Date/Time: Sun, 22 Dec 2024 16:37:56 +0000
High/Low for Time Period-Extended
View Count: 995
[2015-01-18 03:11:52] |
User80617 - Posts: 10 |
This is an excellent study for looking at a set time frame of a market....say the high/low range of the first 30 minutes of trading as an example.......is there a way that a 50% line of that high/low range could be added to this study as how price reacts to the 50% level provides a lot of useful information as the trading day continues.......thanks for the consideration.......Jack
[2015-01-18 06:16:51] |
This is possible to do with a combination of the Arithmetic studies. These are documented here: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s272 Calculate the average between the two Subgraphs of High/Low for Time Period-Extended. Calculate the difference between the average and the bottom Subgraph. And that difference to the High and Subtract that difference from the Low. Also, with not a lot of difficulty you can just simply modify the study to meet your requirements. Refer to this page here: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-18 06:17:33
[2015-01-18 21:43:59] |
Thanks! I used the study subgraph average and it works fine........I'm afraid the build custom studies is a little bit beyond my pay grade.....haha......appreciate your time and suggestions......Jack
