Date/Time: Mon, 05 Oct 2026 12:46:57 +0000
Automatic Vbp Day/Evening Session Profiles?
View Count: 1389
[2015-02-10 05:58:44]
Halco - Posts: 92
If I have my (day) session time set to 3:00:00-16:59:59 and evening session time set to 17:00:00-02:59:59 can I have profiles drawn automatically for these rather than having to draw them manually each session? If so, what are the inputs? I can't seem to figure it out. Thank you.
[2015-02-10 06:43:13]
Halco - Posts: 92
30 min chart, EUR/USD, FXCM tick data. I now have two separate profiles, both "StartTime to EndTime". The evening session is set to Minutes - 600. It's fine on the chart. I set the day session to Minutes - 840 and it draws two to three profiles within the day session. Not sure I'm doing wrong there or if it's a glitch.
I then set the day session to Days - 1 and it draws the day sessions fine except for Fridays, when it draws two profiles, the second of which is Sunday 2:00 - 4:30 pm (EST). I don't suppose there's any way around that.
Still don't know why the Minutes - 840 isn't right, but this way seems to work well enough. Thanks.
[2015-02-10 07:35:40]
Refer to the step-by-step instructions here for what you want to do:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#DayEveningSeparateProfiles
Date Time Of Last Edit: 2015-02-10 07:36:20
