Date/Time: Sun, 22 Dec 2024 16:06:46 +0000
ACSIL: TPO Profile Chart - I can get Open, High, Low, Last and Volume, but can't get PoC, VAH, V
View Count: 1725
[2015-01-17 19:56:03] |
User27611 - Posts: 4 |
Dear support, I'm using TPO Prifile Chart study. I can see on the chart all data including PoC, VAL, VAH, OpenRange and other data. But when I try to get data from TPO Chart, I can't find SG for PoC, VAL, VAH, OR and other. Is it possible to get this data? Thank you. Waiting for your reply, Alex Vysotsky. |
[2015-01-17 20:54:31] |
No, there is not ACSIL access to this data.
[2015-01-17 21:15:49] |
Zosimus - Posts: 345 |
if you want to access this data you can add a TPO Value Area Lines Study to a regular bars chart that has the same sessions settings as your TPO chart and get the TPO VAH/POC/VAL from this chart. I personally write all the code that I need for TPO charts for regular 30m charts (my tpo brackets are usually 30m) because the indexing of the tpo charts is kind of complicated. Date Time Of Last Edit: 2015-01-17 21:19:25
[2015-01-17 21:56:26] |
Yes, this is true. You can get the Point of Control and Value Area High and Low from the TPO Value Area Lines study.
[2015-01-18 06:31:24] |
Sierra Chart Engineering and Yon - thank you for your answers! Ok, I'll use TPO Value Area Lines study now and write my own TPO study like Yon. Thanks a lot. |
