Date/Time: Thu, 02 May 2024 12:40:15 +0000
GetTradeList cpu exception
View Count: 1581
[2013-05-21 06:53:09] |
onnb - Posts: 661 |
I am getting a cpu exception with GetTradeList. It comes by just adding the study to a chart. The size of the list is 4293719478 (from the debugger) Code used is below. Any ideas? std::vector<s_ACSTrade> tradeList; sc.GetTradeList(tradeList); for (int i = 0; i < tradeList.size(); i++) { SCDateTime closeDT = tradeList[i].CloseDateTime; int index = sc.GetContainingIndexForSCDateTime(sc.ChartNumber, closeDT); equity[index] = tradeList[i].ClosedProfitLoss; } |
[2013-05-21 07:02:44] |
We will check on this and resolve it.
[2013-05-21 14:11:01] |
Al SC Developer - Posts: 434 |
We do not see any issues with this routine. Where are you taking the exception? In the GetTradeList() call, or after in your loop? One thing to note, is that TradeList.size() call will return a size_t (unsigned int), and you are using an int for the index. |
