Date/Time: Sat, 21 Dec 2024 17:44:54 +0000
order placement on DOM
View Count: 945
[2015-03-09 21:39:00] |
enemyspy - Posts: 306 |
Hi, Using IB I have been noticing recently that when I click the the Dom to place a limit order if the order is placed on the wrong side of the last traded price, it instead places a stop order, even it the spread is higher/lower than the last traded price (more of an issue for thinly traded markets). But then today I placed a buy limit order, below the last traded price eg last traded price 17970 limit order 17965, it sat on the screen for 30 seconds and then filled as a stop order at 17971. This is all being done through simply clicking the price I want on a Dom in the buy or sell columns. Is this a setting I can turn off? It has really been messing with me lately. |
[2015-03-09 21:52:20] |
When the order is submitted, and it displays on the chart, the order type is shown. Did it show as a limit?Check the Order Input settings in Global Settings >>Chart DOM Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-09 22:17:44] |
Ok now I understand what I need to do going forward. "When the order is submitted, and it displays on the chart, the order type is shown. Did it show as a limit?" I am fairly certain it showed as a limit however I do not have a screen shot, to say for sure, it may not have. I am now aware of these inputs which should stop further issues for me. |
