Date/Time: Tue, 04 Nov 2025 15:43:08 +0000
debugging my function calls to external DLLs
View Count: 1153
[2015-02-25 18:28:07]
shrubberyMoves - Posts: 2
For faster debugging of my custom study, I have set sc.FreeDLL = 1. Therefore I am storing HMODULE my_Handle_To_External_DLL as a persistent variable, rather than as the global variable recommended in "ACSIL Programming Concepts > Making Function Calls to External DLLs." All appears well.
1) by not using a global HMODULE, will multiple copies of the same DLL be loaded for the same study used on different charts?
2) do i need to call FreeLibrary myself?
3) anything else i should mind?
Thank you in advance.
[2015-02-25 19:15:26]
1. No.
2. Yes.
3. Just make sure you call FreeLibrary for every time LoadLibrary has been called.
