Date/Time: Sun, 08 Sep 2024 00:28:20 +0000
starting up problems
View Count: 995
[2015-03-25 13:02:38] |
User14740 - Posts: 11 |
Dear collaborator, My computer crashed some days ago. In my new computer I have to reinstall Sierra charts all over again. But my technical skills fail to install the right settings. It is so complicated. Presently I only have a delayed data stream. Is there a possibility to have a teamview help to reinstall my settings real time? I hope you can help me. Looking forward to your positive help. Regards, Peter van Soest |
[2015-03-25 17:48:25] |
Do you want to connect Sierra Chart to your Interactive Brokers account?
[2015-03-25 18:32:34] |
Dear support team, I have a broker called TradersOnly (the Netherlands) and is finally connected to Interactive Brokers. I want to activate the feed so that I have real time data for trading futures. As soon as I connect from Global settings to Data/Trade sevice settings, and click in the list Interactive brokers, it shows my account in TradersOnly. But after that it does not show the data. Instead it gives the following messages and continues with repeats of this message after that. I hope you will now see the problem and may give me the right instructions to solve it. Thanks in advance. P.l. van Soest Software version: 1241 | 2015-03-25 10:23:22 Uses Old Spreadsheets | 2015-03-25 10:23:22 Usage end date: 2016-02-28 | 2015-03-25 10:23:22 Enabled for: Advanced Features. | 2015-03-25 10:23:22 Enabled for: Sierra Chart Historical Data Service. | 2015-03-25 10:23:22 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-03-25 10:23:22 Active service: Interactive Brokers | 2015-03-25 10:23:22 Time Zone: +00:00:00 (UTC+00) | 2015-03-25 10:23:22 2015-03-25 11:23:22 Local computer clock time | 2015-03-25 10:23:22 2015-03-25 10:23:22 GMT time | 2015-03-25 10:23:22 2015-03-25 10:23:22 Time zone adjusted time | 2015-03-25 10:23:22 Time difference to server time: 0 seconds. | 2015-03-25 10:23:22 Program path: C:\SierraChart\ | 2015-03-25 10:23:22 Data Files path: C:\SierraChart\Data\ | 2015-03-25 10:23:22 OS Version Number: 6.2 | 2015-03-25 10:23:22 Locale Information: C | 2015-03-25 10:23:22 Checking for new symbol settings for ib | 2015-03-25 10:23:22 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-03-25 10:23:22 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-03-25 10:23:22 Symbol settings are up-to-date for ib | 2015-03-25 10:23:22 Interactive Brokers: Connecting to u625900:7496 | 2015-03-25 10:23:27 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-03-25 10:23:27 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-03-25 10:23:27 Socket (0) | Error on address resolution. Windows error code 11001: Host is onbekend. | 2015-03-25 10:23:29 Socket (0) | Shutdown and closed. | 2015-03-25 10:23:29 Interactive Brokers | Failed to connect to the data and trade server. | 2015-03-25 10:23:29 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2015-03-25 10:23:29 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-03-25 10:23:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-03-25 10:23:29 Interactive Brokers | Disconnected. | 2015-03-25 10:23:29 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-03-25 10:23:29 Starting TWS auto-login thread. | 2015-03-25 10:23:31 TWS auto-login thread ending. | 2015-03-25 10:23:31 |
[2015-03-25 21:42:19] |
Select Global Settings >> Data/Trade Service Settings. Set the " Connection Details >> Server" setting to: 127.0.0.1:7496 Press OK. Select "File >> Connect to Data Feed". Post the Message Log again if you still have trouble connecting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-26 02:00:24
[2015-03-25 23:43:15] |
Dear support team. Unfortunately I could not solve my problems of enabling connection to real time data with the advice you gave me. Moreover in the server setting, enable relay server, listening port, the number 127.0.0.1:7496 you advised me is time after time automatically replaced by 127 after I come back again and connect to data feed did not work. I am using a 32 bit of Java in my TWS for the data feed and the computer is 64 bit. Is here may be a reason that may cause the problem? I hope you continue in other setting suggestions that may cause the problems. Otherwise team viewer really may help to solve the problem faster. Regards, P.L. van Soest |
[2015-03-26 17:12:03] |
Have a look at this image: https://www.sierrachart.com/images/IBServiceSettingsWindow.png Notice the red box and within the red box where it says "Server". Make sure it is set as shown: localhost:7496 Try connecting again by selecting File >> Connect to Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-26 17:12:26
[2015-03-27 19:09:11] |
NO! Of course I tried it, but I knew better on beforehand. I must be connected there to my broker with my account U625900 for my P&L account and to get the data feed from. It has always worked like that. The suggestions you gave me so far go from bad to worse. Also the delay in the answering of the questions is very disappointing for a specialysed help desk and for simple questions for experts like starting up a station. Waaaauuw! I am still puzzled and I am looking forward to the right suggestion to get my station running again. For the second time I ask you here: Please log in in a teamviewer and we may be ready in 5 to 10 minutes. Thanks. Peter van Soest |
[2015-03-27 19:14:54] |
Select Help >> Accept Remote Assistance from within Sierra Chart. Create a new ticket here: https://www.sierrachart.com/usercp.php?page=SupportTickets Include the Team Viewer ID and Password. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-27 19:15:04
