Date/Time: Sun, 22 Dec 2024 22:02:32 +0000
FXCM FIX historical data
View Count: 800
[2015-01-06 10:56:38] |
EuropeanTrader - Posts: 290 |
Hello please see this: http://www.sierrachart.com/image.php?l=1420541707225.png My Daily bar does not show good data. The last bar is today but the one before it is Jan 2nd. Deleting and downloading data again doesn't help. Thanks. |
[2015-01-06 16:31:08] |
The server has the data. Therefore the problem must be a communication error with downloading the data. Restart Sierra Chart and download the data following the instructions in help topic 6.3: https://www.sierrachart.com/index.php?page=doc/helpdetails6.html#h6.3 Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
