Date/Time: Tue, 04 Nov 2025 11:33:56 +0000
percent change since open
View Count: 1802
[2015-03-25 00:05:25]
Paul.M - Posts: 113
when I apply the study "percent change since open" to a study, e.g. to "Subgraphs Ratio"
it shows an error (a constant line of -100)
Is this a bug or how do I apply it the correct way ?
TY
[2015-03-25 09:33:36]
This study is not designed to be used with another study. Only on the main price graph.
You can have a look at the source code for it and modify it. Refer to this page:
https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html
