Date/Time: Sun, 22 Dec 2024 13:46:44 +0000
BATS Stock Exchange Supported
View Count: 10486
[2015-02-26 03:44:20] |
The Sierra Chart Real-time and Historical Exchange Data Feed now supports the BATS stock exchange: http://www.batstrading.com/ The exchange fee for this is only 2.50 USD a month and it gives you access to US equities data in real-time. This data can be accessed with any of the supported trading services. So if you are trading futures you also can get US equities data within the same copy of Sierra Chart. Complete instructions are here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-26 03:44:48
[2015-03-08 04:09:21] |
User53441 - Posts: 17 |
So if we purchase the bats data feed we don't need to purchase the US Equites package for real time data as well?
[2015-03-08 05:17:08] |
This is correct. You do not.
[2015-05-01 20:16:56] |
We had a user today enable the BATS exchange and we discovered there was a few different configuration problems preventing real-time data from being received and sometimes historical data being received for BATS symbols. To receive the BATS data, it is necessary to use the latest revision of 1251. To get that update with Help >> Download Prerelease. We are not sure why no one else has pointed out any issue because you would not have been able to get the BATS data after enabling that exchange on your account. If there any problems always let us know promptly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-01 20:17:09
