Date/Time: Tue, 04 Nov 2025 10:44:16 +0000
chart graphics transparency
View Count: 1874
|   [2013-05-23 04:20:52]     |
| Charles Meyer - Posts: 2 |
                Can a user draw a line or ray for example where the line does not completely cover what is underneath it.  Said another way, if I draw a ray over price bars, can a color be selected so that the price bars can be seen through the ray, as if the ray was semi-transparent?  Similar to creating an ellipse where all information inside ellipse is visible but has different chart background color setting the ellipse apart.
|   [2013-05-23 05:22:45]     |
| M5amhan - Posts: 468 |
                you can draw it underneath the price bars by going to chart settings>advanced settings>draw non-highlight chart drawings underneath main graph and studies
|   [2013-05-23 13:15:07]     |
                Most excellent solution, much appreciated!!!
|   [2013-05-23 23:35:49]     |
                The answer given in Post #2 is correct.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-08 15:59:51]     |
| User79074 - Posts: 105 |
                WHat about line transparency?
