-CBOT to next contract occurs at 2012-09-13. | 2015-04-07 23:15:37 Date rule based rollover from YMZ2-CBOT to next contract occurs at 2012-12-13. | 2015-04-07 23:15:37 Date rule based rollover from YMH3-CBOT to next contract occurs at 2013-03-07. | 2015-04-07 23:15:37 Date rule based rollover from YMM3-CBOT to next contract occurs at 2013-06-13. | 2015-04-07 23:15:37 Date rule based rollover from YMU3-CBOT to next contract occurs at 2013-09-12. | 2015-04-07 23:15:37 Date rule based rollover from YMZ3-CBOT to next contract occurs at 2013-12-12. | 2015-04-07 23:15:37 Date rule based rollover from YMH4-CBOT to next contract occurs at 2014-03-13. | 2015-04-07 23:15:37 Date rule based rollover from YMM4-CBOT to next contract occurs at 2014-06-12. | 2015-04-07 23:15:37 Date rule based rollover from YMU4-CBOT to next contract occurs at 2014-09-11. | 2015-04-07 23:15:37 Date rule based rollover from YMZ4-CBOT to next contract occurs at 2014-12-11. | 2015-04-07 23:15:37 Date rule based rollover from YMH5-CBOT to next contract occurs at 2015-03-12. | 2015-04-07 23:15:37 Date rule based rollover from YMM5-CBOT to next contract occurs at 2015-06-11. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMM0-CBOT for the date range from 2010-03-11 to 2010-06-10. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMU0-CBOT for the date range from 2010-06-10 to 2010-09-09. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMZ0-CBOT for the date range from 2010-09-09 to 2010-12-09. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMH1-CBOT for the date range from 2010-12-09 to 2011-03-10. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMM1-CBOT for the date range from 2011-03-10 to 2011-06-09. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMU1-CBOT for the date range from 2011-06-09 to 2011-09-08. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMZ1-CBOT for the date range from 2011-09-08 to 2011-12-08. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMH2-CBOT for the date range from 2011-12-08 to 2012-03-08. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMM2-CBOT for the date range from 2012-03-08 to 2012-06-07. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMU2-CBOT for the date range from 2012-06-07 to 2012-09-13. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMZ2-CBOT for the date range from 2012-09-13 to 2012-12-13. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMH3-CBOT for the date range from 2012-12-13 to 2013-03-07. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMM3-CBOT for the date range from 2013-03-07 to 2013-06-13. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMU3-CBOT for the date range from 2013-06-13 to 2013-09-12. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMZ3-CBOT for the date range from 2013-09-12 to 2013-12-12. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMH4-CBOT for the date range from 2013-12-12 to 2014-03-13. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMM4-CBOT for the date range from 2014-03-13 to 2014-06-12. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMU4-CBOT for the date range from 2014-06-12 to 2014-09-11. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMZ4-CBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMH5-CBOT for the date range from 2014-12-11 to 2015-03-12. | 2015-04-07 23:15:37 Checking Daily data file for symbol YMM5-CBOT for the date range from 2015-03-12 to 2015-04-07. | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27 | Symbols used for continuous contract chart: | 2015-04-07 23:15:37 YMM0-CBOT | 2015-04-07 23:15:37 YMU0-CBOT | 2015-04-07 23:15:37 YMZ0-CBOT | 2015-04-07 23:15:37 YMH1-CBOT | 2015-04-07 23:15:37 YMM1-CBOT | 2015-04-07 23:15:37 YMU1-CBOT | 2015-04-07 23:15:37 YMZ1-CBOT | 2015-04-07 23:15:37 YMH2-CBOT | 2015-04-07 23:15:37 YMM2-CBOT | 2015-04-07 23:15:37 YMU2-CBOT | 2015-04-07 23:15:37 YMZ2-CBOT | 2015-04-07 23:15:37 YMH3-CBOT | 2015-04-07 23:15:37 YMM3-CBOT | 2015-04-07 23:15:37 YMU3-CBOT | 2015-04-07 23:15:37 YMZ3-CBOT | 2015-04-07 23:15:37 YMH4-CBOT | 2015-04-07 23:15:37 YMM4-CBOT | 2015-04-07 23:15:37 YMU4-CBOT | 2015-04-07 23:15:37 YMZ4-CBOT | 2015-04-07 23:15:37 YMH5-CBOT | 2015-04-07 23:15:37 YMM5-CBOT | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Checking for volume based rollover dates. | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMM0-CBOT to YMU0-CBOT occurs at 2010-06-11 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMU0-CBOT to YMZ0-CBOT occurs at 2010-09-10 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMZ0-CBOT to YMH1-CBOT occurs at 2010-12-10 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMH1-CBOT to YMM1-CBOT occurs at 2011-03-11 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMM1-CBOT to YMU1-CBOT occurs at 2011-06-10 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMU1-CBOT to YMZ1-CBOT occurs at 2011-09-09 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMZ1-CBOT to YMH2-CBOT occurs at 2011-12-09 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMH2-CBOT to YMM2-CBOT occurs at 2012-03-09 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMM2-CBOT to YMU2-CBOT occurs at 2012-06-08 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMU2-CBOT to YMZ2-CBOT occurs at 2012-09-14 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMZ2-CBOT to YMH3-CBOT occurs at 2012-12-14 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMH3-CBOT to YMM3-CBOT occurs at 2013-03-08 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMM3-CBOT to YMU3-CBOT occurs at 2013-06-14 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMU3-CBOT to YMZ3-CBOT occurs at 2013-09-13 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMZ3-CBOT to YMH4-CBOT occurs at 2013-12-13 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMH4-CBOT to YMM4-CBOT occurs at 2014-03-14 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMM4-CBOT to YMU4-CBOT occurs at 2014-06-13 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMU4-CBOT to YMZ4-CBOT occurs at 2014-09-12 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMZ4-CBOT to YMH5-CBOT occurs at 2014-12-12 | 2015-04-07 23:15:37 YMM5-CBOT [CV] Daily #27: Volume based rollover from YMH5-CBOT to YMM5-CBOT occurs at 2015-03-13 | 2015-04-07 23:15:37 Date rule based rollover from DX FMM0012!-NYBOT to next contract occurs at 2012-06-15. | 2015-04-07 23:15:37 Date rule based rollover from DX FMU0012!-NYBOT to next contract occurs at 2012-09-14. | 2015-04-07 23:15:37 Date rule based rollover from DX FMZ0012!-NYBOT to next contract occurs at 2012-12-14. | 2015-04-07 23:15:37 Date rule based rollover from DX FMH0013!-NYBOT to next contract occurs at 2013-03-15. | 2015-04-07 23:15:37 Date rule based rollover from DX FMM0013!-NYBOT to next contract occurs at 2013-06-14. | 2015-04-07 23:15:37 Date rule based rollover from DX FMU0013!-NYBOT to next contract occurs at 2013-09-13. | 2015-04-07 23:15:37 Date rule based rollover from DX FMZ0013!-NYBOT to next contract occurs at 2013-12-13. | 2015-04-07 23:15:37 Date rule based rollover from DX FMH0014!-NYBOT to next contract occurs at 2014-03-14. | 2015-04-07 23:15:37 Date rule based rollover from DX FMM0014!-NYBOT to next contract occurs at 2014-06-13. | 2015-04-07 23:15:37 Date rule based rollover from DX FMU0014!-NYBOT to next contract occurs at 2014-09-12. | 2015-04-07 23:15:37 Date rule based rollover from DX FMZ0014!-NYBOT to next contract occurs at 2014-12-12. | 2015-04-07 23:15:37 Date rule based rollover from DX FMH0015!-NYBOT to next contract occurs at 2015-03-13. | 2015-04-07 23:15:37 Date rule based rollover from DX FMM0015!-NYBOT to next contract occurs at 2015-06-12. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMM0012!-NYBOT for the date range from 2012-03-16 to 2012-06-15. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMU0012!-NYBOT for the date range from 2012-06-15 to 2012-09-14. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMZ0012!-NYBOT for the date range from 2012-09-14 to 2012-12-14. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMH0013!-NYBOT for the date range from 2012-12-14 to 2013-03-15. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMM0013!-NYBOT for the date range from 2013-03-15 to 2013-06-14. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMU0013!-NYBOT for the date range from 2013-06-14 to 2013-09-13. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMZ0013!-NYBOT for the date range from 2013-09-13 to 2013-12-13. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMH0014!-NYBOT for the date range from 2013-12-13 to 2014-03-14. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMM0014!-NYBOT for the date range from 2014-03-14 to 2014-06-13. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMU0014!-NYBOT for the date range from 2014-06-13 to 2014-09-12. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMZ0014!-NYBOT for the date range from 2014-09-12 to 2014-12-12. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMH0015!-NYBOT for the date range from 2014-12-12 to 2015-03-13. | 2015-04-07 23:15:37 Checking Daily data file for symbol DX FMM0015!-NYBOT for the date range from 2015-03-13 to 2015-04-07. | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1 | Symbols used for continuous contract chart: | 2015-04-07 23:15:37 DX FMM0012!-NYBOT | 2015-04-07 23:15:37 DX FMU0012!-NYBOT | 2015-04-07 23:15:37 DX FMZ0012!-NYBOT | 2015-04-07 23:15:37 DX FMH0013!-NYBOT | 2015-04-07 23:15:37 DX FMM0013!-NYBOT | 2015-04-07 23:15:37 DX FMU0013!-NYBOT | 2015-04-07 23:15:37 DX FMZ0013!-NYBOT | 2015-04-07 23:15:37 DX FMH0014!-NYBOT | 2015-04-07 23:15:37 DX FMM0014!-NYBOT | 2015-04-07 23:15:37 DX FMU0014!-NYBOT | 2015-04-07 23:15:37 DX FMZ0014!-NYBOT | 2015-04-07 23:15:37 DX FMH0015!-NYBOT | 2015-04-07 23:15:37 DX FMM0015!-NYBOT | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Checking for volume based rollover dates. | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMM0012!-NYBOT to DX FMU0012!-NYBOT occurs at 2012-06-15 | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMU0012!-NYBOT to DX FMZ0012!-NYBOT occurs at 2012-09-14 | 2015-04-07 23:15:37 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:11:32. Record interval: 1. Symbol: TICK-TF | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMZ0012!-NYBOT to DX FMH0013!-NYBOT occurs at 2012-12-13 | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMH0013!-NYBOT to DX FMM0013!-NYBOT occurs at 2013-03-14 | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMM0013!-NYBOT to DX FMU0013!-NYBOT occurs at 2013-06-13 | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMU0013!-NYBOT to DX FMZ0013!-NYBOT occurs at 2013-09-12 | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMZ0013!-NYBOT to DX FMH0014!-NYBOT occurs at 2013-12-12 | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMH0014!-NYBOT to DX FMM0014!-NYBOT occurs at 2014-03-13 | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMM0014!-NYBOT to DX FMU0014!-NYBOT occurs at 2014-06-12 | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMU0014!-NYBOT to DX FMZ0014!-NYBOT occurs at 2014-09-11 | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMZ0014!-NYBOT to DX FMH0015!-NYBOT occurs at 2014-12-11 | 2015-04-07 23:15:37 DX FMM0015!-NYBOT [CV] Daily #1: Volume based rollover from DX FMH0015!-NYBOT to DX FMM0015!-NYBOT occurs at 2015-03-12 | 2015-04-07 23:15:37 HD Request # 14 | Decompressing data. | 2015-04-07 23:15:37 HD Request # 14 | Receiving Intraday data for TICK-TF starting at 2015-04-07 23:11:32 | 2015-04-07 23:15:37 HD Request # 14 | Timestamp of first Intraday data file record written: 2015-04-07 23:11:32 | 2015-04-07 23:15:37 Socket (12) | Shutdown and closed. | 2015-04-07 23:15:37 The network socket for historical data has been closed. | 2015-04-07 23:15:37 HD Request # 14 | Historical data for TICK-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:38 HD Request # 14 | Received 67 records from 2015-04-07 23:11:32 to 2015-04-07 23:15:35 (4.1 minutes) and wrote 67 records for TICK-TF | 2015-04-07 23:15:40 HD Request # 14 | Intraday download COMPLETE for TICK-TF. Completion time: 4s. Unique request ID: 21 | 2015-04-07 23:15:40 Removed historical data download ID 21 | 2015-04-07 23:15:40 HD Request # 15 | Downloading Intraday chart data for NTCK-TF to the file NTCK-TF.scid. Service: statscalc | 2015-04-07 23:15:40 HD Request # 15 | Download start Date-Time: 2015-04-07 23:11:32.0 | 2015-04-07 23:15:40 HD Request # 15 | Using server: ds3.sierracharts.com port 10149 | 2015-04-07 23:15:40 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-04-07 23:15:40 Socket (13) | Connected. | 2015-04-07 23:15:40 HD Request # 15 | Sending historical data logon request message. | 2015-04-07 23:15:40 Rithmic Trading | Disconnected from the server. | 2015-04-07 23:15:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-07 23:15:41 HD Request # 15 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:11:32. Record interval: 1. Symbol: NTCK-TF | 2015-04-07 23:15:41 HD Request # 15 | Decompressing data. | 2015-04-07 23:15:41 HD Request # 15 | Receiving Intraday data for NTCK-TF starting at 2015-04-07 23:11:32 | 2015-04-07 23:15:41 HD Request # 15 | Timestamp of first Intraday data file record written: 2015-04-07 23:11:32 | 2015-04-07 23:15:41 Socket (13) | Shutdown and closed. | 2015-04-07 23:15:41 The network socket for historical data has been closed. | 2015-04-07 23:15:41 HD Request # 15 | Historical data for NTCK-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-04-07 23:15:42 HD Request # 15 | Received 68 records from 2015-04-07 23:11:32 to 2015-04-07 23:15:38 (4.1 minutes) and wrote 68 records for NTCK-TF | 2015-04-07 23:15:42 HD Request # 15 | Intraday download COMPLETE for NTCK-TF. Completion time: 2s. Unique request ID: 22 | 2015-04-07 23:15:42 Removed historical data download ID 22 | 2015-04-07 23:15:42 Rithmic Trading | Port for executable: 63368 | 2015-04-07 23:15:45 Listening socket (1732), port 63368 | Closed. | 2015-04-07 23:15:45 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-04-07 23:15:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63368 | 2015-04-07 23:15:49 Socket (14) | Connected. | 2015-04-07 23:15:49 Rithmic Trading | Connected to server. | 2015-04-07 23:15:49 Rithmic Trading | Sending logon request message. | 2015-04-07 23:15:49 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-07 23:15:50 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-04-07 23:15:50 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-04-07 23:15:50 Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-04-07 23:15:54 Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2015-04-07 23:15:54 Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-04-07 23:15:55 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-04-07 23:15:56 Rithmic Trading | Server Alert: PnL Connection Opened | 2015-04-07 23:15:56 Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-04-07 23:15:57 Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-04-07 23:15:58 Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-04-07 23:15:58 Rithmic Trading | Server Name: SC DTC Bridge. | 2015-04-07 23:15:59 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-07 23:15:59 Rithmic Trading | Successfully connected. IB='AMP'. | 2015-04-07 23:15:59 Rithmic Trading | Trading is supported. | 2015-04-07 23:15:59 Rithmic Trading | Order cancel and replace is supported. | 2015-04-07 23:15:59 Rithmic Trading | Starting real-time market data updates for: 6BM5-CME. ID: 1 | 2015-04-07 23:15:59 Rithmic Trading | OCO Orders supported. | 2015-04-07 23:15:59 Rithmic Trading | Starting real-time market data updates for: 6EM5-CME. ID: 2 | 2015-04-07 23:15:59 Intraday data recording state for symbol 6EM5-CME is set to download pending. | 2015-04-07 23:15:59 HD Request # 16 | Downloading Intraday chart data for 6EM5-CME to the file 6EM5-CME.scid. Service: cme | 2015-04-07 23:15:59 HD Request # 16 | Download start Date-Time: 2015-04-07 22:59:56.0 | 2015-04-07 23:15:59 HD Request # 16 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:15:59 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:15:59 Rithmic Trading | Starting real-time market data updates for: CLK5-NYMEX. ID: 3 | 2015-04-07 23:15:59 Intraday data recording state for symbol CLK5-NYMEX is set to download pending. | 2015-04-07 23:15:59 Socket (15) | Connected. | 2015-04-07 23:16:00 HD Request # 16 | Sending historical data logon request message. | 2015-04-07 23:16:00 HD Request # 16 | Requesting Intraday data. Start Date-Time: 2015-04-07 22:59:56. Record interval: 1. Symbol: 6EM15 | 2015-04-07 23:16:00 HD Request # 16 | Decompressing data. | 2015-04-07 23:16:00 HD Request # 16 | Receiving Intraday data for 6EM5-CME starting at 2015-04-07 22:59:56 | 2015-04-07 23:16:00 HD Request # 16 | Timestamp of first Intraday data file record written: 2015-04-07 22:59:56 | 2015-04-07 23:16:00 Socket (15) | Shutdown and closed. | 2015-04-07 23:16:00 The network socket for historical data has been closed. | 2015-04-07 23:16:00 Rithmic Trading | Starting real-time market data updates for: TF FMM0015!-NYBOT. ID: 4 | 2015-04-07 23:16:01 Intraday data recording state for symbol TF FMM0015!-NYBOT is set to download pending. | 2015-04-07 23:16:01 HD Request # 16 | Received 1 record from 2015-04-07 22:59:56 to 2015-04-07 22:59:56 (0.0 seconds) and wrote 1 record for 6EM5-CME | 2015-04-07 23:16:01 HD Request # 16 | Intraday download COMPLETE for 6EM5-CME. Completion time: 2s. Unique request ID: 23 | 2015-04-07 23:16:01 Removed historical data download ID 23 | 2015-04-07 23:16:01 Real-time Intraday chart data file updates started for 6EM5-CME | 2015-04-07 23:16:01 Intraday data recording state for symbol 6EM5-CME is set to download pending. | 2015-04-07 23:16:01 HD Request # 17 | Downloading Intraday chart data for CLK5-NYMEX to the file CLK5-NYMEX.scid. Service: nymex | 2015-04-07 23:16:01 HD Request # 17 | Download start Date-Time: 2015-04-07 23:11:33.0 | 2015-04-07 23:16:01 HD Request # 17 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:16:01 HD Request # 18 | Downloading Intraday chart data for 6EM5-CME to the file 6EM5-CME.scid. Service: rim | 2015-04-07 23:16:01 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:16:01 HD Request # 18 | Download start Date-Time: 2015-04-07 22:59:56.0 | 2015-04-07 23:16:01 HD Request # 18 | Sending historical data request. Start Date-Time: 2015-04-07 22:59:56. Record interval: 1. Symbol: 6EM5-CME | 2015-04-07 23:16:01 Rithmic Trading | Starting real-time market data updates for: QMK5-NYMEX. ID: 5 | 2015-04-07 23:16:01 Intraday data recording state for symbol QMK5-NYMEX is set to download pending. | 2015-04-07 23:16:01 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:01 Rithmic Trading | Starting real-time market data updates for: DX FMM0015!-NYBOT. ID: 6 | 2015-04-07 23:16:01 Intraday data recording state for symbol DX FMM0015!-NYBOT is set to download pending. | 2015-04-07 23:16:01 Rithmic Trading | Starting real-time market data updates for: FGBL0615-EUREX. ID: 7 | 2015-04-07 23:16:01 Intraday data recording state for symbol FGBL0615-EUREX is set to download pending. | 2015-04-07 23:16:01 Rithmic Trading | Starting real-time market data updates for: FDAX0615-EUREX. ID: 8 | 2015-04-07 23:16:01 Intraday data recording state for symbol FDAX0615-EUREX is set to download pending. | 2015-04-07 23:16:01 Socket (16) | Connected. | 2015-04-07 23:16:01 HD Request # 17 | Sending historical data logon request message. | 2015-04-07 23:16:01 HD Request # 17 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:11:33. Record interval: 1. Symbol: CLK15 | 2015-04-07 23:16:01 HD Request # 17 | Decompressing data. | 2015-04-07 23:16:01 Socket (16) | Shutdown and closed. | 2015-04-07 23:16:02 The network socket for historical data has been closed. | 2015-04-07 23:16:02 HD Request # 18 | Receiving Intraday data for 6EM5-CME starting at 2015-04-07 22:58:00 | 2015-04-07 23:16:02 HD Request # 18 | Received 3 records from 2015-04-07 22:58:00 to 2015-04-07 22:59:00 (60.0 seconds) and wrote 0 records for 6EM5-CME | 2015-04-07 23:16:02 HD Request # 18 | Intraday download COMPLETE for 6EM5-CME. Completion time: 0s. Unique request ID: 26 | 2015-04-07 23:16:02 Removed historical data download ID 26 | 2015-04-07 23:16:02 Real-time Intraday chart data file updates started for 6EM5-CME | 2015-04-07 23:16:02 HD Request # 17 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLK5-NYMEX | 2015-04-07 23:16:02 HD Request # 17 | Intraday download COMPLETE for CLK5-NYMEX. Completion time: 0s. Unique request ID: 24 | 2015-04-07 23:16:02 Removed historical data download ID 24 | 2015-04-07 23:16:02 Real-time Intraday chart data file updates started for CLK5-NYMEX | 2015-04-07 23:16:02 Intraday data recording state for symbol CLK5-NYMEX is set to download pending. | 2015-04-07 23:16:02 HD Request # 19 | Downloading Intraday chart data for CLK5-NYMEX to the file CLK5-NYMEX.scid. Service: rim | 2015-04-07 23:16:02 HD Request # 19 | Download start Date-Time: 2015-04-07 23:11:33.0 | 2015-04-07 23:16:02 HD Request # 19 | Sending historical data request. Start Date-Time: 2015-04-07 23:11:33. Record interval: 1. Symbol: CLK5-NYMEX | 2015-04-07 23:16:02 HD Request # 20 | Downloading Intraday chart data for TF FMM0015!-NYBOT to the file TF FMM0015!-NYBOT.scid. Service: ice.us | 2015-04-07 23:16:02 HD Request # 20 | Download start Date-Time: 2015-04-07 23:10:22.0 | 2015-04-07 23:16:03 HD Request # 20 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:16:03 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:03 HD Request # 19 | Receiving Intraday data for CLK5-NYMEX starting at 2015-04-07 23:10:00 | 2015-04-07 23:16:03 HD Request # 19 | Timestamp of first Intraday data file record written: 2015-04-07 23:12:00 | 2015-04-07 23:16:03 HD Request # 19 | Received 7 records from 2015-04-07 23:10:00 to 2015-04-07 23:15:00 (5.0 minutes) and wrote 4 records for CLK5-NYMEX | 2015-04-07 23:16:03 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:16:03 HD Request # 19 | Intraday download COMPLETE for CLK5-NYMEX. Completion time: 1s. Unique request ID: 31 | 2015-04-07 23:16:03 Removed historical data download ID 31 | 2015-04-07 23:16:03 Real-time Intraday chart data file updates started for CLK5-NYMEX | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: 6AM5-CME. ID: 9 | 2015-04-07 23:16:03 Intraday data recording state for symbol 6AM5-CME is set to download pending. | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: 6JM5-CME. ID: 10 | 2015-04-07 23:16:03 Intraday data recording state for symbol 6JM5-CME is set to download pending. | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: ESM5-CME. ID: 11 | 2015-04-07 23:16:03 Intraday data recording state for symbol ESM5-CME is set to download pending. | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: YMM5-CBOT. ID: 12 | 2015-04-07 23:16:03 Intraday data recording state for symbol YMM5-CBOT is set to download pending. | 2015-04-07 23:16:03 Socket (17) | Connected. | 2015-04-07 23:16:03 HD Request # 20 | Sending historical data logon request message. | 2015-04-07 23:16:03 HD Request # 20 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:10:22. Record interval: 1. Symbol: RJM15 | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: NQM5-CME. ID: 13 | 2015-04-07 23:16:03 Intraday data recording state for symbol NQM5-CME is set to download pending. | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: M6EM5-CME. ID: 14 | 2015-04-07 23:16:03 Intraday data recording state for symbol M6EM5-CME is set to download pending. | 2015-04-07 23:16:03 Intraday data recording state for symbol 6BM5-CME is set to download pending. | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: CC FMK0015!-NYBOT. ID: 15 | 2015-04-07 23:16:03 Intraday data recording state for symbol CC FMK0015!-NYBOT is set to download pending. | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: HGK5-COMEX. ID: 16 | 2015-04-07 23:16:03 Intraday data recording state for symbol HGK5-COMEX is set to download pending. | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: NGK5-NYMEX. ID: 17 | 2015-04-07 23:16:03 Intraday data recording state for symbol NGK5-NYMEX is set to download pending. | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: ZSK5-CBOT. ID: 18 | 2015-04-07 23:16:03 Intraday data recording state for symbol ZSK5-CBOT is set to download pending. | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: SB FMN0015!-NYBOT. ID: 19 | 2015-04-07 23:16:03 Intraday data recording state for symbol SB FMN0015!-NYBOT is set to download pending. | 2015-04-07 23:16:03 Rithmic Trading | Starting real-time market data updates for: GCM5-COMEX. ID: 20 | 2015-04-07 23:16:03 Intraday data recording state for symbol GCM5-COMEX is set to download pending. | 2015-04-07 23:16:03 HD Request # 20 | Decompressing data. | 2015-04-07 23:16:03 Socket (17) | Shutdown and closed. | 2015-04-07 23:16:03 The network socket for historical data has been closed. | 2015-04-07 23:16:03 SC Market Stats | Starting real-time market data updates for: TICK-TF. ID: 21 | 2015-04-07 23:16:03 SC Market Stats | Connecting to the server ds5.sierracharts.com. Port 443 | 2015-04-07 23:16:03 Intraday data recording state for symbol TICK-TF is set to download pending. | 2015-04-07 23:16:03 HD Request # 20 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMM0015!-NYBOT | 2015-04-07 23:16:03 HD Request # 20 | Intraday download COMPLETE for TF FMM0015!-NYBOT. Completion time: 1s. Unique request ID: 25 | 2015-04-07 23:16:03 Removed historical data download ID 25 | 2015-04-07 23:16:03 Real-time Intraday chart data file updates started for TF FMM0015!-NYBOT | 2015-04-07 23:16:03 Intraday data recording state for symbol TF FMM0015!-NYBOT is set to download pending. | 2015-04-07 23:16:03 HD Request # 21 | Downloading Intraday chart data for QMK5-NYMEX to the file QMK5-NYMEX.scid. Service: nymex | 2015-04-07 23:16:03 HD Request # 21 | Download start Date-Time: 2015-04-07 23:11:11.0 | 2015-04-07 23:16:03 HD Request # 21 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:16:03 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-04-07 23:16:03 HD Request # 22 | Downloading Intraday chart data for TF FMM0015!-NYBOT to the file TF FMM0015!-NYBOT.scid. Service: rim | 2015-04-07 23:16:03 HD Request # 22 | Download start Date-Time: 2015-04-07 23:10:22.0 | 2015-04-07 23:16:03 HD Request # 22 | Sending historical data request. Start Date-Time: 2015-04-07 23:10:22. Record interval: 1. Symbol: TF FMM0015!-NYBOT | 2015-04-07 23:16:03 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:03 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:16:03 Socket (19) | Connected. | 2015-04-07 23:16:04 HD Request # 21 | Sending historical data logon request message. | 2015-04-07 23:16:04 HD Request # 21 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:11:11. Record interval: 1. Symbol: QMK15 | 2015-04-07 23:16:04 SC Market Stats | Starting real-time market data updates for: NTCK-NYSE. ID: 22 | 2015-04-07 23:16:04 Intraday data recording state for symbol NTCK-NYSE is set to download pending. | 2015-04-07 23:16:04 HD Request # 22 | Receiving Intraday data for TF FMM0015!-NYBOT starting at 2015-04-07 23:10:00 | 2015-04-07 23:16:04 HD Request # 22 | Timestamp of first Intraday data file record written: 2015-04-07 23:12:00 | 2015-04-07 23:16:04 HD Request # 21 | Decompressing data. | 2015-04-07 23:16:04 Socket (19) | Shutdown and closed. | 2015-04-07 23:16:04 The network socket for historical data has been closed. | 2015-04-07 23:16:04 HD Request # 22 | Received 6 records from 2015-04-07 23:10:00 to 2015-04-07 23:15:00 (5.0 minutes) and wrote 4 records for TF FMM0015!-NYBOT | 2015-04-07 23:16:05 HD Request # 22 | Intraday download COMPLETE for TF FMM0015!-NYBOT. Completion time: 2s. Unique request ID: 46 | 2015-04-07 23:16:05 Removed historical data download ID 46 | 2015-04-07 23:16:05 Real-time Intraday chart data file updates started for TF FMM0015!-NYBOT | 2015-04-07 23:16:05 Socket (18) | Connected. | 2015-04-07 23:16:05 SC Market Stats | Connected to server. | 2015-04-07 23:16:05 SC Market Stats | Sending logon request message. | 2015-04-07 23:16:05 HD Request # 21 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for QMK5-NYMEX | 2015-04-07 23:16:05 HD Request # 21 | Intraday download COMPLETE for QMK5-NYMEX. Completion time: 2s. Unique request ID: 27 | 2015-04-07 23:16:05 Removed historical data download ID 27 | 2015-04-07 23:16:05 Real-time Intraday chart data file updates started for QMK5-NYMEX | 2015-04-07 23:16:05 Intraday data recording state for symbol QMK5-NYMEX is set to download pending. | 2015-04-07 23:16:05 HD Request # 23 | Downloading Intraday chart data for QMK5-NYMEX to the file QMK5-NYMEX.scid. Service: rim | 2015-04-07 23:16:05 HD Request # 23 | Download start Date-Time: 2015-04-07 23:11:11.0 | 2015-04-07 23:16:05 HD Request # 23 | Sending historical data request. Start Date-Time: 2015-04-07 23:11:11. Record interval: 1. Symbol: QMK5-NYMEX | 2015-04-07 23:16:05 HD Request # 24 | Downloading Intraday chart data for DX FMM0015!-NYBOT to the file DX FMM0015!-NYBOT.scid. Service: ice.us | 2015-04-07 23:16:05 HD Request # 24 | Download start Date-Time: 2015-04-07 22:59:11.0 | 2015-04-07 23:16:05 HD Request # 24 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:16:05 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:05 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:16:05 Socket (20) | Connected. | 2015-04-07 23:16:05 HD Request # 24 | Sending historical data logon request message. | 2015-04-07 23:16:05 HD Request # 24 | Requesting Intraday data. Start Date-Time: 2015-04-07 22:59:11. Record interval: 1. Symbol: DXM15 | 2015-04-07 23:16:05 HD Request # 24 | Decompressing data. | 2015-04-07 23:16:06 HD Request # 24 | Receiving Intraday data for DX FMM0015!-NYBOT starting at 2015-04-07 22:59:11 | 2015-04-07 23:16:06 HD Request # 24 | Timestamp of first Intraday data file record written: 2015-04-07 22:59:11 | 2015-04-07 23:16:06 Socket (20) | Shutdown and closed. | 2015-04-07 23:16:06 The network socket for historical data has been closed. | 2015-04-07 23:16:06 SC Market Stats | Starting real-time market data updates for: NTCK-TF. ID: 23 | 2015-04-07 23:16:06 Intraday data recording state for symbol NTCK-TF is set to download pending. | 2015-04-07 23:16:06 HD Request # 23 | Receiving Intraday data for QMK5-NYMEX starting at 2015-04-07 23:10:00 | 2015-04-07 23:16:06 HD Request # 23 | Timestamp of first Intraday data file record written: 2015-04-07 23:12:00 | 2015-04-07 23:16:06 HD Request # 23 | Received 6 records from 2015-04-07 23:10:00 to 2015-04-07 23:14:00 (4.0 minutes) and wrote 3 records for QMK5-NYMEX | 2015-04-07 23:16:06 HD Request # 23 | Intraday download COMPLETE for QMK5-NYMEX. Completion time: 1s. Unique request ID: 48 | 2015-04-07 23:16:06 Removed historical data download ID 48 | 2015-04-07 23:16:06 Real-time Intraday chart data file updates started for QMK5-NYMEX | 2015-04-07 23:16:06 HD Request # 24 | Received 1 record from 2015-04-07 22:59:11 to 2015-04-07 22:59:11 (0.0 seconds) and wrote 1 record for DX FMM0015!-NYBOT | 2015-04-07 23:16:06 HD Request # 24 | Intraday download COMPLETE for DX FMM0015!-NYBOT. Completion time: 1s. Unique request ID: 28 | 2015-04-07 23:16:06 Removed historical data download ID 28 | 2015-04-07 23:16:06 Real-time Intraday chart data file updates started for DX FMM0015!-NYBOT | 2015-04-07 23:16:06 Intraday data recording state for symbol DX FMM0015!-NYBOT is set to download pending. | 2015-04-07 23:16:06 HD Request # 25 | Downloading Intraday chart data for FGBL0615-EUREX to the file FGBL0615-EUREX.scid. Service: eurex | 2015-04-07 23:16:06 HD Request # 25 | Download start Date-Time: 2015-04-07 22:03:34.0 | 2015-04-07 23:16:06 HD Request # 25 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:16:06 HD Request # 26 | Downloading Intraday chart data for DX FMM0015!-NYBOT to the file DX FMM0015!-NYBOT.scid. Service: rim | 2015-04-07 23:16:06 HD Request # 26 | Download start Date-Time: 2015-04-07 22:59:11.0 | 2015-04-07 23:16:06 HD Request # 26 | Sending historical data request. Start Date-Time: 2015-04-07 22:59:11. Record interval: 1. Symbol: DX FMM0015!-NYBOT | 2015-04-07 23:16:06 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:06 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:16:06 Socket (21) | Connected. | 2015-04-07 23:16:06 HD Request # 25 | Sending historical data logon request message. | 2015-04-07 23:16:06 HD Request # 25 | Requesting Intraday data. Start Date-Time: 2015-04-07 22:03:34. Record interval: 1. Symbol: GGM15 | 2015-04-07 23:16:06 SC Market Stats | Server Name: SC Real-Time Server. | 2015-04-07 23:16:06 SC Market Stats | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-07 23:16:06 SC Market Stats | Successfully connected. | 2015-04-07 23:16:06 SC Market Stats | Restarting real-time data updates for symbol: NTCK-NYSE | 2015-04-07 23:16:06 SC Market Stats | Restarting real-time data updates for symbol: NTCK-TF | 2015-04-07 23:16:06 SC Market Stats | Restarting real-time data updates for symbol: TICK-TF | 2015-04-07 23:16:06 HD Request # 26 | Receiving Intraday data for DX FMM0015!-NYBOT starting at 2015-04-07 22:58:00 | 2015-04-07 23:16:06 HD Request # 26 | Received 3 records from 2015-04-07 22:58:00 to 2015-04-07 22:59:00 (60.0 seconds) and wrote 0 records for DX FMM0015!-NYBOT | 2015-04-07 23:16:06 HD Request # 26 | Intraday download COMPLETE for DX FMM0015!-NYBOT. Completion time: 0s. Unique request ID: 50 | 2015-04-07 23:16:06 Removed historical data download ID 50 | 2015-04-07 23:16:06 Real-time Intraday chart data file updates started for DX FMM0015!-NYBOT | 2015-04-07 23:16:06 HD Request # 25 | Decompressing data. | 2015-04-07 23:16:06 HD Request # 25 | Receiving Intraday data for FGBL0615-EUREX starting at 2015-04-07 22:03:34 | 2015-04-07 23:16:06 HD Request # 25 | Timestamp of first Intraday data file record written: 2015-04-07 22:03:34 | 2015-04-07 23:16:06 Socket (21) | Shutdown and closed. | 2015-04-07 23:16:06 The network socket for historical data has been closed. | 2015-04-07 23:16:06 HD Request # 25 | Received 1 record from 2015-04-07 22:03:34 to 2015-04-07 22:03:34 (0.0 seconds) and wrote 1 record for FGBL0615-EUREX | 2015-04-07 23:16:07 HD Request # 25 | Intraday download COMPLETE for FGBL0615-EUREX. Completion time: 0s. Unique request ID: 29 | 2015-04-07 23:16:07 Removed historical data download ID 29 | 2015-04-07 23:16:07 Real-time Intraday chart data file updates started for FGBL0615-EUREX | 2015-04-07 23:16:07 Intraday data recording state for symbol FGBL0615-EUREX is set to download pending. | 2015-04-07 23:16:07 HD Request # 27 | Downloading Intraday chart data for FGBL0615-EUREX to the file FGBL0615-EUREX.scid. Service: rim | 2015-04-07 23:16:07 HD Request # 27 | Download start Date-Time: 2015-04-07 22:03:34.0 | 2015-04-07 23:16:07 HD Request # 27 | Sending historical data request. Start Date-Time: 2015-04-07 22:03:34. Record interval: 1. Symbol: FGBL0615-EUREX | 2015-04-07 23:16:07 HD Request # 28 | Downloading Intraday chart data for FDAX0615-EUREX to the file FDAX0615-EUREX.scid. Service: eurex | 2015-04-07 23:16:07 HD Request # 28 | Download start Date-Time: 2015-04-07 22:03:33.0 | 2015-04-07 23:16:07 HD Request # 28 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:16:07 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:07 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:16:07 Socket (22) | Connected. | 2015-04-07 23:16:08 HD Request # 28 | Sending historical data logon request message. | 2015-04-07 23:16:08 HD Request # 28 | Requesting Intraday data. Start Date-Time: 2015-04-07 22:03:33. Record interval: 1. Symbol: DYM15 | 2015-04-07 23:16:08 HD Request # 28 | Decompressing data. | 2015-04-07 23:16:08 HD Request # 28 | Receiving Intraday data for FDAX0615-EUREX starting at 2015-04-07 22:03:33 | 2015-04-07 23:16:08 HD Request # 28 | Timestamp of first Intraday data file record written: 2015-04-07 22:03:33 | 2015-04-07 23:16:08 Socket (22) | Shutdown and closed. | 2015-04-07 23:16:08 The network socket for historical data has been closed. | 2015-04-07 23:16:08 HD Request # 27 | Receiving Intraday data for FGBL0615-EUREX starting at 2015-04-07 22:03:00 | 2015-04-07 23:16:09 HD Request # 27 | Received 2 records from 2015-04-07 22:03:00 to 2015-04-07 22:03:00 (0.0 seconds) and wrote 0 records for FGBL0615-EUREX | 2015-04-07 23:16:09 HD Request # 27 | Intraday download COMPLETE for FGBL0615-EUREX. Completion time: 2s. Unique request ID: 51 | 2015-04-07 23:16:09 Removed historical data download ID 51 | 2015-04-07 23:16:09 Real-time Intraday chart data file updates started for FGBL0615-EUREX | 2015-04-07 23:16:09 HD Request # 28 | Received 1 record from 2015-04-07 22:03:33 to 2015-04-07 22:03:33 (0.0 seconds) and wrote 1 record for FDAX0615-EUREX | 2015-04-07 23:16:09 HD Request # 28 | Intraday download COMPLETE for FDAX0615-EUREX. Completion time: 2s. Unique request ID: 30 | 2015-04-07 23:16:09 Removed historical data download ID 30 | 2015-04-07 23:16:09 Real-time Intraday chart data file updates started for FDAX0615-EUREX | 2015-04-07 23:16:09 Intraday data recording state for symbol FDAX0615-EUREX is set to download pending. | 2015-04-07 23:16:09 HD Request # 29 | Downloading Intraday chart data for FDAX0615-EUREX to the file FDAX0615-EUREX.scid. Service: rim | 2015-04-07 23:16:09 HD Request # 29 | Download start Date-Time: 2015-04-07 22:03:33.0 | 2015-04-07 23:16:09 HD Request # 29 | Sending historical data request. Start Date-Time: 2015-04-07 22:03:33. Record interval: 1. Symbol: FDAX0615-EUREX | 2015-04-07 23:16:09 HD Request # 30 | Downloading Intraday chart data for 6AM5-CME to the file 6AM5-CME.scid. Service: cme | 2015-04-07 23:16:09 HD Request # 30 | Download start Date-Time: 2015-04-07 22:59:55.0 | 2015-04-07 23:16:09 HD Request # 30 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:16:09 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:09 Rithmic Trading | Starting real-time market data updates for: ZNM5-CBOT. ID: 24 | 2015-04-07 23:16:09 Intraday data recording state for symbol ZNM5-CBOT is set to download pending. | 2015-04-07 23:16:09 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:16:09 Socket (23) | Connected. | 2015-04-07 23:16:09 HD Request # 30 | Sending historical data logon request message. | 2015-04-07 23:16:09 HD Request # 30 | Requesting Intraday data. Start Date-Time: 2015-04-07 22:59:55. Record interval: 1. Symbol: 6AM15 | 2015-04-07 23:16:09 HD Request # 29 | Receiving Intraday data for FDAX0615-EUREX starting at 2015-04-07 22:03:00 | 2015-04-07 23:16:09 HD Request # 29 | Received 2 records from 2015-04-07 22:03:00 to 2015-04-07 22:03:00 (0.0 seconds) and wrote 0 records for FDAX0615-EUREX | 2015-04-07 23:16:09 HD Request # 29 | Intraday download COMPLETE for FDAX0615-EUREX. Completion time: 0s. Unique request ID: 52 | 2015-04-07 23:16:09 Removed historical data download ID 52 | 2015-04-07 23:16:09 Real-time Intraday chart data file updates started for FDAX0615-EUREX | 2015-04-07 23:16:09 HD Request # 30 | Decompressing data. | 2015-04-07 23:16:10 HD Request # 30 | Receiving Intraday data for 6AM5-CME starting at 2015-04-07 22:59:55 | 2015-04-07 23:16:10 HD Request # 30 | Timestamp of first Intraday data file record written: 2015-04-07 22:59:55 | 2015-04-07 23:16:10 Socket (23) | Shutdown and closed. | 2015-04-07 23:16:10 The network socket for historical data has been closed. | 2015-04-07 23:16:10 HD Request # 30 | Received 1 record from 2015-04-07 22:59:55 to 2015-04-07 22:59:55 (0.0 seconds) and wrote 1 record for 6AM5-CME | 2015-04-07 23:16:11 HD Request # 30 | Intraday download COMPLETE for 6AM5-CME. Completion time: 2s. Unique request ID: 32 | 2015-04-07 23:16:11 Removed historical data download ID 32 | 2015-04-07 23:16:11 Real-time Intraday chart data file updates started for 6AM5-CME | 2015-04-07 23:16:11 Intraday data recording state for symbol 6AM5-CME is set to download pending. | 2015-04-07 23:16:11 HD Request # 31 | Downloading Intraday chart data for 6AM5-CME to the file 6AM5-CME.scid. Service: rim | 2015-04-07 23:16:11 HD Request # 31 | Download start Date-Time: 2015-04-07 22:59:55.0 | 2015-04-07 23:16:11 HD Request # 31 | Sending historical data request. Start Date-Time: 2015-04-07 22:59:55. Record interval: 1. Symbol: 6AM5-CME | 2015-04-07 23:16:11 HD Request # 32 | Downloading Intraday chart data for 6JM5-CME to the file 6JM5-CME.scid. Service: cme | 2015-04-07 23:16:11 HD Request # 32 | Download start Date-Time: 2015-04-07 22:59:57.0 | 2015-04-07 23:16:11 HD Request # 32 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:16:11 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:11 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:16:11 Socket (24) | Connected. | 2015-04-07 23:16:11 HD Request # 32 | Sending historical data logon request message. | 2015-04-07 23:16:11 HD Request # 31 | Receiving Intraday data for 6AM5-CME starting at 2015-04-07 22:58:00 | 2015-04-07 23:16:11 HD Request # 31 | Received 3 records from 2015-04-07 22:58:00 to 2015-04-07 22:59:00 (60.0 seconds) and wrote 0 records for 6AM5-CME | 2015-04-07 23:16:11 HD Request # 31 | Intraday download COMPLETE for 6AM5-CME. Completion time: 0s. Unique request ID: 54 | 2015-04-07 23:16:11 Removed historical data download ID 54 | 2015-04-07 23:16:11 Real-time Intraday chart data file updates started for 6AM5-CME | 2015-04-07 23:16:11 HD Request # 32 | Requesting Intraday data. Start Date-Time: 2015-04-07 22:59:57. Record interval: 1. Symbol: 6JM15 | 2015-04-07 23:16:11 HD Request # 32 | Decompressing data. | 2015-04-07 23:16:11 HD Request # 32 | Receiving Intraday data for 6JM5-CME starting at 2015-04-07 22:59:57 | 2015-04-07 23:16:11 HD Request # 32 | Timestamp of first Intraday data file record written: 2015-04-07 22:59:57 | 2015-04-07 23:16:11 Socket (24) | Shutdown and closed. | 2015-04-07 23:16:11 The network socket for historical data has been closed. | 2015-04-07 23:16:11 HD Request # 32 | Received 1 record from 2015-04-07 22:59:57 to 2015-04-07 22:59:57 (0.0 seconds) and wrote 1 record for 6JM5-CME | 2015-04-07 23:16:13 HD Request # 32 | Intraday download COMPLETE for 6JM5-CME. Completion time: 2s. Unique request ID: 33 | 2015-04-07 23:16:13 Removed historical data download ID 33 | 2015-04-07 23:16:13 Real-time Intraday chart data file updates started for 6JM5-CME | 2015-04-07 23:16:13 Intraday data recording state for symbol 6JM5-CME is set to download pending. | 2015-04-07 23:16:13 HD Request # 33 | Downloading Intraday chart data for 6JM5-CME to the file 6JM5-CME.scid. Service: rim | 2015-04-07 23:16:13 HD Request # 33 | Download start Date-Time: 2015-04-07 22:59:57.0 | 2015-04-07 23:16:13 HD Request # 33 | Sending historical data request. Start Date-Time: 2015-04-07 22:59:57. Record interval: 1. Symbol: 6JM5-CME | 2015-04-07 23:16:13 HD Request # 34 | Downloading Intraday chart data for ESM5-CME to the file ESM5-CME.scid. Service: cme | 2015-04-07 23:16:13 HD Request # 34 | Download start Date-Time: 2015-04-07 23:11:26.0 | 2015-04-07 23:16:13 HD Request # 34 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:16:13 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:13 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:16:13 Socket (25) | Connected. | 2015-04-07 23:16:13 HD Request # 34 | Sending historical data logon request message. | 2015-04-07 23:16:13 HD Request # 33 | Receiving Intraday data for 6JM5-CME starting at 2015-04-07 22:58:00 | 2015-04-07 23:16:13 HD Request # 33 | Received 3 records from 2015-04-07 22:58:00 to 2015-04-07 22:59:00 (60.0 seconds) and wrote 0 records for 6JM5-CME | 2015-04-07 23:16:13 HD Request # 33 | Intraday download COMPLETE for 6JM5-CME. Completion time: 0s. Unique request ID: 55 | 2015-04-07 23:16:13 Removed historical data download ID 55 | 2015-04-07 23:16:13 Real-time Intraday chart data file updates started for 6JM5-CME | 2015-04-07 23:16:13 HD Request # 34 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:11:26. Record interval: 1. Symbol: ESM15 | 2015-04-07 23:16:13 Rithmic Trading | Requesting Trade Positions data. | 2015-04-07 23:16:13 Requesting market depth updates for: 6AM5-CME if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: 6BM5-CME if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: 6EM5-CME if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: 6JM5-CME if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: CC FMK0015!-NYBOT if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: CLK5-NYMEX if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: DX FMM0015!-NYBOT if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: ESM5-CME if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: FDAX0615-EUREX if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: FGBL0615-EUREX if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: GCM5-COMEX if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: HGK5-COMEX if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: M6EM5-CME if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: NGK5-NYMEX if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: NQM5-CME if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: QMK5-NYMEX if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: SB FMN0015!-NYBOT if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: TF FMM0015!-NYBOT if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: YMM5-CBOT if supported. | 2015-04-07 23:16:13 Requesting market depth updates for: ZSK5-CBOT if supported. | 2015-04-07 23:16:13 HD Request # 34 | Decompressing data. | 2015-04-07 23:16:13 Socket (25) | Shutdown and closed. | 2015-04-07 23:16:13 The network socket for historical data has been closed. | 2015-04-07 23:16:13 HD Request # 34 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM5-CME | 2015-04-07 23:16:14 HD Request # 34 | Intraday download COMPLETE for ESM5-CME. Completion time: 1s. Unique request ID: 34 | 2015-04-07 23:16:14 Removed historical data download ID 34 | 2015-04-07 23:16:14 Real-time Intraday chart data file updates started for ESM5-CME | 2015-04-07 23:16:14 Intraday data recording state for symbol ESM5-CME is set to download pending. | 2015-04-07 23:16:14 HD Request # 35 | Downloading Intraday chart data for ESM5-CME to the file ESM5-CME.scid. Service: rim | 2015-04-07 23:16:14 HD Request # 35 | Download start Date-Time: 2015-04-07 23:11:26.0 | 2015-04-07 23:16:14 HD Request # 35 | Sending historical data request. Start Date-Time: 2015-04-07 23:11:26. Record interval: 1. Symbol: ESM5-CME | 2015-04-07 23:16:14 HD Request # 36 | Downloading Intraday chart data for YMM5-CBOT to the file YMM5-CBOT.scid. Service: cbot | 2015-04-07 23:16:14 HD Request # 36 | Download start Date-Time: 2015-04-07 23:11:25.0 | 2015-04-07 23:16:14 HD Request # 36 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:16:14 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:14 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:16:14 Socket (26) | Connected. | 2015-04-07 23:16:14 HD Request # 36 | Sending historical data logon request message. | 2015-04-07 23:16:14 HD Request # 36 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:11:25. Record interval: 1. Symbol: YMM15 | 2015-04-07 23:16:15 HD Request # 36 | Decompressing data. | 2015-04-07 23:16:15 Socket (26) | Shutdown and closed. | 2015-04-07 23:16:15 The network socket for historical data has been closed. | 2015-04-07 23:16:15 HD Request # 35 | Receiving Intraday data for ESM5-CME starting at 2015-04-07 23:10:00 | 2015-04-07 23:16:15 HD Request # 35 | Timestamp of first Intraday data file record written: 2015-04-07 23:12:00 | 2015-04-07 23:16:15 HD Request # 35 | Received 6 records from 2015-04-07 23:10:00 to 2015-04-07 23:14:00 (4.0 minutes) and wrote 3 records for ESM5-CME | 2015-04-07 23:16:15 HD Request # 35 | Intraday download COMPLETE for ESM5-CME. Completion time: 0s. Unique request ID: 56 | 2015-04-07 23:16:15 Removed historical data download ID 56 | 2015-04-07 23:16:15 Real-time Intraday chart data file updates started for ESM5-CME | 2015-04-07 23:16:15 HD Request # 36 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMM5-CBOT | 2015-04-07 23:16:15 HD Request # 36 | Intraday download COMPLETE for YMM5-CBOT. Completion time: 0s. Unique request ID: 35 | 2015-04-07 23:16:15 Removed historical data download ID 35 | 2015-04-07 23:16:15 Real-time Intraday chart data file updates started for YMM5-CBOT | 2015-04-07 23:16:15 Intraday data recording state for symbol YMM5-CBOT is set to download pending. | 2015-04-07 23:16:15 HD Request # 37 | Downloading Intraday chart data for YMM5-CBOT to the file YMM5-CBOT.scid. Service: rim | 2015-04-07 23:16:15 HD Request # 37 | Download start Date-Time: 2015-04-07 23:11:25.0 | 2015-04-07 23:16:16 HD Request # 37 | Sending historical data request. Start Date-Time: 2015-04-07 23:11:25. Record interval: 1. Symbol: YMM5-CBOT | 2015-04-07 23:16:16 HD Request # 38 | Downloading Intraday chart data for NQM5-CME to the file NQM5-CME.scid. Service: cme | 2015-04-07 23:16:16 HD Request # 38 | Download start Date-Time: 2015-04-07 23:11:16.0 | 2015-04-07 23:16:16 HD Request # 38 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:16:16 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:16 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:16:16 Socket (27) | Connected. | 2015-04-07 23:16:16 HD Request # 38 | Sending historical data logon request message. | 2015-04-07 23:16:16 HD Request # 37 | Receiving Intraday data for YMM5-CBOT starting at 2015-04-07 23:10:00 | 2015-04-07 23:16:16 HD Request # 37 | Timestamp of first Intraday data file record written: 2015-04-07 23:13:00 | 2015-04-07 23:16:16 HD Request # 37 | Received 5 records from 2015-04-07 23:10:00 to 2015-04-07 23:14:00 (4.0 minutes) and wrote 2 records for YMM5-CBOT | 2015-04-07 23:16:16 HD Request # 37 | Intraday download COMPLETE for YMM5-CBOT. Completion time: 1s. Unique request ID: 57 | 2015-04-07 23:16:16 Removed historical data download ID 57 | 2015-04-07 23:16:16 Real-time Intraday chart data file updates started for YMM5-CBOT | 2015-04-07 23:16:16 HD Request # 38 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:11:16. Record interval: 1. Symbol: NQM15 | 2015-04-07 23:16:16 HD Request # 38 | Decompressing data. | 2015-04-07 23:16:16 Socket (27) | Shutdown and closed. | 2015-04-07 23:16:16 The network socket for historical data has been closed. | 2015-04-07 23:16:16 HD Request # 38 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQM5-CME | 2015-04-07 23:16:17 HD Request # 38 | Intraday download COMPLETE for NQM5-CME. Completion time: 1s. Unique request ID: 36 | 2015-04-07 23:16:17 Removed historical data download ID 36 | 2015-04-07 23:16:17 Real-time Intraday chart data file updates started for NQM5-CME | 2015-04-07 23:16:17 Intraday data recording state for symbol NQM5-CME is set to download pending. | 2015-04-07 23:16:17 HD Request # 39 | Downloading Intraday chart data for NQM5-CME to the file NQM5-CME.scid. Service: rim | 2015-04-07 23:16:17 HD Request # 39 | Download start Date-Time: 2015-04-07 23:11:16.0 | 2015-04-07 23:16:17 HD Request # 39 | Sending historical data request. Start Date-Time: 2015-04-07 23:11:16. Record interval: 1. Symbol: NQM5-CME | 2015-04-07 23:16:17 HD Request # 40 | Downloading Intraday chart data for M6EM5-CME to the file M6EM5-CME.scid. Service: cme | 2015-04-07 23:16:17 HD Request # 40 | Download start Date-Time: 2015-04-07 22:59:34.0 | 2015-04-07 23:16:17 HD Request # 40 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:16:17 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:17 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:16:17 Socket (28) | Connected. | 2015-04-07 23:16:17 HD Request # 40 | Sending historical data logon request message. | 2015-04-07 23:16:17 HD Request # 40 | Requesting Intraday data. Start Date-Time: 2015-04-07 22:59:34. Record interval: 1. Symbol: M6EM15 | 2015-04-07 23:16:18 HD Request # 39 | Receiving Intraday data for NQM5-CME starting at 2015-04-07 23:10:00 | 2015-04-07 23:16:18 HD Request # 40 | Decompressing data. | 2015-04-07 23:16:18 HD Request # 40 | Receiving Intraday data for M6EM5-CME starting at 2015-04-07 22:59:34 | 2015-04-07 23:16:18 HD Request # 40 | Timestamp of first Intraday data file record written: 2015-04-07 22:59:34 | 2015-04-07 23:16:18 Socket (28) | Shutdown and closed. | 2015-04-07 23:16:18 The network socket for historical data has been closed. | 2015-04-07 23:16:18 HD Request # 39 | Timestamp of first Intraday data file record written: 2015-04-07 23:12:00 | 2015-04-07 23:16:18 HD Request # 39 | Received 6 records from 2015-04-07 23:10:00 to 2015-04-07 23:14:00 (4.0 minutes) and wrote 3 records for NQM5-CME | 2015-04-07 23:16:18 HD Request # 39 | Intraday download COMPLETE for NQM5-CME. Completion time: 0s. Unique request ID: 58 | 2015-04-07 23:16:18 Removed historical data download ID 58 | 2015-04-07 23:16:18 Real-time Intraday chart data file updates started for NQM5-CME | 2015-04-07 23:16:18 HD Request # 40 | Received 1 record from 2015-04-07 22:59:34 to 2015-04-07 22:59:34 (0.0 seconds) and wrote 1 record for M6EM5-CME | 2015-04-07 23:16:18 HD Request # 40 | Intraday download COMPLETE for M6EM5-CME. Completion time: 0s. Unique request ID: 37 | 2015-04-07 23:16:18 Removed historical data download ID 37 | 2015-04-07 23:16:18 Real-time Intraday chart data file updates started for M6EM5-CME | 2015-04-07 23:16:18 Intraday data recording state for symbol M6EM5-CME is set to download pending. | 2015-04-07 23:16:18 HD Request # 41 | Downloading Intraday chart data for M6EM5-CME to the file M6EM5-CME.scid. Service: rim | 2015-04-07 23:16:18 HD Request # 41 | Download start Date-Time: 2015-04-07 22:59:34.0 | 2015-04-07 23:16:18 HD Request # 41 | Sending historical data request. Start Date-Time: 2015-04-07 22:59:34. Record interval: 1. Symbol: M6EM5-CME | 2015-04-07 23:16:18 HD Request # 42 | Downloading Intraday chart data for 6BM5-CME to the file 6BM5-CME.scid. Service: cme | 2015-04-07 23:16:18 HD Request # 42 | Download start Date-Time: 2015-04-07 22:59:59.0 | 2015-04-07 23:16:18 HD Request # 42 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:16:18 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:18 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:16:18 Socket (29) | Connected. | 2015-04-07 23:16:18 HD Request # 42 | Sending historical data logon request message. | 2015-04-07 23:16:18 HD Request # 41 | Receiving Intraday data for M6EM5-CME starting at 2015-04-07 22:59:00 | 2015-04-07 23:16:18 HD Request # 41 | Received 2 records from 2015-04-07 22:59:00 to 2015-04-07 22:59:00 (0.0 seconds) and wrote 0 records for M6EM5-CME | 2015-04-07 23:16:18 HD Request # 41 | Intraday download COMPLETE for M6EM5-CME. Completion time: 0s. Unique request ID: 59 | 2015-04-07 23:16:18 Removed historical data download ID 59 | 2015-04-07 23:16:18 Real-time Intraday chart data file updates started for M6EM5-CME | 2015-04-07 23:16:18 HD Request # 42 | Requesting Intraday data. Start Date-Time: 2015-04-07 22:59:59. Record interval: 1. Symbol: 6BM15 | 2015-04-07 23:16:18 HD Request # 42 | Decompressing data. | 2015-04-07 23:16:18 HD Request # 42 | Receiving Intraday data for 6BM5-CME starting at 2015-04-07 22:59:59 | 2015-04-07 23:16:18 HD Request # 42 | Timestamp of first Intraday data file record written: 2015-04-07 22:59:59 | 2015-04-07 23:16:18 Socket (29) | Shutdown and closed. | 2015-04-07 23:16:18 The network socket for historical data has been closed. | 2015-04-07 23:16:18 HD Request # 42 | Received 1 record from 2015-04-07 22:59:59 to 2015-04-07 22:59:59 (0.0 seconds) and wrote 1 record for 6BM5-CME | 2015-04-07 23:16:20 HD Request # 42 | Intraday download COMPLETE for 6BM5-CME. Completion time: 2s. Unique request ID: 38 | 2015-04-07 23:16:20 Removed historical data download ID 38 | 2015-04-07 23:16:20 Real-time Intraday chart data file updates started for 6BM5-CME | 2015-04-07 23:16:20 Intraday data recording state for symbol 6BM5-CME is set to download pending. | 2015-04-07 23:16:20 HD Request # 43 | Downloading Intraday chart data for 6BM5-CME to the file 6BM5-CME.scid. Service: rim | 2015-04-07 23:16:20 HD Request # 43 | Download start Date-Time: 2015-04-07 22:59:59.0 | 2015-04-07 23:16:20 HD Request # 43 | Sending historical data request. Start Date-Time: 2015-04-07 22:59:59. Record interval: 1. Symbol: 6BM5-CME | 2015-04-07 23:16:20 HD Request # 44 | Downloading Intraday chart data for CC FMK0015!-NYBOT to the file CC FMK0015!-NYBOT.scid. Service: ice.us | 2015-04-07 23:16:20 HD Request # 44 | Download start Date-Time: 2015-04-07 19:29:59.0 | 2015-04-07 23:16:20 HD Request # 44 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:16:20 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:20 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:16:20 Socket (30) | Connected. | 2015-04-07 23:16:20 HD Request # 44 | Sending historical data logon request message. | 2015-04-07 23:16:20 HD Request # 44 | Requesting Intraday data. Start Date-Time: 2015-04-07 19:29:59. Record interval: 1. Symbol: CCK15 | 2015-04-07 23:16:20 HD Request # 43 | Receiving Intraday data for 6BM5-CME starting at 2015-04-07 22:58:00 | 2015-04-07 23:16:20 HD Request # 43 | Received 3 records from 2015-04-07 22:58:00 to 2015-04-07 22:59:00 (60.0 seconds) and wrote 0 records for 6BM5-CME | 2015-04-07 23:16:20 HD Request # 43 | Intraday download COMPLETE for 6BM5-CME. Completion time: 0s. Unique request ID: 60 | 2015-04-07 23:16:20 Removed historical data download ID 60 | 2015-04-07 23:16:20 Real-time Intraday chart data file updates started for 6BM5-CME | 2015-04-07 23:16:20 HD Request # 44 | Decompressing data. | 2015-04-07 23:16:20 HD Request # 44 | Receiving Intraday data for CC FMK0015!-NYBOT starting at 2015-04-07 19:29:59 | 2015-04-07 23:16:20 HD Request # 44 | Timestamp of first Intraday data file record written: 2015-04-07 19:29:59 | 2015-04-07 23:16:20 Socket (30) | Shutdown and closed. | 2015-04-07 23:16:20 The network socket for historical data has been closed. | 2015-04-07 23:16:20 HD Request # 44 | Received 1 record from 2015-04-07 19:29:59 to 2015-04-07 19:29:59 (0.0 seconds) and wrote 1 record for CC FMK0015!-NYBOT | 2015-04-07 23:16:20 HD Request # 44 | Intraday download COMPLETE for CC FMK0015!-NYBOT. Completion time: 0s. Unique request ID: 39 | 2015-04-07 23:16:20 Removed historical data download ID 39 | 2015-04-07 23:16:20 Real-time Intraday chart data file updates started for CC FMK0015!-NYBOT | 2015-04-07 23:16:20 Intraday data recording state for symbol CC FMK0015!-NYBOT is set to download pending. | 2015-04-07 23:16:20 HD Request # 45 | Downloading Intraday chart data for CC FMK0015!-NYBOT to the file CC FMK0015!-NYBOT.scid. Service: rim | 2015-04-07 23:16:20 HD Request # 45 | Download start Date-Time: 2015-04-07 19:29:59.0 | 2015-04-07 23:16:20 HD Request # 45 | Sending historical data request. Start Date-Time: 2015-04-07 19:29:59. Record interval: 1. Symbol: CC FMK0015!-NYBOT | 2015-04-07 23:16:20 HD Request # 46 | Downloading Intraday chart data for HGK5-COMEX to the file HGK5-COMEX.scid. Service: comex | 2015-04-07 23:16:20 HD Request # 46 | Download start Date-Time: 2015-04-07 23:07:38.0 | 2015-04-07 23:16:20 HD Request # 46 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:16:20 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:20 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:16:20 Socket (31) | Connected. | 2015-04-07 23:16:20 HD Request # 46 | Sending historical data logon request message. | 2015-04-07 23:16:20 HD Request # 46 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:07:38. Record interval: 1. Symbol: HGK15 | 2015-04-07 23:16:21 HD Request # 45 | Receiving Intraday data for CC FMK0015!-NYBOT starting at 2015-04-07 19:28:00 | 2015-04-07 23:16:21 HD Request # 45 | Received 3 records from 2015-04-07 19:28:00 to 2015-04-07 19:29:00 (60.0 seconds) and wrote 0 records for CC FMK0015!-NYBOT | 2015-04-07 23:16:21 HD Request # 45 | Intraday download COMPLETE for CC FMK0015!-NYBOT. Completion time: 0s. Unique request ID: 61 | 2015-04-07 23:16:21 Removed historical data download ID 61 | 2015-04-07 23:16:21 Real-time Intraday chart data file updates started for CC FMK0015!-NYBOT | 2015-04-07 23:16:21 HD Request # 46 | Decompressing data. | 2015-04-07 23:16:21 Socket (31) | Shutdown and closed. | 2015-04-07 23:16:21 The network socket for historical data has been closed. | 2015-04-07 23:16:21 HD Request # 46 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for HGK5-COMEX | 2015-04-07 23:16:21 HD Request # 46 | Intraday download COMPLETE for HGK5-COMEX. Completion time: 0s. Unique request ID: 40 | 2015-04-07 23:16:21 Removed historical data download ID 40 | 2015-04-07 23:16:21 Real-time Intraday chart data file updates started for HGK5-COMEX | 2015-04-07 23:16:21 Intraday data recording state for symbol HGK5-COMEX is set to download pending. | 2015-04-07 23:16:21 HD Request # 47 | Downloading Intraday chart data for HGK5-COMEX to the file HGK5-COMEX.scid. Service: rim | 2015-04-07 23:16:22 HD Request # 47 | Download start Date-Time: 2015-04-07 23:07:38.0 | 2015-04-07 23:16:22 HD Request # 47 | Sending historical data request. Start Date-Time: 2015-04-07 23:07:38. Record interval: 1. Symbol: HGK5-COMEX | 2015-04-07 23:16:22 HD Request # 48 | Downloading Intraday chart data for NGK5-NYMEX to the file NGK5-NYMEX.scid. Service: nymex | 2015-04-07 23:16:22 HD Request # 48 | Download start Date-Time: 2015-04-07 23:10:51.0 | 2015-04-07 23:16:22 HD Request # 48 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:16:22 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:22 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:16:22 Socket (32) | Connected. | 2015-04-07 23:16:22 HD Request # 48 | Sending historical data logon request message. | 2015-04-07 23:16:22 HD Request # 48 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:10:51. Record interval: 1. Symbol: NGK15 | 2015-04-07 23:16:22 HD Request # 47 | Receiving Intraday data for HGK5-COMEX starting at 2015-04-07 23:06:00 | 2015-04-07 23:16:22 HD Request # 47 | Timestamp of first Intraday data file record written: 2015-04-07 23:13:00 | 2015-04-07 23:16:22 HD Request # 47 | Received 5 records from 2015-04-07 23:06:00 to 2015-04-07 23:14:00 (8.0 minutes) and wrote 2 records for HGK5-COMEX | 2015-04-07 23:16:22 HD Request # 47 | Intraday download COMPLETE for HGK5-COMEX. Completion time: 0s. Unique request ID: 62 | 2015-04-07 23:16:22 Removed historical data download ID 62 | 2015-04-07 23:16:22 Real-time Intraday chart data file updates started for HGK5-COMEX | 2015-04-07 23:16:22 HD Request # 48 | Decompressing data. | 2015-04-07 23:16:22 Socket (32) | Shutdown and closed. | 2015-04-07 23:16:22 The network socket for historical data has been closed. | 2015-04-07 23:16:22 HD Request # 48 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NGK5-NYMEX | 2015-04-07 23:16:22 HD Request # 48 | Intraday download COMPLETE for NGK5-NYMEX. Completion time: 0s. Unique request ID: 41 | 2015-04-07 23:16:22 Removed historical data download ID 41 | 2015-04-07 23:16:22 Real-time Intraday chart data file updates started for NGK5-NYMEX | 2015-04-07 23:16:22 Intraday data recording state for symbol NGK5-NYMEX is set to download pending. | 2015-04-07 23:16:22 HD Request # 49 | Downloading Intraday chart data for NGK5-NYMEX to the file NGK5-NYMEX.scid. Service: rim | 2015-04-07 23:16:22 HD Request # 49 | Download start Date-Time: 2015-04-07 23:10:51.0 | 2015-04-07 23:16:22 HD Request # 49 | Sending historical data request. Start Date-Time: 2015-04-07 23:10:51. Record interval: 1. Symbol: NGK5-NYMEX | 2015-04-07 23:16:22 HD Request # 50 | Downloading Intraday chart data for ZSK5-CBOT to the file ZSK5-CBOT.scid. Service: cbot | 2015-04-07 23:16:22 HD Request # 50 | Download start Date-Time: 2015-04-07 20:14:59.0 | 2015-04-07 23:16:22 HD Request # 50 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:16:22 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:22 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:16:22 Socket (33) | Connected. | 2015-04-07 23:16:23 HD Request # 50 | Sending historical data logon request message. | 2015-04-07 23:16:23 HD Request # 50 | Requesting Intraday data. Start Date-Time: 2015-04-07 20:14:59. Record interval: 1. Symbol: ZSK15 | 2015-04-07 23:16:23 HD Request # 49 | Receiving Intraday data for NGK5-NYMEX starting at 2015-04-07 23:09:00 | 2015-04-07 23:16:23 HD Request # 49 | Timestamp of first Intraday data file record written: 2015-04-07 23:11:00 | 2015-04-07 23:16:23 HD Request # 49 | Received 7 records from 2015-04-07 23:09:00 to 2015-04-07 23:14:00 (5.0 minutes) and wrote 4 records for NGK5-NYMEX | 2015-04-07 23:16:23 HD Request # 49 | Intraday download COMPLETE for NGK5-NYMEX. Completion time: 0s. Unique request ID: 63 | 2015-04-07 23:16:23 Removed historical data download ID 63 | 2015-04-07 23:16:23 Real-time Intraday chart data file updates started for NGK5-NYMEX | 2015-04-07 23:16:23 HD Request # 50 | Decompressing data. | 2015-04-07 23:16:23 HD Request # 50 | Receiving Intraday data for ZSK5-CBOT starting at 2015-04-07 20:14:59 | 2015-04-07 23:16:23 HD Request # 50 | Timestamp of first Intraday data file record written: 2015-04-07 20:14:59 | 2015-04-07 23:16:23 Socket (33) | Shutdown and closed. | 2015-04-07 23:16:23 The network socket for historical data has been closed. | 2015-04-07 23:16:23 HD Request # 50 | Received 1 record from 2015-04-07 20:14:59 to 2015-04-07 20:14:59 (0.0 seconds) and wrote 1 record for ZSK5-CBOT | 2015-04-07 23:16:24 HD Request # 50 | Intraday download COMPLETE for ZSK5-CBOT. Completion time: 2s. Unique request ID: 42 | 2015-04-07 23:16:24 Removed historical data download ID 42 | 2015-04-07 23:16:24 Real-time Intraday chart data file updates started for ZSK5-CBOT | 2015-04-07 23:16:24 Intraday data recording state for symbol ZSK5-CBOT is set to download pending. | 2015-04-07 23:16:24 HD Request # 51 | Downloading Intraday chart data for ZSK5-CBOT to the file ZSK5-CBOT.scid. Service: rim | 2015-04-07 23:16:24 HD Request # 51 | Download start Date-Time: 2015-04-07 20:14:59.0 | 2015-04-07 23:16:24 HD Request # 51 | Sending historical data request. Start Date-Time: 2015-04-07 20:14:59. Record interval: 1. Symbol: ZSK5-CBOT | 2015-04-07 23:16:24 HD Request # 52 | Downloading Intraday chart data for SB FMN0015!-NYBOT to the file SB FMN0015!-NYBOT.scid. Service: ice.us | 2015-04-07 23:16:24 HD Request # 52 | Download start Date-Time: 2015-04-07 18:59:58.0 | 2015-04-07 23:16:24 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:24 HD Request # 52 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:16:24 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:16:24 Socket (34) | Connected. | 2015-04-07 23:16:24 HD Request # 52 | Sending historical data logon request message. | 2015-04-07 23:16:24 HD Request # 52 | Requesting Intraday data. Start Date-Time: 2015-04-07 18:59:58. Record interval: 1. Symbol: SBN15 | 2015-04-07 23:16:24 HD Request # 51 | Receiving Intraday data for ZSK5-CBOT starting at 2015-04-07 20:13:00 | 2015-04-07 23:16:24 HD Request # 51 | Received 3 records from 2015-04-07 20:13:00 to 2015-04-07 20:14:00 (60.0 seconds) and wrote 0 records for ZSK5-CBOT | 2015-04-07 23:16:24 HD Request # 51 | Intraday download COMPLETE for ZSK5-CBOT. Completion time: 0s. Unique request ID: 64 | 2015-04-07 23:16:24 Removed historical data download ID 64 | 2015-04-07 23:16:24 Real-time Intraday chart data file updates started for ZSK5-CBOT | 2015-04-07 23:16:24 HD Request # 52 | Decompressing data. | 2015-04-07 23:16:24 HD Request # 52 | Receiving Intraday data for SB FMN0015!-NYBOT starting at 2015-04-07 18:59:58 | 2015-04-07 23:16:24 HD Request # 52 | Timestamp of first Intraday data file record written: 2015-04-07 18:59:58 | 2015-04-07 23:16:24 Socket (34) | Shutdown and closed. | 2015-04-07 23:16:24 The network socket for historical data has been closed. | 2015-04-07 23:16:24 HD Request # 52 | Received 1 record from 2015-04-07 18:59:58 to 2015-04-07 18:59:58 (0.0 seconds) and wrote 1 record for SB FMN0015!-NYBOT | 2015-04-07 23:16:24 HD Request # 52 | Intraday download COMPLETE for SB FMN0015!-NYBOT. Completion time: 0s. Unique request ID: 43 | 2015-04-07 23:16:24 Removed historical data download ID 43 | 2015-04-07 23:16:24 Real-time Intraday chart data file updates started for SB FMN0015!-NYBOT | 2015-04-07 23:16:24 Intraday data recording state for symbol SB FMN0015!-NYBOT is set to download pending. | 2015-04-07 23:16:24 HD Request # 53 | Downloading Intraday chart data for SB FMN0015!-NYBOT to the file SB FMN0015!-NYBOT.scid. Service: rim | 2015-04-07 23:16:24 HD Request # 53 | Download start Date-Time: 2015-04-07 18:59:58.0 | 2015-04-07 23:16:24 HD Request # 53 | Sending historical data request. Start Date-Time: 2015-04-07 18:59:58. Record interval: 1. Symbol: SB FMN0015!-NYBOT | 2015-04-07 23:16:24 HD Request # 54 | Downloading Intraday chart data for GCM5-COMEX to the file GCM5-COMEX.scid. Service: comex | 2015-04-07 23:16:24 HD Request # 54 | Download start Date-Time: 2015-04-07 23:11:09.0 | 2015-04-07 23:16:24 HD Request # 54 | Using server: scdf2.sierracharts.com port 10149 | 2015-04-07 23:16:24 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:24 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-04-07 23:16:24 Socket (35) | Connected. | 2015-04-07 23:16:24 HD Request # 54 | Sending historical data logon request message. | 2015-04-07 23:16:24 HD Request # 54 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:11:09. Record interval: 1. Symbol: GCM15 | 2015-04-07 23:16:25 HD Request # 54 | Decompressing data. | 2015-04-07 23:16:25 Socket (35) | Shutdown and closed. | 2015-04-07 23:16:25 The network socket for historical data has been closed. | 2015-04-07 23:16:25 HD Request # 53 | Receiving Intraday data for SB FMN0015!-NYBOT starting at 2015-04-07 18:58:00 | 2015-04-07 23:16:25 HD Request # 53 | Received 3 records from 2015-04-07 18:58:00 to 2015-04-07 18:59:00 (60.0 seconds) and wrote 0 records for SB FMN0015!-NYBOT | 2015-04-07 23:16:25 HD Request # 53 | Intraday download COMPLETE for SB FMN0015!-NYBOT. Completion time: 1s. Unique request ID: 65 | 2015-04-07 23:16:25 Removed historical data download ID 65 | 2015-04-07 23:16:25 Real-time Intraday chart data file updates started for SB FMN0015!-NYBOT | 2015-04-07 23:16:25 HD Request # 54 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCM5-COMEX | 2015-04-07 23:16:25 HD Request # 54 | Intraday download COMPLETE for GCM5-COMEX. Completion time: 1s. Unique request ID: 44 | 2015-04-07 23:16:25 Removed historical data download ID 44 | 2015-04-07 23:16:25 Real-time Intraday chart data file updates started for GCM5-COMEX | 2015-04-07 23:16:25 Intraday data recording state for symbol GCM5-COMEX is set to download pending. | 2015-04-07 23:16:25 HD Request # 55 | Downloading Intraday chart data for GCM5-COMEX to the file GCM5-COMEX.scid. Service: rim | 2015-04-07 23:16:25 HD Request # 55 | Download start Date-Time: 2015-04-07 23:11:09.0 | 2015-04-07 23:16:25 HD Request # 55 | Sending historical data request. Start Date-Time: 2015-04-07 23:11:09. Record interval: 1. Symbol: GCM5-COMEX | 2015-04-07 23:16:25 HD Request # 56 | Downloading Intraday chart data for TICK-TF to the file TICK-TF.scid. Service: statscalc | 2015-04-07 23:16:25 HD Request # 56 | Download start Date-Time: 2015-04-07 23:15:35.0 | 2015-04-07 23:16:25 HD Request # 56 | Using server: ds4.sierracharts.com port 10149 | 2015-04-07 23:16:25 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:25 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-04-07 23:16:25 Socket (36) | Connected. | 2015-04-07 23:16:25 HD Request # 56 | Sending historical data logon request message. | 2015-04-07 23:16:25 HD Request # 55 | Receiving Intraday data for GCM5-COMEX starting at 2015-04-07 23:10:00 | 2015-04-07 23:16:26 HD Request # 55 | Timestamp of first Intraday data file record written: 2015-04-07 23:12:00 | 2015-04-07 23:16:26 HD Request # 55 | Received 6 records from 2015-04-07 23:10:00 to 2015-04-07 23:14:00 (4.0 minutes) and wrote 3 records for GCM5-COMEX | 2015-04-07 23:16:26 HD Request # 55 | Intraday download COMPLETE for GCM5-COMEX. Completion time: 0s. Unique request ID: 66 | 2015-04-07 23:16:26 Removed historical data download ID 66 | 2015-04-07 23:16:26 Real-time Intraday chart data file updates started for GCM5-COMEX | 2015-04-07 23:16:26 HD Request # 56 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:15:35. Record interval: 1. Symbol: TICK-TF | 2015-04-07 23:16:26 HD Request # 56 | Decompressing data. | 2015-04-07 23:16:26 HD Request # 56 | Receiving Intraday data for TICK-TF starting at 2015-04-07 23:15:35 | 2015-04-07 23:16:26 HD Request # 56 | Timestamp of first Intraday data file record written: 2015-04-07 23:15:35 | 2015-04-07 23:16:26 Socket (36) | Shutdown and closed. | 2015-04-07 23:16:26 The network socket for historical data has been closed. | 2015-04-07 23:16:26 HD Request # 56 | Received 10 records from 2015-04-07 23:15:35 to 2015-04-07 23:16:22 (47.0 seconds) and wrote 10 records for TICK-TF | 2015-04-07 23:16:27 HD Request # 56 | Intraday download COMPLETE for TICK-TF. Completion time: 2s. Unique request ID: 45 | 2015-04-07 23:16:27 Removed historical data download ID 45 | 2015-04-07 23:16:27 Real-time Intraday chart data file updates started for TICK-TF | 2015-04-07 23:16:27 HD Request # 57 | Downloading Intraday chart data for NTCK-NYSE to the file NTCK-NYSE.scid. Service: statscalc | 2015-04-07 23:16:27 HD Request # 57 | Download start Date-Time: 2015-04-07 23:15:27.0 | 2015-04-07 23:16:28 HD Request # 57 | Using server: ds3.sierracharts.com port 10149 | 2015-04-07 23:16:28 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-04-07 23:16:28 Socket (37) | Connected. | 2015-04-07 23:16:28 HD Request # 57 | Sending historical data logon request message. | 2015-04-07 23:16:28 HD Request # 57 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:15:27. Record interval: 1. Symbol: NTCK-NYSE | 2015-04-07 23:16:28 HD Request # 57 | Decompressing data. | 2015-04-07 23:16:29 HD Request # 57 | Receiving Intraday data for NTCK-NYSE starting at 2015-04-07 23:15:27 | 2015-04-07 23:16:29 HD Request # 57 | Timestamp of first Intraday data file record written: 2015-04-07 23:15:27 | 2015-04-07 23:16:29 Socket (37) | Shutdown and closed. | 2015-04-07 23:16:29 The network socket for historical data has been closed. | 2015-04-07 23:16:29 HD Request # 57 | Received 12 records from 2015-04-07 23:15:27 to 2015-04-07 23:16:22 (55.0 seconds) and wrote 12 records for NTCK-NYSE | 2015-04-07 23:16:29 HD Request # 57 | Intraday download COMPLETE for NTCK-NYSE. Completion time: 3s. Unique request ID: 47 | 2015-04-07 23:16:30 Removed historical data download ID 47 | 2015-04-07 23:16:30 Real-time Intraday chart data file updates started for NTCK-NYSE | 2015-04-07 23:16:30 HD Request # 58 | Downloading Intraday chart data for NTCK-TF to the file NTCK-TF.scid. Service: statscalc | 2015-04-07 23:16:30 HD Request # 58 | Download start Date-Time: 2015-04-07 23:15:38.0 | 2015-04-07 23:16:30 HD Request # 58 | Using server: ds5.sierracharts.com port 10149 | 2015-04-07 23:16:30 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-04-07 23:16:30 Socket (38) | Connected. | 2015-04-07 23:16:31 HD Request # 58 | Sending historical data logon request message. | 2015-04-07 23:16:31 HD Request # 58 | Requesting Intraday data. Start Date-Time: 2015-04-07 23:15:38. Record interval: 1. Symbol: NTCK-TF | 2015-04-07 23:16:31 HD Request # 58 | Decompressing data. | 2015-04-07 23:16:31 HD Request # 58 | Receiving Intraday data for NTCK-TF starting at 2015-04-07 23:15:38 | 2015-04-07 23:16:31 HD Request # 58 | Timestamp of first Intraday data file record written: 2015-04-07 23:15:38 | 2015-04-07 23:16:31 Socket (38) | Shutdown and closed. | 2015-04-07 23:16:31 The network socket for historical data has been closed. | 2015-04-07 23:16:31 HD Request # 58 | Received 9 records from 2015-04-07 23:15:38 to 2015-04-07 23:16:22 (44.0 seconds) and wrote 9 records for NTCK-TF | 2015-04-07 23:16:32 HD Request # 58 | Intraday download COMPLETE for NTCK-TF. Completion time: 2s. Unique request ID: 49 | 2015-04-07 23:16:32 Removed historical data download ID 49 | 2015-04-07 23:16:32 Real-time Intraday chart data file updates started for NTCK-TF | 2015-04-07 23:16:32 HD Request # 59 | Downloading Intraday chart data for ZNM5-CBOT to the file ZNM5-CBOT.scid. Service: cbot | 2015-04-07 23:16:32 HD Request # 59 | Download start Date-Time: 2015-04-07 22:59:59.0 | 2015-04-07 23:16:32 HD Request # 59 | Using server: scdf1.sierracharts.com port 10149 | 2015-04-07 23:16:32 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-04-07 23:16:32 Socket (39) | Connected. | 2015-04-07 23:16:32 HD Request # 59 | Sending historical data logon request message. | 2015-04-07 23:16:32 HD Request # 59 | Requesting Intraday data. Start Date-Time: 2015-04-07 22:59:59. Record interval: 1. Symbol: ZNM15 | 2015-04-07 23:16:32 HD Request # 59 | Decompressing data. | 2015-04-07 23:16:32 HD Request # 59 | Receiving Intraday data for ZNM5-CBOT starting at 2015-04-07 22:59:59 | 2015-04-07 23:16:32 HD Request # 59 | Timestamp of first Intraday data file record written: 2015-04-07 22:59:59 | 2015-04-07 23:16:32 Socket (39) | Shutdown and closed. | 2015-04-07 23:16:32 The network socket for historical data has been closed. | 2015-04-07 23:16:32 HD Request # 59 | Received 1 record from 2015-04-07 22:59:59 to 2015-04-07 22:59:59 (0.0 seconds) and wrote 1 record for ZNM5-CBOT | 2015-04-07 23:16:32 HD Request # 59 | Intraday download COMPLETE for ZNM5-CBOT. Completion time: 0s. Unique request ID: 53 | 2015-04-07 23:16:32 Removed historical data download ID 53 | 2015-04-07 23:16:32 Real-time Intraday chart data file updates started for ZNM5-CBOT | 2015-04-07 23:16:32 Intraday data recording state for symbol ZNM5-CBOT is set to download pending. | 2015-04-07 23:16:32 HD Request # 60 | Downloading Intraday chart data for ZNM5-CBOT to the file ZNM5-CBOT.scid. Service: rim | 2015-04-07 23:16:32 HD Request # 60 | Download start Date-Time: 2015-04-07 22:59:59.0 | 2015-04-07 23:16:32 HD Request # 60 | Sending historical data request. Start Date-Time: 2015-04-07 22:59:59. Record interval: 1. Symbol: ZNM5-CBOT | 2015-04-07 23:16:32 Rithmic Trading | Requesting historical Minute data. | 2015-04-07 23:16:32 HD Request # 60 | Receiving Intraday data for ZNM5-CBOT starting at 2015-04-07 22:58:00 | 2015-04-07 23:16:33 HD Request # 60 | Received 3 records from 2015-04-07 22:58:00 to 2015-04-07 22:59:00 (60.0 seconds) and wrote 0 records for ZNM5-CBOT | 2015-04-07 23:16:33 HD Request # 60 | Intraday download COMPLETE for ZNM5-CBOT. Completion time: 1s. Unique request ID: 67 | 2015-04-07 23:16:33 Removed historical data download ID 67 | 2015-04-07 23:16:33 Real-time Intraday chart data file updates started for ZNM5-CBOT | 2015-04-07 23:16:33 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 23:30:00. Filename: TICK-TF.scid | 2015-04-07 23:17:34 TICK-TF 15 Sec #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-02-12 23:35:15. Next Bar Date Time: 2015-02-12 Date Time Of Last Edit: 2015-04-08 05:43:12
[2015-04-08 06:26:54] |
We see no indication of a lost connection to the Rithmic trading system from this Message Log. Nothing at all. We see a successful connection. Rithmic Trading | Successfully connected. IB='AMP'. | 2015-04-07 23:15:59 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-08 07:42:40] |
inverter - Posts: 42 |
today has not lost connections,, yesterday several times was ok,,, when you lose connection then I put the log here,, thanks
[2015-04-08 09:40:21] |
Please start a new thread at that time. And only post the last 100 lines.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-08 09:40:31
